===============================================0 n2 a2 O0 Z7 s# f& g
$ R* i& M$ M6 N' t6 \4 gcadence SPB RELEASE 16.3 README -- UNIX Version9 j, l- L% A; c; l7 h. P
" }8 W" Z: E: h8 q+ Z=============================================== j/ U5 E- C V' K1 I( Z: t
# X" L' g: l4 s+ H- v
# B+ t& v+ }4 ]' y
INSTALLATION GUIDE
0 `9 \! U P; Y) E8 m5 s
8 ]0 j' L1 s7 L$ w/ C' ^% B6 P' N--------------------
; j. h: ~0 b; u' OYou can find the UNIX installation guide on Cadence Online Support or the) d+ Z4 L/ A& I( F3 D0 h- B
Cadence downloads site.& g, F H. W9 W' ?
" C: Z+ O, ?7 d3 e2 s
6 U3 r. `' v1 L0 V) N
MIGRATION INFORMATION
a+ G# w4 f; X
; o$ H Z9 B/ V0 a" A5 S8 C$ Z% o-----------------------2 ~/ _* c' G5 w2 E; |
Important migration information is contained in the "Migration
& ]% ^% Y. I2 i' y" z; `" k8 \Guide for allegro Platform Products Release 16.3", which is
3 g$ r" v' B: bavailable when you install this software or on Cadence Online Support.2 c/ N ^2 p O4 C6 n! H3 Y( Q: L
E1 ~/ `% X: m- h% R, J2 u
3 x1 y q7 d' u# \1 g) v- x# P; m1 USYSTEM REQUIREMENTS
) z8 v1 _8 o: s/ r! c. G; q
# [+ W! Y/ l8 \----------------------! r {# b! [! s9 m7 u v0 D
" E6 N; ?2 E7 R
Information about minimum and recommended system requirements can be
4 S2 _0 w# U$ B- {* |; K, Cfound in the "Allegro Platform System Requirements" document in the
+ {$ g7 d B: Z, \Cadence product documentation or on Cadence Online Support.
% ~3 D! v! g7 `/ [/ B! {* S
, N( d* g+ m3 `* T) h- Q
; q6 G* c! j1 s8 S3 x' w ]WHAT'S NEW, F, ~' l4 x* M; ~
7 x. S& D" r3 ]4 l# A$ |Product release notes are available at: n# i4 B. t9 g; B2 d* E
[url=http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin ocumentViewer]http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin ocumentViewer[/url];+ F% r ~+ A7 @2 ]9 W
src=pubs;q=landing/spb163/prodList.html; P9 A- j z" O& H; A, d U" r
# N. e; W8 y9 r! z9 a+ G, y
+ j) Y8 {( @$ F6 SKPNS1 l/ j& G2 k( \' ~
----0 p) f% A9 h8 d
The Known Problems and Solutions (KPNS) document is located at:
& e( y3 T6 N: B& s/ ~[url=http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin ocumentViewer]http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer[/url];5 n2 A( P: v7 U; @, Y' X
src=pubs;q=landing/spb163/kpnsList.html
; g8 P) Z4 o6 {! h1 J S' C% Q" B, z. L+ e! L6 w- I
7 b% k/ ~, W* @- B) @' [- Q
Allegro /SigXplorer ABIML LIBRARIES FOR DEFAULT TRACE MODELS
5 }6 O1 U: n/ s' z+ o( @
, b( e D1 O W% J--------------------------------------------------------------
2 I$ f I) f" u5 |6 u. WThe Allegro /SigXplorer ABIML Library is a free library that includes ABIML 8 E. V+ j6 k. N/ t
libraries for SigXplorer default trace models with suRFace roughness effect.
3 C* R! Q5 g, i( K) x2 `6 U. aIt is designed to provide accurate trace models in Allegro /SigXplorer without
: l: M: @0 ]4 r! Xtime consuming EMS2D solver runs. The libraries can be found at:
% u" r- C) F7 \1 y" y% Qhttp://www.cadence.com/products/pcb/pages/Downloads.aspx, `5 w" M. {2 R* v# A
* M1 W! a$ S2 H* T3 m& NThis ABIML library is provided free of charge for use with Allegro and SigXplorer. ! ]6 c/ B) a5 a/ e0 X3 W+ f1 |% O( n5 e
The library is provided as a zipped archive, with installation instructions included.: }' T- C4 I$ b' ]) o
' U: F( K7 Z+ k; I
CUSTOM ENVIRONMENTS
$ H+ b) u f; {# ^$ j: x
5 K* v1 Y9 u' h: b2 N6 ]; Q0 a-------------------. b& N3 `2 F! P; @; y- \
Customers using custom batch files or scripts to set up their environments must add ; z7 e( j6 }0 ]+ M# q) L3 s: R
the following to their path. There is the potential that some Allegro products may not
! V( Q. p; W8 h+ Ulaunch without this setting.
6 `2 X& l# z0 ^& a1 y K. S%CDSROOT%\OpenAccess\bin\win32\opt
3 o2 S) C- O |4 H. j
% R3 z9 I; |4 a5 Z& q @/ ]
' C/ n6 L: l- l- f! t1 e
" X5 K8 T* G- g* y2 ^8 R9 e' y# P" |! n( }4 W7 Z
List of Fixed CCRs* b& g [8 K& ^; i( ?/ c
-------------------4 v$ w: x9 A$ M( t' M7 O
8 W5 F. }* S% U, D* `, }! Y' _( A! i4 |* M; y" x, e% i2 |1 ]
1 h! [% @$ e; p3 l4 [* Y* nENHANCEMENT CCRs
8 B. V' z# |9 Y0 T2 w e----------------4 {+ [+ d7 I: D+ @2 R$ T
# `1 F. G/ s. z" x \CCR Description
6 F( o3 Y0 A8 a( k6 ]4 N----- -----------
, h, [# C% V" I- Y( B----- ----------- % b& _* U6 G7 U, g. V: J
4 L9 L/ U6 Z' X5 U* m) _1 y, B6 N
7419 Customer menu options added to Allegro menus
+ Z9 s! k; T- v- h1 }9 D+ D8230 Use via in area constraint does not work
+ Z) l/ Z% ^# J6 }10658 Modify default formatting for Label texts and linewidths' A$ d' g# w2 }! k$ b- l% b
12216 Cannot set color or line width for wires on net-by net basis
! J# G3 W9 x o& O, V, ?13083 flip/mirror design to back side
) ]; \, C7 s) E4 y' E# x4 d7 J13373 Select length of pin graphics
0 r1 h p. D$ W! X- }: z# [18072 Add docking option for probe cursor box.
# x( h& }$ N; {% Z# a6 ~! r5 k; t21451 Change Probe print trace color yellow to alternate.
9 L \ O2 {7 H+ a32798 pxllite complex hierarchy netname enhancement9 Q# Y- G; _& p2 w. _
39600 Option to see time spent on allegro database
, G6 _0 z& }2 g: u60427 Add different subclasses for pin_number top and bottom4 ]' F4 x* \) S: I& n
132769 Footprint viewer in CIS should also show pad spacing info
) [8 d0 Y/ D6 r5 R* R( @6 _% N158838 Need easy way to delete marker
0 ]% U8 o8 E+ S8 i) Q; j159977 need attribute mapping capability in mbs2lib and mbs2brd
" @" m8 m1 d; ^8 _% `164790 Improve autorouting quality on diff pair w/match length rule$ ]/ Z' u L* b1 ^
205909 Constraint Manager displays in Allegro no graphic mode
: }& D+ M; v: @210027 Delete dynamic shape removes net name from copied vias, h4 O- n$ U* `- G4 h
222127 pads_IN: Constraints are not imported with the design.
