查看: 386|回复: 2
[allegro15.2][6层] CCD_DSC数码相机主板(NT96450+DDR2+RT9971)原理图和pcb文件
发表于 2020-2-27 19:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
3 q, c1 m- [3 `3 F$ r' g- I1 R2 R
1 V8 ^4 i. [9 ^" @0 P* s[allegro15.2][6层] CCD_DSC数码相机主板(NT96450+DDR2+RT9971)原理图和pcb文件% j+ y. Q* K3 z9 c
- n+ c6 h; g& ~/ Z+ B" o' E
+ O+ d  z' [( W$ w9 Y文件描述:
1 |2 c/ L; f/ F+ d, G1. 作品用途:CCD_DSC数码相机主板! Y1 O  E; w. c1 }
2. 软件版本:allegro15.2
& G3 T) |/ Z: m4 r$ ]3. 层数:6层7 ^/ T; I- e1 e; U; k9 x
4. 用到的主要芯片:NT96450+DDR2+RT9971$ g/ }# \: G& `
5. pcb尺寸: 异形
  w5 N. Q% {! i2 L; E
3 ]: ~7 F& F( Z5 j* j( o
" u1 u9 t( F8 m6 c8 g1 a2 V
作品截图如下:. R+ X# y: ]% y, D9 ]% G4 U, e
顶层截图:
% J( [3 g/ i/ h5 V: f( m( a& ]   j2 u; A& \3 A
底层截图:
+ B3 S% w* y6 {7 B, U
3 }! o9 C( I$ ^$ L3 F全层截图:
7 `+ `; G9 y0 V6 d 4 G8 R4 N" |2 }5 G% v
叠层阻抗信息如下:
$ @6 v9 d" E3 h. D8 I; { 5 a9 Q- x6 ]5 D$ P9 R9 }5 H
BOM:
0 O+ k/ A; N, A. [7 k+ v  k
Bill of Material Report (Condensed)
名称类型属性类别数量位号
5PINUSB5PINUSB_3_5PINUSB_USBCONUSBCONIC1J3
1206CCAP_NP_1206C_0.033UF_600V0.033uF_600VIC1C174
1206CCAP_NP_1206C_0.033UF\600V0.033uF\600VIC1C177
3225-CRYSTALCRYSTAL_3225-CRYSTAL_40MHZ40MhzIC1Y3
BATTERY_PADTP_BATTERY_PAD_TPTPIC2BAT+1; BAT-1
BGA104ADDI9004_BGA104_VSP6244BZRCVSP6244BZRCIC1U7
BGA_NT5TU_DDRDDR2-84BALL_BGA_NT5TU_DDR_DDR2-DDR2-84ballIC1U6
BL-4C_BATTERYA027DN01_6_BL-4C_BATTERY_BL-4C_BL-4C_BATTERYIC1TP1
C0402CAP_NP1_C0402_1UF_10V1uF_10VDISCRETE2C1; C10
C0402CAP_NP1_C0402_1NF1nFDISCRETE2C6; C14
C0402CAP_NP1_C0402_10PF10pFDISCRETE2C7; C15
C0402CAP_NP1_C0402_0.1UF0.1uFDISCRETE2C17; C76
C0402CAP_NP1_C0402_22PF22pFDISCRETE1C21
C0402CAP_NP1_C0402_33PF33pFDISCRETE1C24
C0402CAP_NP1_C0402_560PF560pFDISCRETE1C26
C0402CAP_NP1_C0402_2.2NF2.2nFDISCRETE1C27
C0402CAP_NP3_C0402_68NF68nFDISCRETE1C28
C0402CAP_NP3_C0402_1UF1uFDISCRETE4C29; C41; C70; C105
C0402CAP_NP6_C0402_2.2NF2.2nFDISCRETE1C30
C0402CAP_NP2_C0402_1UF1uFDISCRETE9C31; C52; C56; C59; C60; C64; C66; C68; C86
C0402CAP_NP2_C0402_0.1UF0.1uFDISCRETE19C32; C33; C34; C38; C40; C45; C47; C51; C55; C61; C62; C82; C84; C85; C87; C89; C90; C91; C175
C0402CAP_NP6_C0402_1UF1uFDISCRETE1C36
C0402CAP_NP4_C0402_10PF10pFDISCRETE6C39; C42; C43; C44; C140; C141
C0402CAP_NP2_C0402_N.MN.MIC2C48; C49
C0402CAP_NP2_C0402_0.01UF0.01uFDISCRETE4C50; C54; C63; C83
C0402CAP_NP3_C0402_0.1UF0.1uFDISCRETE8C58; C71; C106; C110; C149; C151; C153; C156
C0402CAP_NP6_C0402_0.1UF0.1uFDISCRETE3C67; C69; C77
