查看: 480|回复: 0
[Pads VX.2x.2x][4层]HI3536挂一个DDR3 +RTL8211EG+TLV320AIC31
发表于 2020-1-7 09:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:
[pads VX.2x.2x][4层]HI3536挂一个DDR3 +RTL8211EG+TLV320AIC31
文件描述
1 功能描述:
2 软件版本:Pads VX.2x
3. 层数:4层板
4 用到的主要芯片:DDR3 +RTL8211EG+TLV320AIC31
5  PCB板尺寸:  50mm*95mm
' W' r8 R2 D  Q) R3 T
8 \/ }) I. _1 W  g0 K) a2 b* N$ v( `9 [
顶层
& |8 m4 S' o) M: Q; |
底层
, L/ z+ g& z( w% x+ j3 d
全层
$ a' z+ o( V; K; w: f9 \  ~  `
) z( ]: a: S; S2 d) t* z
BOM
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C4SC1210B22UF
C5SC1210B22UF
C6SC080522UF
C7SC0402100NF
C9SC080510UF
C11SC0402100NF
C13SC12061NF
C14SC0402100NF
C16SC0402-BGA4.7UF
C17SC080522UF
C18SC0402100NF
C19SC0402220NF
C20SC0402220NF
C21SC0402100NF
C22SC0402100NF
C23SC0402100NF
C24SC0402100NF
C25SC0402100NF
C26SC0402100NF/NC
C27SC0402-BGA2.2UF
C28SC0402100NF
C31SC0402100NF
C32SC0402
C33SC0402100NF
C34SC0402100NF
C35SC0402100NF
C36SC0402100NF
C37SC0402100NF/NC
C38SC0402100NF
C39SC0402100NF
C40SC0402100NF
C41SC0402100NF
C42SC0402100NF
C43SC0402100NF
C44SC0402100NF
C45SC060310UF
C46SC0402100NF
C47SC0402-BGA2.2UF
C48SC06034.7UF
C49SC0402100NF
C50SC060310UF
C51SC0402-BGA100NF
C52SC040222NF
C53SC04024.7UF
C54SC0402-BGA100NF
C55SC0402-BGA100NF
C57SC0402100NF
C58SC04021NF
C60SC0402-BGA100NF
C61SC060310UF
C62SC060310UF
C63SC0402100NF
C64SC0402100NF
C65SC06034.7UF
C66SC06034.7UF
C67SC04021NF
C68SC060333PF
C69SC04021UF
C70SC04021UF
C71SC04021UF
C72SC0402100NF
C73SC04021UF
C74SC04022.2UF
C75SC0402100NF
C76SC0402100NF
C79SC04021NF
C80SC04021NF
C81SC0402100NF
C82SC0402100NF
C83SC0402100NF
C89SC0402100NF
C90SC0402100NF
C91SC0402100NF
C92SC0805B47UF
C93SC0805B47UF
C126SC0402-BGA100NF
C128SC0402-BGA1UF
C131SC0402-BGA100NF
C133SC0402-BGA100NF
C134SC0402-BGA100NF
C135SC0402-BGA470NF
C136SC0402-BGA100NF
C137SC0402-BGA1UF
C138SC04021NF
C140SC0402-BGA1UF
C141SC0402-BGA1UF
C142SC0402-BGA1UF
C143SC0603100NF
C145SC0402-BGA1UF
C150SC0603100NF
C151SC0402100NF
C161SC0402-BGA1UF
C163SC0402-BGA2.2UF
C167SC080510UF
C168SC0402100NF
C186SC0402100NF
C188SC0402-BGA100NF
C192SC0402-BGA1UF
C193SC1210B22UF
C204SC0402-BGA10NF
C205SC0402-BGA10NF
C206SC0402-BGA10NF
C207SC0402-BGA10NF
C210SC0402-BGA470NF
C212SC0402-BGA1UF
C213SC0402-BGA1UF
C214SC0402-BGA100NF
C215SC0402-BGA1UF
C225SC04022.2UF
C226SC04022.2UF
C227SC040227PF