( \3 i: V& E: d236698 Report Unused parts in multiple parts package should be DRC7 J5 f t. v# k' V* v/ E9 X/ v5 v
245193 export dxf height information when blocks are unchecked
8 Q# C% v9 {" i254183 Multithreading for DRC and CM analysis in Allegro
" H# B7 j# K7 i% G282027 Problem with Split Part and part graphics# C6 Y; ? ]$ F w
282507 request to import IBIS file directly! @/ L- A0 T3 K) s/ Q7 r
283698 place by schematic page number window need enhancement
7 Z" F, E; ]. l: x. ?% e. B288540 Schematic page# display order request for Quick place
1 }% ^2 s! ?- v9 v290641 Option to copy paste cursor value6 n. I; N; D( y- \( N3 Z
298081 Models from Funtion.olb need more explanation2 W0 R( |7 w) ^# S9 o& t
323813 Need negation and exclusion function in ADE reports
' q* V \# N2 I! f; o, h6 M5 A341484 Wirebond: Tools to generate wirebond manufacturing outputs
6 f: q$ Q$ u2 [9 e- L* ?2 j5 g353212 Variant Name is not coming in Standard BOM
1 Q4 ^* ~) L% v3 } H9 `# D360602 Enhancement to Show element on a via7 t* x9 |2 e# F3 O
362934 Enhancement for Allegro to utilize Dual Processors.7 ?( k6 \' j- m4 S) l$ `3 |
364850 change the font properties of Label Text& a/ u9 _$ t! L
367468 Need a real DML_PATH environment variable
% g$ G+ E7 W; q6 S380714 Ability to have Power pin set to Not Connect
2 N. ]. N8 f, G$ N L* l" N8 c) q382860 Display parts and nets in different colors1 |( B0 n( @# v$ W- w* W# s5 r, N
384488 Add DEVICE and REFDES filter to Signal Model Browser) F _4 R$ r" M$ A- h4 X
391487 Ability to have user defined directory for storing distribution files for MC analysis/ O7 {5 L' X8 n( j7 y2 m
420008 The renamed differential pair names are different in CM of conceptHDL and CM of Allegro.3 @( w z& b3 e, Y( w3 F z: f- R
420023 It should be possible to Delete a differential pair defined by SIGNAL_MODEL (.dml) on CM.
6 S% [& I: F9 W, y& a; ?420648 Need to get RF Elements to retain previously entered values9 C, r( l2 P8 V3 @2 j5 J
429280 ARC is unable to load/save rules - submitted for tracking with Medtronic SiP benchmark5 w: U. \3 j( o9 O- v
430549 GUI for ADRC XML Rule files8 Q( Y' W; A, \% Y9 Q
430558 Store last used ADRC rule check ini and check values in .sip database8 e% c7 u: j( O5 X
452606 Can we have last plot as a default
( D' l! e0 K- w+ I; k; ^ \6 w3 l; s( v454452 Allow neighboring/overlapping die pads on same net to go to same finger during wirebond add./ ? `9 j6 Z% L
464056 Setup option to always prompt to baseline a new part
s/ k' p/ M5 C/ ~* B3 Z, _$ r469378 Enhancement : Hide/Unhide feature for trace+ O* }) k$ n( [
475077 Schematic Generation Setup form is missing the Port symbol selection. It was there in the 15.7 release.4 c" H A3 \: V6 t- e
475714 User Guide should mention that Temp Sweep is not honored in AA Flow?
4 ~) K: |8 C' v6 a$ q480843 Requesting ability to View > Zoom Mirror current view.1 x- N9 ~ B: e- u. d
484632 Request for Bond finger to snap to Guide in Free placement of Bond pads
1 Z9 V. ?6 E! Q& s2 r+ V490948 Provide a sketch line and text property form
c' U- m8 I( O3 f, Q/ T) x# S1 \0 |- }500550 CRef's should be preserved with the next run of the schgen in the preserve mode.
* ]8 U7 Q- c( M. a- c505284 Enhance The ConceptHDL can set the color for $XR0 property.: a/ j, c8 d' h( X+ w
512748 improving arc routing8 Q6 k: _ o* K( X
513967 staggered C-line via arrays! b B* t. Q7 g- G7 A5 i+ _7 T
515333 Option to specify spacing between Components in the Generated Schematic% R" i4 [4 H/ K. S8 w7 k
525748 Why is MC Analysis Sigma value 1/3rd of 15.7 version value?/ c6 C. q7 j( }. i4 |8 f
526818 Retain Hard Packaging Information option does not work for SECs.* G+ I" F7 h: Q- z0 x% D
528391 SigXplorer measurement is wrong
# }+ N5 t* A+ D- i" O533844 Allegro password not encrypted in the .brd file.
6 k; B9 m, M$ P* q3 ]+ {" @( F536681 In the ADRC tool requesting a "Layer" option for Conductor to Package Substrate Edge Spacing7 J6 R" W" b* T5 W
536948 Allow sorting of power symbols8 ?" e: n) b. H( C5 K7 |) U
539407 In ADRC Minimum Shape Check requesting individual "Layer" option$ X6 I4 o5 U1 n. n3 [& z
541145 slide command does not support to keeping the existing arc# P) \ t S0 i
541214 about supporting OpenDrain Model in Quad2signoise" e9 O- q, h, _3 u6 L% s: O
542414 A function to force diff pair spacing to primary gap.
8 \/ D# h" V4 h+ T6 l! b/ d: r2 n- J542803 A "Minimum Shape Check Soldermask" entry is needed in ADRC+ B: X1 }1 C/ N
543470 Provide rectangle and line width thickness for Drill legend in NC drill Param# O& A9 d) e9 b" u1 Q$ g5 Z& {
543766 Crefer fails to annotate occurrence properties to offpage symbols in replicated blocks
, K) H3 v: }+ m( v) l) f545408 Cursors are toggled off when deleting a plot
5 i; f. W- T% e546891 Enhancement: message improvement when expand design action in Concept
& B: V7 q( S* `5 Y O7 H546985 XOR function to allow to compare layers within different or same designs( L; R+ S& b% Z @. k
548920 Add a document of which properties can be synced and which cannot be and the files required
5 g s: f$ q4 _+ e/ F) U553669 Add a 3D viewer to Allegro
& l( w! \$ S& `+ ]$ h+ I) b1 V555183 Wire Bond Report --- Report field should have save function for reuse, B1 ?* F+ X/ S% x. d
556200 Need listing of DE HDL command names and switches.
3 i7 c9 G( I v2 {556883 Grid point for Origin to be highlighted* q! M( s i, O+ y* A
559638 Enhancement for importing height from PADS in allegro
! |$ s0 |+ Z( ^! N/ T( z559724 Request cline via arrays to be applied to diffpair nets
, ^9 o, i# D4 P' B9 F560134 Show Element Customized Display
, a& C' \4 s: S$ V/ Z; B6 |563957 Enhance Color Dialog form Class/Subclass section to expand vertically when the form size increases.4 w5 D/ S3 h* {
568058 Request to have component information available through the context menus# v @, z* J8 e( Q/ L- N7 [" T. j( ^
569615 Enhancement to import constraints from mentor Board Station to Allegro PCB, n s" x3 C( d: ^2 m
569680 BOMHDL defaults to the wrong file type when html report type is selected
9 ?5 \& Z- `6 g0 L; l6 R569784 Request ability to assign netname to via during copy
: W, H& g# A* u- E: y9 W6 ~" O7 c569863 User would like to set a larger default trace width! i: q. S: L8 Q/ \
570128 Enhancement : Packager setup for subdesign drop down
6 L+ U& |0 m& q; T/ b570195 SiP - Provide option to create/combine BF labeling with additional text required for Bond diagrams
: ]% `! W J+ F' R# }' N570861 Unconnected mark does not be removed even after wire is connected to the pin.
/ Z, f9 e) T8 o; c; r+ j. N575211 Web links in CIS explorer are not working when Firefox 3 as a default Browser
4 S. I7 U& ^: J4 \! c577944 Enhancement request to have the drill legend for thru holes and slots to be separated without being on top of each other. T% j) K5 V: m/ s( j) H# k
583630 Can Multiple Section pop up box be disabled?
! k* ]% s! a0 {583712 Ability to have string values for SCHEMATIC_GROUP property. ~+ ~6 t* E+ m! n
585904 Find a schematic page with help of nets+ U1 J2 w- q4 [8 \: g
589512 RF component snap is 'too clever'" G3 s1 {0 i" h) D; h8 O8 V8 y$ v
590246 CIS to Allegro flow to include or ignore constraints same as HDL to Allegro) q& D, s" i5 m8 J! C3 u" Q$ L
591306 Suppress RF edit window when changing RF Element properties0 m( J8 x+ ]/ k8 E) g8 m
591318 Use RF setup values or retain changed values in RF Element forms5 K0 c- O# K1 f
591443 Temporary highlighting is lost when using the Copy command2 O0 X: _/ w, i8 V* l4 r
591450 Provide a dynamic tapering option to RF PCB Route
& |3 V: j8 l4 r/ ~2 L/ ]3 t6 [: M591489 Would like to suppress RF Snap windowing around the user pick automatically
! e3 M+ l( [$ a, X1 c3 L# @591812 Provide move options for the RF Snap command
- s5 K/ ~8 |/ ]. T591817 Provide easy group and element ID in repackage form! {+ s5 M! [+ L5 q% D
591825 Quickplace for RF Elements
! b8 t; ]4 m2 m591865 Request for more information on 'Other' Netlist formats" d$ n) y, r/ k! m$ r. ]& \