C0402CAP_NP3_C0402_N.MN.MIC5C73; C74; C75; C80; C88
C0402CAP_NP3_C0402_10PF10pFDISCRETE2C78; C79
C0402C_C0402_0.1UF0.1uFDISCRETE3C99; C167; C168
C0402CAP_NP3_C0402_N.M_10PFN.M_10pFIC1C108
C0402C0603_105_C0402_0.1UF0.1uFDISCRETE14C112; C118; C119; C121; C122; C123; C124; C125; C126; C128; C129; C130; C142; C143
C0402C0603_105_C0402_0.1UF_16V0.1uF_16VIC2C117; C120
C0402C0603_105_C0402_1UF1uFDISCRETE1C127
C0402C0603_105_C0402_N.M_10PFN.M_10PFIC1C131
C0402C0805_104_C0402_10PF10pFDISCRETE1C132
C0402C_C0402_1UF1uFDISCRETE1C134
C0402C_C0402_22NF22nFDISCRETE2C135; C144
C0402CAP_NP4_C0402_0.1UF0.1uFDISCRETE4C160; C162; C164; C169
C0402CAP_NP4_C0402_1UF1UFDISCRETE1C161
C0402CAP_NP4_C0402_1NF1nFDISCRETE1C163
C0402CAP_NP5_C0402_N.M_10PFN.M_10PFIC1C165
C0402CAP_NP5_C0402_NM_10PFNM_10PFIC1C166
C0402CAP_NP5_C0402_0.1UF0.1uFDISCRETE1C171
C0402C_C0402_180PF180PFDISCRETE1C172
C0402CAP_NP1_C0402_N.MN.MIC1C178
C0402CAP_NP2_C0402_N.M_0.1UFN.M_0.1uFIC1C179
C0402CAP_NP_C0402_N.MN.MIC1C180
C0603C_C0603_4.7UF_10V4.7uF_10VIC2C9; C109
C0603CAP_NP1_C0603_1UF_16V1uF_16VDISCRETE1C22
C0603CAP_NP1_C0603_NM_0.1UFNM_0.1uFIC1C37
C0603CAP_NP2_C0603_4.7UF4.7uFDISCRETE2C53; C65
C0603CAP_NP4_C0603_4.7UF4.7uFDISCRETE3C72; C107; C159
C0603CAP_NP1_C0603_4.7UF4.7uFDISCRETE1C81
C0603CAP_NP4_C0603_4.7UF_10V4.7uF_10VIC5C92; C93; C95; C96; C100
C0603CAP_NP3_C0603_4.7UF_10V4.7uF_10VIC7C94; C103; C111; C133; C138; C139; C176
C0603C_C0603_2.2UF_16V2.2uF_16VIC4C97; C101; C102; C104
C0603CAP_NP4_C0603_4.7UF_25V4.7uF_25VIC1C98
C0603CAPACITOR-NON-POL_C0603_2.2UF_12.2uF_16VIC1C113
C0603C0805_104_C0603_2.2UF_16V2.2uF_16VIC1C114
C0603C0603_105_C0603_0.22UF_16V0.22uF_16VIC1C115
C0603CAPACITOR-NON-POL_C0603_4.7UF_14.7uF_10VIC1C116
C0603CAPACITOR-NON-POL_C0603_2.2UF2.2uFDISCRETE2C152; C154
C0603CAP_NP6_C0603_4.7UF4.7uFDISCRETE1C155
C0603CAP_NP6_C0603_2.2UF2.2uFDISCRETE2C157; C158
C0805CAP_NP1_C0805_10UF_10V10uF_10VDISCRETE11C2; C3; C4; C11; C12; C18; C19; C23; C35; C46; C57
C0805CAP_NP1_C0805_10UF_16V10uF_16VDISCRETE7C5; C8; C13; C137; C145; C146; C148
C0805CAP_NP3_C0805_10UF_16V10uF_16VIC1C136
C0805CAPACITOR-NON-POL_C0805_10UF_1610uF_16VIC1C147
CD30INDUCTOR_CD30_10UH-VE3521-100K10uH-VE3521-100KIC3L1; L3; L5
CD30INDUCTOR_CD30_2.2UH-VE3521-2R2M2.2uH-VE3521-2R2MIC2L2; L4
CD30INDUCTOR_CD30_4.7UH-VE3521-4R7M4.7uH-VE3521-4R7MIC2L6; L7
CON6P-1_0X1_5-1_8PAD2_15_CON6P-1_0X1_5-1_8_TOP_PTOP_PADIC1CN5
