: ]: y6 R3 Z9 y. ^& u0 N# F4 G# M; P/ w
5 c8 c; V j# k. B
[AD 10][6层]多路LVDS信号处理板(EP4CE55F23C8+CY7C68013A-100AXC+MT47H64M16HR-25E)原理图和PCB文件7 U8 D& w7 N7 r8 ?" v! F3 D
% O) V4 d/ q- ? N) r5 P7 l
文件描述0 L* `: L% I. s r
1. 作品用途:多路LVDS信号处理板7 [$ Y# f# B: O
2. 软件版本:AD 109 Q% q% `( W+ p
3. 层数:6层板7 a* u! g( f3 A0 t6 ^+ w6 S: l& P
4. 用到的主要芯片:EP4CE55F23C8+CY7C68013A-100AXC+MT47H64M16HR-25E
% P/ D" h$ u" @5. PCB尺寸:135*70 mm
; [* @" o i% E$ Q& J" T+ q' N# N0 `' e# y8 H
作品截图如下:2 `" \% g; n. e% D
顶层截图:1 @) w. m' C% z$ m7 \
& `' I! Z0 v1 n; t
- G9 Y- u2 J$ S: g- f) J" N+ w! g9 Q
底层截图:
! H6 K* j5 h0 D2 h% d, r
~! M- }, B6 \, H7 R
4 P4 l) R! D/ C. c+ O
全层截图:
2 Y2 ]$ A5 x" P. s
. j. D4 c' ]9 q; E& v叠层信息截图如下:
' L# l2 F8 L" A3 T* L. @: F1 I5 b
/ m% _5 x4 z- a+ N1 K# ZBOM:
^1 L+ f2 m; M) o1 u0 E# G0.1uF/16v | C1, C2, C10, C11, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C55, C56, C57, CD1, CD2, CD3, CD4, CE1, CE2, CE3, CE4, CS2, CS11, CS12, CS13, CS14, CS15, CS17, CS18, CS20, CS21, CS22, CS25, CS26, CS27, CS28, CS29, CU1, CU2, CU3, CU4, CU5, CU6, CU7, CU8, CU9, CU10, CU11, CU12, CU13, CU14, CY1, CY2 | C_0402 | 87 | AL_CAP | C3 | Cap_D-AL | 1 | 10uF/16v | C4, C6, C7, C9, C12, C13, C54, C58, C59, CS1, CS3, CS6, CS10 | C_1206 | 13 | 2.2uF/16v | C5, C8 | C_0603 | 2 | 1uF/16v | C60, CS7, CS8, CS16, CS19, CS23, CS24, CS30, CS31 | C_0603 | 9 | 1uF | C61 | C_0603 | 1 | 0.1uF/16v | CS4, CS5, CS9 | C_0603 | 3 | SS34 | D1 | 1N5822 | 1 | LED_GREEN_0805 | D2, D3, D4, D5 | LED_0805 | 4 | JTAG-6PIN | JG1 | DF13-6P-1.25 | 1 | micro_USB_molex_47589 | JH1 | micro_usb_47589 | 1 | DF13A-10DP-1.25V | JS1, JS2 | DF13-10DP-1.25 | 2 | Inductor | L1, L3, L4 | CD32 | 3 | FB | L2, Z1, Z2, Z3, Z4, Z5, Z6 | R_0603 | 7 | MHDR2X10 | P1, P2, P3, P4, P6, P7, P8, P9 | DF13-20DP-1.25V | 8 | Header 2 | P5 | 3.96mm/5195 | 1 | Header 3 | PU | HEADER-3_2.0MM | 1 | 22 R 0402 * 4 | R1, R2, R11, R13, R14 | EXB28V | 5 | 51 R 0402 * 4 | R3, R4, R5, R12, R15, R16 | EXB28V | 6 | 1K | R6, R7, R8, R9, R10 | R_0402 | 5 | 22R | R17, R30 | R_0603 | 2 | 10K | R18, R19, R20, R21, R22, R23, RU1, RU3 | R_0402 | 8 | 33K | R24, R26 | R_0603 | 2 | 75K | R25, R27, R28 | R_0603 | 3 | 24K | R29 | R_0603 | 1 | 0R SEL | R31, R32 | R_0603 | 2 | 100K | R33 | R_0603 | 1 | 100R | RD1, RD2, RD3, RD4, RD5, RD6, RD7, RD8, RD9, RD10, RD11, RD12, RD13, RD14, RD15, RD16, RD17, RD18, RD19, RD20, RD21, RD22, RD23, RD24, RD25, RD26, RD31, RD32, RD33, RD34, RD35, RD36, RS1 | R_0402 | 33 | 1K | RD27, RD28, RD29, RD30 | R_0603 | 4 | 50R 1% | RDN1, RUP1 | R_0402 | 2 | 22R | RU2, RY1, RY2 | R_0402 | 3 | 2.2K | RU4, RU5 | R_0402 | 2 | 75K | RU6 | R_0402 | 1 | SMT_key | S1 | RESET_SMT | 1 | SW SMT-1.27 | SY1 | 2_bit_switch | 1 | LP2997M | U1 | M08A_N | 1 | EP4CE55F23C8 | U2 | FBGA484 | 1 | CY7C68013A-100AXC | U3 | A101_N | 1 | MT47H64M16HR-25E | U4 | MICT-HR-84 | 1 | TPS650243RHBR | U5 | RHB32-3450X3450TP | 1 | 24LC64F-I/ST | U6 | TSSOP-ST8_N | 1 | SN74LVC16244ADGGR | U7 | DGG048_N | 1 | EPCS16SI8N | U8 | SOIC8_N | 1 | REG1117-3.3 | U9 | ZZ311 | 1 | EMI2121 | UB1 | SOIC127P230X80_HS-8N | 1 | 50MHz_OSCILLATOR | Y1 | XTAL(5032) | 1 | 32MHz_OSCILLATOR | Y2 | XTAL(5032) | 1 | 24MHz_OSCILLATOR | Y3 | XTAL(5032) | 1 | FB | Z7 | R_1206 | 1 | 附件:
* w) z Q% y. a2 G7 O b原理图和PCB文件如下:+ t2 W4 o, v- U' N1 }) x: m
4 X0 Y4 Y$ p7 z7 Q
" ?3 ~' Y& u$ ?; P- n. F