596392 Publish PDF needs improved error messages for missing installation.
3 ^ h! s0 D& [+ E: z& G* v, J. q+ g596555 Request alias symbols documentation to include and clarify when necessary to rotate 180 degrees
3 d8 V& A& U. k7 b. G. R596843 Cannot do global search after importing read-only schematic block/ x6 b% t3 E; s. @
597808 Option to increase the default thickness of all traces in Probe. p2 r/ c( _$ g$ N* P5 S
599499 Plotting from within Allegro does not find path to stipple file
7 W2 c" Y. _; C- Y: T$ _) M604125 Manufacture>Create Bond finger Soldermask.
) b7 {# B m5 P+ O$ _605023 Need rats by layer function for Free Viewer
$ @2 i1 D+ J( R) K' N$ S, T, U605112 Dies should not be counted as conductor layers in Design Summary Report of SiP
8 k& a( _, }" S; q/ ^* A605373 importing and Exporting BondWires
9 v" g# k! X; ^2 b' P609035 Voltage_bus part - Make pin number invisible
7 Q8 @* j3 T6 `2 |. ~2 `609561 Enhance Circuit Replicate to support coppers shapes connect lines and vias+ \# f8 T# j" U/ l. M
610934 Retain user input values in RF PCB forms
2 Y1 q- ?! x6 T1 ~) @612008 Mirror Rules need to be documented for axlTransformObject.6 S+ L+ V1 G7 G% S
613639 Update Documentation for "split_inst_name" property.) P7 K- x* m) U7 U2 e3 C* X
614345 Email facility for Design partition on Solaris does not work1 v$ Q: K; \% y# j/ ?% H
615139 option DMFACTOR documentation missing in pspcref.pdf
- S# E, N- [% C615374 Retain Soldermask Thickness value in 3D Viewer Options
9 a0 l2 T' F4 {615850 Auto Setup should honor device setup parameters if component value is null" W$ Z- D l2 o& y
615988 PDV WHen importing from Mentor does the browser not remember the last location of import! q1 N* O7 y0 f o
616529 15.7 Design Entry HDL fails with Out of Memory message3 h, X& f: r( U
616873 Uppercase characters in design name error should be improved' P" E) H7 @: z1 w
617976 Enhancement for a way to sort user subclass in define subclass form9 l J9 E, O; g; A4 P @+ b
620289 Server 2003 support information in pcbsystemreqs.pdf
7 Z# e6 x# y; Y% y620303 Enhancement: Shortcut key for "Select Entire Net"
( C) x7 ~% M5 K+ w- q. c3 F621054 Renamed net in netlist isolates components from the rest of the net.
" X; ~' Z0 T9 w1 e1 ?+ B621955 Offset Via Generator utility should show a warning message if vias are already present.
: F# u/ Y0 Y# M8 P622203 Requesting that "DFA Constraint Spreadsheet" icon be added in Customization >Toolbar commands: _7 |5 [% }* y0 {+ X) C
623218 display pin names associated with a net in net Properties
+ \7 x+ M: n# o1 ]; k623908 Mirror Symbols while dynamically moving enhancement% q7 \4 ]4 Z |. ]6 t) Y
624817 Display padstack name in data tips when hovering over Pad-stack
* y1 C7 v' w' I) g+ Q625733 In Netlist Report they are requesting square bracket vs angle bracket; M& j9 Z* L. I2 Z! S& Z6 p% |- ]
626605 Extract topology with routed interconnect to include via's in Allegro DesignPlanner, PCB XL and PCB GXL0 N4 a" } Q( f9 H8 G
626673 16.2 Die Stack Editor - Add option for DIE x y cords within DIE STACK form - shows rotation and allows move but1 s* h- W N$ \, W/ ]: t
629008 enhancements for find command
: l( h2 b; |5 O. \8 u5 z8 G8 g, w5 \629548 Request an Option in Create Plating Bar where it may be directed to a different Subclass
. d2 w5 Q! I E, W. W$ L' x630949 DRC for bond wire to bond wire requires additional parameter "wire profile" to "wire profile"
0 p/ y; F: L' S O630955 SCM does not see design difference after update of fixed die/BGA in cdnsip
4 w# H8 J, x- `3 Q( P630973 SCM should see the net assignment made in CDNSIP for Power and Ground pins. m6 ]& a$ E8 n }0 ?7 Q' x
631609 Clarify how to generate a cref.dat file in Cadence Help% K" v3 k/ z* n& {9 O( q* I7 @
631697 Want to degass many shapes in succession with custom parameters
+ x0 ]) Q) c, g6 d( C632754 pspPN and lib_list should reflect location of new models in 16.2
6 n' s$ R6 |# e633440 Sensitivity not varying components correctly
7 s( \3 n2 o7 `& R2 {633842 Add note to docs regarding padstack quickview
' w r; @' i; V! N) \634350 Enhancement suggestions for pop up info boxes.2 {2 e" ]. t+ f
634877 Export netlist with properties changes scope from global to local
8 u: [; g3 @- X9 I1 I; _5 o635118 skill variable to obtain list of Classes and user defined subclasses in a database
# S7 b- k" {/ k6 ?2 G* x7 C635233 Place hierarchical pin tool tip5 k; Z/ P" |7 k& n
635543 Any command to get the current line/lock type information?! J: p6 G* S3 ^' V
635579 Enhancement for Structured format in parameter file
7 C( ~4 B1 Y3 p3 q% @. |' w' s636930 Die Export option to create symbol either from schematic or layout4 X4 @" I2 s7 x8 `4 U: ^
637195 Allow for SKill access to backdrill info on padstacks
6 q/ [- O- Z% i8 r637768 Enhancement to assign different colors to different net based on a unique property
( E' q( O/ N" B, U0 I+ A4 u! G638455 Enhancement: Add some details regarding nomd.lib
1 y$ q2 A, D, u* m" }638581 ENH - Press ESC button Spreadsheet window disappear
# L3 P5 x' }4 ]! N. H638622 Add note to CM Spacing Domain Region worksheets regarding shape2element clearance+ V# v% U# r& H b; @' ]
638910 Enhancement to sort the list of available vias alphabetically in the via list ?: ]# o) ~- | a. N7 H
639630 Does the Net_Short property work with Modules?: x( L8 M+ P& M0 T. l
640262 Request object membership count in the status line and forms of CM.8 b* s/ ]7 c' T! A
640280 Provide resizable windows in CM and other apps$ Q" ]* A* f9 ] R* p2 D$ y- V
640668 File>Change Editor needs ability to go from GXL to Performance L or Design L.) ~0 [! G+ C( @, Y8 g5 ?
642095 Ability to disable the Pop-Up description of elements# {! i: s6 t0 H& R/ j
642298 ENH: For license checkout detailed message8 n# m' V# U U
642422 After Copy parameters from one part to other in partmanager forgets previously highlighted line& d2 l" v5 j& f4 W$ h
642865 Allow format of hyperlinks in ptf files0 h |0 n8 ]4 _! w0 r9 y" [7 ^
642894 ERROR(SPCOCN-1993) is not documented anywhere in Cadence Help
2 X* v# _- k) G% ]643381 Add an option to ts2dml to allow user specified port ordering.$ r" v8 ^4 |7 \; ?* B
643390 Request for a switch or button that would allow Properties to be maintained during a shape merge
( I) M* P9 P6 q ~ e1 F% P! y643625 Bond Wire export to DXF does not support WYSWYG! Z) U, H3 a/ X! p- b) h3 G! ~
643790 Include Associated Components in the Verilog netlist; j0 A4 R" A4 a$ X- H# c, `# b" K
644216 Store Filter Row Data and Units Of Measurement in site-specific file.
) z1 i( v1 b! y; \9 g$ R! h644248 Need a better solution to identify and handle unstuffed components' X/ `" C% U/ j5 \3 E3 k
644350 Incorrect upper/lower case for axlPadstackToDisk in Allegro SKILL reference manual3 R7 g7 Y9 v9 A; |+ r" q; Z3 E" j
