查看: 5006|回复: 48
[allegro17.2][6层]mtk手机PCB(FBGA221+MT6735+MT6328)原理图和pcb文件
发表于 2020-1-10 16:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
文件描述:
1. 作品用途:mtk手机PCB
2. 软件版本:allegro17.2
3. 层数:6层
4. 用到的主要芯片:FBGA221+MT6735+MT6328
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
2-1L1B_SMD_SSM3K35MFV2-1L1B_SMD_SSM3K35MFVIC1U2116
ACPF-7141_SMDACPF-7141_SMDIC1U3220
ANT_2P_SMD_P25_3X3ANT_2P_SMD_P25_3X30.1DISCRETE1ANT3611
ANT_2P_SMD_PVT1024ANT_2P_SMD_PVT10240.1DISCRETE11ANT3604; ANT3605; ANT3606; ANT3607; ANT3608; ANT3609; ANT3610; ANT5001; ANT5002; ANT5003; ANT5004
AUDIOJACK_5P_SMD_EJ-3699M-GPAUDIOJACK_5P_SMD_EJ-3699M-GPIC1CON6001
BALUN_SMD_HHM22112A2BALUN_SMD_HHM22112A2IC1U3210
BALUN_SMD_TFSZ06051897-3317A1BALUN_SMD_TFSZ06051897-3317A1IC1U3317
BALUN_SMD_TFSZ06052460-3310A2BALUN_SMD_TFSZ06052460-3310A2IC2U3323; U3410
BAT_SMD_KBC23S3D4XR_KEIRAKUBAT_SMD_KBC23S3D4XR_KEIRAKUIC1CON2101
BEAD0402BEAD04020.1DISCRETE1BEAD5001
BEAD0603BEAD06030.1DISCRETE6BEAD6001; BEAD6002; BEAD6003; BEAD6004; BEAD6005; L6002
C0201C02010.1DISCRETE282C1101; C1102; C1104; C1105; C1106; C2022; C2023; C2030; C2031; C2032; C2033; C2034; C2036; C2041; C2042; C2043; C2044; C2046; C2047; C2048; C2051; C2054; C2056; C2057; C2315; C2323; C2413; C3101; C3102; C3103; C3104; C3105; C3106; C3108; C3109; C3110; C3112; C3116; C3205; C3206; C3207; C3210; C3211; C3215; C3216; C3217; C3222; C3223; C3225; C3226; C3228; C3233; C3241; C3242; C3243; C3244; C3245; C3248; C3249; C3250; C3251; C3252; C3254; C3255; C3256; C3257; C3258; C3259; C3260; C3261; C3262; C3263; C3264; C3265; C3271; C3272; C3273; C3276; C3285; C3286; C3288; C3289; C3290; C3291; C3302; C3303; C3304; C3307; C3310; C3311; C3312; C3313; C3314; C3315; C3316; C3317; C3318; C3321; C3323; C3324; C3325; C3327; C3328; C3330; C3331; C3334; C3335; C3336; C3340; C3341; C3342; C3343; C3344; C3348; C3349; C3352; C3353; C3361; C3362; C3383; C3401; C3405; C3407; C3412; C3413; C3414; C3415; C3416; C3417; C3418; C3419; C3420; C3421; C3432; C3433; C3434; C3435; C3436; C3438; C3439; C3447; C3453; C3454; C3455; C3456; C3457; C3458; C3459; C3499; C3703; C3705; C3707; C3709; C3710; C3801; C3802; C3805; C3806; C3807; C3808; C3901; C3902; C3903; C3904; C3906; C3909; C3910; C3912; C3913; C3915; C3916; C4102; C4105; C4106; C4107; C4108; C4109; C4110; C4112; C4114; C4115; C4116; C5001; C5002; C5004; C5005; C5007; C5008; C5009; C5012; C5013; C5014; C5015; C5016; C5116; C5120; C5121; C5123; C5125; C6007; C6008; C6012; C6013; C6015; C6016; C6019; C6020; C6021; C6023; C6024; C6025; C6031; C6032; C6034; C6035; C6038; C6039; C6101; C6106; C6107; C6201; C6202; C6205; C6206; C6207; C6210; C6303; C6304; C6305; C6306