查看: 382|回复: 2
[allegro16.6][4层]AM335X 底板(DP83848I+BQ24616RGE+AD7888BR)原理图和pcb文件
发表于 2020-1-13 14:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
& m. D$ A5 }- ~! t# D7 W
% e/ \5 a# Q6 V# k: H" i8 F2 ], q5 u+ Q* p9 j1 \, w$ h7 ?
文件描述:
/ C% |4 R/ c# V5 O$ l
) X0 R' a: \- z# b1 q" n1. 作品用途: AM335X 底板
" v! y( v9 g, f4 C3 k2. 软件版本:allegro16.6& _* S# p  t# m  ~* Y6 m: @
3. 层数:4层6 O& j5 d5 e3 }5 g, i& j
4. 用到的主要芯片:DP83848I+BQ24616RGE+AD7888BR
& E9 f& d' Q! g1 h! W# b1 ~! z, l5. pcb尺寸: 7283.185*6692.901 MIL" r2 d/ n% {6 d4 K5 ?: K
4 ?& M) v; D% J( ?" i
作品截图如下:6 d3 c2 t: r% S$ W; E7 Y6 r
& P& a( e  \! S+ f) A顶层截图:+ z1 e7 k0 [9 F
3 j3 n/ j* P( R* Y" W  W底层截图:
; V4 n) a" \& _/ m5 ]9 v3 @$ x; X$ _- \$ |0 L
0 O3 Y7 q& \! ^- c$ o# I" [; C
全层截图:3 F7 z" S: E* E
: [6 `- {. v8 I6 m+ G2 ]
BOM:
6 @0 m& B2 a; d. N7 y( U
B2B_0D50_50P_RT_SMD_FEMALEMG323_B2B_0D50_50P_RT_SMD_FEMALB2B 0.5MM 50P FEMALEIC1CON16
BL-8188-4M_SMDCON_BL-8188-4M_1_BL-8188-4M_SMDBL-8188-4MIC1CON4
BLK-MD-BC04-LBLK-MD-BC04-L_BLK-MD-BC04-L_BLKBLK-MD-BC04-LIC1MOD1
BUTTON_SPST_SMTSW PUSHBUTTON-SPST_BUTTON_SPST_SW_PUSHBUTTON_SPSTIC4SW2; SW3; SW6; SW7
BZ_1280DX730HDIP_BUZZER-1205_D120-P65-H100BuzzerIC1BUZ1
C0402CAP NP 0402_C0402_100NF100nFIC127C18; C23; C25; C27; C41; C48; C55; C60; C61; C64; C66; C70; C73; C74; C75; C76; C79; C80; C81; C83; C84; C87; C89; C90; C91; C92; C99; C100; C102; C103; C106; C108; C110; C111; C113; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C140; C141; C142; C143; C145; C146; C147; C148; C150; C152; C162; C164; C166; C167; C168; C169; C171; C172; C173; C174; C184; C185; C186; C187; C189; C190; C191; C192; C201; C202; C203; C204; C205; C206; C219; C220; C221; C222; C224; C225; C227; C228; C229; C230; C235; C238; C239; C240; C248; C255; C258; C259; C260; C262; C266; C279; C280; C282; C287; C291; C301; C305; C307; C310; C313; C326; C329; C331; C332
C0402CAP NP 0402_C0402_22PF22pFIC1C33
C0402CAP NP 0402_C0402_1.5NF1.5nFIC3C36; C44; C53
C0402CAP NP 0402_C0402_150PF150pFIC3C40; C47; C56
C0402CAP NP 0402_C0402_10NF10nFIC73C58; C59; C62; C63; C67; C69; C72; C93; C94; C105; C109; C144; C151; C153; C154; C155; C156; C157; C158; C159; C160; C163; C175; C176; C177; C178; C179; C180; C181; C182; C193; C194; C195; C196; C199; C200; C213; C214; C215; C216; C217; C218; C236; C237; C241; C242; C249; C256; C257; C263; C264; C267; C269; C281; C284; C286; C288; C292; C293; C294; C299; C302; C304; C306; C308; C309; C316; C317; C318; C319; C327; C328; C330