646662 Enhancement to add feature to toggle on/off inter communication tool from within PCB Editor when using DE CIS.
: X! Q+ e9 W2 w1 p, ?646981 about the treatment of NO_GLOSS property in Missing Fillets Report* o" u( |! a, C) G! s1 d
647480 global setting for adrc settings in sip via techfile. Q* ?4 A0 ~8 T3 Q) ]5 J H
647617 Degassing not suppressing shapes less than size specified6 L g+ U8 I! Y8 i6 o( k
648210 Request for Working Layer (WL) model in all tier Allegro tools..
* O0 t% Q0 j, v# }, B648218 must delete keyword "multiwire" from Doc( f$ [+ Z$ B# H) q, p
648533 The cross probe highlighting between DEHDL and Allegro PCB Editor is not documented9 U; F& c: I( u2 k+ y# q3 ?5 E
648801 Stream Out issue for SPACER: U# N( V* i( e
648930 If two PPT option set names match a given component which one will be used?- U) V. O5 d1 e/ o. `' n+ j
649603 about spara import
9 Q& {6 ~ x- Q1 k( k- q0 n$ H649607 Management of SiP Technology File and Project Information
1 e7 K& B$ p% u% m7 k6 j649610 Management of Part Table (PTF) Files! X1 v0 t m B' q
649613 Management of Library Lists
2 d9 q5 T W" Q652335 Tooltips clutter Place Part dialog.Option to switch it OF and ON
+ ]. v; p7 Q3 `; _9 {0 T J652511 Unplace Component command
$ f7 n2 t! h/ P& a; p652554 Enhancement request for Allegro to check the vias used to the allowable vias defined in constraint manager3 Y5 F+ @: ]& v1 t
652939 Is there a way to predefine the values for Sample Start Height and Sample Start Length in Wire Profile Editor?
1 N8 Q( y: A9 C3 }& C653027 Explicit RMB "Done" option is required in Part Developer symbol editor when editing text
) m: z9 O; D e& h653359 Setting the $PN to # does not set the pin numbers to invisible when part is sectioned using the section command
5 N$ u' b( N) G0 t+ N3 q/ I1 h% F653420 Enhance ADRC rule for Acute Angle Merged Metal Check to work on a user defined minimum constraint value
! H$ ?7 _9 g- m2 l" U653471 Request for Die Text In Wizard option to Flip the DIE coordinates
! t8 {9 {( H! k+ R- l' `! t+ D653825 sigxp_tier was not reset when installing a new product suite3 d. y/ \1 {: j; k8 K8 h
657180 Enhancement: Tooltip for DRC markers2 E% b" I1 R* m1 G! F# n
657187 SI model delete enhancement
! \/ f$ x9 ^4 z: N/ k% u657189 SI Model assign enhancement #2
: I, ^+ d1 A* R/ }657501 Negative planes doesn't match with Film View
0 P% K+ H, m0 K$ O659543 Need a Report to show which Die Pins have no bond wire attached4 h6 e; Y, t! I8 _3 g# {% c5 L
659661 Function needs for setting the rotation angle in finger by group.
( X: w8 f! L: J* b661477 Color192 window sections to be resizable
1 I8 Y* P5 Z6 Z+ d) b) r662215 Please add the function of renaming net by batch command.
% d" u! h# t; c2 ~/ e% v662325 Skill code example axlDBGetProperties.txt not correct- _& y& z. |( Z7 }- _+ G; O& P+ N
662982 When you edit shape, ministat should always enable shape
. E' A& {2 l0 A7 L. y663260 Enhancement: ALG0051 message should be more specific
' H! j* w6 ?6 C$ g# v" z9 I. ]# I663754 Enhancement to create Device file when saving dra file on opening another design
! s6 R: p! U/ F6 u C! |664240 Add CNVPATH in User Preferences to place default CNV files
_: Y2 {/ ?) E. F2 e5 Y665798 163BETA - provide graphical examples to show result of Flexible Shape Editor actions
" o( o% W& L- d9 ?& ?/ i7 G666186 Enhancement FishEye functionality in Variant View Mode5 R5 r/ \5 p6 r' T& x7 l6 p" _
666768 Temporary graphics for modules / groups do not reflect true size
, I# b) F' F2 a: _" @& \3 F4 a666775 Update microvia to microvia DRC markings to avoid upper and lower case confusion
# ]' a6 m: d( h1 L$ X" X& c667773 Request for ability to set grid definition by entering simple formula- F3 G) k5 {, P1 d$ a/ X
668110 Customer wants to enter the value of radius when editing routes.+ h, t) _+ a E
669373 Xnets are not formed correctly in CM. Up to 14 'extra' in a copy of the same design.& ~/ P- E- T1 L
669380 Add options for ts2dml in MI' A) I: a( M/ k+ \5 R- D
669798 Add all 5 Dyn_Thermal_Con_Type property options to Via_Array.
/ P- A; ]% W s c) e. R/ \+ B( z670775 Request to make the SKILL _axlSetDynamicsRotation and Mirror functions public3 f3 q4 A. P) M. X0 {4 S2 d
671194 Allegro not to crash when opening unsupported files( a3 L% x$ {* b: t* i& P5 H" T
671337 Request performance improvement to access DML libraries from SigXplorer or PCB SI.
7 [# I7 _! a* x$ L9 |671757 Handling of double quotes in HSPICE subckt.
: M, P) I+ C/ s' W p- B u672930 ERROR [DRC0039] Tap may not be connected with the bus Check Entire net
7 @* ]& ]3 `: b674666 Report the wirebonds XY coordinates3 q9 V( \& T7 \# ^& A& f
675118 Cline change width command enhancement) M/ t- z% k2 p# n& |; i" O
675151 Insert comment option for database elements
; k0 z8 u1 \5 X/ Q/ b: B+ m675398 RF PCB setup should automatically point at the project file if Allegro is launched form a project manager# P: m( o4 Q% X$ f3 h+ L# H
675551 schematic to sip layout fail7 W- j. \/ G, C z
676814 Signal Library command with Allegro performance license.
$ a# @4 e7 m$ p# V( c* A676906 Add switch -regenerate_xnets to the dbdoctor dUI
W- ]/ N6 y% d& j1 a2 g9 ^677983 about setting of ibis2signoise option "-d" as default
9 e; W2 N& N3 W* O3 B678036 Request for a Physical design compare.) |& M1 I/ i8 V2 W1 {2 ]9 B
678798 Identify DC nets command doesn't remove the RATSNEST_SCHEDULE: a$ j1 p" `. K* |- z: F2 m! s" ~
679926 Testprep fails with no route keepin. Message in testprep.log ambigious at best' _% D! O- v: a
680586 Explanation of functions and macros in online help
; R) n q) B. h1 S$ Q682695 Offset is outside or on pad edge. DEFAULT INTERNAL: REGULAR-PAD message needs rephrased) b; ?2 t& D0 z; C0 Q% |
682865 When using PTC format IDF files don't use forward slashes.
9 Q" y0 F+ Q8 Y2 V$ x3 z684713 pin_count view needed for packages
$ L! B# D% ]$ P7 W( d8 j684796 do not delete all vias with DRC for via array
5 k& `% S6 z$ Q. j) J5 L686103 Replace vias evenly spaced apart
3 X8 C& u+ V# A9 |686112 Add Connect and Slide keeps cline length
: t4 T) H3 u# P5 T) f7 B686122 Select objects by polygon
$ E0 g. q% y5 R# }% n4 p, `687155 License for batch signoise command
0 a, h, I0 [& D C687187 BGA Full stagger matrix wizard generation: | k' k; f" R% b b9 f0 b2 V4 P
687201 Improvement in Find feature
& w4 R' Q/ z9 k687685 Documentation of new properties in Variables block1 h/ C0 O7 ~, G9 o; j7 v" r+ {- w# X
688047 Include blank space in pin name as the illegal character in PDV user guide
" D/ V5 ]: X$ V688830 renaming feature discrete library translator
& ?) o2 K4 V# P: I; m# G/ h; }3 r689720 Need the ability to re-center Vis's in center of Pins when a Die is changed.0 K2 V. I6 t9 b8 n- J m; B
695957 master.tag generated from the table design needs to contain the verilog representation of the sch./ Y1 c/ ^* g+ y
696661 Add ability in Offset Via Generator to add vias per a given Net
" L; `& a) e* `6 y7 y, ?696812 provide description for axlCnsPurgeAll() skill function in doc2 Y$ H r" C8 f! t+ T2 m- \ B
