查看: 4412|回复: 61
[allegro16.6][8层]工业通信板(XC7K325TFBG676_FBG676 +88E1111-BAB1I000+ISL6539...
发表于 2020-1-21 17:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]工业通信板(XC7K325TFBG676_FBG676 +88E1111-BAB1I000+ISL6539IA)原理图和pcb文件
文件描述:
1. 作品用途:工业通信板
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:XC7K325TFBG676_FBG676 +88E1111-BAB1I000+ISL6539IA
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1X3_2J31X3IC8JP15; JP16; JP17; JP18; JP19; JP20; JP21; JP22
2X5PFAN3_0_2X5P_UARTUARTIC2JP13; JP14
BGA64_8X10MMPC28F00AP30TF_BGA64_8X10MM_BGA6BGA64_8X10MMIC1U51
BR1225HCBATTERY_0_BR1225HC_TS518FE FL35TS518FE FL35EIC1BT1
C0402CAP NP_9_C0402_10NF10NFIC4C3; C4; C8; C9
C0402CAP_C0402_0.1UF0.1uFIC84C11; C12; C22; C25; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C58; C59; C60; C63; C64; C65; C66; C67; C68; C69; C78; C79; C83; C85; C86; C87; C88; C113; C114; C115; C116; C122; C123; C124; C125; C126; C127; C256; C257; C261; C262; C263; C264; C265; C266; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C294; C300; C301; C302; C303; C304; C305; C306; C307; C308
C0402CAP_C0402_0.01UF0.01uFIC27C13; C14; C15; C19; C23; C24; C26; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C117; C118; C119; C128; C129; C130; C298; C299
C0402CAP NP_C0402_22PF22PFIC5C27; C28; C61; C62; C84
C0402CAP NP_9_C0402_100NF100NFIC36C39; C40; C44; C48; C49; C50; C51; C52; C53; C229; C231; C235; C238; C239; C240; C241; C242; C243; C1021; C1022; C1024; C1026; C1027; C1029; C1030; C1032; C1033; C1035; C1036; C1038; C1039; C1041; C1042; C1044; C1045; C1047
C0402CAP NP_9_C0402_470NF470NFIC12C41; C42; C43; C45; C46; C47; C230; C232; C233; C234; C236; C237
C0402CAP NP_9_C0402_1UF1UFIC16C82; C133; C139; C140; C154; C160; C161; C1023; C1025; C1028; C1031; C1034; C1037; C1040; C1043; C1046
C0402CAP_C0402_1UF1uFIC4C120; C121; C131; C132
C0402CAP NP_9_C0402_22PF22PFIC2C134; C155
C0402CAP NP_9_C0402_100PF100PFIC4C137; C138; C158; C159
C0402CAP NP_9_C0402_1000PF1000pFIC2C141; C162
C0402CAP NP_9_C0402_220PF220PFIC2C142; C163
C0402CAP NP_9_C0402_330PF330PFIC2C143; C164
C0402CAP NP_C0402_1500PF1500pFIC4C144; C145; C211; C212
C0402CAP NP_C0402_0.1UF0.1uFIC24C147; C150; C167; C169; C174; C177; C180; C181; C182; C189; C191; C192; C202; C203; C204; C205; C221; C222; C223; C224; C225; C226; C227; C228
C0402CAP NP_C0402_1UF1uFIC4C166; C178; C190; C200
C0402CAP NP_C0402_0.01UF0.01uFIC14C175; C185; C187; C198; C208; C210; C213; C214; C215; C216; C217; C218; C219; C220
C0402CAPV_0_C0402_1UF NC1uF NCIC2C186; C209
C0603CAP NP_9_C0603_100NF100NFIC9C2; C5; C6; C7; C16; C18; C81; C135; C156
C0603CAP NP_9_C0603_0.33UF0.33UFIC2C136; C157
