查看: 3634|回复: 56
[AD 16][2层]RK3288 POS机主板V.2.0 (4DDR+eMMC+LVDS)原理图和PCB源文件
发表于 2020-2-19 10:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 16][2层]RK3288 POS机主板V.2.0 (4DDR+eMMC+LVDS)原理图和PCB源文件
# I  _, V1 Q3 _2 K$ x5 U
9 \( s# i1 z0 e2 ]) r( c* R文件描述
; ?* `6 O2 |& d4 Z+ B( y1. 作品用途:POS机主板
+ O5 J( M( b1 y, j6 e# C/ O2. 软件版本:AD 16* U0 q; ?% q9 ?' O
3. 层数:2层板
, A# _( q! s% }$ [; |4. 用到的主要芯片:miniPCIe Module* L8 a0 w0 I$ o% l5 n6 z1 {2 x
5. PCB尺寸:171.2mm*97.1mm9 A' T* g6 h) j. _
% O6 ?$ z2 m' x& o$ G
作品截图如下:0 o2 a/ ?2 _; e  T& E& h
顶层截图:
+ {: u4 [$ v4 e! Z; J# X  o 1 M; f4 U3 z- R  ^# a  H# V% s
' `" B; L4 j" \
底层截图:
+ v, ~9 z: i$ p1 `& Z9 Y
5 h* X$ m5 V" ^4 q
/ F- V' }  q4 V* J全层截图:
$ n- r4 x# `: {/ E( f ; |5 ~9 a+ V0 p  b4 M  }6 k" Y
' Z; }% }9 n6 e7 n! I/ \# |- Q
叠层信息截图如下:
% b+ \& O1 X% L) k: y 4 u# ~8 E' n7 I" R! |  u) i
9 _% _9 {5 Z$ L3 O# C( ABOM:
  h; w% L% _6 E; a$ v8 e
Comment(属性)
Designator(位号)
Footprint(封装)
Quantity(数量)
ANT
ANT1
ANT_JACK
Battery
BT1
BATTERY
Cap
C1, C2, C3, C4, C5,  C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C19, C21, C23, C26, C28, C29,  C31, C32, C33, C34, C36, C37, C38, C46, C47, C49, C50, C185, C186, C187,  C188, C189, C190, C191, C192, C193, C194, C195, C196, C197, C198, C199, C201,  C202, C203, C204, C205, C208, C209, C210, C211, C212, C213, C214, C215, C216,  C217, C218, C219, C220, C221, C319, C320, C323, C324, C325, C326, C327, C328,  C329, C330, C331, C332, C333
C0402
79
Cap
C16, C17, C18, C20,  C22, C24, C25, C30, C35, C39, C44, C45, C48, C51
C0603
14
0.1uF
C27, C53, C55, C61,  C75, C76, C77, C78, C79, C80, C81, C82, C87, C88, C89, C90, C91, C92, C93,  C94, C97, C105, C107, C108, C110, C112, C113, C114, C115, C116, C121, C124,  C125, C129, C130, C131, C132, C142, C143, C150, C151, C153, C154, C155, C156,  C157, C159, C165, C168, C170, C175, C184, C225, C227, C232, C234, C237, C255,  C256, C257, C269, C272, C275, C277, C296, C298, C301, C303, C305, C306, C307,  C309, C312, C314, C316, C334, C335, C336, C337, C338, C339, C343, C345, C347,  C349, C350, C351, C352, C356, C358, C360, C362, C374, C376, C382, C385, C390
C0402
97
10uF
C40, C41, C62, C66,  C161, C230, C236, C264, C342, C344, C346, C348, C355, C357, C359, C361, C363,  C365, C381, C394
C0805
20
100pF
C42, C43, C104
C0402
Cap
C52, C318, C321, C322
c0805
47uF
C54, C68, C69, C396,  C397
C1206
100nF
C56, C58, C65, C70,  C71, C166, C173, C222, C223, C240, C243, C244, C245, C246, C247, C248, C249,  C250, C251, C252, C254, C261, C265, C364, C366, C387, C393, C398, C399
C0402
29
100uF
C57, C386
C_SMD6.0
47uF/25V
C59, C60, C388, C389
C1206
120PF
C63, C391
C0402
0.012UF
C64, C392
C0402
22pF
C67, C118, C119, C395
C0402
22uF
C72, C84
C0603
10uF
C73, C85, C96, C106,  C123, C127, C140, C147, C148, C158, C160, C167, C169, C174, C176, C183, C224,  C226, C268, C274, C295, C315, C317
C0603
23
1uF
C74, C86, C120, C141,  C149, C162, C163, C164, C178, C180, C182, C200, C207, C235, C238, C239, C241,  C242, C293, C300, C383, C384
C0402
22
1nF
C83, C95, C98, C99,  C100, C101, C102, C103, C122, C126, C144, C152, C297, C299, C302, C304, C308,  C310