697824 Components not installed of variant design should not be extracted into SigXplorer.
4 U* e; s# t% J, u698097 Color Dialog form (color192) does not resize correctly+ q2 k, K: Y4 J: @+ q
700262 Unable to add Signal Library Model paths in the Allegro Physical Viewer (part of the Allegro PCB SI -L tool): i/ y2 F# R+ t7 a4 g
700712 Defined pin locations are not used when using Die Text-in Wizard with default option Center pins on symbol origin9 q6 j: `& l# q4 |
701514 axlCNSGetSpacing online documentation enhancement request regarding "bbvia_gap"' R& R$ O9 R1 f; r
702190 Request support of Windows 2008 Server Editions.8 P* g; l2 K9 z# U- [' q1 r% M* d
702613 Request SaveRefdesModelAssignments support the include original model path option.
! [/ j) e: G* q+ r, D, L% \+ j6 D$ N703905 Need Hot Fix number Info on Help >> About! J8 J1 {6 H3 {: R o8 E8 X
704594 Update symbol removes the text present on Package_Geometry/Silkscreen" E& W- v0 a( y$ A; h" O
704899 Split Bundle Methodology Should Include a Next Function
, n7 Y' f. I0 Y% Q3 j: c* U T& Y0 U705601 Please make listnindex a public Skill command6 `' V- z7 p2 L z& b( j8 h
705615 During Updating Symbol the text location and size are changed so Reset Text location is confusing) l( I! q6 M5 @/ | C% f
706165 idf import fails to expand drawing enough to accept text.+ g( }( w* K7 l; x# b, E
706457 Change type of the fourth optional argument for Mirror in axlGeoRotatePt to boolean( `2 I! C P4 M- o' D) \* T8 V
706463 Add optional Character in the starting of each line of the file created by axlLogHeader! W, X7 o# @2 c( L3 P
706787 Fillet should remain when user slide the segment far from pin/via.
1 g: x6 Q& {4 t {. C p) G709119 Requesting a pull down menu with "Comp" and "Net" to be added in the Offset Via Generator
3 _- L" T( g o! N/ G/ E: A# `; _711837 remove the comma from the image of grid value separator5 [& ~! s g0 H1 X6 {3 g. B
714840 Enhancement: Anti-etch can be recognized as Void element.
! K2 n: E, y" G1 Z' k& b6 v8 N/ v: B715454 Option to configure Design Entry HDL for Cadence Help- V* i; @ ~- P, y
715713 Enhancement for Wire Short Check during move feature- v# M( x( c" X* j: s% o) J
716671 About the log file of the na2 interface.
) y# _( V1 t+ u717722 Pad designer File > save as should have recent file name in file field7 G4 `' ^9 K- r* ]
718431 Enhancement request to have DRC checks on negative layers.
- g. i+ E* f6 a H; f' z7 p3 g719050 Log file should contain username date and time while creating or saving .DRA file7 j3 V R% d8 V# |" P. u
719514 Request length column be added to the Dangling Line Report. l) X% A4 [+ R5 i4 o7 A
720297 about "rip up thermal-relief clines"
+ d% \5 Y& L+ \722346 DRC checks for mismatches in labeling Net
9 e u+ g6 ~8 s1 K7 O% y) V723661 Add *.pad in the File of type drop down menu when executing QVUpdate- U. K; M) c" I+ O
724832 Tackpoint move on a non standard wire bond -> *Error* difference: can't handle (2043.0 - nil); p y9 l* Z. |; l
726057 Request incremental DRC update when enabling DFA constraints.) G% E4 M7 J6 O' V) e% d
728908 Add Color View Save and Load in Symbol Editor5 I* ^4 v: O7 l p& ~- ^& P$ Y
729947 User would like a metal usage report1 J4 ~& [" Y! Y; b
9 K6 w- T" {+ l y# f+ Y
! h; E9 n; j" u% J* x) `, NBUG CCRs
' }0 U# ?- n0 A& C- h: T--------) R% l! U; B7 c1 ` S1 | ]% S
T# B0 m* y& M( Z
. _# J2 D+ m4 d3 K- V: ?CCR Description; @# D6 P& Y1 p& U) A
----- ----------- 7 X# P6 {1 n5 Y% s$ I, ]! F! K
----- -----------' @2 T- q* k8 j$ K$ z1 ^$ X9 V2 e2 J
3 t3 N! a3 W' o/ @- e2 G" f6 @3 H
10116 Add Intersheet references does not work in Complex Hierarchy, F2 }9 `5 _# I5 ?5 v; Z% k5 j
11833 Junction not automatically placed when it should be.
6 A8 n9 J! Y; m" S, S; |3 U* _: C8 |1 q16310 Simple hierarchy, intersheet refs not refering to H-block
9 U5 p% ~- a3 d1 H/ o$ P: F2 @19343 Request for intersheet reference to show grid reference zone2 u" m7 ~5 K: N) |
22424 Intersheet refs wont work on imported off-page connectors# L3 Q7 {$ l) \, k, z5 l
34275 Ibis2signoise fails with legal characters in file6 d. j/ ?+ Z$ @
85735 Cref annotations of the P_ID+00 Bus were missing
/ f3 X. b: e4 b. U0 g! n134692 DDB_WARN: POWER_GROUP prop. not allowed wrongly coming/ k3 C" R6 v# _8 x# o- [
199343 Stackup-Aware SigXplorer
: {1 b" z- S( s' r' s207620 Part in MISC2.OLB has incorrect pin out
2 N7 |# D! h; d- s7 V' Y* c/ x2 B% _270347 Changes to AXL SKILL must be Documented.& X, O; F' ^ p0 ^7 p
283839 lm117 dropout voltage is too large
2 T7 `9 ~1 i% ~, \! k5 r8 r296826 Variant view displays library property7 a9 H& s5 Y5 M4 _! r: X
299384 Part rotation resets the text to default position3 {/ M( z4 c3 p
328647 Replace Cache takes time for network libraries; v# W/ \0 D1 N+ R, U& a
340323 Dynamic shapes need same tweaks in 15.7 as in 15.5.1 to fill
: @6 C$ Z" b7 k* |6 p8 ?1 ^* q341035 Dynamic shape fails to fill in design that has cline arcs
: A; ^! {. B1 q" S. D" `390692 Via not getting transferred through the Area Constraint from Allegro to Specctra
; Z9 }, L6 p* v. t405611 Environment variable for SIGNAL_INSTALL_DIR is resolved.. s7 {8 i" J- _- i; Q. V4 x5 o
428261 spaces at end of pin name Could not create new pin inst library correction utility: g" Z9 }, x: ]. r) y' c5 B
436908 The color dialog window will loose the vertical scroll bar after being minimized.
, u {; |. a; s( T0 Q437369 Menu selection of Export > Libraries fails to issue the dlib command.
& P0 I& s0 {1 [( Q462783 Busname is too long1 c, H0 Z: d& ]1 `. ~
495671 Unable to add the signal stubs due to the overlap between SIG_NAME & VALUE Props.) ~' e/ K5 [1 \7 V
509393 NC drill legend copies null nc_param.txt to current dir.
. w' h$ ^. `; J$ s6 p+ R: \: J: u512809 Window Prt.part.ptf shrinks by 30% and I have to maximize it.
7 a8 g `5 C5 T9 f- E5 Y" ]- b520802 Global Navigate Zoom to Object needs to remember last setting
' k1 [- U, R' C& h; k6 ? V! |528686 During text edit the cursor overlaps a letter rather than in between0 b6 v8 I: d/ [" F. X