; C6308; C6313; C6314; C6315; C6501; C6502; C6503; C6601; C9001; C10005; C10010; C10018; C10025; C10027; C10035; C10037; C10039; C10052; C10053; C10059; C10060; C10062; C10064; C10068; C10069; C10070; C10071; C10072; C10073; C10076; C10077; C10078; C10082; C10083; C10084; C10085; C10086; C10088; C10089; C10090; C10091; C10092; C10093; C10094; C10095; C10096; C10097; C10098; C10099; C10100; L3301; L3433
C0402C04020.1DISCRETE73C1103; C2011; C2012; C2013; C2014; C2015; C2016; C2017; C2018; C2019; C2020; C2027; C2038; C2055; C2058; C2312; C2320; C2322; C2402; C2403; C2412; C3601; C3602; C3603; C3604; C3702; C3704; C3706; C3905; C3907; C3908; C3911; C3914; C4001; C4101; C4103; C4104; C4111; C4113; C5003; C5006; C5011; C5017; C5101; C5102; C5104; C5105; C5106; C5107; C5108; C5109; C5110; C5111; C5112; C5115; C5117; C5119; C5122; C5124; C5126; C6203; C6204; C6310; C10004; C10007; C10016; C10017; C10046; C10047; C10075; C10079; C10080; C10087
C0603C06030.1DISCRETE16C2007; C2008; C2039; C2040; C2101; C2319; C2411; C3239; C3339; C10008; C10009; C10012; C10040; C10065; C10066; C10067
C0805C08050.1DISCRETE3C10006; C10036; C10038
CABLE_CLIP_3P_SMD_PCV1003CABLE_CLIP_3P_SMD_PCV1003IC2SC9185; SC9186
CAMERA_MODULE_30P_SMD_CM9156-B1300BA-ECAMERA_MODULE_30P_SMD_CM9156-B1300BA-EIC1CON6201
CAMERA_MODULE_30P_SMD_Q5V22K-0JGCAMERA_MODULE_30P_SMD_Q5V22K-0JGIC1CON6202
CITIZENLS10_BOSSCITIZENLS10_BOSSIC3CON6503; CON6504; CON6505
COAXIAL_SMD_TA-RF02-001-03-811COAXIAL_SMD_TA-RF02-001-03-811IC2CON3303; CON3601
CON5X2_SMD_P0_4_F_AXE510127CON5X2_SMD_P0_4_F_AXE510127IC1CON6101
CON15X2_SMD_F_P0_4_24-5804-030-000-829HTCON15X2_SMD_F_P0_4_24-5804-030-000-829HTIC1CON6102
CON20X2_SMD_M_AXT640124_FPCCON20X2_SMD_M_AXT640124_FPCIC1CON9001
CRYS_SMD_3_2X1_5_9H032000XX_TXCCRYS_SMD_3_2X1_5_9H032000XX_TXC0.1DISCRETE1X2001
CRYS_SMD_FA-128CRYS_SMD_FA-128IC1X5101
DIODE_SMD_MMSZ5221BDIODE_SMD_MMSZ5221B0.1DISCRETE1D2103
DIPLEXER_6P_SMD_FI212P0829G2DIPLEXER_6P_SMD_FI212P0829G2IC1DIPX3801
DSBGA9_P0_4_B0_225_LM3242DSBGA9_P0_4_B0_225_LM3242IC1U3901
DSBGA9_SMD_P0_5_LM3642DSBGA9_SMD_P0_5_LM3642IC1U2301
DUPLEXER_8P_SMD_SAYEY710MBA0F0ADUPLEXER_8P_SMD_SAYEY710MBA0F0AIC5U3301; U3306; U3308; U3309; U3313
FBGA221_P0_5_B0_27_11_5X13_SAMSUNGFBGA221_P0_5_B0_27_11_5X13_SAMSUNGIC1U4102
FDFDIC5FM9101; FM9102; FM9103; FM9104; FM9105
FILTER_SMD_885049FILTER_SMD_885049IC1U3215
FILTER_SMD_ACPF-7124FILTER_SMD_ACPF-7124IC1U5005
FILTER_SMD_FI-168L083523-TFILTER_SMD_FI-168L083523-TIC1LPF3801
FILTER_SMD_LFB212G49CG7D755FILTER_SMD_LFB212G49CG7D755IC1U3216
FILTER_SMD_LFD211G57ME3FILTER_SMD_LFD211G57ME3IC1F5001
FILTER_SMD_SPU0410HR5H-PBFILTER_SMD_SPU0410HR5H-PBIC2MIC6002; MIC6003
