1. control command 线后面的并联上拉电阻不是起到阻抗匹配的 --- the pullups are for parallel termination, which usually are placed at receiving end, they are for impedance match (50ohm). 5 B0 U1 ^" k6 D5 o4 m( f% l' Y2. 数据线的串联电阻因为是双向的,所以要靠近DDR那边 --- my understanding is the position doesn't matter for bi-directional bus. putting them at DDR side is for easier/neater routing.
你要看看你的DDR是怎样的 拓扑结构。* E5 W) V; ?% [ ]0 O v
并联电阻是VTT端接电阻,那个是用来吸收噪声的。对于没有DIMM的P to P拓扑,可以却掉的,但同时你要考虑一下你的DDR的驱动能力问题。没有DIMM的P to P 拓扑中数据线上的串联电阻的位置,也可以放在中间的,由两方的驱动能力强弱,器件放置等因素共同决定。
