find8 ~ \6 w+ c6 ]
查找非零元素的索引和值1 y( v8 v9 C. s
# i. H2 K! Q$ n- _
5 _8 K3 o$ z; j7 l. s; v1 m( h7 k2 M
Syntax
: l. r8 E# W, |% E: A5 A1 p2 tk = find(X)2 Y. V6 `# Y! D1 ?' K/ {* G; o
: b; Y* H K9 @2 d3 T0 Z4 u) W
k = find(X,n)
# C/ S k' Z* A/ U/ E5 D/ b
" e% o9 ?& o% Z4 [$ K nk = find(X,n,direction)
- k2 \- x/ K7 ]3 M' h3 {% c* u( J7 D, f, o2 a( H9 \6 G p; U2 d! E
[row,col] = find(___)
" a* l _: G7 ?" e
1 i9 O+ Y* {/ r: J[row,col,v] = find(___)
: K2 ]9 {4 y3 @4 A8 H2 [' c1 i, B) l9 s
& x8 k* u( D; ~/ y, z* BDescription- z7 u* Z6 o% v3 \" u; C* M( Y5 ]6 n
' K4 q. y( |. Yk = find(X) 返回一个向量, 其中包含数组 x 中每个非零元素的线性索引。
. T0 ?0 z2 T% [/ O/ a
& g8 F5 o Z' S- 如果 X 是向量, 则 find 返回与 x 方向相同的向量。& ~; K# {1 u2 e4 H. Y
. `5 ?2 h2 d* Y. M# y
- 如果 X 是多维数组, 则 find 返回结果的线性索引的列向量。6 f6 ^- B* s8 x( Q
! Z5 R( ^. i+ L/ y3 ?- 如果 X 不包含非零元素或为空, 则 find 返回空数组。6 L1 T5 s" ]7 b/ K# U
3 k3 F7 H: N2 u
例子:" W9 F. y. @. o( n: A' T$ ~9 H
1 ~8 k2 I! J0 S% A% I: K' _/ q) R
Zero and Nonzero Elements in Matrix, s* _- {0 z" L, P" T9 E
% i! M5 n1 @( B4 ]: y7 J
Find the nonzero elements in a 3-by-3 matrix.
/ e4 H, u9 K$ k. M, M
. o. K# Y. Y0 m; F. T0 MX = [1 0 2; 0 1 1; 0 0 4]5 V( ^, V5 R0 [# r1 Q u# K$ u" r5 ?
- {' L ]7 z2 J) \X = 3×3
" B0 Q, C9 w) U( v& w' o
i; g2 j3 _5 [8 ? 1 0 2. _+ ~8 f5 K) z( w3 ^ P
0 1 1
8 X" P2 T7 A' H y1 C/ k 0 0 4' J& \6 m+ k5 k3 k; z3 S8 \- f* a
( @; s% H. \- |/ f: U; \' _; M
k = find(X)& G' H7 K, o/ ?" q
8 ^4 i( R. W+ x. @( J9 |, b6 y$ \k = 5×1
% {1 Y4 o! \: E( `3 ^: s! {7 e
& R* ^; ^; c& T* l% s 1
8 M5 o0 K8 t s( p2 i 5- H) F/ P! c+ p0 d& s9 n `, m6 ^* H
75 R. q1 j6 F! i8 K& z( k( i
8: a- V% z6 `- t$ J- U
9
- [% E! w G- }* p% m
+ H8 Y y$ G* A* v- uUse the logical not operator on X to locate the zeros.0 P" @( y) z) A* {' }& \! M
' b7 [; `. x) ^/ N( [
k2 = find(~X)
: r" w9 I, N, T6 T) q. i& w, a% J* w# X2 w0 y2 H4 o
k2 = 4×1
) F5 k8 ] R) T- S8 Z. O6 q+ h. E( k
2 f0 h/ e$ D5 Q } 3. ] r. I3 O# U
4: ]4 u6 ~: X7 O& b
69 m/ z3 i4 E; i" N0 Y4 [
& `' a( p; n* o" l& a7 B% L4 kk = find(X,n) 返回与 x 中的非零元素对应的前 n 个索引。
0 ]/ n$ `- B o1 u
3 [! s) }& E' ^1 w# r例子:
