查看: 441|回复: 2
pcb抄板pcb设计基本步骤(Basic+steps+of+PCB+board+PCB+design)
发表于 2020-2-17 15:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pcb 抄板 pcb 设计基本步骤(Basic steps of PCB board PCB design)2 o' v2 D4 ]* q* T
The first step of PCB design: the initial work of PCB board circuit
) g2 t; R1 v1 S% }7 E- f) \. Rboard* x* h  A# }3 V8 a- v3 V8 g) y0 _
1. Use schematic design tools to draw schematic diagram, and
' X& @* ?+ t: \3 Agenerate the corresponding network table. Of course, some special
2 m- U4 f4 o9 ^6 vcircumstances, such as the circuit board is relatively simple, have a8 w  R: X- V( g
design may not principle under the circumstance of network graph table,! x. E* q- e& d! W" v/ @0 ~
directly into the PCB system design, in the design of PCB system, can be2 s/ q2 g& |# V9 q  H1 Z
directly used parts package, artificially generated network table.) y8 O! o9 L9 L9 F$ G
2, manually change the network table, some components on the fixed/ a3 s. h9 u& @% i3 W$ N2 t
foot, such as the principle of no pads on the definition of the network, k& H9 s9 p# ^3 x. x* Y5 A1 o
to communicate with it, without any physical connection can be defined
8 \- S8 K" ^% D! y( @. S" h1 q* ^. [to the ground or protective ground. The pin names of some schematics and
/ ~: F* `& D& K, Y7 j1 g" Rinconsistent pin names in the PCB packaging library are changed into the
! @" N' ~$ _5 n" {. A6 nsame as those in the PCB packaging library, especially the two, triode
) @% B) u. b. f/ fand so on.2 Y- G3 G  e2 }. b3 S: n1 k
PCB design steps two: draw their own definition of non-standard
0 X3 b' O+ l% w1 ]8 Wcomponents of the packaging Library4 v1 n! F8 v7 V
It is recommended to put all of the devices you have painted into
. V$ b. j6 {8 d# e3 hone of your own PCB library specific design files.
5 C& Q* s& z2 \
& ^5 r- u# P" W# {! V$ Y
, B5 W& Z( @- n1 |) E8 }% W. W( _% W3 }8 O' g  X( g  ~
游客,如果您要查看本帖隐藏内容请回复
4 S' g- E6 b* _. {
    奋斗
    2019-12-2 15:27
    发表于 2020-2-21 09:48 | 只看该作者
    pcb抄板pcb设计基本步骤
    郁闷
    2020-3-28 15:10
  • 签到天数: 40 天
    [LV.5]常住居民I
    发表于 2022-1-19 15:28 | 只看该作者
    GMT+8, 2025-10-11 07:28 , Processed in 0.140625 second(s), 26 queries , Gzip On.
