作品名:[AD 10][2层] TPA3110D2+AX3071UA+OB350G 数字功放PCB文件和原理图: R Z0 p- b& _* u1 T
6 Y2 ~. a5 a% Z8 l- ?" O文件描述
- H1 h; V3 U+ o. \- j5 ^5 o1. 作品用途:数字功放
, K2 T: R% X4 T' G8 M; j2. 软件版本:AD 10
: q" \) E3 r0 a/ S5 a4 a3. 层数:2层板, ~- i. L' i2 I" ^3 q
4. 用到的主要芯片:TPA3110D2+AX3071UA+OB350G
$ q/ S# I" Q. K+ }, s5. PCB尺寸:107mm*78.3mm) a- S/ _$ D A) c0 E8 ~" h
! Y/ t1 V3 `6 d1 j8 n作品截图如下:+ b- d9 i0 T3 N5 o. `; f
顶层截图:; t, p/ K3 D" @5 x9 G$ c
# ^! D/ k5 m( w3 n. z% Y* d
6 G- R" x1 j4 V9 b/ Z! M
底层截图:
B4 a# F# l% T7 L+ s
; y+ [' k' G3 c* Y8 u1 X, J0 p
4 [5 }# A1 f' Q1 J3 v0 `# q
全层截图:9 Y% W- U( V+ H v7 `' Z& j
: S8 e& k) q/ `* A- X$ F& O, A7 O
$ l5 m3 v2 |! D _+ o叠层信息截图如下:/ x3 i# U/ o% ~) q9 q2 J
. F! Q: j' ]5 {% h) T! V3 G! j. f) U5 ^1 g" r8 P: N
BOM:
+ r+ y( @% I$ N7 T r4 R& _Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 100PF | AC1, AC4, AC5, AC6, AC17, AC27, AC29 | C0402 | 7 | 100NF | AC2, AC3, AC8, AC12, AC13, AC38, AC39, AC45, AC50 | C0402 | 9 | 220NF | AC7, AC10, AC18, AC20, AC25, AC28 | C0402 | 6 | 1NF | AC9, AC11, AC16, AC22, AC26 | C0402 | 5 | 2.2NF | AC14, AC23, AC30, AC31, AC32, AC33 | C0402 | 6 | 1UF | AC15, AC21, AC24, AC40, AC41 | C0402 | 5 | 15P | AC19 | C0402 | 1 | 22PF | AC34, AC35, AC36, AC37 | C0402 | 4 | 220PF | AC42 | c1206 | 1 | 33UF | AC43 | CC5B8_3 | 1 | 2.2NF | AC44 | c1206 | 1 | 1UF | AC46 | C0603 | 1 | 100NF | AC47, AC49 | c0603 | 2 | 2.2NF | AC48 | c0805 | 1 | CON4-DIP/2.0MM | ACN1 | CON4/2.0/W | 1 | MMBT3906 | AQ1, AQ2, AQ3, AQ4 | SOT-23 | 4 | TPA3110D2 | AU1 | SOP28 | 1 | DC3 | CN1 | DC3 | 1 | CKX-3.5-11 | CN2 | PHONE/3.5 | 1 | CON2 | CNS1 | CON2-3.81-DIP | 1 | TVS | D1 | smb | 1 | SS54 | DL1, DL2, DL3, DL4, DL5, DL6 | SMB | 6 | SS34 | DL7, DL8, DL11 | SMB | 3 | 4148 | DL9 | ll-34 | 1 | SS34 | DL10 | DO-201-17.5 | 1 | SS34 | DL12 | LL-34 | 1 | 470UF | E1, E3, E4, E7, E8, E9 | CAP6MM_AI | 6 | 580UF | E2, E5 | CAP10MM_AI | 2 | 100UF | E10 | CAP6MM_AI | 1 | 33UF | E11, E12 | CAP10MM_AI | 2 | 10UF | E13 | CAP10MM_AI | 1 | FUSE | F1 | F125V5A | 1 | FUSE | F2 | FUSE30N | 1 | FUSE | F3 | r1206 | 1 | | H1, H2, H3, H4 | MT-6(NEW) | 4 | 4.7UH | L1, L2 | cd60 | 2 | 68UH | L3 | LCH-1213_7.5W | 1 | 68UH | LT1 | TI12-W | 1 | 47UH | LT2 | LCH-1213_7.5W | 1 | 47UH | LT3 | L-2011 | 1 | 68UH | LT4, LT5, LT6, LT7 | CD54/D | 4 | MMBT3904L | Q1, Q2 | SOT-23 | 2 | MOS-N(SMD)_2 | QL1, QL2 | to-252 | 2 | 4.7K | R1, R59 | R0402 | 2 | 4.7R | R2, R3, R6 | R0402 | 3 | 10R | R4 | R0402 | 1 | 51K | R5 | R0402 | 1 | 6.8K | R7 | R0402 | 1 | 10K | R8, R11, R18, R19, R20, R27, R58, R60 | R0402 | 8 | R0402 | R9 | R0402 | 1 | 58K | R10, R21, R22, R23, R24 | R0402 | 5 | 50mR | R12, R13, R14, R15, R16, R17 | r1206 | 6 | 47K | R25 | R0402 | 1 | 0R | R26, R49, R50 | R0402 | 3 | 33K | R28, R30 | R0402 | 2 | 1K | R29, R51, R52, R53, R57, R61, R66 | R0402 | 7 | 10R | R31 | r1206 | 1 | 4.7R | R32 | R0603 | 1 | 20K | R33, R38, R44 | r0805 | 3 | 20R | R34 | r0805 | 1 | 10K | R35 | r0603 | 1 | 15R | R36 | r1206 | 1 | 0R | R37 | r0603 | 1 | 100K | R39, R40 | R0402 | 2 | 470 | R41 | r0603 | 1 | 10R | R42 | r0603 | 1 | 20K | R43 | r0603 | 1 | 0.39 | R45, R46, R47, R48 | r1206 | 4 | 5.1K | R54, R56 | R0402 | 2 | 0R | R55 | R1206 | 1 | 2.49 | R62, R63, R64, R65 | r1206 | 4 | | SCN1 | CON5/2.0 | 1 | CS14 | SH2 | HS14X7 | 1 | | SJ1 | CON6/2.0 | 1 | OB350G | SU1 | SOP8-225-50 | 1 | AMS4004 | U1 | SOP8-225-50 | 1 | AVB4004 | U2 | SOP8-225-50 | 1 | AX3071UA | U3 | SSOP-10 | 1 | MT3606 | U4, U5 | SOT-23.6 | 2 | ! Q7 _! I; r) Q
附件:$ t/ X1 k+ {+ k* M/ R
原理图和PCB源文件如下:$ _8 m4 j7 V, T8 B ` |1 f
9 t1 s/ G, w' S9 T9 w# s/ A* K) e( t/ W+ Z5 a; v, T% R! l4 \