C0402CAP NP 0402_C0402_1NF1nFIC5C68; C283; C285; C289; C303
C0402CAP NP 0402_C0402_10PF10pFIC6C85; C86; C95; C96; C97; C98
C0402CAP NP 0402_C0402_33PF33pFIC4C295; C296; C297; C298
C0603CAP NP 0603_C0603_100NF100nFIC25C1; C4; C7; C8; C10; C11; C13; C14; C15; C16; C26; C29; C30; C39; C46; C54; C250; C252; C270; C271; C273; C274; C321; C322; C324
C0603CAP NP 0603_C0603_10NF10nFIC25C2; C3; C9; C35; C42; C49; C165; C170; C251; C253; C268; C272; C275; C276; C320; C323; C325; C333; C334; C335; C336; C337; C338; C339; C340
C0603CAP NP 0603_C0603_1NF1nFIC2C114; C115
C0805CAP NP 0805_C0805_1UF1uFIC6C19; C20; C22; C24; C28; C34
C0805CAP NP 0805_C0805_10UF10uFIC23C50; C57; C65; C71; C77; C82; C88; C101; C107; C112; C149; C161; C247; C254; C261; C265; C277; C278; C300; C311; C312; C314; C315
C0805CAP NP 0805_C0805_22UF22uFIC1C78
C0805CAP NP 0805_C0805_100NF100nFIC10C207; C208; C209; C210; C211; C212; C231; C232; C233; C234
C1210CAP NP 1210_C1210_10UF10uFIC1C31
CAPAE_6D3X5D7CAP POL_CAPAE_6D3X5D7_22UF22uFIC6C12; C17; C21; C32; C139; C223
CAPAE_10X10CAP POL_CAPAE_10X10_470UF470uFIC1C290
CAPAE_12D5X13D5CAP POL_CAPAE_12D5X13D5_220UF220uFIC2C5; C6
CAP_CASE_DCAP POL_CAP_CASE_D_100UF100uFIC6C37; C38; C43; C45; C51; C52
CON_1D25_8P_SMD_DF14B1.25MM 8P SMD DF14B_CON_1D25_8P1.25mm 8P SMD DF14BIC1J2
CON_1D27_2X50_SMD_BOX_RTCON100A 2MH_CON_1D27_2X50_SMD_B1.27mm 2x50 SMD BoxIC2CON1; CON2
CON_2D00_2X6_TH_PHD_VERTCON12A_CON_2D00_2X6_TH_PHD_VERT2.00mm 2x6 TH PHDIC5CON10; CON11; CON12; CON13; CON15
CON_2D00_2X8_TH_PHD_VERTCON16A_CON_2D00_2X8_TH_PHD_VERT2.00mm 2x8 TH PHDIC1CON14
CON_2D00_2X12_TH_PHD_VERTCON24A_CON_2D00_2X12_TH_PHD_VER2.00mm 2x12 TH PHDIC1CON9
CON_2D54_1X3_TH2.54MM 1X3 TH PIN_CON_2D54_1X3_2.54mm 1x3 TH PINIC1J10
CON_2D54_1X4_TH_TJC32.54MM 1X4 TH TJC3_CON_2D54_1X42.54mm 1x4 TH TJC3IC2J4; J9
CON_2D54_1X6_TH_TJC32.54MM 1X6 TH TJC3_CON_2D54_1X62.54mm 1x6 TH TJC3IC3J5; J6; J8
CON_2D54_2X5_DIP_PIN_VERTCON10A_0_CON_2D54_2X5_DIP_PIN_V2.54MM 2X5 DIP PINIC1J7
CON_3D96_1X2_DIP_DEADER_RTCON2_CON_3D96_1X2_DIP_DEADER_RT3.96mm 1x2 TH VHIC2CON3; CON18
CON_BATTERY_CR2032_SMDCON BATTERY CR2032 SMD_CON_BATTCON BATTERY CR2032 SMDIC1CON19
CON_DIP_6P_1D27_SOPSW DIP-6_CON_DIP_6P_1D27_SOP_1.1.27mm 6BIT SMD SOP SwitchIC6SW1; SW4; SW5; SW8; SW9; SW10
CON_FFC_0D5_50PFFC 0.5MM 50P FLIP_CON_FFC_0D5_FFC 0.5mm 50P FLIPIC1CON17
CON_L850070_092L85007-09201C_CON_L850070_092_TTF CARD PUSHIC1CON8