C228SC040227PF
C234SC120647UF
C238SC0402100NF
C240STC3528-1220UF
C241SC040218PF
C246SC080522UF
C247SC080522UF
C249SC060310UF
C263SC0402100NF
C266SC0402-BGA1UF
C271SC0402-BGA1UF
C272SC0402-BGA1UF
C273SC0402-BGA1UF
C289SC0402-BGA1UF
C290SC0402-BGA2.2UF
C310SC080522UF
C312SC120647UF
C1179SC1210B22UF
C1182SC0402-BGA2.2UF
C1187SC0402-BGA2.2UF
C1188SC0402-BGA100NF
C1191SC0402-BGA100NF
C1192SC0402-BGA1UF
C1195SC0402-BGA1UF
C1198SC0402-BGA1UF
C1200SC0402-BGA1UF
C1201SC0402-BGA1UF
C1206SC0402-BGA1UF
C1207SC0402-BGA1UF
C1210SC0402-BGA1UF
C1212SC0402-BGA1UF
C1241SC0402-BGA4.7UF
C1242SC0402-BGA1UF
C1245SC0402-BGA4.7UF
C1249SC0402-BGA100NF
C1253SC0402-BGA1UF
C1285SC060310UF
C1286STC3528-1100NF
C1287STC3528-1100NF
C1288SC0402
C1289SC0402100NF
C1290STC3528-1
C1291SC060310UF
D4HSOD882DZ_L
D5HSOD882DZ_L
D10HSOD882DZ3
D11HSOD882DZ_L
D15HSOD323AD_A
D16HSOD882DZ_L
D17HSOD882DZ3
D18SD1710ADZ3
D19SD0805-LEDLED
D20HSOD882DZ3
D21HSOD882DZ3
D22SD1714DDZ3
D23SD0805-LEDLED
D31SD1714A
D32HSOD882DZ_L
D33HSOD882DZ_L
D34HSOD882DZ_L
D35HSOD882DZ_L
D36HSOD882DZ_L
D37SD0805-LED
D38SD0805-LED
D39SD0805-LED
D40SD0805-LED
D41HSOD882DZ_L
D42HSOD882DZ_L
ID1ID-BOARDNC
ID2ID-BOARDNC
ID3ID-BOARDNC
ID4ID-BOARDNC
J3SIP-1PNC
J4SIP-1PNC
J5SIP-1PNC
J6SIP-1PNC
J10SATA7-M-ASIP7M2
J16MOLEX_47151DB19S4
J37DIP-4PIN-2.0MM-1
J38DIP-4PIN-2.0MM-1
J39DIP-2PIN-2.0MM
J40DIP-2PIN-2.0MM
J41DIP-5PIN-2.0MM
J43DIP-6PIN-2.0MMMIC6M1_B
J44DIP-3PIN-2.0MM
J45DIP-2PIN-2.0MMMIC6M1_B
J47SMD-6PIN-1.25MMUSB-4S4
J48SMD-8PIN-1.25MMUSB-4S4
J49SMD-4PIN-1.25MM
J50SMD-4PIN-1.25MM
L1SPL0505H4.7U
L2SL10081UH
L3SPL0404L2.2UH
L4SL28284.7UH
L9HSL1008D2.2U
L10HSL10082.2UH
LB1SL0805LB
LB2SL0805LB
LB3SL0805LB
LB4SL0805LB
LB5SL0402LB
LB6SL0402LB
LB9SL0805LB
LB10SL0402LB
LB11SL0402LB
LB12SL0402LB
LB18SL0402LB
LB21SL0402LB
LB74SL0402LB
LB79SL0402LB
LB80SL0402LB
LB83SL0402LB
LB94SL0402LB
LB96SL0402LB
M1MTH_C40MMD3P2MMNC
M2MTH_C40MMD3P2MMNC
M3MTH_C40MMD3P2MMNC
M4MTH_C40MMD3P2MMNC
OSC2HSX4-0302B25MHZ
Q6309SOT-23
R3SR04020
R4SR040282K
R6SR04021K
R7SR04021K
R8SR04020
R9SR040210K
R10SR04027.68K
R11SR040233
R12SR040233
R21SR040233
R22SR040233
R23SR040222
R24SR04021MEG
R25SR040222
R26SR040233
R27SR040210K
R28SR040220K
R29SR04020
R30SR040210K
R31SR040233
R33SR04020/NC
R34SR04020
R35SR04020/NC
R36SR04020
R37SR040233
R38SR040210K
R39SR04022K