8 }9 u3 @9 N3 Z7 \7 R8 \+ z+ e* j1 d
Elements Satisfying a Condition
0 D- r) {# x6 s2 V, B
8 D# }& q( {( ~5 a: s7 ]" H! SFind the first five elements that are less than 10 in a 4-by-4 magic square matrix.
) j9 s$ r" L* z4 n5 P5 O. e% N* t- v7 \4 w
X = magic(4)' B0 }7 H& c: s
; s5 y2 j- ]( o# l
X = 4×4
' W* A1 Y' V- ~
6 x7 B# @* y; n& d( x& L 16 2 3 13. f) Q6 `. Q% j* K$ ~9 q
5 11 10 8
1 D8 u6 f/ [* h' A0 e( P 9 7 6 12
3 o& q3 F' V$ i( E9 q 4 14 15 1+ y( t/ ]# T9 r0 B
! \6 Q; p- W: _$ N; g K/ ik = find(X<10,5)
+ Z/ \: ? y8 p& }! x1 a
( I% B1 w+ u6 Q. i$ Wk = 5×1; l( p) B1 ~: [2 h
: j7 f$ u" r' f, I5 U 2
2 D, N8 n, p; R' s2 t 3. Z, f; u* z2 P# V
48 I9 C' l' _2 F$ Z6 f9 `
2 v% Q+ ]; L0 Q; E9 P3 l2 e$ ? 7
6 _2 S% n% s6 \- E! ], d' ?4 s. e& O7 L4 y
View the corresponding elements of X.
8 A, ]5 e F1 ~; j4 _: i1 F! ?* Z
K# T. K. d2 a/ aX(k)" L: `2 H& N7 Q. i/ k6 j1 o
& I+ z1 y9 R0 c) H5 \4 {0 r& G
ans = 5×1
& Z m" A2 D8 x1 ~( e3 `- u8 ?; Q
6 x, W" N! X$ U( @ 5, ]- ~9 o8 e3 p! Y5 h% f
9
6 v# b K; ~- B* i- n 40 y: {8 S- r M# ?9 k& p+ K5 ^- \
; y. H6 ^4 q( q- F+ L" y0 i) X& m 7# q; r' R5 L, s2 S" g5 W9 O
0 r9 O$ H V5 X# v! `8 u- L
k = find(X,n,direction), 如果方向为 "last", 则查找与 x 中的非零元素对应的最后 n 个索引。directionis "first" 的默认值, 它查找与非零元素对应的第一个 n 索引。) n. O5 f) c) u+ g: {
0 {8 T8 d& r8 f) P2 g& P7 _9 j3 o& M例子:; g8 h2 w& _6 d2 X. \- q
* ^0 i3 @: ` M4 B6 @
Last Several Nonzero Elements6 S- ?. I+ @/ T9 r
- w) e$ I; O: `, ?9 G( M* ]$ Z4 fCreate a 6-by-6 magic square matrix with all of the odd-indexed elements equal to zero.% W2 l6 e, O) K3 e4 t
8 P& Y2 Z0 P* t" X( @: I0 C
X = magic(6);$ {. P8 U0 Z- N9 Q$ s. D5 ^+ `
% {: [( u$ A5 D _0 F6 ^7 v' pX(1:2:end) = 0
$ i# w( e, Q0 ?' J; R
7 N' ~) i( t, u* hX = 6×6
- L. ? x1 Q) M4 Z
: `& B4 |7 S$ ~ 0 0 0 0 0 00 H4 l6 H1 K+ v6 m' H6 w* h2 c
3 32 7 21 23 25
3 y0 ]9 l2 O( Y 0 0 0 0 0 00 V: L& O3 \. ^( f3 x( m" S/ @
8 28 33 17 10 15, ^0 e% ]- o5 b H
0 0 0 0 0 00 ~! B6 Z; U) ~2 J( \# U
4 36 29 13 18 11" v$ }$ p8 D) c" x- ~. h9 r
4 J, a- ]* {; G1 Y3 JLocate the last four nonzeros.
" Q' ?, z& W& _" P: X
* {8 k( n- {7 A. W0 p" t/ ek = find(X,4,'last')
) J" c2 d: X# U% I, r% \2 E8 s) x' Z
) s, I4 @; Q& x `$ vk = 4×1
5 e& J5 @9 H. j; g
' k0 r1 D: {- {. I4 M3 a4 N 30( W8 H/ y- h3 b/ d5 f( r/ W
328 ]7 T5 h8 D: M0 q6 Y2 B
343 j5 B; [, n( c) b3 W: o& W' M
36% M, E- N0 `( j, e) U7 C9 _
5 e! ]: {; v! o5 q. q' C
x(k)
* j Q+ q4 B! `& k" S( `+ y% C5 S2 Y/ P0 \9 J Q
ans =
2 z# ^$ `% ?! |0 ~
l9 w' C" B7 V 188 Z& ~4 K6 x( q* f
25
% D3 ~# N9 L4 v. J# u( Y7 n+ d! o 15
9 A# z3 Y' z9 l# O. f7 p6 ^7 J9 w 118 p4 k6 |$ D( \1 R
. D1 u% x6 @# B- \0 G! v
+ ~, l& B3 k% Z7 @; m: @- Q2 X[row,col] = find(___)使用以前的语法中的任何输入参数返回数组 X 中每个非零元素的行和列下标。
* ~+ Z7 q8 a! C2 S: ~) I1 s6 A% Y9 C* O7 M% j* j0 @. n
- L! t2 L8 D! v+ G6 `! AElements Satisfying Multiple Conditions, W& R& N2 K9 }
7 E, M! G6 j) Q8 ?' \
Find the first three elements in a 4-by-4 matrix that are greater than 0 and less than 10. Specify two outputs to return the row and column subscripts to the elements.