FLASH_LED_LUW_F8DNFLASH_LED_LUW_F8DN0.1DISCRETE1LED2302
H2_SMD_P0_8_SM02B-SURS-TF_SURH2_SMD_P0_8_SM02B-SURS-TF_SURIC1CON6601
H6_SMD_P0_5_FH34S-06S-0_5SHH6_SMD_P0_5_FH34S-06S-0_5SHIC1CON6301
L0201L02010.1DISCRETE99C3460; L3206; L3207; L3209; L3210; L3211; L3213; L3214; L3215; L3217; L3218; L3219; L3221; L3222; L3223; L3234; L3238; L3302; L3303; L3304; L3305; L3308; L3309; L3310; L3311; L3312; L3313; L3314; L3315; L3316; L3317; L3318; L3322; L3328; L3329; L3330; L3331; L3332; L3333; L3334; L3335; L3336; L3337; L3338; L3340; L3341; L3342; L3343; L3344; L3346; L3347; L3350; L3351; L3401; L3402; L3403; L3409; L3410; L3411; L3412; L3413; L3414; L3415; L3416; L3417; L3418; L3421; L3429; L3430; L3431; L3437; L3439; L3440; L3441; L3442; L3443; L3444; L3445; L3499; L3801; L3802; L3803; L3804; L3805; L3806; L3815; L3819; L3820; L3821; L3822; L3901; L5005; L5006; L5007; L5008; L5009; L5010; L5011; L5012
L0402L04020.1DISCRETE15L3601; L3602; L3603; L3605; L3606; L3607; L3608; L3609; L3610; L3611; L3612; L3816; L5002; L5003; L5004
LED190LED1900.1DISCRETE1D6301
LGA12_SMD_P0_5_MC3410LGA12_SMD_P0_5_MC3410IC1U6303
L_CHOKE_SMD_DLP0NS0806L_CHOKE_SMD_DLP0NS0806IC5EMI6101; EMI6102; EMI6103; EMI6104; EMI6105
L_CHOKE_SMD_LQH3NPL_CHOKE_SMD_LQH3NP0.1DISCRETE1PL2303
L_IND_SMD_0603L_IND_SMD_06030.1DISCRETE2L5101; L5102
L_IND_SMD_2016L_IND_SMD_20160.1DISCRETE1L2009
L_IND_SMD_2520L_IND_SMD_25200.1DISCRETE3L2001; L2401; PL2305
L_IND_SMD_LQM21PNR54MG0L_IND_SMD_LQM21PNR54MG00.1DISCRETE1PL3901
L_IND_SMD_VLS201610EL_IND_SMD_VLS201610E0.1DISCRETE4L2003; L2006; L2008; L2402
MICROSD_8P_SMD_TA-M017-012-07-811MICROSD_8P_SMD_TA-M017-012-07-811IC1CON4001
MICROUSB_5P_SMD_P0_65_R_KIU90511S1RMICROUSB_5P_SMD_P0_65_R_KIU90511S1RIC1CON6401
MM8130-2602MM8130-2602IC2CON3301; CON3802
MM8430-2600BMM8430-2600BIC1CON5001
MT6158_VFBGA91_P0_4_B0_25_4_2X4_2MT6158_VFBGA91_P0_4_B0_25_4_2X4_2IC1U3701
MT6169_VFBGA175_P0_4_B0_25_6_2X5_4MT6169_VFBGA175_P0_4_B0_25_6_2X5_4IC1U3101
MT6328_VFBGA206_P0_4_B0_25_6_6X6_6MT6328_VFBGA206_P0_4_B0_25_6_6X6_6IC1U2001
MT6605_MQFN32_SMD_P0_4_4X4_SMT6605_MQFN32_SMD_P0_4_4X4_SIC1U5101
MT6625_SQFN40_SMD_P0_4_5X5MT6625_SQFN40_SMD_P0_4_5X5IC1U5001
MT6735_VFBGA641_P0_4_B0_25_12_6X12_6MT6735_VFBGA641_P0_4_B0_25_12_6X12_6IC1U1001
NC_MMD_L1_4MILNC_MMD_L1_4MIL0.1DISCRETE21R1037; R2138; R2139; R2140; SH1001; SH1002; SH1003; SH1004; SH1005; SH1006; SH5103; SH5106; SH5107; SH5108; SH5112; SH5113; SH5114; SH5115; SH5116; SH5117; SH5118
NC_RNC_R0.1DISCRETE2SH6003; SH6004
PAD_1P_R2_2PAD_1P_R2_2IC2ANT5101; ANT5102
QFN16_SMD_P0_5_ITG-1010QFN16_SMD_P0_5_ITG-1010IC1U6302
