作品名:[AD 15][2层] STM32F767IGT6+EPM240T100C5+USB3300+MPU6050+WM8978+LAN8720A 工业多功能控制板PCB和原理图, W' ^; k- t/ t% n: i0 V) D1 A
& R" {% y8 H" V文件描述) |* o/ ^1 c, j) u
1. 作品用途: 工业多功能控制板
7 a# J" H+ O6 u4 ?7 F2. 软件版本:AD 15
8 F0 [' M; ]4 q. v" c3. 层数:2层板5 N9 N3 w+ n7 s3 l
4. 用到的主要芯片:STM32F767IGT6+EPM240T100C5+USB3300+MPU6050+WM8978+LAN8720A/ c% r1 C7 ~. Q% O! ~3 S4 i
5. PCB尺寸:142.5mm*99.7mm
; v5 X; r {) r) Q. O5 b+ h' }2 o. P+ m. \) c+ P
作品截图如下:: \ y+ x6 u+ N! |' b# P- b; X4 n
顶层截图:, T/ r# v; N1 {# u$ _
/ n) q x) R6 K+ u; {7 }1 J7 E
' f8 o- i- z/ w底层截图:
* I* Q' r. G3 \9 Y4 k+ N1 y
y! R, T F% P! r
9 [$ v% R5 O4 w全层截图:1 q8 T: R' l2 b7 a
& R) V/ p8 \8 V: ]/ O5 V+ {
1 m2 {% P$ P( N( d
叠层信息截图如下:* i1 Y1 z ~! ]" J
: F( R/ O+ @- v/ q
b5 [& \7 n! R7 ^& g& cBOM: F, W8 Z' p+ y3 x
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 复位 | bt1 | KEY-3*6*2.5MM_SMD | 1 | 4.7uf | C1, C42, C45 | 0805CAP | 3 | 104 | C2, C3, C4, C5, C7, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C26, C27, C28, C29, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C46, C47, C48, C49, C51, C52, C53, C58, C59, C60, C61, C63, C64, C75, C77, C78, C79, C80, C81, C82, C83, C84, C85, C88, C90, C92, C99, C100, C102, C104, C105, C107, C109, C110, C111, C112, C113 | 0603CAP | 67 | 474 | C6, C8, C9 | 0603CAP | 3 | 22pf | C10, C11, C22, C23, C65, C66 | 0603CAP | 6 | 6pf | C24, C25 | 0603CAP | 2 | 104*2 | C30, C44, C76, C86 | 0603CAP | 4 | 474 | C43, C97, C98 | 0805CAP | 3 | 104*3 | C50 | 0603CAP | 1 | 10 | C54, C55, C56, C57 | 0603CAP | 4 | 10uf | C62, C93, C103, C106, C108 | 0805CAP | 5 | 100uf | C67 | C107 | 1 | 1uf | C68, C69, C70, C71, C72, C73, C74, C87, C89, C91, C94, C101 | 0603CAP | 12 | 1uf*2 | C95 | 0603CAP | 1 | 220pf | C96 | 0603CAP | 1 | BAT54C | D1 | SOT23 | 1 | BAT54A | D2, D3 | SOT23 | 2 | M7 | D4 | V_M7 | 1 | 串口通讯 | DB1 | MSCom-9 | 1 | DC5V | DC1 | DC-005_DIP | 1 | 3V | DC2 | DC_CR1220 | 1 | ADC输入 | J6 | JP6(3 *2)_2.54MM | 1 | GPIO | j3 | JP12(6*2)_2.54MM | 1 | SWDIO | J1 | JP4_2.54MM | 1 | TOUCH | J2 | FPC1.0_4P | 1 | RS485&CAN | J4 | KF301-5P_5.08MM | 1 | OV2640 | J5 | FPC0.5_24PIN | 1 | JTAG | JP1 | JDIP10 | 1 | 10uH | L1, L3, L4 | 0805RES | 3 | L1 | L2 | 0805RES | 1 | 音频输出 | LINE1 | LINE_SMD_5L | 1 | MIC | MIC1 | MIC | 1 | 220 | PR1, PR2 | 8P4R_0603 | 2 | LED | Q1, Q3, Q4 | LED0805 | 3 | TL431 | Q2 | SOT23 | 1 | 1.3V | Q5 | SOT23-5 | 1 | 2.8V | Q6 | SOT23-5 | 1 | VS1838B | Q7 | IR_DIP | 1 | 680 | R1, R78 | 0603RES | 2 | 12k | R2 | 0603RES | 1 | 20k | R3, R6, R7, R16, R22, R23, R24, R36, R39, R48, R50, R51, R80, R81 | 0603RES | 14 | 1k | R4, R9, R12, R13, R14, R20, R43, R57, R59, R63, R68, R69, R71, R73 | 0603RES | 14 | 1M | R5, R10, R11, R41, R42 | 0603RES | 5 | 33 | R8, R15, R21 | 0603RES | 3 | - | R17, R27, R28 | 0603RES | 3 | + | R18, R25, R26 | 0603RES | 3 | 0 | R19, R82 | 0805RES | 2 | 4.7k*2 | R29 | 0603RES | 1 | 4.7k | R30, R44, R83 | 0603RES | 3 | 49.9R | R31, R32, R33 | 0805RES | 3 | 49.9R*4 | R34 | 0805RES | 1 | 20k*2 | R35, R49 | 0603RES | 2 | 510 | R37 | 0603RES | 1 | 510*2 | R38 | 0603RES | 1 | 12.1k | R40 | 0603RES | 1 | 120 | R45, R46 | 0805RES | 2 | 20k*3 | R47 | 0603RES | 1 | 22 | R52, R53, R60, R67, R75 | 0603RES | 5 | 47k | R54, R79 | 0603RES | 2 | 200R | R55, R61, R70 | 8P4R_0603 | 3 | 330R | R56, R62, R72 | 8P4R_0603 | 3 | 3.3k | R58, R64, R66, R74 | 0603RES | 4 | 3.3k*2 | R65 | 0603RES | 1 | 0 | R76, R77 | 0603RES | 2 | 网络通讯 | RJ1 | RJ8-HR911105A | 1 | SD | SD1 | SD | 1 | DHT12 | t1 | DHT12_DIP4 | 1 | LM75A | t2 | SOP8 | 1 | TF | tf1 | TF | 1 | USB3300 | u1 | QFN32 | 1 | NANDFLASH | u2 | TSOP48 | 1 | FLASH | u3 | SOIC8 | 1 | SDRAM | u4 | TSOP54 | 1 | STM32F767IGT6 | u5 | LQFP176 | 1 | LCD | u6 | FPC0.5_40PIN | 1 | XPT2046 | u7 | TSSOP16 | 1 | MPU6050 | u8 | QFN24 | 1 | AT24C02 | u9 | SOP8 | 1 | LAN8720A | u10 | QFN24 | 1 | MAX3232 | u11 | SOP16 | 1 | SN75176 | u12 | SOP8 | 1 | TJA1050 | u13 | SOP8 | 1 | EPM240T100C5 | u14 | LQFP100 | 1 | WM8978 | u15 | QFN32 | 1 | BH1750FVI | u16 | WSOF6I | 1 | BMP180 | u17 | LGA7 | 1 | USB_HS | USB1 | MINI_USB_M_SMD | 1 | USB_HOST | USB2 | 标准USB-母头贴片 | 1 | USB_Slave | USB3 | MINI_USB_M_SMD | 1 | 3.3V | v1 | SOT-223 | 1 | VGA视频输出 | VGA1 | VGA_B | 1 | 24M | Y1 | OSC_49S_DIP | 1 | 12M | Y2 | OSC_49S_DIP | 1 | 32.768khz | Y3 | 32.768k | 1 | 25M | Y4 | OSC_49S_DIP | 1 | ! M: {. s# G4 V2 [9 }
附件:1 O" [: ^1 S! S) |
原理图和PCB源文件如下:: u9 Z" K' w- w9 V
' T( ?) t% b0 [; z5 B) G3 c7 j; X
