查看: 811|回复: 12
[allegro16.3][8层]光口网口主板(FPGA+QFP+光口)pcb文件
发表于 2020-2-28 11:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
* g" r5 a6 W, J1 I[allegro16.3][8层]光口网口主板(FPGA+QFP+光口)pcb文件3 H- C( [% ~( p1 J! Y6 ~1 A# j
$ t& y9 j1 \0 M$ m% O6 `$ ]
文件描述:
5 v9 l9 L. z  w  W% I9 ^
. f1 O% U7 C  L( ~1. 作品用途:光口网口主板
1 l) t4 f( K! e! w+ w! X( ?5 S2. 软件版本:allegro16.3  y( t' }2 Y: k4 r8 [) ]
3. 层数:8层
0 z" Q3 M- p" E4. 用到的主要芯片:FPGA+QFP+光口  U) x) t4 u- ]1 g$ [
5. pcb尺寸: 8937.01*6296.72 MIL, T0 G- g! ]5 C% g5 u. M4 Z6 m  }
: u: m% f, \: d+ |5 {
作品截图如下:2 r; m; h' T& ^$ e
$ O- H7 ?) u4 P2 x0 }顶层截图:
! {6 U) J1 w- ~4 ^1 o
" j! K! Z. `2 `$ `, K" ?# A' e底层截图:/ e' D! Z& x- g
: x3 l1 K0 `2 z7 D2 ?7 `" |5 e0 }6 I9 u# l  k7 Z, i2 ~
全层截图:* X$ |: J; J3 T
4 j; H* c9 S5 H, B0 A; J2 r( x* c7 e; {8 g' b8 l, f' j
叠层阻抗信息如下:  K* d' N& I; ?( [. M
; E# Z# Y/ o+ XBOM:
4 h. v+ ~+ k) W6 z
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C0402C0402IC453C1; C4; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C48; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C70; C71; C72; C73; C75; C76; C78; C79; C80; C81; C83; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C96; C98; C99; C100; C101; C103; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C130; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C145; C147; C148; C151; C152; C153; C154; C155; C157; C159; C160; C161; C163; C165; C167; C169; C170; C172; C174; C175; C176; C178; C180; C181; C183; C185; C186; C188; C190; C191; C192; C193; C194; C196; C198; C199; C200; C201; C202; C203; C204; C205; C208; C210; C211; C212; C213; C214; C215; C217; C218; C219; C222; C223; C224; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C263; C264; C265; C266; C267; C268; C269; C270; C271; C275; C276; C282; C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C294; C295; C296; C297; C298; C299; C300; C303; C304; C305; C306; C307; C308; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344; C345; C346; C347; C348; C349; C350; C351; C352; C356; C357; C363; C364; C365; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387; C388; C389; C390; C391; C392; C393; C394; C395; C396; C397; C398; C399; C400; C401; C402; C403; C404; C405; C406; C407; C408; C409; C410; C411; C412; C413; C414; C415; C416; C417; C418; C419; C420; C421; C423; C424; C426; C427; C430; C431; C434; C440; C441; C450; C452; C453; C456; C457; C458; C460; C461; C462; C463; C465; C468; C469; C472; C473; C474; C477; C478; C479; C481; C482; C484; C489; C490; C493; C494; C497; C498; C499; C500; C501; C502; C503; C504; C505; C506; C507; C508; C509; C512; C513; C514; C517; C519; C521; C536; C537; C538; C571; C575; C576; C577; C578; C579; C580; C581; C582; C583; C584; C585; C586; C606; C607; C608; C609; C611; C619; C620; C621; C629; C630; C636; C638; C639; C640; C643; C644; C650; C652; C654; C659; C660; C661; C662; C664; C670; C671; C674; C675; C676; C677; C678; C679; C680; C681; C683; C684; C1567; C1568