C0603CAP NP_C0603_0.015UF0.015uFIC6C152; C153; C183; C184; C206; C207
C0603CAP NP_C0603_0.15UF/25V0.15uF/25VIC4C172; C173; C196; C197
C0805CAP_C0805_47UF47uFIC4C89; C90; C91; C92
C0805CAPV_0_C0805_10UF/16V10uF/16VIC4C146; C148; C149; C151
C0805CAP NP_C0805_10UF/16V10uF/16VIC6C165; C170; C171; C188; C194; C195
C0805CAP NP_C0805_4.7UF/16V4.7uF/16VIC6C168; C176; C179; C193; C199; C201
C1206CAP NP_9_C1206_10UF/10V10UF/10VIC8C54; C55; C56; C57; C244; C245; C246; C247
C1206CAP_C1206_100UF100uFIC8C93; C94; C95; C96; C97; C98; C99; C100
D16SN74AVC4T245_D_0_D16_VALUEValueIC8U2; U3; U4; U5; U6; U25; U26; U27
DFN10-3X3ISL80102_0_DFN10-3X3_ISL80103IRISL80103IRAJZIC2U58; U59
DIGILENT_USB_JTAGDIGILENT_USB_JTAG_2_DIGILENT_USDIGILENT_USB_JTAGIC1U77
DIODEDIODE SCHOTTKY_0_DIODE_SS14SS14IC1D2
DIP2-79-160HEADER_0_DIP2-79-160_1X21X2IC12JP1; JP2; JP3; JP4; JP5; JP6; JP7; JP8; JP9; JP10; JP11; JP12
DL4148DIODE SCHOTTKY_0_DL4148_DL4148DL4148 100VIC1D14
DVBSN74LVC1T45_DVB_0_DVB_SN74LVC1TSN74LVC1T45IC1U54
DVBSN74LVC1T45_DVB_1_DVB_SN74LVC1TSN74LVC1T45IC1U79
F1206FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020IC4F1; F2; F5; F6
FAN3PFAN3_1_FAN3P_FANFANIC1J11
FB0805INDUCTOR_H_FB0805_MJ2125HM420NTMJ2125HM420NT NCIC4FB1; FB3; FB4; FB5
FB0805INDUCTOR_H_FB0805_MJ2125HM420_1MJ2125HM420NTIC16FB2; FB6; FB7; FB12; FB13; FB14; FB15; FB97; FB98; FB99; FB100; FB101; FB102; FB103; FB104; FB105
FBG676XC7K325TFBG676_FBG676_(S1+S2+S3xc7k325tfbg676IC1U55
HDR1X9HDR 1X9_HDR1X9_HDR 1X9HDR 1X9IC2J12; J13
IHLP2525INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IC6L1; L2; L3; L4; L5; L6
IS62WV20488BLLIS62WV20488BLL_0_IS62WV20488BLLIS62WV20488BLLIC1U56
JTAGJTAG_JTAG_JTAGJTAGIC1J1
LED0805LED_32_LED0805_LED_GREENLED_GreenIC16LED1; LED2; LED3; LED4; LED5; LED6; LED7; LED8; LED9; LED10; LED11; LED12; LED13; LED14; LED17; LED22
LED0805LED_LED0805_LEDLEDIC4LED18; LED19; LED20; LED21
MM3Z2V7BDIODE SCHOTTKY_0_MM3Z2V7B_MM3Z2MM3Z2V7B 2.7VIC1D15
NDS331NMOSFET_N_NDS331N_NDS331N 460MWNDS331N 460MWIC1Q39
NDT3055L2020000600_0_NDT3055L_NDT3055LNDT3055L 1.3WIC1Q40
OSC4-XO53OSC_OSC4-XO53_OCJTDLJANF-125MHZOCJTDLJANF-125MHZ NCIC1Y4
OSC4-XO53OSC_OSC4-XO53_OCJTDLJANF-66MHZOCJTDLJANF-66MHZIC1Y5
OSC4-XO53OSC_OSC4-XO53_OVETDLJANF-33MHZOVETDLJANF-33MHZIC1Y7
PHM0622B-TCPCI5_M_5_PHM0622B-T_CPCI5_MCPCI5_MIC1U11
PHM0625A-TCPCI1_M_PHM0625A-T_CPCI1_MCPCI1_MIC1U1
PHM0625A-TCPCI4_M_6_PHM0625A-T_CPCI4_MCPCI4_MIC1U10
PW0014A_NLSF0204PWR_0_PW0014A_N_VALUEValueIC1U24
PW0020ALSF0108PWR_PW0020A_VALUEValueIC4U83; U84; U85; U86
R0402R-0603_1_R0402_10,5%10,5%IC53R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53
R0402R-0603_1_R0402_10 5% NC10 5% NCIC1R62
