作品名字:[pads VX.2.4][2层]IW2691 5V 2A 苹果IPAD充电器(BAV70+SPU02N60C3)原理图+PCB文件分享下载# E: E6 u9 X; U1 I# U
5 X# l8 `' H, P+ z6 L8 R, \9 W
文件描述
# X/ m% N0 {, Y; h P# u/ f! V 7 P; }, k) z7 B& g
1.功能描述:苹果IPAD充电器
; \ M2 r6 U0 n6 c , k2 L: G! ^2 H1 U9 ^6 k+ f
2.软件版本:PADS VX.2.4
+ @0 g# @; \1 O$ Z8 K% T* B
. a' _7 R( H$ g# \- D( r3.层数:2层板2 j+ _+ q; m; X% |9 K
! V3 l+ ~( E( p/ K) w" z/ q
4.用到的主要芯片:SPU02N60C3 - K. ~* n6 F/ d0 U: ?( H' B
5.PCB板尺寸:42.5mm*22mm
6 ?$ ~" L0 B7 O6 |4 z
. A0 a2 [7 K4 c* |* Q2 ^! W作品截图如下: % o ]3 \* ?+ ?. J' a( Z2 l, n
% ^9 b1 t9 ?" N- d7 H5 Z顶层截图:. A% t2 Z" @8 P0 {3 f! W
3 W6 n0 H4 x K- n: l底层截图:* E2 t7 C8 _8 o8 ^7 w0 `9 Y
3 K' ]$ y' u! [8 w5 `" G全层截图:1 q; C9 D& t" p3 A6 \4 j
4 ?' `& i: O0 W9 [9 [; Q {7 n/ p0 f0 O$ |0 W: ^/ G7 p- c( |8 v* T
叠层截图:4 G* E5 V( v6 U; r
BOM: REFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | A | PADS1A | L | B | PADS1A | L | BR1 | BS-106-00-PCBA | | C1 | CE-D10XL10-P5-1-PCBAAAAAAA | 10uF/200V | C2 | CE-D10-P5-PCB | 15uF/400V | C3 | CS-1206-PCB | 10pF | C4 | R-S0805 | 1nF | C6 | CS-0402-PCB | 100pF | C7 | CS-0402-PCB | 10pF | C8 | CS-0402-PCB | 470pF | C9 | CS-0805-PCB | 0.1uF | C10 | CS-0805-PCBA | 0.1uF | C11 | CS-0402-PCB | 22pF | C12 | CS-0603-PCB | 1nF | C13 | CE-D8-P3.5-PCBA | 680uF/16V | C14 | CE-D6.3-P2.5-PCB | 100uF/16V | C15 | CS-1206-PCB | 1nF | C16 | CS-0402-PCB | 10pF | CY1 | CY-222-3.5X8-P7-1-PCBA | | D1 | DS-S1ALS1ML-PCBAA | 1N4148 | D2 | DS-S1ALS1ML-PCBAA | 1N4148 | D3 | DS-S1ALS1ML-PCBAA | 1N4148 | D4 | DS-S1ALS1ML-PCBAA | 1N4148 | D5 | BAV70-SOT23 | BAV70 | D6 | DS-S1ALS1ML-PCBAA | 1N4148 | D7 | DIODE-0805B | 1N4148 | D8 | TO-252-231-PCBA | | F1 | FUSE-2P1AA | 10R | IC1 | IC-SO8-OPT | iW1691-03 | L1 | LE-8.3-01-PCBA | 8.5mH | L2 | LC-0410V-PCBAAAAAAAAAAAAAAAAAAAA | 470uH | N | PADS1 | L | NTC1 | R-S0603A | 100K | Q1 | TO-251-123-PCBAA | SPU02N60C3 | R1 | RS-0402-PCB | | R4 | R-S1206 | 3M | R5 | R-S1206A | 10R | R6 | R-S1206BAA | 220K | R7 | R-S0805 | 10R | R8 | R-S1206 | 1.4R | R9 | RS-0402-PCB | | R10 | RS-0402-PCB | | R11 | RS-0402-PCB | | R12 | RS-0402-PCB | | R13 | RS-0402-PCB | | R14 | RS-0402-PCB | | R15 | RS-0402-PCB | | R16 | RS-0402-PCB | | R17 | RS-0402-PCB | | R18 | RS-0402-PCB | | R19 | RS-0402-PCB | | R20 | R-S0603 | | R21 | R-S0805 | 2K | R22 | SMD0402 | | R23 | SMD0402 | | R24 | SMD0402 | | R25 | SMD0402 | | T1 | TH-EPC17N-02-PCBAAAAAAA | EPC17 | USB1 | JU-DF17-PCBAA | | 4 n' Y& z6 H+ W1 `! h- U5 g
/ {5 }* o* V! y' T G* |4 ^2 { 9 n$ w+ h0 x) V- Q
! C% t* H' S4 u
附件: ) u1 }3 j. w- y8 ~9 A
