7. Specify the directory where you want to install the products.
0 @9 U G. u# G7 ~Note: For each version of a release, you can only change the destination the first time
0 Y. d9 n' o% Pyou install the products. During all subsequent installations, the destination is fixed to the
7 |0 ~7 q7 }; X8 r# @0 R3 t5 xexisting directory path. You will no longer be able to change the destination. / K& p, N8 c* ~$ c/ D. P5 b" \
以上是自带的安装指导里的说明,只能第一次安装时改,似乎以后再装就改不了了。
0 f: C3 s+ O+ d, Y% F/ W- y' d+ m& \4 @我也郁闷着呢,有高手可以解决吗? |
