POWER SI仿真的时候报错,大佬帮忙看看,哪里出了问题 8 M1 o# a0 y; V& S. j3 ?& C
7 R, p5 d9 `: a1 j9 f
"Via1302::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".* G) O) |9 r- a. ^) t3 G3 G
"Via1313::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND"." Y7 X, W! b. h5 ^8 [
"Via1316::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".
3 ]1 w+ r2 M1 z! Y5 e8 J5 M4 K / J. ?; ^: [# F9 U1 K% o
"Via1317::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".4 A+ H4 J5 p/ Q, a2 F
"Via1320::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".
8 N( p6 A* N$ q1 Q: k( n "Via1321::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".! X0 {& R: g F W! f$ v1 S
"Via1347::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".& }$ r* {0 J" d8 n9 h* T
"Via1348::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".4 L' M! k. q/ l7 l! V$ k9 V' K
"Via1354::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".
% a3 ]+ O; l* M- o* e' Q2 ~' h7 I "Via1355::VREG_S1A_0P8" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".0 Q$ S ^# p" E: O7 P
"Via1421::VDD_EBI_IO" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND".0 K* A( _. f& ?( {; C
"Via1479::VDD_EBI_IO" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND"., m7 z! X0 I' L
"Via1481::VDD_EBI_IO" on layer "Signal$Inner_Layer7" is outside of the plane "Polygon324774::GND". |
