作品名:[AD 10][4层] TFT液晶驱动板(WM8978+S25FL128+S26KL512DABHI000)原理图、PCB源文件2 T% [' X+ P F3 ?* Y
9 ~) B: ]7 D) b, _' O! G+ M1 {0 {文件描述' e- ^4 w4 l- h! `) l9 i
1. 作品用途:液晶驱动板: U- j2 d" V7 I* C! J( ~/ U
2. 软件版本:AD 10
- v8 K% ^& F; F2 \( x3 |( Z) Q4 M9 ]7 |1 C3. 层数:4层板
) g/ P4 J1 K1 Q/ K5 C6 i4. 用到的主要芯片:WM8978+S25FL128+S26KL512DABHI000
, y" j# }. K9 Y8 Y, f5. PCB尺寸:150mm*98mm
6 E7 a8 K$ A: y9 w4 v5 m r9 d/ o% Z
作品截图如下:
' e# R3 P) \8 c* @3 f, p顶层截图:
8 ?8 n$ E1 L& P; y% |0 ~
5 k. b6 H R: O
底层截图:, A: L3 B; J' [; H
# R7 @5 H c- [; M7 `5 u/ W2 V: t! r
全层截图:
' F, d) w' D! `7 ~* d& ?
& y5 \$ D- I6 \' q# O1 K叠层信息截图如下:% c e* P, D0 l' N4 _! ] R. ?% b
2 z+ m& z6 N3 I7 d JBOM:9 C; @; r% y8 h2 W1 |
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1uF | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C16, C17, C20, C22, C24, C26, C30, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C45, C46, C47, C48, C49, C51, C53, C54, C55, C56, C57, C58, C59, C61, C64, C71, C72 | 0603-C | 49 | 1uf | C15, C52, C65, C66, C67, C68, C69, C70 | 0603-C | 8 | 10uF/16V | C18 | 3528-TB | 1 | 100uF/10V | C19 | 6032-TC | 1 | 10uF | C21 | 0805-C | 1 | 47uF | C23 | 6032-TC | 1 | 12pF | C25, C28 | 0603-C | 2 | 4.7U | C27 | 0805-C | 1 | 10pF | C29, C31 | 0603-C | 2 | 20pF | C43 | 0603-C | 1 | 10uF钽电容 | C44 | 3528-TB | 1 | 100UF/16V | C50 | SMD-C | 1 | 10uF | C60, C62, C63, C73, C74 | 0603-C | 5 | 220pF | C75 | 0603-C | 1 | 102 | C76 | 0603-C | 1 | 101 | C77 | 0603-C | 1 | SD_Card | CN1 | MICROSD | 1 | Comment | Designator9, Designator14 | MARK1 | 2 | Comment | Designator10 | NLOGO-540mil | 1 | LBAT54CLT1G | DIO1 | SOT-23-3P | 1 | FB | F1, F2, F3, F4, F5, F7, F8 | 0805-R | 7 | PWR2.5 | J1 | CZ-DC | 1 | MD | J2 | SIP2-2.54 | 1 | USB-HOST | J3 | USB-A-F | 1 | KF2EDG-X-5.08-2P | J4 | CON2-5.0 | 1 | JUMPER | JP1 | JMP | 1 | | K1, K2, K3, K4, K5, K6, K7 | SMT6*6 | 7 | SWPA252012S3R3MT | L1, L2 | 6 X 6-L | 2 | Red | LED1 | 0603-D | 1 | | LED2, LED3, LED4, LED5, LED6, LED7 | 0603-1 | 6 | Speaker | LS1 | SIP2-2.54 | 1 | Mic2 | MK1 | SIP2-2.54 | 1 | 9012 | N1 | SOT-23-3P | 1 | Header 2 | P1, P8 | SIP2-2.54 | 2 | ADC | P2 | SIP2-2.54 | 1 | Header 3X2H | P3 | IDC6-2.54 | 1 | Header 3X2 | P4 | IDC6-2.54 | 1 | Header 3 | P5, P6, P10, P11, P12, P13 | SIP3-2.54 | 6 | Header 25X2 | P7 | IDC50-2.54 | 1 | 54819-0519 | P9 | USB-min-F | 1 | 10K | R1, R2, R3, R12, R13, R14, R15, R16, R17, R18, R19, R20, R22, R23, R40, R77, R78, R93, R94, R95, R96, R97, R98, R107, R110, R111, R114, R118, R123, R124, R126, R127, R129, R132, R134, R137, R138, R139, R140, R150, R155, R156, R159 | 0603-R | 43 | 0R | R4, R153, R157, R161 | 0603-r | 4 | 68K | R5 | 0603-R | 1 | 100K | R6, R9 | 0603-R | 2 | 13K | R7, R24, R25, R26, R27, R28, R29, R30, R31, R32, R33, R34, R35, R36, R37, R38, R39, R41, R42, R43, R44, R45, R46, R47, R48, R49, R50, R51, R52, R53, R54, R55, R56, R57, R58, R59, R60, R61, R62, R63, R64, R65, R66, R67, R68, R69, R70, R71, R72, R73, R74, R75, R76, R79, R80, R81, R82, R83, R84, R85, R86, R87, R88, R89, R90, R91, R92, R99, R100, R101, R102, R103, R104, R105, R141, R142, R143, R144, R145, R146, R147, R148, R149, R151, R152 | 0603-R | 85 | 330 | R8 | 0603-R | 1 | 47K | R10, R160, R163 | 0603-R | 3 | 15K | R11, R108, R109, R121, R122 | 0603-R | 5 | | R21 | 0603-R | 1 | 5.1k | R106 | 0603-R | 1 | 27R | R112, R113, R119, R120 | 0603-R | 4 | 1.5K | R115 | 0603-R | 1 | 0 | R116 | 0603-R | 1 | 2.2K | R117 | 0603-R | 1 | 120R | R125 | 0603-R | 1 | 330R | R128, R130, R131, R133, R135, R136 | 0603-R | 6 | 10R | R154 | 0603-R | 1 | 680R | R158 | 0603-R | 1 | 4.7K | R162 | 0603-R | 1 | SW-PB | S1 | SMT6*6 | 1 | 220uF' | TC1 | SMD-E | 1 | 220uF | TC2 | SMD-E | 1 | S6E2DH | U1 | PQFP-176P-0.5MM | 1 | ST1S40 | U2, U3 | SOIC-8P | 2 | 20PIN-JTAG | U4 | DC3-20P | 1 | IS42S16800 | U5 | TSOP-54 | 1 | TPS2051BD | U6 | MSOP-8P | 1 | SP3232EEN | U7 | SOIC-16P | 1 | MC34901-SOIC8Pin | U8 | SOIC-8P | 1 | S26KL512DABHI000 | U9 | FBGA-24P-1.0MM | 1 | S25FL128 | U10 | S03-016 | 1 | SJ-3523-SMT | U11, U13 | JACK_OKI | 2 | WM8978 | U12 | QFN-32P-0.5MM | 1 | XPT2046 | U14 | SSOP-16P | 1 | DB9(母座) | UART1 | DB9RA/F | 1 | 32768Hz | XT1 | 2*6 | 1 | 4MHz | XT2 | HC-49 | 1 | Comment | [NoValue], 5, 10, 15 | HOLE-M3-UNP | 4 | 附件:+ L T. G2 Q. N* ]
原理图和PCB源文件如下:
6 X. o4 r% K/ ~) l1 D
: R. G! w& [" H" q" D4 r" w! U l; U
7 F) J/ n/ ^# l- k |