% r2 W+ a1 F3 r& N4 D) d/ z4 ^+ k: n6 y
X = [18 3 1 11; 8 10 11 3; 9 14 6 1; 4 3 15 21]5 Y* w) @+ y6 O) U6 m1 x
0 Z% {/ B+ t2 DX = 4×4# `# A5 _6 X) O& \9 _9 w
8 t3 `+ Z! g5 u/ m8 l$ V( N 18 3 1 11" T& G5 Q( E; i# B
8 10 11 3/ q8 {, O, e" `# _& e, ^6 Q
9 14 6 1( P6 X$ M$ k0 V% r/ M
4 3 15 21
. B! s4 d2 T2 O9 j
( _7 v% F! [$ J$ _: `[row,col] = find(X>0 & X<10,3)7 ]& V. d H, _& \/ Q2 P# k- {
8 w a$ A7 n- L s1 o/ X0 @* V& o
row = 3×1# k/ }# l4 p/ W+ p8 k4 X0 M
9 p1 w* |' e# V6 B 2
1 v+ Q; _" V- [4 R: T 3# ]4 J9 K: q8 ^7 h4 \8 b7 H/ t! U: l
* {! f. b+ O. F
" M) w" k' ~8 `2 q2 Qcol = 3×1
% K' y1 [9 G t. ]- L
4 o) Y! F/ n0 o# l- f0 r 1- A) w' e5 J# |3 z; f; Z
- R/ J& Q& S! R/ v4 i4 u 1
- o! m5 C5 Z2 F1 B: \$ N p- u8 d2 d: u3 W) B
The first instance is X(2,1), which is 8.# n5 }/ {9 N" x/ g& w' O% d
. o3 x$ ?% z2 `: [- x[row,col,v] = find(___) 还返回向量 v, 其中包含 x 的非零元素。
+ A. n3 ^2 _/ B
0 z5 {7 _- O) e0 Z+ f% P8 \+ V. W$ Y* f0 G: P* L% K6 l2 Y. Z
Subscripts and Values for Nonzero Elements
. I2 C) u0 P2 C8 T& V1 Q( o* V" U5 O- f m. i$ k( L. O2 I. A6 l0 M
非零元素的下标和值
& t! L; ^; C: a# s5 X* x/ Z: W* _9 ]3 B& M+ }7 d
Find the nonzero elements in a 3-by-3 matrix. Specify three outputs to return the row subscripts, column subscripts, and element values.( s# }6 Z& {4 m) f
) m5 ?& W B- q8 n% s
X = [3 2 0; -5 0 7; 0 0 1]
7 D% U6 y1 E8 l. S- y S9 G& ?$ r5 B Q5 ~5 R5 g. {
X = 3×38 [, h3 @ n3 x# ]
) Y) Q3 n( f: L3 v/ B; r
3 2 0
+ K" A9 C& r! [ -5 0 7
+ M4 o9 w: ]2 ^' p1 b) e) @ 0 0 15 L0 s/ |% B4 P/ Q* I' x7 @
% ?: ?0 K& w9 n& |; `) j2 k
[row,col,v] = find(X)
9 z5 }! _+ P2 x9 g* M F7 K9 _ U R* I! _, [' X2 a
row = 5×17 X' Z5 K& n$ ^7 a
( p+ _# R7 `$ |5 M 1% W9 D- f6 Z7 Z" g/ G0 N
2& Y5 E- _! Z1 ? i! Y
1& W3 D7 M7 \2 n; _
x7 p# t6 o$ d 3
4 O+ @. ]4 m! f9 Z2 w- I3 K: I" q& a. Y: g' A5 M6 F& |
col = 5×1, B8 r1 m& C9 A
% {7 S z1 @# @6 W0 T f1 u
# i. V' h6 ?4 x 1
) f( Z4 o- d a4 C" ]& _5 F 25 X& d6 L/ ]: J9 x& Q3 G' P9 k
30 N# i1 ~; u+ m& {8 O
( g- ]- g4 {0 S* P" w4 @
# w7 f' q7 W; u% Z0 m, E$ uv = 5×1
0 L( C5 o, Y1 T ]9 ]1 K- b3 a |+ I( {9 G: B9 O7 H+ W% e1 I
35 M% |: t3 L0 U% \; x
-5+ i1 M1 B- w# [* g+ k
, l/ ?" j% ^! X/ ~' v, `2 w 7
. h4 E: O& \$ e' v+ c 1
9 r# e% e, l+ i- l) w+ }
- x* a5 @6 b0 A- f9 L