C0402
18
4.7uF
C109, C111, C253,  C282, C285, C289, C367, C373, C380
C0603
9
0.1uF
C117
C0603
NC
C128, C313
C0402
22uF
C133, C134, C135,  C136, C137, C138, C139, C145, C146, C171, C177, C179, C181, C228, C266, C267,  C273, C276, C291, C292, C500
c0805
21
1uF
C172, C229, C231,  C501
C0603
20pF
C258, C259, C340,  C341, C353, C354
C0402
4.7uF
C260
c0805
27pF
C262, C263
C0402
10uF/10V
C270, C271, C279
C0805
4.7uF/10V
C278
C0805
2.2uF
C280, C281, C283,  C284, C286, C287, C288, C290
C0603
8
47nF
C294
C0402
12pF
C311
C0402
10pF
C368
C0402
8pF
C369, C370
C0402
33pF
C371, C372, C375,  C377, C378, C379
C0402
RJ11
CON1
RJ11
LVDS/EDP_CON
CON2
HDR2*15_2mm
EDP_CON
CON3
HDR2*10_2mm
USB_DOUBLE
CON4, CON5
USB_Connector *2
SS34
D1, D2
SOD-123
SS34
D3, D5
SS34
D4
D0805
D Zener
D7, D8, D9, D10, D13
SOD-123
Diode
D11, D12
SOD-123
NC/ESD9B5V
ED1, ED2, ED3, ED12,  ED13, ED14, ED15, ED16, ED17, ED18, ED23, ED24, ED25, ED26, ED27, ED28, ED29,  ED30, ED31, ED32, ED33, ED34, ED35, ED36, ED37, ED38, ED39, ED40, ED41, ED42,  ED43, ED44, ED45
E0402N
33
NC/ESD9B5VL
ED4, ED5, ED6, ED7,  ED19, ED20, ED21, ED22
E0402N
8
Inductor
FB1, FB2, FB3, FB4
R0402
Inductor
FB5, FB6, FB8, FB10,  FB11, FB12, FB13, FB14
R0603
8
Inductor
FB7
R0805
HOLE
H1, H2, H3, H4
H3.8MM
PWR2.5
J2
DC36-D
TF_SD_SOCKET
J3
SDCARD-TRF-11008ZB-PBW
HDMI_CNT
J4
HDMI_A
FPC26PIN
J5
FPC26PIN
D Connector 9
J6
DSUB1.385-2H9
PhoneJack
J10
PJ_342B
10UH/5A
L1, L12
L8040
2.2uH/2A
L2, L13
L-3D16
BLM18PG181SN1
L3
L0603
2.2uH
L4
L-3D16
0.22uH/5A
L5, L10
L-3D16
2.2uH/1.5A
L6, L7, L8, L9
IND_3X3
SWPA3012S4R7MT/1A
L11
L-3D16
RED
LED1
D0805
Header 4H
P1
HDR1*4_2mm
Header 5X2
P2, P3, P13, P14,  P15, P16, P18, P19
HDR2X5
8
Header 6
P4, P7, P8, P9
HDR1*6_2mm
Header 4
P5, P6
HDR1*4_2mm
Header 3X2
P10, P11
HEADER2*3
Header 3
P12
HDR1*3_2MM
Header 4
P17
HDR1X4
TRANS
Q1, Q2, Q13, Q14,  Q15, Q16, Q17
SOT23
2N3904
Q3, Q5, Q10, Q12,  Q20, Q21
2N3904
APM2305
Q4, Q9, Q11, Q18, Q19
KRLML6401
CJ2305
Q6
SOT23
L2SK3018WT1G
Q7, Q8
SC.70
TRANS_FLIP
Q50
HDR1X3
Res3
R1, R2, R3, R4, R5,  R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R16, R17, R18, R19, R20, R21,  R22, R23, R24, R25, R26, R215, R216, R217, R220, R221, R222, R241
R0402
33
Res3
R27, R37
R0603
100K
R33, R42, R46, R65,  R101, R109, R112, R118, R121, R125, R153, R154, R155, R156, R166, R239, R251,  R282, R288, R301, R307, R500, R501
R0402
23
1K
R34, R94, R95, R110,  R113, R157, R158, R168, R223, R230, R231, R232, R233, R269, R286
R0402
15
10K
R38, R44, R45, R49,  R67, R68, R69, R71, R72, R73, R74, R75, R76, R77, R78, R79, R80, R81, R82,  R98, R100, R111, R114, R115, R116, R117, R119, R120, R122, R123, R124, R159,  R160, R162, R204, R205, R214, R219, R234, R235, R236, R237, R238, R247, R249,  R270, R271, R276, R289, R290, R291, R292, R293, R302, R305, R306
R0402
56
4.7K
R39, R87, R91, R92,  R97, R99, R107, R108, R170, R171, R172, R174, R195, R198, R200, R201, R202,  R203
R0402
18
470R
R40, R176, R184
r0402
51R
R41, R303
R0402
51K
R43, R304
R0402
R47
R0402
143k
R48, R308
R0402
3.74K
R50, R309
R0402
19.1k