C0603C0603IC53C28; C29; C30; C31; C47; C49; C69; C74; C77; C82; C84; C95; C97; C102; C104; C129; C131; C144; C146; C149; C150; C156; C158; C162; C164; C166; C171; C173; C177; C179; C182; C184; C187; C189; C195; C197; C216; C279; C360; C485; C486; C487; C488; C491; C492; C495; C496; C626; C645; C648; C649; C653; C682
C0805C0805IC69C42; C43; C44; C45; C46; C168; C209; C220; C221; C246; C247; C272; C273; C274; C277; C278; C280; C281; C301; C302; C327; C328; C353; C354; C355; C358; C359; C361; C362; C422; C425; C428; C429; C432; C433; C454; C455; C459; C464; C466; C467; C470; C471; C475; C476; C480; C483; C510; C511; C515; C516; C518; C573; C574; C610; C617; C622; C627; C628; C631; C632; C634; C635; C637; C641; C642; C651; C663; C672
C1206C1206IC1C572
C1210C1210IC23C602; C603; C604; C605; C612; C613; C614; C615; C616; C623; C624; C625; C633; C646; C647; C655; C656; C657; C658; C665; C666; C667; C668
CA2C_T12R5D10R0CA2C_T12R5D10R0IC8C442; C443; C444; C445; C446; C447; C448; C449
CC_AVX_AVX1812_T2R54_BCC_AVX_AVX1812_T2R54_BIC2C539; C673
CC_MRT_GRM21_T1R25CC_MRT_GRM21_T1R25IC1C618
CNF_JST_BM10B-SRSS-TBCNF_JST_BM10B-SRSS-TBIC1JP1
CNF_TYC_1888247-1_2007198-1CNF_TYC_1888247-1_2007198-1IC1J11
CNF_XXX_PRESS-FIT-SFPCNF_XXX_PRESS-FIT-SFPIC1J1
CN_HSD_HEC3800CN_HSD_HEC3800IC1CN2
CN_JST_S4B-PH-K-SCN_JST_S4B-PH-K-SIC1J4
DFN15-20-118DFN15-20-118IC6U30; U31; U32; U33; U35; U36
EBGA048_EONEBGA048_EONIC1IC2
EBGA096_MCR_01EBGA096_MCR_01IC4IC3; IC4; IC5; IC6
EBGA769_NELEBGA769_NELIC1IC1
FBGA144_VITFBGA144_VITIC1IC19
FFL_BLM18FFL_BLM18IC13FL2; FL3; FL4; FL5; FL6; L22; L23; L27; L30; L31; L32; L33; L34
FFL_BLM31FFL_BLM31IC2FL1; FL7
FGHOLE3_2_01FGHOLE3_2_01IC6TP39; TP40; TP44; TP46; TP47; TP49
FGHOLE3_8_01FGHOLE3_8_01IC3TP33; TP34; TP35
FSWP_ALP_SKRKAEE010FSWP_ALP_SKRKAEE010IC1SW3
FSWS_CPL_CHS-08BFSWS_CPL_CHS-08BIC1SW2
FZ_LTF_0451FZ_LTF_0451IC1F1
FZ_LTF_R451FZ_LTF_R451IC1F3
HD1X8HD1X8IC1JP2
LCC049_BRC_48-PIN-MLPLCC049_BRC_48-PIN-MLPIC1IC11
LEA_LOT_LTST-C155KGKFKTLEA_LOT_LTST-C155KGKFKTIC2LD7; LD11
LES_LOT_LTST-C150GKTLES_LOT_LTST-C150GKTIC6LD1; LD2; LD3; LD4; LD8; LD12
OF_MRT_BLM21OF_MRT_BLM21IC17L2; L3; L4; L5; L6; L7; L8; L9; L10; L11; L12; L13; L14; L15; L16; L17; L18
OF_MRT_BLM41OF_MRT_BLM41IC1L1
OF_MRT_DLW5BT_AOF_MRT_DLW5BT_AIC1L24