9 e! j% q& `# ~5 j' F8 PSubscripts of Multidimensional Array
4 _% X" F1 W+ j. I9 ]1 f- u; c0 |* P; ?" Z) `, Y
Find the nonzero elements in a 4-by-2-by-3 array. Specify two outputs, row and col, to return the row and column subscripts of the nonzero elements. When the input is a multidimensional array (N > 2), find returns col as a linear index over the N-1 trailing dimensions of X.4 s$ q9 H; ?/ @
( i, s# g+ a$ W7 TX = zeros(4,2,3);; P7 f# [& P9 W6 ~
! c+ q. I4 S- N+ g$ Y
X([1 12 19 21]) = 16 e6 B# W7 W' `6 b
! C2 d" B) H3 h+ B7 ?X = % h/ Z( N8 X+ L9 f- u
. A5 z2 j3 p5 o- aX(:,:,1) =* i( U8 ~& u/ j9 Z9 {
k# H# g4 @) V( [0 i- x0 _. d 1 0 O6 R' j% \: v
0 0
9 K0 h% f" E! m. G 0 0% D+ R. a& G3 b# Z) \5 m) u
0 0
! a& T1 S( ]( [ x# S9 ]( ]2 [% z9 Z4 Y& O
" g: L: n# o/ V% ]X(:,:,2) =
9 O$ v. B! T9 [# K+ e1 W1 D `; J3 r7 B! s8 z0 P3 R5 s
0 0
T# L' k7 V3 g, r8 C0 J) C1 X 0 0
! c" ~# l7 c2 r 0 0% b6 h. G' G; m3 d" G
1 00 S3 D% n& c! \+ w) l) E
1 |3 [1 `, X6 Q! Y2 d# X: B
, w" F6 |3 H- _% Q& e4 Y
X(:,:,3) =9 C. q& ]" F: k! Q
* F, m9 B: g9 ~0 @) X$ ~/ j
0 1
# R' f+ B* k% K 0 09 g3 c* a; _( Z2 {. a6 G# U
1 0/ t* w) R- ~% K8 f1 f1 j$ p
0 0
1 s& d1 E0 V: y2 Q; d- A8 L2 |
8 v- @8 k% N; q1 h4 @[row,col] = find(X)
" q( E+ W/ Z+ F" _ E; m7 S3 r& t9 c7 i- H, `. p) |
row = 4×1
$ x8 m9 k; Y; \- e/ W! i; r5 f) E4 J, X' m3 O% T+ e
1- B1 d5 g3 Y& n. g. L( @# g
4- C; i$ A2 Z+ o: c/ Z: c% J
3: e/ ]2 t1 _) l; c, @; q. [
1+ Q7 M# h: C, C* Y, z
3 a) M( B3 K) B% C; X
col = 4×18 S( d5 h: e' x/ @6 G* A7 v6 P
# Y m6 p* {* M9 t. _$ r: K2 Y7 q3 J 1
9 i5 ?) M( V0 c 3( x( j+ A) @3 l5 _& J
54 E, w( q' Z+ y# V* H- L
2 ~! N5 C; ?+ h3 w9 M( n
+ o% Q' |, z4 X5 w: R( l3 s$ N, I4 x
最后介绍下线性索引:' Q& E! M a% z3 ~5 g6 C: F, `
0 j% e; s3 F6 U" T1 {5 B4 I y* g" Z/ ^/ M% f: ]: k+ [0 o
线性索引允许使用单个下标索引到数组中, 如 a (k)。MATLAB®将数组视为单个列向量, 并将每个列附加到上一列的底部。因此, 线性索引将列中的元素从上到下、从左到右编号。6 Q6 T8 T+ N8 n) F5 {* u% W3 q; E6 C
/ O9 z& p, W) J2 l/ P例如, 考虑一个3乘3矩阵。您可以引用 a (22) 元素与 a (5) 和 a (23) 元素具有 a (8)。线性索引根据数组的大小而变化;a (5) 返回一个3乘3矩阵的不同位置的元素, 而不是4到4矩阵。
% Z8 U9 q0 \. F9 J
# S8 G& |% @9 i* xsub2ind 和 ind2sub 函数在下标和线性索引之间转换时非常有用。
% d8 O3 n) t# D& Y! b6 Z) b+ R) A. T0 S7 V
( ^9 ?; E6 L7 V+ O- T- F# k" F n |
2 Q& @5 U6 Z) L' f+ T |