R40SR04020
R41SR0402270
R42SR0402270
R43SR04025.1K/NC
R44SR04020
R46SR04021K
R47SR060310K/NC
R48SR040210K
R49SR040210K
R51SR04020
R54SR040275
R56SR04022K
R58SR04020
R59SR04020/NC
R60SR040212K
R61SR04020
R62SR04021K/NC
R63SR040210K
R64SR040275
R65SR040222
R67SR04021.5K
R68SR0402510
R69SR0402
R70SR040290.9K
R71SR04024.7K/NC
R72SR0402100K
R73SR04022.49K
R76SR04024.7K
R77SR040233
R80SR04024.7K/NC
R81SR04024.7K
R82SR04024.7K
R83SR04024.7K
R84SR04024.7K
R85SR04024.7K
R86SR04024.7K
R87SR04024.7K
R88SR04024.7K
R89SR04024.7K/NC
R90SR04024.7K
R91SR04024.7K
R92SR04024.7K
R93SR04024.7K
R94SR0402100K
R95SR04020
R96SR04020
R97SR04020
R98SR040282K
R99SR040220K
R100SR04020/NC
R101SR040211.3K
R103SR060310
R105SR04021K
R106SR04021K
R107SR04021K
R108SR060310
R109SR06031.1K
R112SR06031.1K
R113SR04024.7K
R114SR04024.7K
R115SR0402100K
R120SR0402100K
R121SR040218K
R122SR040213.7K
R124SR06030
R125SR06030
R127SR04021K
R128SR04024.7K
R131SR04021K
R132SR040222/NC
R134SR0402100K
R135SR04021K
R136SR04021K
R137SR04021K
R138SR04021K
R139SR04024.7K/NC
R152SR04021K
R153SR0402100K
R158SR0402240
R168SR040239.2K
R179SR0402100K
R183SR0402100K
R184SR04024.7K/NC
R186SR0402100K
R187SR040275K
R190SR0402120K
R191SR0402150K
R192SR040212K
R193SR040251K
R194SR04020
R195SR040251K
R196SR0402100K
R198SR040240.2K
R201SR04024.7K
R204SR0402100
R208SR040227K
R209SR040227K
R210SR040215K
R211SR040247K
R212SR040218K
R213SR04025.1K
R218SR0402121K
R220SR04021K
R221SR040249.9
R222SR04024.7K
R282SR04021K
R437SR040275
R745SR0402240
R746SR0402
R747SR0402
R748SR04024.7K
RN1SRN8-080433
RN2SRN8-080422
TS2TP24-SMDNC
U2SOP8-50-150ADM706SAR
U3DFN2510P10E_AZ1045AZ1045-04F
U5WSON8-MX25L12835ZNNC
U7HSOT-SC70-DCKSN74LVC1G125Q-Q1
U8HBGA427-26-2323HI3536CV100_SYS
U9HSOT-563MP1601
U10BGA96-32-1609MMT41J256M16RE-15E-D
U11SOT23-6BRT9065
U12TSOT23-8MP1494
U15TSOT23-8MP1494
U16SBAT2-13APWR1-2
U17TSOT23-8MP2122
U18DFN2510P10E_AZ1045AZ1045-04F
U19SOT23-6LAZC199-04S
U20MLF6-065-0202LTPS2551DRVR
U21QFN64-050-0909LHRTL8211EG_1
U22MLF32-050-0505LETLV320AIC31
U32WSON8-MX25L12835ZNNC
U34STFM16-50-285
X1HSX4-0302B24MHZ
X2HSX2-030232.768KHZ
; ~( U* h" }" b: ~! ]
) P- @9 j- j4 S" {
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
: d3 K% \# `9 Z4 H# i6 d
GMT+8, 2025-9-13 16:16 , Processed in 0.140625 second(s), 28 queries , Gzip On.