CON_USBA_FEMALE_SINGLE_SMDUSB FEMALE TYPE A SINGLE_CON_USCON USB FEMALE TYPE A SINGLE SMTIC1CON6
CON_USB_MINI-AB_RECEPMINI USB-AB SMD5_CON_USB_MINI-AMINI USB-AB SMD5IC1CON5
CON_YDS_13F-64GYD2PLXNL13F-64GYD2PL2NL_CON_YDS_13F-64G13F-64GYD2PL2NLIC1CON7
D0402DIODE TVS BI-DIR_D0402_RCLAMP05RCLAMP0521PIC10D12; D13; D25; D26; D30; D31; D32; D33; D37; D38
D0603LED_D0603_LED REDLED REDIC2LED1; LED5
D0603LED_D0603_LED GREENLED GREENIC12LED2; LED3; LED4; LED6; LED7; LED8; LED9; LED10; LED11; LED12; LED13; LED14
F1206FUSE_F1206_2A2AIC2F1; F2
F1206FUSE_F1206_200MA200mAIC2F3; F4
GW-SIM8PPSIM8PP_GW-SIM8PP_GW-SIM8PP-0LY8GW-SIM8PP-0LY8IC1P1
L10D0X8D0X5D0MMCOMMON MODE CHOKE_L10D0X8D0X5D05uHIC1L1
L12D5X12D5X8D0MMINDUCTOR_L12D5X12D5X8D0MM_22UH22uHIC4L2; L3; L4; L5
L0603FERRITE BEAD_L0603_220R/100MHZ220R/100MHzIC81FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20; FB21; FB22; FB23; FB24; FB25; FB26; FB27; FB28; FB29; FB30; FB31; FB32; FB33; FB34; FB35; FB36; FB37; FB38; FB39; FB40; FB41; FB42; FB43; FB44; FB45; FB46; FB47; FB48; FB50; FB52; FB53; FB54; FB55; FB56; FB57; FB58; FB59; FB60; FB61; FB62; FB63; FB64; FB65; FB67; FB68; FB69; FB70; FB71; FB72; FB73; FB74; FB75; FB76; FB77; FB78; FB79; FB80; FB81; FB82; FB83; FB84; FB85
LQFP48_G48DP83848I_LQFP48_G48_DP83848IDP83848IIC1U12
MHOLE_C150D90HOLE_MHOLE_C150D90_C150D90C150D90IC7H1; H2; H3; H4; H11; H12; H13
MHOLE_C260D160HOLE_MHOLE_C260D160_C260D160C260D160IC6H5; H6; H7; H8; H9; H10
QFN24BQ24616RGE_QFN24_BQ24616RGEBQ24616RGEIC1U1
R0402R_R0402_10K10KIC63R1; R2; R3; R4; R16; R17; R18; R29; R35; R42; R46; R47; R48; R49; R50; R51; R52; R53; R54; R61; R62; R80; R82; R111; R113; R114; R115; R116; R117; R118; R127; R128; R130; R140; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R175; R284; R285; R287; R288; R296; R297; R305; R306; R307; R312; R314; R352; R353; R365; R367; R369
R0402R_R0402_1K1KIC23R9; R11; R31; R41; R75; R76; R77; R78; R98; R102; R119; R120; R240; R241; R242; R246; R247; R298; R299; R300; R303; R304; R313
R0402R_R0402_100K100KIC19R12; R45; R55; R56; R57; R58; R59; R60; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R318
R0402R_R0402_56K56KIC1R13
R0402R_R0402_73.2K 1%73.2K 1%IC1R14
R0402R_R0402_15K15KIC4R19; R20; R21; R84
R0402R_R0402_150K 1%150K 1%IC1R22
R0402R_R0402_2.2K 1%2.2K 1%IC3R23; R36; R38
R0402R_R0402_49.9K49.9KIC1R24
R0402R_R0402_100R100RIC3R25; R286; R292
R0402R_R0402_6.8K 1%6.8K 1%IC1R26
