作品名:[AD 10][2层]SG3525 2500w&9600W织机脉冲电源控制部分原理图和PCB源文件- t0 x l `$ ~" u$ K) g7 I8 D
1 P% o) d. Z" _* O文件描述
0 Z) q" p B3 I$ I: U# S a* [, @1. 作品用途:织机脉冲电源控制部分' B$ h; [' C7 ?- J* e& ^
2. 软件版本:AD 10
- q1 `4 ^" q! f# B3. 层数:2层板
4 O, s: c- ]! K2 s! E" F4 ?1 X4. 用到的主要芯片:LM317T
* y) l+ s% [/ D5. PCB尺寸:60.1mm*140.3mm e* W5 ]) C" T- o. a
- l+ j& s7 y$ `8 N8 q* o
作品截图如下:: k! Q; A( @+ F3 x: o. c; j
顶层截图:
4 Z" B# I7 N' L: ~
1 X3 v0 _0 N4 k' Y4 Z+ i6 F; ]# }
0 H: y! q* \6 K s" v4 s( R& M
底层截图:
. A4 Z s2 w+ c+ y0 u
2 i$ R6 J4 _7 T. w5 g* m
3 Q: Q, e1 Y2 t- j# n全层截图:
" I# d4 Y* B* W3 L# R5 H
6 j1 n; f! e" b/ [# X$ k& N9 W& V. M2 u w+ |
叠层信息截图如下:
" i# a$ K$ B; B. A* a
M- e/ X: {2 X* F
: a- v; q4 E/ ^1 z& vBOM:
; H6 r' b2 g* P! eComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | C104 | C7, C124, C149 | C0805 | 3 | C337 | C14 | CAP200*400 | 1 | C102 | C15, C16, C20A, C45, C119, C125 | C0805 | 6 | C104J | C17 | C0805 | 1 | R | C17X, R25X | R0805 | 2 | C | C18, C24, C25, C26, C601 | C1206 | 5 | Cap | C19 | C0805 | 1 | C337 | C20 | C150-350 | 1 | C103 | C21, C22, C127, C129, C130 | C0805 | 5 | C337 | C44 | C1206 | 1 | 330uF | C118 | C150-350 | 1 | C332 | C122 | C0805 | 1 | C101 | C123, C126 | C0805 | 2 | Cap Pol1 | C175 | C150-350 | 1 | Cap Pol1 | CN7 | CAP200*400 | 1 | 1N4007 | D4, D15, D24, D29, D30 | D1206 | 5 | D S | D6 | D1206 | 1 | 5.1V | D7, D17 | D1206 | 2 | 1N5819 | D8, D9, D10, D22 | SMA | 4 | 1N4148 | D11, D12, D13, D14, D18, D19, D20, D21, D31, D32 | D1206 | 10 | D27V | D16 | D1206 | 1 | D Z12V | D23, D33 | D1206 | 2 | B | D27 | QD5.08x2.0 | 1 | Bridge1 | D100 | QD5.08x2.0 | 1 | | D109, D113 | SMA | 2 | D Zener | D110, D123 | D1206 | 2 | | D111, D112, D124, D125, D126 | D1206 | 5 | D Zener | D114 | SMA | 1 | Inductor Iron | L2 | C150-350 | 1 | Header 3H | P1 | HDR1X3H | 1 | Header 10X2H | PC1 | HDR2X10H | 1 | Header 7X2 | PE4 | HDR2X7 | 1 | Header 3 | PE5 | HDR1X3 | 1 | Header 5X2 | PT1 | HDR2X5 | 1 | PMBT3904 | Q1 | SOT23 | 1 | 2N7002 | Q6, Q7 | SOT54 | 2 | PMBT3906 | Q9, Q13 | SOT23 | 2 | R2401 | R5 | R0805-M | 1 | R202 | R6, R11, R31 | R0805-M | 3 | R244 | R10 | R0805-M | 1 | R104 | R12 | R0805-M | 1 | R102 | R13, R16, R25, R32, R45, R47, R127 | R0805-M | 7 | R103 | R14, R40, R49, R114 | R0805-M | 4 | R622 | R15 | R0805-M | 1 | R753 | R17 | R0805-M | 1 | R363 | R18 | R0805-M | 1 | R153 | R19, R115 | R0805-M | 2 | R563 | R19A | R0805-M | 1 | R564 | R20 | R0805-M | 1 | R393 | R20A, R33, R63 | R0805-M | 3 | R673 | R21 | R0805-M | 1 | R473 | R22 | R0805-M | 1 | R242 | R23 | R0805-M | 1 | R220 | R26, R131 | R0805-M | 2 | R? | R27 | R0805-M | 1 | R122 | R28, R39, R64 | R0805-M | 3 | R394 | R30 | R0805-M | 1 | R101 | R35, R36 | R1206 | 2 | 1000 | R37 | R1206 | 1 | R152 | R38 | R0805-M | 1 | R472 | R41, R137 | R0805-M | 2 | R182 | R42, R44, R66 | R0805-M | 3 | R102 | R48 | R1206 | 1 | R471 | R62 | R0805-M | 1 | R123 | R65 | R0805-M | 1 | R132 | R116 | R0805-M | 1 | R100 | R117 | R0805-M | 1 | R1102 | R123, R146 | R0805-M | 2 | R473 ? | R124 | R0805-M | 1 | R352 | R126 | R0805-M | 1 | R272 | R128 | R0805-M | 1 | R680 | R132 | R0805-M | 1 | R223 | R133 | R0805-M | 1 | R332 | R134 | R0805-M | 1 | R510 | R138 | R0805-M | 1 | BC817-25 | TR3 | SOT23 | 1 | Res Thermal | TS1 | RAD0.2 | 1 | LM317T | U1, U112 | TO-220 | 2 | LM339AD | U2 | SO14_N | 1 | LM358AD | U4 | SO8_L | 1 | SG3525AN | U5 | DIP16 | 1 | BT151 | U6 | TO-220 | 1 | H11L1 | U8 | DIP6 | 1 | CNY17 | U9, U10, U11, U12 | DIP6 | 4 | UC3842AN | UF2 | SO-8 | 1 | , i7 _7 n/ ?9 O4 }5 B0 z* F
附件:$ U. v7 {0 F6 ?" p# Z8 Y+ w+ N0 x
原理图和PCB源文件如下:
# Q8 ?3 s$ E, a4 `5 U3 Q( T
; W, ]8 Y* i; r; m! n- y7 z" R& {- n4 Z" v# a+ N0 \