R0201R02010.1DISCRETE97NTC6302; R1007; R1011; R1101; R1103; R1105; R1106; R1109; R1201; R1202; R1203; R1204; R1205; R1206; R1207; R1208; R1209; R1227; R2002; R2003; R2005; R2026; R2030; R2034; R2310; R2404; R2406; R2407; R2416; R2417; R3101; R3102; R3103; R3105; R3107; R3108; R3201; R3209; R3210; R3214; R3226; R3230; R3231; R3232; R3301; R3302; R3305; R3306; R3327; R3328; R3333; R3334; R3701; R3702; R3703; R3704; R3712; R3714; R3716; R3717; R3718; R3719; R3732; R3801; R3802; R3804; R3813; R3815; R3817; R3818; R3819; R3902; R3903; R3904; R3907; R3908; R3910; R3911; R4103; R4104; R5005; R5006; R5007; R5013; R5014; R5016; R5108; R5130; R6006; R6007; R6011; R6029; R6211; R6507; R6508; R6509; R6510
R0201_1-2R0201_1-2IC1R5001
R0402R04020.1DISCRETE68NTC3701; NTC6301; R2032; R2033; R2103; R2192; R2308; R2316; R2320; R2405; R3220; R3224; R3234; R3278; R3380; R3601; R3602; R3603; R3604; R3605; R3606; R3607; R3608; R3609; R3610; R3611; R3612; R3613; R3614; R3615; R3616; R3617; R3618; R3619; R3622; R3624; R3625; R3626; R3627; R3628; R3629; R3630; R3631; R3709; R3713; R3715; R3905; R3906; R5004; R5101; R5102; R5103; R5104; R5105; R5116; R5128; R5129; R6002; R6005; R6012; R6207; R6212; R6314; R6350; R6351; R6352; R6501; R6504
R0603R06030.1DISCRETE4R1005; R1021; R3901; R3909
R0805R08050.1DISCRETE2R2135; R3239
R1206R12060.1DISCRETE1R2137
RB160M-30-EVBRB160M-30-EVB0.1DISCRETE1D2301
RECEIVE_SMD_NXPRECEIVE_SMD_NXP0.1DISCRETE1REC6001
RF1141ARF1141AIC2U3601; U3602
RF1628RF1628IC2U3302; U3401
RF7255RF7255IC1PA3901
SAWFILTER_SMD_F6QB2G595P2BSSAWFILTER_SMD_F6QB2G595P2BSIC9U3322; U3403; U3404; U3406; U3407; U3408; U3411; U3412; U3414
SAWFILTER_SMD_SAWFD1G90BH0F0ASAWFILTER_SMD_SAWFD1G90BH0F0AIC1U3305
SAW_8P_SMD_D2_0X1_6_SAYFH833MCA0F00SAW_8P_SMD_D2_0X1_6_SAYFH833MCA0F00IC1DPX3802
SAW_SMD_1_05X1_35SAW_SMD_1_05X1_35IC1U5003
SB_0201SB_02010.1DISCRETE22R1036; R1102; R2403; R4101; R4102; R5003; R5008; R5015; R6023; R6024; R6025; R6026; R6027; R6028; R6030; R6307; R6308; R6318; R6601; SH4101; SH5001; SH5002
SB_0402SB_04020.1DISCRETE55L6001; R1004; R1008; R1009; R1012; R1013; R1014; R1016; R1018; R1022; R1023; R1026; R1027; R1028; R1029; R1030; R1031; R1035; R2039; R2040; R2041; R2042; R2043; R2044; R2045; R2046; R2048; R2105; R2408; R4001; R6003; R6004; R6021; R6022; R6104; R6105; R6201; R6202; R6203; R6204; R6205; R6206; R6209; R6311; R6313; SH2014; SH5101; SH5102; SH5104; SH5105; SH5109; SH5110; SH5111; SH6501; SH6502
SB_0603SB_06030.1DISCRETE12R2036; R2037; R2047; R2098; R2099; R6019; R6020; SH2009; SH2010; SH2011; SH2012; SH2013
SHIELD_CAN_CLIP_3P_SMD_PTV3121NSHIELD_CAN_CLIP_3P_SMD_PTV3121NIC30SC9128; SC9129; SC9130; SC9131; SC9132; SC9133; SC9134; SC9135; SC9136; SC9137; SC9145; SC9146; SC9147; SC9148; SC9149; SC9150; SC9151; SC9152; SC9161; SC9162; SC9163; SC9164; SC9165; SC9166; SC9167; SC9168; SC9169; SC9170; SC9171; SC9172