OF_MRT_DLW21SOF_MRT_DLW21SIC4FL22; FL23; FL24; FL25
OZ_TYY_CBC3225OZ_TYY_CBC3225IC2L28; L29
PF_MAC_HK-2-G_01PF_MAC_HK-2-G_01IC8TP6; TP7; TP8; TP10; TP11; TP26; TP27; TP29
PL6060PL6060IC4L20; L21; L39; L40
PL8383PL8383IC2L19; L25
QFP144-050-2020QFP144-050-2020IC1IC20
R0402R0402DISCRETE350R3; R4; R5; R6; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R44; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R118; R119; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R160; R161; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R244; R245; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R272; R273; R288; R289; R290; R292; R293; R294; R295; R296; R297; R298; R299; R300; R301; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R316; R317; R320; R322; R323; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R348; R349; R351; R358; R359; R360; R361; R380; R381; R382; R383; R452; R453; R454; R455; R456; R457; R458; R459; R460; R461; R462; R463; R464; R465; R466; R467; R468; R469; R470; R473; R474; R475; R476; R477; R482; R483; R484; R485; R486; R499; R505; R814; R815; R816; R817; R818; R819; R820; R821
R0603R0603IC31R41; R42; R43; R45; R117; R120; R121; R122; R123; R156; R157; R158; R159; R314; R315; R319; R321; R324; R325; R350; R352; R353; R354; R355; R362; R364; R365; R471; R472; R478; R487
R0805R0805IC6R140; R176; R268; R269; R270; R271
R1206R1206IC2R503; R504
RJ8-B663N-8815-U002RJ8-B663N-8815-U002IC1CN3
SF5_TI_DCKSF5_TI_DCKIC3U10; U28; U29
SOP8-50-150SOP8-50-150IC2U11; U34
SOT08_ONSSOT08_ONSIC1U7
SOT23SOT23IC3Q5; Q6; Q7
SOZ11_TI_DRC_MTSOZ11_TI_DRC_MTIC2U2; U3
TESTPAD_STESTPAD_SIC29TP9; TP12; TP13; TP23; TP25; TP30; TP31; TP32; TP36; TP37; TP38; TP41; TP42; TP43; TP45; TP48; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP60; TP61; TP62; TP63; TP64; TP65
TFL24-40-280TFL24-40-280IC1U13
TSOP48_TITSOP48_TIIC1U4
XTF_DSK_DSO321SRXTF_DSK_DSO321SRIC3X1; X2; X6
XTF_DSK_DSO323SXTF_DSK_DSO323SIC1X3
XTF_DSK_DSV753SXTF_DSK_DSV753SIC1X5
附件:
8 `& @+ m4 M, N: i( _- PPCB文件如下:
$ S4 {9 j  X. L3 n" ~* G, p/ |
游客,如果您要查看本帖隐藏内容请回复
( \3 R1 x/ k* W, G/ y
$ n/ R3 C, v% U/ F2 L; A( |  ]
    2023-3-30 15:06
    发表于 2022-5-11 14:28 | 只看该作者
    学习一下学习一下学习一下学习一下
    - U) e- S. E5 H1 p/ N' r  x8 U
    发表于 2023-5-29 00:09 | 只看该作者
    谢谢分享
    “来自电巢APP”
    发表于 2023-10-16 19:22 | 只看该作者
    " X' W; d% P4 q, H* s学习一下学习一下学习一下学习一下
    发表于 2023-10-26 15:57 | 只看该作者
    学习一下学习一下学习一下学习一下
    2021-1-21 15:57
  • 签到天数: 121 天
    [LV.7]常住居民III
    发表于 2025-2-17 15:12 | 只看该作者
    谢谢分享  下载太贵啦。。。
    8 X9 `0 t# b) ?( K  }! S" A
    GMT+8, 2025-10-9 22:36 , Processed in 0.171875 second(s), 27 queries , Gzip On.