R0402RES_R0402_4.7K NC4.7K NCIC4R73; R77; R171; R174
R0402RES_R0402_4.7K4.7KIC19R75; R90; R91; R94; R95; R96; R97; R103; R144; R158; R159; R161; R162; R163; R164; R170; R249; R250; R252
R0402RES_R0402_00DISCRETE37R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R92; R93; R98; R99; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R160; R165; R166; R271; R273; R298; R300; R318
R0402RES_R0402_1K 1%1K 1%IC4R100; R167; R253; R409
R0402RES_R0402_4.99K 1%4.99K 1%IC2R101; R168
R0402RES_R0402_330330IC16R104; R105; R106; R107; R169; R172; R173; R175; R176; R177; R178; R384; R411; R412; R413; R414
R0402RES_R0402_4.7K NC4.7K NCIC1R238
R0402RES_R0402_22 1%22 1%IC1R242
R0402RES_R0402_22 1%22 1%IC1R243
R0402RES_R0402_1.21K 1%1.21K 1%IC5R244; R245; R246; R247; R248
R0402RES_R0402_2222IC1R254
R0402RES_R0402_22 5%22 5%IC1R255
R0402RES_R0402_22 NC22 NCIC1R256
R0402R-0603_1_R0402_680K,5%680K,5%IC2R259; R277
R0402RES_R0402_5.1K 1%5.1K 1%IC2R269; R270
R0402RES_R0402_1.27K 1%1.27K 1%IC2R272; R274
R0402RES_R0402_10K10KIC8R297; R299; R303; R314; R315; R316; R320; R391
R0402RES_R0402_100K100KIC4R301; R302; R317; R319
R0402RES_R0402_49.9 1%49.9 1%IC16R322; R323; R324; R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337
R0402RES_R0402_7575IC8R338; R339; R340; R341; R342; R343; R344; R345
R040210KOHMRESISTOR1/10W1%0402_R0402120 1%IC2R389; R408
R0402RES_R0402_100 1%100 1%IC1R390
R0402RES_R0402_1K1KIC8R415; R416; R417; R418; R419; R420; R421; R422
R0402R-0603_1_R0402_10M,5%10M,5%IC1R589
R04021KOHMRESISTOR1/16W0402_R0402_20200KIC4R595; R596; R597; R598
R0603R-0603_1_R0603_2.7K,5%2.7K,5%IC11R54; R55; R57; R58; R59; R60; R61; R63; R65; R66; R67
R0603R-0603_1_R0603_100K,5%100K,5%IC5R56; R258; R261; R276; R279
R0603R-0603_1_R0603_10K,5%10K,5%IC8R108; R113; R118; R122; R346; R351; R356; R360
R0603R-0603_1_R0603_1K,5%1K,5%IC24R109; R110; R114; R115; R119; R120; R123; R124; R126; R127; R129; R130; R347; R348; R352; R353; R357; R358; R361; R362; R364; R365; R367; R368
R0603R-0603_1_R0603_0,5% NC0,5% NCIC12R111; R116; R263; R264; R266; R267; R281; R282; R283; R285; R349; R354
R0603R-0603_1_R0603_120,5%120,5%IC12R112; R117; R121; R125; R128; R131; R350; R355; R359; R363; R366; R369
R0603R-0603_1_R0603_0,5%0,5%IC15R132; R134; R136; R138; R139; R142; R268; R284; R286; R370; R372; R374; R376; R377; R380
R0603R-0603_1_R0603_4.7K,5%4.7K,5%IC12R133; R135; R137; R140; R141; R143; R371; R373; R375; R378; R379; R381
R0603R-0603_1_R0603_100K,5% NC100K,5% NCIC2R257; R275
R0603R-0603_1_R0603_27K,5% NC27K,5% NCIC2R260; R278
R0603R-0603_1_R0603_0,5%_10,5%IC1R265
R0603RES_R0603_00IC4R287; R288; R304; R305