SHIELD_CAN_CLIP_PTV0703BSHIELD_CAN_CLIP_PTV0703BIC33SC9101; SC9102; SC9103; SC9104; SC9105; SC9106; SC9107; SC9108; SC9109; SC9110; SC9111; SC9112; SC9113; SC9114; SC9115; SC9116; SC9117; SC9118; SC9119; SC9120; SC9121; SC9138; SC9139; SC9140; SC9141; SC9142; SC9153; SC9154; SC9155; SC9156; SC9157; SC9158; SC9159
SIM_10P_SMD_SCGD1B0307SIM_10P_SMD_SCGD1B0307IC2CON6501; CON6502
SKY13418SKY13418IC1U3402
SKY13489SKY13489IC2U3603; U3604
SKY77643SKY77643IC1U3203
SKY77910SKY77910IC1U3307
SOD882_SMD_PESD5V0S1BLSOD882_SMD_PESD5V0S1BL0.1DISCRETE2VR2101; VR2102
SON6_SMD_P0_65_TPS61161SON6_SMD_P0_65_TPS61161IC1U2305
SOT-6SOT-6IC1U2106
SPEAKER_SMD_2403-260-00071SPEAKER_SMD_2403-260-000710.1DISCRETE1SPK6001
TCXO3225TCXO3225IC1X3701
TCXO_SMD_2_5X2_0_IT2205BETCXO_SMD_2_5X2_0_IT2205BEIC1U5002
TCXO_SMD_2_5X2_0_KT2520FTCXO_SMD_2_5X2_0_KT2520FIC1U3102
TP30MILTP30MILIC3TP3601; TP3602; TP3603
TP_SMD_12MILTP_SMD_12MILIC32TP2015; TP2016; TP2029; TP3701; TP3702; TP3703; TP3704; TP3705; TP3706; TP3707; TP3708; TP3709; TP3710; TP3711; TP3712; TP3713; TP3714; TP3715; TP3716; TP3717; TP3718; TP3719; TP3720; TP3801; TP3802; TP3901; TP3902; TP3903; TP3904; TP3905; TP5101; TP5102
TSLP6_SMD_P0_4_BGA725L6_STSLP6_SMD_P0_4_BGA725L6_SIC1U5004
UQFN20_SMD_P0_4_CXM3599URUQFN20_SMD_P0_4_CXM3599URIC1U3801
VMT3_SMD_RUM003N02VMT3_SMD_RUM003N02IC2Q6301; Q6302
WDFN8_SMD_P0_5_NCP6324WDFN8_SMD_P0_5_NCP6324IC1U2401
WLCSP6_P0_4_B0_2_FAN53611WLCSP6_P0_4_B0_2_FAN53611IC1U2402
WLCSP8_SMD_P0_4_B0_25_AK09911WLCSP8_SMD_P0_4_B0_25_AK09911IC1U6301
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
- N3 x$ r4 C; Z3 A# w
推荐
发表于 2020-9-9 10:17 | 只看该作者
你这是原生的Allegro还是pads转过来的,17.2打不开。( _, |9 R" n* f
楼主能否降下版本。
推荐
发表于 2025-9-7 10:54 | 只看该作者
学习学习学习学习学习学习学习学习学习学习
    奋斗
    2024-1-17 15:33
  • 签到天数: 23 天
    [LV.4]偶尔看看III
    推荐
    发表于 2020-11-5 16:52 | 只看该作者
    学习学习学习学习学习学习学习学习学习学习- O( x# u- D' t) X4 `# ?2 f9 J$ d  [
    发表于 2020-5-26 16:07 | 只看该作者
    学习参考一下子
    1 Q* r7 \9 ^% ^+ Q- g
    2020-5-19 15:01
  • 签到天数: 12 天
    [LV.3]偶尔看看II
    发表于 2020-7-23 12:25 | 只看该作者
    更好的活动活动回顾回顾
    2024-8-26 15:16
    发表于 2020-8-5 17:09 | 只看该作者
    好不错,下载看看
    , ]9 k8 m& H& X
    发表于 2020-8-27 17:22 | 只看该作者
    看到图很不错,来学习学习
    % A& x; }5 C) f& @
    发表于 2020-9-1 23:30 | 只看该作者
    学习参考一下子
    发表于 2020-9-1 23:44 | 只看该作者
    学习参考一下子
    发表于 2020-9-8 19:36 | 只看该作者
    下载看看,谢谢。* m& v, R2 V& I0 {- |; g
    14#
    发表于 2020-9-28 12:10 | 只看该作者
    你好,怎么才能下载呢
    GMT+8, 2025-10-10 03:33 , Processed in 0.187500 second(s), 29 queries , Gzip On.