R0402R_R0402_36K 1%36K 1%IC3R27; R33; R39
R0402R_R0402_12.1K 1%12.1K 1%IC2R28; R43
R0402R_R0402_3.83K 1%3.83K 1%IC1R30
R0402R_R0402_549R549RIC3R32; R37; R44
R0402R_R0402_10K 1%10K 1%IC1R34
R0402R_R0402_21K 1%21K 1%IC1R40
R0402R_R0402_0R0RIC13R73; R83; R250; R344; R345; R346; R347; R348; R349; R350; R351; R354; R355
R0402R_R0402_4.7K4.7KIC9R74; R87; R366; R368; R370; R375; R376; R377; R378
R0402R_R0402_33R33RIC3R79; R81; R105
R0402R_R0402_2.43K 1%2.43K 1%IC1R85
R0402R_R0402_1.5K1.5KIC11R86; R220; R221; R222; R223; R224; R225; R234; R235; R236; R237
R0402R_R0402_2.2K2.2KIC9R88; R89; R90; R97; R100; R106; R107; R108; R109
R0402R_R0402_49.9R 1%49.9R 1%IC4R91; R92; R93; R94
R0402R_R0402_22R22RIC15R95; R96; R99; R101; R103; R104; R112; R125; R126; R129; R243; R244; R245; R248; R249
R0402R_R0402_4.87K 1%4.87K 1%IC1R110
R0402R_R0402_240R 1%240R 1%IC24R157; R158; R167; R168; R169; R170; R171; R172; R173; R174; R184; R185; R186; R187; R188; R189; R190; R191; R200; R201; R202; R203; R206; R207
R0402R_R0402_22K22KIC20R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R226; R227; R228; R229; R230; R231; R232; R233
R0402R_R0402_75R 1%75R 1%IC29R315; R316; R317; R319; R320; R321; R322; R323; R324; R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R374
R0402R_R0402_1M 1%1M 1%IC1R372
R0402R_R0402_274K 1%274K 1%IC1R373
R0603R_R0603_10R10RIC23R6; R159; R160; R161; R162; R163; R164; R165; R166; R176; R177; R178; R179; R180; R181; R182; R183; R192; R194; R196; R197; R198; R199
R0603R_R0603_100K100KIC2R8; R10
R0603R_R0603_0R0RIC1R358
R0603R_R0603_180R180RIC3R359; R360; R363
R0603R_R0603_1R 1%1R 1%IC10R381; R382; R383; R384; R385; R386; R387; R388; R389; R390
R0805R_R0805_1K1KIC3R141; R142; R144
R0805R_R0805_120R120RIC9R143; R356; R357; R361; R362; R364; R371; R379; R380
R0805R_R0805_249R 0.1%249R 0.1%IC10R276; R277; R278; R279; R280; R281; R282; R283; R290; R293
R2512R_R2512_10MR 1%10mR 1%IC2R7; R15
REX3SREX3S_REX3S_ZIGBEE_REX3SZIGBEE_REX3SIC1MOD2
SC70-6_DCK6SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKIC9U7; U8; U9; U31; U65; U66; U67; U72; U74
SLP2510P8RCLAMP0524P.TCT_SLP2510P8_RCLAMRCLAMP0524P.TCTIC1U75
SMADIODE SCHOTTKY_SMA_MBRA340T3GMBRA340T3GIC7D1; D2; D4; D5; D8; D9; D10
SMADIODE SCHOTTKY_SMA_SS14SS14IC2D7; D20
SMBDIODE TVS BI-DIR_SMB_P6SMB33AP6SMB33AIC2D3; D6
SMBDIODE TVS UNI-DIR_SMB_P6SMB33AP6SMB33AIC3D14; D15; D16
SMBDIODE TVS UNI-DIR_SMB_P6SMB6.8AP6SMB6.8AIC3D21; D23; D24