R0603RES_R0603_10K 1%10K 1%IC8R289; R291; R295; R296; R306; R309; R312; R313
R0603RES_R0603_2.2K 1%2.2K 1%IC4R290; R292; R307; R308
R0603RES_R0603_1.6K 1%1.6K 1%IC1R293
R0603RES_R0603_3.5K 1%3.5K 1%IC1R294
R0603RES_R0603_18.0K 1%18.0K 1%IC2R310; R311
R0805RES_R0805_0 5%0 5%IC2R202; R204
R0805RES_R0805_0 5% NC0 5% NCIC2R203; R382
R2512R-0603_1_R2512_0.005,1%0.005,1%IC2R262; R280
RSW10SN74AVC2T245_RSW_1_RSW10_VALUEValueIC1U78
SD1206DIODE SCHOTTKY_2_SD1206_MBR0520MBR0520IC2D4; D6
SD1714DIODE SCHOTTKY_3_SD1714_IR_30BQIR_30BQ015IC2D5; D7
SDA05H1SBDFPGA SEL SWITCH_2_SDA05H1SBD_SDSDA05H1SBDIC1SW1
SIT9102SIT9102_0_SIT9102_SIT9102SIT9102IC1Y3
SM-7351-CAP-04020.1UFCAPACITOR16V10%0402_SM-7_110uFIC3C70; C258; C259
SM-7351-CAP-04020.1UFCAPACITOR16V10%0402_SM-7350.1uFIC21C71; C72; C73; C74; C75; C76; C77; C248; C249; C250; C251; C252; C253; C254; C255; C260; C267; C268; C295; C296; C297
SM-7351-CAP-04020.1UFCAPACITOR16V10%0402_SM-7_20.1uF NCIC1C80
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-73100 1%IC16R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_10 NCIC1R195
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_24.7KIC8R196; R197; R198; R199; R206; R392; R393; R394
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_315 1%IC7R200; R201; R207; R208; R386; R387; R388
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_44.7K NCIC1R205
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_50 1%DISCRETE32R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; R239; R240; R241
SM-7351-RES-04021KOHMRESISTOR1/16W0402_SM-7351-4.7K 1%IC1R251
SM-7351-RES-04021KOHMRESISTOR1/16W0402_SM-735_1330 5%IC1R321
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_610K, 1%IC4R383; R385; R402; R403
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_74.53K 1%IC1R395
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_81K 1%IC2R396; R397
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM-_910K 1%IC2R398; R399
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM_104.75K 1%IC1R400
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM_110 NCIC1R401
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM_1210K 1% NCIC2R404; R406
SM-7351-RES-040210KOHMRESISTOR1/10W1%0402_SM_1310K 1% NCIC2R405; R407
SM-7351-RES-04021KOHMRESISTOR1/16W0402_SM-735_20 5%IC2R590; R592
SM-7351-RES-04021KOHMRESISTOR1/16W0402_SM-735_30 5% NCIC2R591; R593
SO16N25Q128_SO16_SO16_SPI_FLASHSPI_FLASHIC1U52
SOP8-50-150MAX485_1_SOP8-50-150_MAX485ESAMAX485ESAIC4U16; U17; U67; U68
SOP8-50-244MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYIC4Q1; Q2; Q3; Q4
SOP14-26-17374LV14DB_SOP14-26-173_SN74HC14PSN74HC14PWIC2U15; U66