CRY3225CRYTAL-3225_CRY3225_NC_12MHZNC_12MHzIC1OSC1
DIODE_IN5819ZHCS750_DIODE_IN5819_RGF1JRGF1JIC1D11
DIP2_4MM_NCAP_DIP2_4MM_N_80UF80UFDISCRETE1C173
EMT3DTC_0_EMT3_DTC124EEDTC124EEIC1Q2
EMT3DTC_2_EMT3_DTC124EEDTC124EEIC1Q5
EMT3DTC_1_EMT3_DTC124EEDTC124EEIC1Q6
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_UPUPIC1SW1
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_ZOOM_OUZOOM_OUTIC1SW2
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_DOWNDOWNIC1SW3
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_ZOOM_INZOOM_INIC1SW4
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_LEFTLEFTIC1SW5
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_MENUMENUIC1SW6
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_RIGHTRIGHTIC1SW7
ES_BOTTONSW_PUSHBUTTON_ES_BOTTON_MODEMODEIC1SW8
FPC12PIN0_5MMCON12PIN_FPC12PIN0_5MM_NCNCIC1CN1
FPC20UPAUTO_FOCUS_LENS_1_FPC20UP_LENS_LENS_FPC_CON_20P_P0_5IC1J2
FPC40DOWNA027DN01_4_FPC40DOWN_TFT-40PINTFT-40PinIC1CON1
FPC45PINX2-0_2MMCCD_FPC_9_FPC45PINX2-0_2MM_45PI45PINX2IC1CON2
FPGA18X18-0_65NT96433_1_FPGA18X18-0_65_NT9645NT96450IC1U2
L0603RES2_L0603_N.M_2.2UHN.M_2.2UHIC2L13; L16
L0603RES2_L0603_2.2UH2.2UHDISCRETE1L15
LAMP_NLAMP_LAMP_N_LAMP_NLAMP_NIC1LAMP-1
LAMP_PLAMP_LAMP_P_LAMP_PLAMP_PIC1LAMP+1
LED0606LEDTWO_3_LED0606_R/GR/GIC1D9
QFN28WT7026_QFN28_WT7026WT7026IC1U10
R0402INDUCTOR_R0402_0R0RDISCRETE5L8; L9; L10; L11; L12
R0402R_R0402_15K_1%15K_1%IC2R1; R24
R0402R_R0402_130K_1%130K_1%IC1R2
R0402R_R0402_510K_1%510K_1%DISCRETE1R3
R0402R_R0402_120K_1%120K_1%IC1R4
R0402R_R0402_0R0RDISCRETE5R5; R19; R79; R110; R111
R0402R_R0402_102K_1%102K_1%IC1R6
R0402R_R0402_56K_1%56K_1%IC1R7
R0402R_R0402_470K_1%470K_1%DISCRETE2R8; R18
R0402R_R0402_10K_1%10K_1%IC3R9; R48; R119
R0402R_R0402_150K_1%150K_1%IC1R10
R0402R_R0402_187K_1%187K_1%IC1R12
R0402R_R0402_12K_1%12K_1%IC1R13
R0402R_R0402_374K_1%374K_1%DISCRETE2R14; R20
R0402R_R0402_6.8R_1%6.8R_1%IC1R15
R0402R_R0402_16K_1%16K_1%IC1R16
R0402R_R0402_N.M_ORN.M_ORIC1R17
R0402R_R0402_10K10KDISCRETE6R21; R22; R54; R55; R56; R70
R0402R_R0402_39K_1%39K_1%DISCRETE1R23
R0402RES2_R0402_N.M_10KN.M_10KIC1R25
R0402RES2_R0402_10K10KDISCRETE4R26; R151; R159; R160
R0402RES4_R0402_12K_1%12K_1%IC1R27
R0402RESISTOR_R0402_0R0RDISCRETE9R28; R30; R31; R33; R35; R78; R81; R82; R88
R0402RES3_R0402_3.3K_1%3.3K_1%IC1R29
R0402RESISTOR_R0402_2K_1%2K_1%IC1R32