R51, R310
R0402
280K
R52, R311
R0402
39K
R53, R312
R0402
62K
R54, R313
R0402
240R
R55, R56, R57, R58,  R224, R225
R0402
NC/240R
R59, R60, R61, R62
R0402
100R
R63, R64, R70, R102,  R104, R164, R165, R213, R218, R242, R243, R400, R401, R402, R403, R404, R405,  R406, R407, R408, R409, R410, R411, R412, R413, R414, R415, R416, R417, R418,  R419, R420
R0402
32
10R
R66
R0603
33R
R83, R85, R294, R295,  R296, R297, R298, R299
R0402
8
1M
R84, R152, R199,  R256, R285
R0402
R86
R0402
1.62K%1
R93
R0402
nc
R96, R167, R196,  R197, R207, R208, R209, R210, R211, R212
R0402
10
22R
R105, R106, R169,  R175, R177, R178, R179, R180, R182, R183, R185, R186, R187, R188, R189, R190,  R191, R192, R193, R194
R0402
20
0R
R126, R132, R133,  R134, R135, R136, R137, R138, R139, R140, R141, R142, R143, R144, R145, R146,  R147, R148, R149, R150, R151, R161, R300
R0402
23
4K7
R127, R128, R129,  R130, R131
R0402
4.02K,%1
R163
R0402
1.5K
R173
R0402
2.49K/1%
R181
R0402
0R
R206
R0603
120K
R226, R227, R228,  R229, R240
R0402
5.1R
R244, R246, R257,  R258, R259, R260, R261, R262, R263, R264, R266, R268, R272, R273, R274, R275,  R278, R279, R280, R281
R0402
20
680/1%
R245, R267
R0603
200R
R248, R253, R255
R0402
20K
R250, R277
R0402
510K
R252, R283
R0402
47K
R254, R284
R0402
15K
R265
R0402
6K8
R287
R0402
SIM
SIM1
SIM_CARD
SW_TM-1100
SW1
UBOOT_KEY
TEST
T1, T2
TEST
miniPCIe  Module
U1
4G_MODULE
PT5108E23E-18
U2, U5
SOT25
mcu_RK3288
U3
BGA636_1
ALC5640
U4
QFN48-6X6
TSP54335D_SOP8
U6, U36
MP1484
SY8009B
U7, U37
SOT_23_5
DDR3-512MB
U8, U9, U10, U11
FBGA96-10X14
eMMC
U12
inand_169
SGM2019-1.8YN5G
U13
SOT25
RCLAMP0524P
U14, U15
RCLAMP0524P
NCS8801
U16
QFN56_7*7
XC6219B152MR
U17, U20
SOT-25
XC6219B282MR
U18
SOT-25
XC6219B182MR
U19, U35
SOT-25
RTL8211E-VB-CG
U21
QFN48-6X6
HR911130C
U22
HR911130C
SYR827
U23
WLCSP-20
ACT8846
U24
QFN48-6X6
SYR828
U25
WLCSP-20
HYM8563
U26
SOIC8
DS2480
U27
SOIC8
DS2411
U28
SOT23
MAX3232EUE
U29, U30
TSSOP16
GL850G
U31, U32
SSOP_28
SY6280AAC
U33
SOT23-5-SY6280AAC -  duplicate
AP6255
U34
SOP44_AP6S
24M,12pF,20ppm
Y1
CRY-3225
24M-20ppm
Y2
CRY-3225
25MHz
Y3
XTAL-3225
32.768K
Y4
32.768K_XTAL
12MHz
Y5, Y6
oscd-A
37.4MHz-20ppm
Y7
CRY-3225
# D, B. P3 ?: b# \; u
附件:
& p% d. a# Z/ O" _; f原理图和PCB源文件如下:
/ L- o8 Y& n# j3 `4 R4 D4 a( E' K
游客,如果您要查看本帖隐藏内容请回复
! u  `' Q! i1 F7 p* r8 L
8 d( A9 M# a6 m. q1 n) e
    郁闷
    2025-5-6 15:47
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    推荐
    发表于 2023-10-28 19:01 | 只看该作者
    多谢楼主分享,EDA365有你更精彩
    推荐
    发表于 2023-10-26 18:22 | 只看该作者
    多谢楼主分享,EDA365有你更精彩
    推荐
    发表于 2023-10-11 10:01 | 只看该作者
    多谢楼主分享,EDA365有你更精彩
    慵懒
    2025-9-11 15:29
  • 签到天数: 190 天
    [LV.7]常住居民III
    发表于 2020-11-18 11:05 | 只看该作者
    来学习学习
    擦汗
    2021-9-14 15:25
  • 签到天数: 58 天
    [LV.5]常住居民I
    发表于 2020-11-18 15:07 | 只看该作者
    下载了学习学习
    13#
    发表于 2020-12-14 09:20 | 只看该作者
    ad越来越强大了
    15#
    发表于 2020-12-18 21:30 | 只看该作者
    来学习学习
    ( U$ l/ P2 x( K
    16#
    发表于 2020-12-19 10:38 | 只看该作者
    下来学习一下
    GMT+8, 2025-10-11 20:57 , Processed in 0.218750 second(s), 29 queries , Gzip On.