531555 The diode BAV99 from library works inverted in compare with the graphical representation.' c. r3 N( e+ w: o
532603 Specifying TC1 and TC2 properties does not seem to have effect! F# h. N% M7 h: Y) `5 }
547339 CM-SigXplorer extraction shows different topology in DE HDL vs PCB Editor& ~+ r5 ^& {+ m5 g
548143 Dynamic shape on Etch TOP will not void properly.9 |, j' F: k& m& i6 s
550657 Importing registries do not setup printers from MWcontrol
, V1 Z L" C0 E) L h9 K552227 about die export padstack layer mapping
1 B s& Y% p1 h, c; Y: Q W6 ]553035 Cref Synonym and Netsbypage reports do not match netlist' A$ J6 r# i, d7 b
558164 All variants are affected by function regardless of being called for
4 Z7 `7 M! U, |& ?! n. @0 H" o. H558692 Memory leak problem in loading marker files% r; M* A# G- c7 Q. |& A* h
565681 Filling in values in CM by using ctrl+c,ctrl+v and arrow keys is not working as it should.
* j+ Z5 G3 {( G2 b3 K& E" z567606 PDV selecting pins in symbol editor shows pins off grid during move" b8 h0 W3 `' ]7 W& G7 b8 q
568049 Genview crashes
$ ?7 I$ p C0 I' Y8 T: Y5 o. d1 I" x575353 Large box displayed with place manual-h and no RefDes variable set2 O8 q' F8 [/ s0 L: [* m7 n8 g/ y8 G0 S" O
581848 not able to edit Padstack Boundary+ D) x( B5 a5 |2 L+ S
591847 Add Intersheet References does not work on simple H design.# ?9 V3 ?3 U# p; F8 Y) b7 S$ Q
592381 Physical Min/Max line width values not check on internal rows or forms.
" v, c) b# _4 Y" k7 l: g8 C, y593076 Cannot redisplay an invisible OFFPAGE connector's name. w) h( d9 _3 _8 P, i( l* D
598038 Detail button of Markers window with 16.01: q. \! M; B6 S+ _. R$ s
601415 Allegro Design Entry Tutorial corrections.
4 ^8 ~# D% g* D4 a0 p( d601531 When using the place manual command and rotating part a ghost image is left behind8 r3 c5 {; |$ s$ j
603181 Formula to calculate the Actual Temperature for Smoke is incorrect.
6 Q: K+ d, |9 y/ H- ]604965 need to document how tcl cmd addComponent handles property values with spaces
1 E9 l+ S1 r- B7 `8 T1 r9 Q9 `605843 Aliased nets do not fully dehighlight when next net is highlighted
4 B3 ~2 `5 K8 O& t5 D+ Y( Y: T606493 Targeted nets are not remaining targets1 W1 u7 y7 ~' Y9 x! b2 x% b' Z
608150 TestPrep generation is creating DRC errors6 V! y1 D( V6 [3 R1 A
608787 Missing Constraints Report
9 h# P" ~0 W/ a6 c, d. \608942 PDF Publisher output misaligns text in tables. o9 l G. O4 {$ S0 g- ?+ E7 l# ^
612511 Error in Flow Tutorial regarding checking default user units
`) N$ V/ N7 h- p612982 VLIM model giving error that line is too long' X# K% Z- N0 d
613194 Adding wire bonds with current selection does not yield DRC's, mismatching Allow DRC violations option.
3 H7 L8 `/ ?+ N; _613738 Variant BOM report lists identical parts in separate lines due to POWER_GROUP
$ K; w" ?# w: ]- r617146 Symbol fails to place through Component Browser3 s7 d2 T: j( C$ d6 @
617327 Change root operation results in SCM crash
1 B# x! `' b" T y ^: E. A+ ~+ y618150 Property Editor Functionality5 C( p. J" _9 A) d/ U7 U
618617 Enabling strokes requires checking/unchecking options boxes
9 F' k& N4 Q4 `( [$ _618771 PDV error SPLBPD-382 when importing from APD.' T' w8 _' N: ~8 \
619053 Diff Pair problem with creating them in DEHDL.
$ ~- v/ @# k: Y4 m( g. \619849 Hierarchical Blocks Loosing reference
1 w8 N+ o; _7 P9 r620001 Measurement's Maximum range calculation is not correct
% A; a0 i8 x' H' p3 u* H# H620343 Bogus error during schematic write( _7 r& i9 c8 j* O; I7 V' v+ R: K
620826 Changing the units of dimensions does not work+ e& A& T! ?- I8 u3 g+ A
621163 Ambiguity about the how is the ?start of the wire" defined in CDNSIP for ADRC Wire to bondfinger optical short
3 k+ h7 X. @! K# J" k7 G/ B622263 Drill Customization sort order for oval oblong slots should account for Size Y
0 m: I+ x, i* |* x' T/ E8 n622583 Allegro produces erroneous error msg - symbol not found when the placebound is too large for the board.
' C( b& z/ O: ~* p. F1 w; @ l622692 Why is VGSR negative for N-channel MOSFETs( |! D: N" n& y8 P/ c4 h) c
624378 Device file content conflict
& D3 Q7 g2 c+ h) y [+ Z% W% R624492 Model Editor finds the wrong model definition for BAV99
6 N: e* g' n0 U4 n* g625462 Symbol pins Property are lost when once stretched0 L# ]$ P0 [+ v$ a% T r+ L; c
625519 hspice_mt is not used in Channel Analysis simulation5 M. c4 a9 Q% P
626674 Allegro CDS_SITE setting don't appear to match documentation
) S: r) J4 q" `& A9 Q4 j627018 Find Net in instance mode displays twice
: @! K3 U# u ^# F) U: F' C% O" q627864 EDIF c2esch crashes7 e+ {& v; Y8 E! a5 |9 i& K
628077 Degas not voiding correctly; M+ A* Z9 s8 v" T& B
628265 no "Unused Blind/Buried Via"Report in APD products
% I* P `% P$ z5 {) E) n+ Z628845 Markers> Packager menu is unselectable even after pxl.mkr is created.
( `! ]6 G8 p# P2 x3 {+ {- C631344 Mouse Wheel Scroll misses the "along with the Control Button"1 a6 A- R3 I4 u; |
633130 The Verilog netlis is wrong0 ^, i( f; }/ @% G: ^6 ?
633223 Running skill from a HDL script causes segmentation fault.4 P) [7 B* i5 F2 \8 V
633473 INPUT_SCRIPT inconsistency when removed from .cpm file
/ j; D% Z7 H: N d' p/ A634075 draw_etch_outline doesn't work for circular shape/arcs& ~7 z9 g' C2 E$ [7 E
635779 Allegro OpenGL distorting text at certain zoom levels
% Y7 P; a4 T" x$ a% ^* Q' c% f; X6 Q636215 Allegro documentation for Export Parameters is incorrect T3 r6 Q( p3 J8 A) V# U
636688 Signal Model Assignment UI and Find filter association is broken; i, i _, q( T/ s! f
636819 Documentation wrongly indicates that DFA Analysis in unavailable in XL
; |0 l$ K* ~. R" Y637379 No column for ROOM shown in Constraint Manager
& R1 j- M+ [7 i# ~2 W( F$ Y638140 Intersheet References not offsetting relative to Port- \/ v+ }" }9 j9 V; |. F% y n
638670 Testprep parameters - padstack selections - Bottom Side replacement text not entirely visible.% a$ ^/ P5 V; _+ {8 v
638987 Change command hangs on customer?s database1 ~# ~/ \! m" L0 W
639052 Database Objects Preventing Layer From Being Deleted report fails to run
, `2 j, A( h* `639698 HOME variable defined with %USERNAME% doesn't use value of variable.
3 Q) V2 h# Z: {639829 After setting Zoom key(F10) to a new alias Tool Tip is missing the key number% L+ x, O. E* \, e3 F' s
640127 Correct IDF documentation regarding UNOWNED objects
' I: U. h9 j0 y: M* }4 [# J5 ?# ]640293 performance issues with scm and large pin count devices
0 n3 p0 ^" d5 k640314 The number of menus written in DE-HDL UserGuide is untrue for Unix/Linux users.
5 W+ C P/ I/ {641503 Stop running the VAN check on a PLUMBING body symbol in PDV
# g9 D( z( r- u! z641676 Incorrect link to assign refdes help
1 G7 Q& Y+ I. e: i5 L* f642053 Drag Connected Objects icon is always display as on
- r& w. ]6 x2 E7 X642299 Switch the windows mode by set command
) D/ Q! o$ f, M8 B' o6 g642436 Save As symbol in part editor is not working fine6 x) R9 { t# w2 v8 R6 F
642713 Materials are not refreshed when material name have only numbers.
. q4 J& ~/ g9 o: g2 `8 L2 K' U642873 Dynamic shapes out of date message refers to Setup Drawing Options( X' u! k$ O; [$ y
643721 Attributes with Null values in symbol.css files are removed when saved in PDV
; Q) ^8 x: j: J; J; a4 e+ a2 @643949 Can not create Region-Class-Class for same net class.- S& q! V; [1 v5 K% Z7 i
644016 APD crashes when creating a tile from LEF file3 r0 B8 ?+ W5 g) V1 ]
644733 Import reference text file gives incorrect results- _* Y+ Q3 {" y4 q! k/ g
644879 Change forms to enforce naming of lib.defs file
* K* \8 x; z2 q4 I( r& j4 G4 }645046 SG1525A PWM model is reporting unmodel pins and producing incorrect results
. s% `" Q: J: P {0 j645427 The save button is not enabled on changing the line width; o$ j4 ?5 q2 K1 K8 }
645996 con2con fails to parse ppt file correctly& Z, o! k. e8 }8 V# l
646175 Please modify the limit length of "Allegro PCB Editor Limits" correctly.7 r0 l4 D( r7 L
647555 Drill Customization text Non-standard Drill is not readable.1 ~" T- B2 t2 V6 b- V. Z8 _
647628 Annotate Type should be removed from PPT Option set files and documentation
# Y7 j+ q( N5 \: \, _648443 Launching SCM without a license is not reported in debug.log
5 K: ~5 C- ~ f+ x649222 Silent install adds extra License Server to CDS_LIC_FILE on the client
/ D# l: }3 ?/ l& U @$ s" ^' ?% f650558 Die Pad layer changed after refresh padstack
0 W9 Z% j7 |: K650997 Incorrect Pin Shape in CIS Explorer Footprint window5 D7 L& `9 {, a
651000 "Wire length over parent die" violation is incorrect.