R0402RESISTOR_R0402_N.M_0RN.M_0RIC1R34
R0402RESISTOR_R0402_10K10KDISCRETE1R36
R0402RES2_R0402_0R0RDISCRETE8R38; R46; R47; R102; R103; R104; R153; R157
R0402RES3_R0402_510R_1%510R_1%IC1R39
R0402RES1_R0402_22R_1%22R_1%DISCRETE2R40; R42
R0402RES3_R0402_1M1MDISCRETE1R41
R0402RES5_R0402_1K_1%1K_1%IC2R43; R120
R0402RES5_R0402_N.M_100RN.M_100RIC1R44
R0402RES5_R0402_N.M_1KN.M_1KIC1R45
R0402R_R0402_100K_1%100K_1%IC1R49
R0402R_R0402_300K_1%300K_1%IC1R50
R0402RES4_R0402_100K100KDISCRETE3R52; R69; R144
R0402RES2_R0402_10K_1%10K_1%DISCRETE3R53; R106; R107
R0402R_R0402_22R_1%22R_1%IC6R57; R58; R59; R60; R63; R64
R0402RES3_R0402_10K_1%10K_1%IC2R61; R65
R0402R0603R_R0402_22R_1%22R_1%DISCRETE1R71
R0402RES3_R0402_N.MN.MIC2R72; R74
R0402R_R0402_100R100RDISCRETE1R75
R0402R_R0402_100K100KDISCRETE1R76
R0402R_R0402_33K33KDISCRETE1R77
R0402RES3_R0402_10K10KDISCRETE3R83; R84; R90
R0402RES3_R0402_N.M_10KN.M_10KIC2R85; R95
R0402RESISTOR_R0402_22R22RDISCRETE1R86
R0402R_R0402_2.2R2.2RDISCRETE4R91; R92; R96; R97
R0402RES2_R0402_150R_1%150R_1%DISCRETE3R100; R101; R105
R0402RES2_R0402_15K_1%15K_1%DISCRETE1R108
R0402RES3_R0402_0R0RDISCRETE1R109
R0402RES3_R0402_2.2K_1%2.2K_1%IC2R112; R117
R0402R_R0402_N.M_0RN.M_0RIC2R113; R115
R0402R_R0402_510R_1%510R_1%IC1R114
R0402R_R0402_3K_1%3K_1%DISCRETE1R116
R0402RES3_R0402_1K_1%1K_1%IC1R118
R0402RES5_R0402_0R0RDISCRETE3R121; R125; R126
R0402RES5_R0402_N.M_100KN.M_100KIC1R122
R0402RES5_R0402_N.M_20KN.M_20KIC1R124
R0402RES4_R0402_10K_1%10K_1%DISCRETE4R128; R129; R135; R136
R0402RES4_R0402_1K_1%1K_1%IC5R131; R132; R140; R141; R142
R0402RES4_R0402_5.6K_1%5.6K_1%IC2R133; R134
R0402RES4_R0402_20K_1%20K_1%IC2R137; R138
R0402RES6_R0402_10K10KDISCRETE1R139
R0402RES3_R0402_100K100KDISCRETE1R143
R0402RES6_R0402_100K100KDISCRETE1R145
R0402RES2_R0402_N.M_0RN.M_0RIC1R152
R0402RES2_R0402_1K_1%1K_1%DISCRETE2R154; R158
R0402RES2_R0402_10R_1%10R_1%DISCRETE2R155; R156
R0402RES2_R0402_39K_1%39K_1%IC1R161
R040227V_VR1005BBA270_R0402_N.MN.MIC10RV1; RV2; RV3; RV4; RV5; RV6; RV7; RV8; RV9; RV10
R0603FUSE-1_5A63V-1206_R0603_0R0RDISCRETE1F1
R0603RES2_R0603_2.2UH2.2UHDISCRETE1L14
R0603R_R0603_0R0RDISCRETE1R11
R0603RES1_R0603_N.M_33RN.M_33RIC1R37
R0603RES6_R0603_N.M_0RN.M_0RIC1R51
R0603RES3_R0603_0R0RDISCRETE6R62; R66; R73; R87; R93; R94
R0603RES4_R0603_N.M_0RN.M_0RIC1R67
R0603RES4_R0603_0R0RDISCRETE1R68
R0603RES3_R0603_N.M_0RN.M_0RIC2R80; R89
R0603RES2_R0603_1R_1%1R_1%IC1R98