SOP14-50-150MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDIC4U18; U19; U69; U70
SOP14-50-150MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDIC8U20; U21; U22; U23; U71; U72; U73; U74
SOP24-26-208LTC1736_SOP24-26-208_LTC1736IGLTC1736IGIC2U57; U60
SOT23BAT54C_SOT23_SOT23_BAT54CWBAT54CWIC4D8; D9; D10; D11
SOT23_6SN74LVC1G18DBVR_SOT23_6_SOT23_6SOT23_6IC1U82
SOT96-1PCA82C250_2_SOT96-1_PCA82C250PCA82C250IC2U75; U76
SSOP28MAX3243_0_SSOP28_MAX3243EAIMAX3243EAIIC4U13; U14; U64; U65
SSOP28_150ISL6539_SSOP28_150_ISL6539IAISL6539IAIC2U61; U62
STC3528CAP_POL_STC3528_47UF47uFIC4CD4; CD5; CD11; CD15
STC3528CAP_POL_STC3528_10UF/16V10UF/16VIC5CD16; CD24; CD25; CD31; CD32
STC3528CAP_POL_STC3528_220UF220uFIC7CD17; CD18; CD19; CD20; CD21; CD22; CD23
STC3528CAP_POL_STC3528_4.7UF/16V4.7UF/16VIC2CD30; CD37
STC7343CAP_POL_4_STC7343_220UF220uFIC6CD1; CD2; CD3; CD12; CD13; CD14
STC7343CAP_POL_STC7343_470UF/6V470UF/6VIC8CD26; CD27; CD28; CD29; CD33; CD34; CD35; CD36
STC7343CAP_POL_STC7343_220UF220uFIC12CD38; CD39; CD40; CD41; CD42; CD43; CD44; CD45; CD46; CD47; CD48; CD49
STC7343CAP_POL_1_STC7343_47UF/25V47UF/25VIC1CD50
TFBGA11788E1111_TFBGA117_88E1111-BAB1I088E1111-BAB1I000IC2U12; U50
TFM48-40-300H5020_0_TFM48-40-300_HX5020NLHX5020NLIC1U63
TO252MOSFET_N_TO252_AOD452AOD452IC8Q5; Q6; Q7; Q8; Q9; Q10; Q11; Q12
TPC26B_S4_68TP_TPC26B_S4_68_TPC26BTPC26bIC9TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9
UJ_5ADP123AUJZ_R7_0_UJ_5_VALUEValueIC1U81
X53FXTAL_0_X53F_XVHEELNANF-25MHZXVHEELNANF-25MHZIC2Y1; Y2
ZKE96SN74AVC32T245_ZKE_0_ZKE96_VALUEValueIC1U8
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
$ u0 J2 E/ ^7 P# R
推荐
发表于 2022-3-15 21:07 | 只看该作者
厉害厉害
    慵懒
    2019-11-20 15:30
    推荐
    发表于 2020-7-10 09:46 | 只看该作者
    谢谢分享 我是为了撸FBG676封装来的,我只有FFG676; ^. N) D: A* P: ^
    2024-8-26 15:16
    发表于 2020-8-1 16:10 | 只看该作者
    通信板卡吗??
    5 l& o( s6 {/ L( g" j3 X; m
    发表于 2020-8-1 17:32 | 只看该作者
    如果您要查看本帖隐藏内容) G$ Q, e1 _2 c# s
    2024-8-26 15:16
    发表于 2020-8-2 08:28 | 只看该作者
    只有layout图,没有电路图
    郁闷
    2024-4-8 15:07
  • 签到天数: 51 天
    [LV.5]常住居民I
    发表于 2020-8-3 15:14 | 只看该作者
    好人一生平安
    发表于 2020-8-3 23:08 | 只看该作者
    谢谢分享 我是为了FBG676封装来的
    13#
    发表于 2020-9-14 20:09 | 只看该作者
    14#
    发表于 2020-9-14 21:53 | 只看该作者
    感谢分享,呵呵呵呵呵呵4 X3 d5 d% A" h- [2 E  }
    2020-9-15 15:22
    15#
    发表于 2020-9-15 10:15 | 只看该作者
    非常需要一个allegro的例子,非常感谢
    6 p( l- @6 U0 v3 `3 h% E
    郁闷
    2025-8-29 15:40
  • 签到天数: 403 天
    [LV.9]以坛为家II
    16#
    发表于 2020-10-2 14:29 | 只看该作者
    谢谢分享哦哦
    GMT+8, 2025-10-9 22:37 , Processed in 0.187500 second(s), 29 queries , Gzip On.