* {* G. Q2 r* Q C6 ]5 ?651153 Results for imported CSV inconsistent in PDV* V( S/ }/ b4 o9 S7 F8 ]1 U
651521 Resizing the display color visibility dialog box corrupts the display0 f+ r' c7 p1 C. N! U& V
651526 Parts are missing in a advance analysis library list document and font size issue
& `+ z4 A+ x( s1 C i& X; u! r1 u651532 Scroll bars disappear after minimizing the color visibility form
! u) T; f$ y$ M, }( h: Z, k652050 Append waveform does not work in 16.2 for .dat files created in previous release with import text format
% _& [5 o, @) m2 W652904 significantly low performance issues when using edit interface to delete ports of block
9 I* ~" Q9 z, O! f( \8 {653067 Incorrect warning SPMHNI-198 - Pin name is not legal and will be replaced by `$#?/ n( M" [0 U. H5 ?4 M
653784 Off-page connector name change to internal starting like "I12345555"! P6 G" T" i7 K; W
654580 Save As should update lib.defs without executing the edit die operation; j5 [- w# Y5 U( ]/ f; k
656282 BGA Generator adds outline and RefDes to wrong subclass7 N, [4 M/ Y4 ?7 F
656723 visibility of clines in 3d viewer needs ALL instead of just CON field in layers
! Q8 j2 d2 a! i- |) L, ?: T657836 Text crop on User Preferences Editor form* j) y% m0 }4 a# M: z2 g
658347 Rule Continuous Soldermask Coverage Check should not work on Cline Segments5 O3 e9 _0 a* D3 }9 ~
659437 Move group fails to display anything with Open GL enabled.& w# c1 o& B0 t( C
660937 Import techfile fails with etch on layer yet layer has no etch1 p+ \8 W5 V! ^. b
661369 Importing design fails with the SPCOCN-1158 error when DBL_STR_LEN 'ON'
& y2 h; [2 t* ~: ]# T/ l9 `$ w661754 Hyperlink publish pdf to correct page but wrong grid location7 @' e, H. ~) ~, B$ O
662622 Export Physical reports error Output Layout Filename contains space
+ T+ b6 [' H2 N662918 Skill code example for axlReportRegister does not work+ _$ _6 Z" D+ w4 w! P. _
662971 Moving Bondwires disconnect bondfingers./ F4 r* W. l/ X% B7 R# R
663088 Cannot add connect to a C-line in Etch Edit Mode1 u3 I {" a- Y; D0 C% w! Y
663220 IMPORT_HFS_HARDSEC_ON_SWAP_PINS directive causes error on save in DEHDL: C% ~! _! W" o- v, x
663726 ?Each? menu under RefDes is missing in BOM HDL user guide
2 \6 X* G4 N% U3 c" k" o664764 Material changes when layer type is changed/ e4 v# B* J; y. g
664900 Project manager User Preferences Editor form has text crop.1 H& w- c, p& x9 ~6 G
665236 Unable to import a Quartus-II version 9.0 pin file.
; C# n: ~- I8 M# @# N) U+ |665389 Spread between voids not working for customer design; m0 ~: r" I# E3 s6 k) X
665413 In File> "Import and Export"> "Import-ECO pin table" the NEXT button does nothing.
; e3 r+ p, u# N7 d8 K% @665451 Import - Part logic - information popup window has incorrect user preferences Editor Category7 L2 [4 N% e8 }/ ?7 Z! s% F8 P1 x" Z
665661 Wirebond Die Escape Generator failed to generate Clines& J7 J3 m$ o' w1 a
666099 Mandating at least one symbol with sizable pins for using size..1(not for size-1..0) SPLBPD-310/SPLBPD-309 on reload
3 t7 v& V1 l8 g- e666667 Relational Table View Browsing Issue! ~( A" M: }3 X R6 ]$ c3 S) t* q+ m
667286 import IFF No Component Shape Line Via found in IFF file.
7 b, _2 U& h; s1 `( U, f667751 db(v(out)) and vdb(out) gives different results for FFT
4 Z( b9 z0 _/ v: a9 A7 K F668080 Improve handling of curved routes, E$ v+ q% N6 l
668393 Dielectric constant or loss tangent values do not update when changing conductor3 @, ]" h6 @8 E: z* f6 r& j
668876 Text on the Add button is crop on the Edit via list form.
5 \& t1 B& s/ N8 j8 z2 J) s; `668892 Incorrect Parallel Length data in parallelism report$ j2 H/ m! u/ T, I) C- l8 z. W
669206 Parallelism rule causing significant performance issues during DRC update; \' j' y q% `, ~
669238 Unable to use permanent highlighting for groups in version 16.x6 s% Q) n+ A/ j
669323 Allegro PCB SI User Guide Doc page 229 ignoring vias needs to be updated* H7 H, e6 b/ F9 F
669336 Error in documentation of DE HDL Reference Guide* w. w4 H' v- A; a) R
670874 getVersion() function not reporting tool version- R) R1 e7 L& G, b1 C; P c2 s+ _
671811 Allegro extracta fails with more than 10 output files# s3 z7 @$ _; W& j1 D
672420 User defined property added to component instance is a function property in Allegro- Y& F, S9 l# Z z+ L
672614 translator converts the symbol "\" in the original Spice model to "[url=]\\\\[/url]"
% B+ J2 G. h7 X* U1 |( O672615 Translator generates 6 external nodes should only have up to 5 nodes. n6 {, n! A& v t3 c
672618 Translator generates statement in the dml file: Language=hspice causing Spectre run errors
: I$ c* f1 ]3 e+ C672715 Steam_out takes a long time and then fails but the .log file reports a successful export
3 m8 A4 f1 U; H0 h- d. a v673279 Same characters are listed as both valid and invalid in naming rules., n$ B' d3 [( k, d! f
673410 search by net name is finding electrical
6 o8 n3 ~' Z/ |5 K( D674058 Incorrect Variant Report, ^. d/ \% u! J) U# |3 d6 I e
674291 Library Explorer fails to start and I receive a 'Runtime Error!' pop-up7 Z, M- T+ ?6 Q- ~0 i, E8 e
674555 If the DSN filename contains spaces, autobackup will not write any DBK files to
4 O M) a0 m1 x3 s5 Y- D675192 Adding a second BGA caused dsa_api.c to crash
- s1 w$ x3 x) [4 }: y675231 SiP Layout doesn't handle ! characters in port names from Verilog and OpenAccess.' H' j; B2 T y" B0 w
675562 axlWindowFit() documentation needs to be changed.