R0603RES2_R0603_0R0RDISCRETE1R99
R0603RES5_R0603_0R0RDISCRETE2R123; R127
R0603R_R0603_22R_1%22R_1%IC1R130
R0603R0603R_0_R0603_0R0RDISCRETE1R146
R0603RES2_R0603_120K_1%120K_1%IC1R147
R0603RES2_R0603_100K_1%100K_1%IC1R148
R0603SMD_R_0603100K_1%IC1R149
R0603RES2_R0603_130K_1%130K_1%IC1R150
R0603R0805_R0603_0R0RDISCRETE2R162; R163
RT9971BRT9917_RT9971B_RT9971RT9971IC1U1
SDCARD-510SD_CARD_SDCARD-510_J-SD-510J-SD-510IC1J1
SIP2-2_0MMPAD2_SIP2-2_0MM_MICMICIC2CN2; CN3
SIP2-2_0MMPAD2_SIP2-2_0MM_SPEAKERSpeakerIC1CN4
SIP2_2_0MMCONN_CIR_2_R_SIP2_2_0MM_C190KGKC190KGKTIC1CON3
SO8_NORFLASHX25F128_SO8_NORFLASH_MX25L32MX25L32IC1U5
SOD323DIODE_SCHOTTKY_SOD323_IN5819IN5819IC3D1; D2; D3
SOD323DIODE_SCHOTTKY_SOD323_N.M_IN581N.M_IN5819IC1D4
SOD323DIODE_SOD323_IN4148IN4148IC3D5; D6; D7
SOD323DIODE_SCHOTTKY_SOD323_MMPZ5232BMMPZ5232BPTIC1D8
SOT23BAT54_1_SOT23_MMBD3004SMMBD3004SIC1D10
SOT23FDN338P_0_SOT23_ME2301ME2301IC3Q1; Q3; Q4
SOT232N7002EPT_SOT23_ME2302ME2302IC1Q7
SOT23AAT3522_SOT23_RT9818C-27PVLRT9818C-27PVLIC1U3
SOT23AAT3522_SOT23_NM_RT9818C-30PVLNM_RT9818C-30PVLIC1U4
SOT23_5RT9029_SOT23_5_RT9020-31GU5RT9020-31GU5IC2U8; U9
SOT23_5RT9167_SOT23_5_FSP4054FSP4054IC1U11
TANACAP_NP1_TANA_10UF_10V10uF_10VDISCRETE3C16; C20; C25
TANACAP_TANA_10UF10uFDISCRETE2C150; C170
TANACAPACITOR_TANA_47UF47UFDISCRETE1GC1
TEST_PINTP_TEST_PIN_TPTPIC95TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58; TP59; TP60; TP61; TP62; TP63; TP64; TP65; TP66; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP75; TP76; TP77; TP78; TP79; TP80; TP81; TP82; TP83; TP84; TP85; TP86; TP87; TP88; TP89; TP90; TP91; TP92; TP93; TP94; TP95; TP96
TRANSFORMER_LD7266TRIGCOIL_2_TRANSFORMER_LD7266_44200-FBT-EE0504SIC1T1
TSOJ_8_RJP4010AP28G45EM_TSOJ_8_RJP4010_TIG064TIG064E8IC1Q9
TSSOP_8_AP28G45AP28G45EM_TSSOP_8_AP28G45_N.MN.MIC1Q8
TS_45BTRNSFMR-PHOTOFLASH00_14_TS_45B_4200TT0505S-4.3KVIC1T2
WDFN-10LLD7270_WDFN-10L_LD7270EGLLD7270EGLIC1U12
XTAL2X6XTAL_XTAL2X6_32_768KHZ32_768KHzIC1Y1
XTAL2X6XTAL_XTAL2X6_12MHZ12MHzIC1Y2
附件:) s8 ]) g2 f* z! ^/ x8 s/ L
原理图和PCB文件如下:7 \' y1 O6 C+ Q$ \# B, C2 G
游客,如果您要查看本帖隐藏内容请回复
: ~& U/ w6 p* N9 b4 V! _
" e& j4 t4 L: Q+ @4 U- L4 }
发表于 2021-9-10 14:40 | 只看该作者
学习学习,数码相机主板原理以及布局布线设计8 a2 c: t" u; X- ?% k5 }
发表于 2022-11-23 13:37 | 只看该作者
11111111111111111112 A4 ]- w9 ]/ ^( G- b- {
GMT+8, 2025-10-12 21:19 , Processed in 0.187500 second(s), 27 queries , Gzip On.