SMBDIODE TVS BI-DIR_SMB_P6SMB6.8CAP6SMB6.8CAIC1D22
SMD_3225OSCILLATOR SMD 4PIN_SMD_3225_5050MHzIC1OSC1
SMD_3225CRYSTAL SMD 4PIN_SMD_3225_30MHZ30MHzIC1Y1
SO5_OPTOCOUPLERTLP155E_SO5_OPTOCOUPLER_TLP155ETLP155EIC3U87; U88; U89
SO8SLVU2.8-4_SO8_SLVU2.8-4SLVU2.8-4IC1U13
SO16_OPTOCOUPLERTLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)IC9U36; U37; U43; U44; U49; U50; U55; U56; U60
SOD-523DIODE_SOD-523_1N41481N4148IC7D11; D27; D28; D29; D34; D35; D36
SOIC8_D8FDS4935A_SOIC8_D8_FDS4935AFDS4935AIC3Q1; Q2; Q3
SOIC8_D8FDS6982_SOIC8_D8_FDS6982FDS6982IC1Q4
SOIC8_D8FDS8433A_SOIC8_D8_FDS8433AFDS8433AIC2U2; U6
SOIC8_D8ADR02AR_SOIC8_D8_ADR02ARADR02ARIC1U64
SOIC8_D8AD8531AR_SOIC8_D8_OP07DRZOP07DRZIC2U70; U71
SOIC16_D16AD7888BR_SOIC16_D16_AD7888BRAD7888BRIC1U68
SOIC16_DW16ISO1176DW_SOIC16_DW16_ISO1176DWISO1176DWIC1U17
SON8_DDA8TPS5430DDA_SON8_DDA8_TPS5430DDATPS5430DDAIC3U3; U4; U5
SOT23MOSFET N SOT_SOT23_2N7002K2N7002KIC8Q10; Q11; Q12; Q15; Q16; Q22; Q23; Q24
SOT23-3_DBZ3MMBT3904/SOT_1_SOT23-3_DBZ3_MMBMMBT3904IC3Q5; Q18; Q19
SOT23-3_DBZ3PESD2CAN_SOT23-3_DBZ3_PESD2CANPESD2CANIC2U18; U19
SOT23-3_DBZ3PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTIC8U21; U23; U25; U26; U29; U30; U33; U34
SOT23-3_DBZ3PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTIC16U38; U39; U40; U41; U45; U46; U47; U48; U51; U52; U54; U57; U58; U59; U61; U62
SOT23-3_DBZ3PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTIC10U77; U78; U79; U80; U81; U82; U83; U84; U85; U86
SOT23-3_DBZ3PESD24VL2BT_SOT23-3_DBZ3_PESD24PESD24VL2BTIC2U90; U91
SOT23-6_DBV6TMP100_SOT23-6_DBV6_TMP100TMP100IC1U14
SOT143BPRTR5V0U2X_SOT143B_PRTR5V0U2XPRTR5V0U2XIC2U11; U76
SOT346MOSFET P SOT_SOT346_AO3415AO3415IC2Q20; Q21
SOT353PESD5V0L4UG_SOT353_PESD5V0L4UGPESD5V0L4UGIC3U15; U16; U73
TP30TEST POINT_TP30_TP30TP30IC3TP1; TP6; TP7
TQFP48_PFB48UPD720114_TQFP48_PFB48_UPD72011uPD720114IC1U10
TSSOP14AD5025BRUZ_TSSOP14_AD5025BRUZAD5025BRUZIC1U69
TSSOP16_PW16MAX3232EIPW_TSSOP16_PW16_MAX323MAX3232EIPWIC4U20; U24; U28; U32
TSSOP16_PW16SN74LV4051APW_TSSOP16_PW16_SN74SN74LV4051APWIC2U22; U27
TSSOP24PCA9539PW_TSSOP24_PCA9539PWPCA9539PWIC2U35; U42
附件:
/ g! B+ r; T, l/ d  d# m. |原理图和PCB文件如下:) K# Z! a% u) z# N
游客,如果您要查看本帖隐藏内容请回复
& x" Z4 M9 k. W
1 j" b' u! i6 X" n$ i5 [4 ~# D
发表于 2023-4-14 18:24 | 只看该作者
看看老方案
+ o- ]2 u( N' u1 P! W* P/ Q1 `
GMT+8, 2025-10-12 14:50 , Processed in 0.171875 second(s), 27 queries , Gzip On.