- n) u0 U! ?( Q675783 SiP Wirebond moving a BF sometimes results in the BF placement on the guideline to become unplaced from alignment option2 U8 J. @- j" s$ V6 [- i; u6 _
676201 Cross section impedance not calculating with single license
; O8 D/ f/ Y8 ~/ p9 D/ i X# c676601 behavior of launch product from library manager: b2 q( {1 g4 C5 V2 h4 A
677582 mirror of die component on sip designs
: U, H$ g9 _9 R. t& v678013 Error: Symbol not found, though symbol is mapped in psmpath& O+ |$ h$ p! q- X+ [2 O+ Z
678427 repeatedly placed symbols has strange instance name4 T/ e- ]2 w/ Z1 E2 B( H) f4 p
678538 Why derive database does not transfer the Schematic Part property to CIS
/ ^" P9 b; ^: J6 G' y678814 Spin a temp group will not rotate the symbol) r7 R9 n6 J# |5 Q& n; X" I
678851 Difference in lengths in 16.01 and 16.2
7 Y1 E' y+ i- z, c678884 dbdoctor fixes corruption and then it's reintroduced: ~8 f' g8 k3 {
679224 dbdoctor states it fixes an error but the error returns$ M7 T: \: G- Z" a
681197 Report generator Hangs Up Allegro PCB Editor# W3 O2 j( l# _* O ]/ r; d
682135 Justification of $PN placeholders not working in 16.2 release7 P6 P T; L. g# M% k& B" O+ O' B
682204 Cdsserv.exe and cdsqmgr.exe crashes using 16.2 release on Windows7 Y$ R0 \) g* z, G: j& D
682331 Incorrect reference to the middle mouse button.
. S# L4 h: v/ @/ @- t8 h& o8 k! Q3 n683146 export variant path appears wrong in output folder while two DSN are open simultaneously2 m7 }% j, @% v/ I
683182 DRC0037 shows incorrect Alternate Net Alias.) S7 U! o( v' i2 B5 b( a
683379 ERROR in Measurement ConversionGain_XRange+ p& k$ }# e# j" w# y
684180 Sizable pins and vector pins cannot reside together in a component.
7 M: i, ?) f4 G) s' e$ i' c684661 via array created wrong results' |0 q! m8 I: b
684700 via array can not be placed on both sides of the cline8 m3 z- g- X) O J
684912 16.2 documentation is incorrect for axlDeleteFillet3 W$ K7 t& l3 K# d5 P
684915 Incorrect mention of creating graphics template in the PDV user guide
* K$ X* h/ o/ ~- ^685685 When the customer tried to merge shapes, they disappeared and do not merge.
1 }) e) t; u% b, S2 E( c686338 ERROR #8012 Database Operation Failed with MS SQL database+ E2 G; ^# t' O, g) M
686560 Changing pin group property after pin swap resets pin numbers2 Z- o( N2 U. @% M# n/ h% ~5 X
686736 Load property does not propagate to the associated MECH part
\* H0 Q; }5 {2 Q687008 ERROR 8020 after removing Place Icon
* z0 l6 y; c2 O9 M, D) P687074 Part disappears when you open it
& l; \. P2 n- |6 S- h1 o5 ]* v687354 Not able to create allegro netlist 228 ERROR(SPCODD-228): Cannot package
. r t8 P+ @$ o- Z+ G687385 Publish PDF outputs the net name (with underscore) overlaps with wire.9 F! u, Y* n! \. ]$ D
687708 Smoke deration calculations for Capacitor: S; q2 L) @; y* n* q
687715 Getting Warning TJL will not be smoke checked
8 T) V6 `& \# {# k! Q/ b* Q688606 Inconsistency in synchronization between bias display and icon! d3 {: N6 ]" z! |( N
689542 Comma in ESpice model name causes simulation failure3 L7 c* _, B! |
690112 Ignored nets are displayed in simulated crosstalk worksheet in CM
$ M: P: U5 T; E1 R) l( W- H691668 Stimulus editor hangs on doing change type! I% ~* s$ t( ~
691740 crash when setting coincident uvias in CM beta testing 16.3: A7 h0 f- Q4 ~% j. Y
694139 Case difference of net and bus while generating FPGA netlist' ?' J: [7 o' C# v" m
694716 Waveforms are flat when using IO b-element in HSpice9 y$ e: w; a% l, d) u
695109 Incorrect Diff-pair topology extracted by Paksi-E field solver' ?+ b0 F" c7 E1 W
695431 csv2ptf fails without providing any error message: x6 t$ F4 g8 d
696273 Shape disappears when updated in CDNSIP 16.01 and not following the constraints
. ?4 O8 T/ I, p7 m. l; h9 C696534 Pin Visibility check box doesn't work while creating part from spreadsheet editor( E( `; @/ h; V; E* Y
698494 Shape not getting filled correctly# n( f& U& h5 ~) `4 q* q
700160 Error: TVCurve must start at time zero .9 S9 I F% m5 S
700644 Allegro Crashes on doing Zoom In T8 x* _8 e# C6 B3 ]$ G) Z
700725 Create Fanout with Via structure add structure from Top to Int. for bottom pins
9 c0 l5 Q; k: e/ L2 V- `5 A701128 Inconsistent warning message : TBreak (Tknee)is less than Simulation Temperature3 D* \* c# A( O$ f
702557 Incorrect Behavior with FSP 2 FPGA Option License3 Y( q/ y) p( @/ J8 t6 K# L
703324 Cross probing board DRC objects to CM DRC spreadsheet fails to zoom in6 J J6 }4 X! R% u# K) q7 y
704268 remove ARC and TOGGLE rmb options when in add rectangle or add circle command' m$ |; Q5 S- L" Q( x. C9 W5 i9 D
704475 Allegro SI change editor to Allegro PCB XL causes menu problems& e2 B: o' L/ t
705902 ERROR(SPMHUT-144): Illegal arc specification error when Run DBDoctor
. r; P2 O, c3 H705903 Cannot remove a matrix view after modifying the connections
( O2 w7 q: L' k& M, c706169 IDF in error has spelling mistake( D" y4 V. o1 j
706613 Diff pair is not extracting properly through design link.4 Z, b5 Y6 k% Z p! T+ |% r
706729 Import properties fails with ERROR [IMP0020]/ R* X, D% \6 A/ ?" ^$ z% ]" e
708134 Place > Manually command menus not refreshing the Placement list8 [. X; S1 A$ Z% m7 C, ?' l
708145 Creating a netlist with Rev. 57AQ is not formatting correctly
6 G b2 o* e6 |' u" ^4 E708634 Shapes getting incorrectly displayed in 16.29 g5 g" U8 O9 w) i1 ~
710279 ERROR 8020# Place component operation failed.
* g+ ?& T4 J5 f, y+ n& `$ s4 p710859 Unable to create Diff Pair from Autosetup
& i0 i3 r5 K- r& I2 F3 k! J5 H; y2 g711739 selecting one component/symbol of class IC can move unrelated component due to incorrect group membership.
& d5 D1 `& j/ T! c712299 Internal application error while creating new design1 x7 ~2 s, V% F8 k0 ?
712898 Netrev should not read PARENT_PPT_PART property value while importing the logic, due to which import logic fails8 x0 I, H) G2 g4 S" |+ g- B9 S
713465 Problems with dynamic shape creation over routed full-arcs diffpairs
! Q$ Z; u T; H! r- K2 M! c& v9 G: S713480 Display issue when adding a custom property to the first bit of the bus.% O, |, v- {. e$ X! X. n6 C
714072 Error while linking database part4 y- z- J6 H3 K6 v# u/ Z
716097 Specctra is crash during route.
' {, [: V% x) y7 I3 o716212 PACK_SHORT property gives package error for visible POWER pins
, J1 W# O J4 @ {* X' _717484 Dynamic shape creating voids when moving a symbol6 H7 v8 z% ^2 J6 l# y
718151 Geometry not selected when we click tab for selection filter in pad designer: `: ?9 N1 }+ C/ D/ t- w
720092 Difference of behavior for slide for segments in options tab & RMB options( G4 P+ U* M/ D9 w6 R6 D
720191 Delay tune cannot keep the Gap if the diffpair segment is diagonal.
' K8 D- K& K' E721415 Two buses are connected without a warning when moved on top of each other) V0 d+ W. k; J( f+ V% S, {
721938 Cross-Section open error( I* \1 T9 Z$ W& q- c* ?: I4 ~( Y( i
722997 Hyperlink function does not work if zone info. includes hyphen
( O7 |7 W' o) H* K8 ?8 f723146 Pb during compilation using predicate getFileStrings1 i5 }; T+ ^9 \( T
723159 Typographical Error under "Synchronizing PTF Information" section5 j% L [* r( v- G
723235 client install results in incorrect, redundant, and problematic cds_lic_file variable7 V+ {, b$ ^4 Y
724414 State Wins Over Design does not reset the subdesign_suffix block values
7 j9 j# S$ c5 r! S% Y724969 Allegro crashes when using place replicate function
! ~4 b- e5 I, `( ]# @1 \725852 Impedance has little difference - BEM2D3 |0 C! P- X+ o2 m1 B; n; v
726731 SiP - Wirebond -> Edit -> select bond finger -> RMB Change characteristics results in bf not following snap& q7 i* C; e8 D# T
726763 crash during logic import in Allegro CM enabled flow p _- `) K' Z' g6 W. f! _) I
727663 Remove Subclass in My Favorites (Color Dialog) doesn't refresh properly
. _- C' X3 x' W* C+ f729496 Build error in 16.3 and 16.4 cdnsip.exe |
