一个简单的电机与驱动PID算法4 o* r+ [* G( F# k% X3 E/ R2 s, V
& H7 f5 c" W7 uPID
/ ~: ~! m: ~: V; g3 G+ B; C# Z' l7 \ C8 M. e6 j7 n# x
- #include <hidef.h> /* common defines and macros */
- #include "derivative.h" /* derivative-specific definitions */
- #include <mc9s12xs128.h>
- //定义PID参数
- #define VV_KPVALUE 3 //比例
- #define VV_KIVALUE 40 //积分
- #define VV_KDVALUE 3 //微分
- #define VV_MAX 10000 //返回的最大值,是pwm的周期值
- #define VV_MIN 0
- #define VV_DEADLINE 0X08 //速度PID,设置死区范围
- typedef struct PID //定义数法核心数据
- signed int vi_Ref; //速度PID,速度设定值
- signed int vi_FeedBack; //速度PID,速度反馈值
- signed long vi_PreError; //速度PID,前一次,速度误差,,vi_Ref - vi_FeedBack
- signed long vi_PreDerror; //速度PID,前一次,速度误差之差,d_error-PreDerror;
- unsigned int v_Kp; //速度PID,Ka = Kp
- unsigned int v_Ki; //速度PID,Kb = Kp * ( T / Ti )
- unsigned int v_Kd; //速度PID,
- signed long vl_PreU; //电机控制输出值
- }PID;
- PID sPID; // PID Control Structure
- void PIDInit(void)
- sPID.vi_Ref = 0 ; //速度设定值
- sPID.vi_FeedBack = 0 ; //速度反馈值
- sPID.vi_PreError = 0 ; //前一次,速度误差,,vi_Ref - vi_FeedBack
- sPID.vi_PreDerror = 0 ; //前一次,速度误差之差,d_error-PreDerror;
- sPID.v_Kp = VV_KPVALUE;
- sPID.v_Ki = VV_KIVALUE;
- sPID.v_Kd = VV_KDVALUE;
- sPID.vl_PreU = 0 ; //电机控制输出值
- unsigned int v_PIDCalc( PID *pp )
- signed long error,d_error,dd_error;
- error = (signed long)(pp->vi_Ref - pp->vi_FeedBack); // 偏差计算
- d_error = error - pp->vi_PreError;
- dd_error = d_error - pp->vi_PreDerror;
- pp->vi_PreError = error; //存储当前偏差
- pp->vi_PreDerror = d_error;
- if( ( error < VV_DEADLINE ) && ( error > -VV_DEADLINE ) ); //设置调节死区
- //速度PID计算
- pp->vl_PreU += (signed long)( pp -> v_Kp * d_error + pp -> v_Ki * error + pp->v_Kd*dd_error);
- else if( pp->vl_PreU >= VV_MAX ) //速度PID,防止调节最高溢出
- pp->vl_PreU = VV_MAX;
- else if( pp->vl_PreU <= VV_MIN ) //速度PID,防止调节最低溢出
- pp->vl_PreU = VV_MIN;
- else
- return ( pp->vl_PreU ); // 返回预调节占空比
- void main(void) {
- /* put your own code here */
- Initmcu();
- IncPIDInit();
- int g_CurrentVelocity=0; //全局变量也初始化
- int g_Flag=0; //全局变量也初始化
- EnableInterrupts;
- While(1)
- if (g_Flag&&vi_FeedBack)
- PWMOUT+= v_PIDCalc( PID *pp );
- g_Flag&=~ vi_FeedBack;
- for(;;) {
- _FEED_COP(); /* feeds the dog */
- } /* loop forever */
- /* please make sure that you never leave main */
4 e" f9 U1 o% e. W ! b' D, d4 h8 M' w+ J9 [, }
( b! s) m0 [) m/ @, c3 q
: W1 o" j1 h: f- T! y
$ r" P. c- |- F2 A& `% R5 _
# _; g0 @ j+ E7 l' j; f% N
