目录 1 通过Pspice仿真设计温控电路电路的设计需求:主板上的关键电子物料工作温度为-10度,为确保电路在-40度以下能正常工作;需要设计一个PCB环境温度控制电路,当主板上的温度低于-10度启动加热,维持主板上的温度在-10度以上 1.1 电路两个核心器件:1.1.1 NTC电阻: 用于实时检测当时温度值,当温度升高电阻值变小,温度降低时电阻值变大, NTC电阻选用 Murata NCU15XH103F6SRC,以下是从官网上获取到的温度-阻值参数表; R25 10 k ohm +/- 1% B(25/50) 3380 K +/- 1% -40 188.0202 195.6520 203.5731 -39 177.8044 184.9171 192.2951 -38 168.2141 174.8452 181.7195 -37 159.2069 165.3910 171.7981 -36 150.7435 156.5125 162.4860 -35 142.7877 148.1710 153.7418 -34 135.3055 140.3304 145.5274 -33 128.2659 132.9576 137.8071 -32 121.6397 126.0215 130.5481 -31 115.4001 119.4936 123.7198 -30 109.5221 113.3471 117.2940 -29 103.9894 107.5649 111.2522 -28 98.7725 102.1155 105.5611 -27 93.8512 96.9776 100.1981 -26 89.2071 92.1315 95.1423 -25 84.8227 87.5588 90.3741 -24 80.6819 83.2424 85.8755 -23 76.7698 79.1663 81.6295 -22 73.0722 75.3157 77.6204 -21 69.5761 71.6768 73.8336 -20 66.2694 68.2367 70.2554 -19 63.1477 64.9907 66.8807 -18 60.1923 61.9190 63.6889 -17 57.3933 59.0113 60.6689 -16 54.7415 56.2579 57.8105 -15 52.2283 53.6496 55.1040 -14 49.8456 51.1779 52.5406 -13 47.5859 48.8349 50.1117 -12 45.4422 46.6132 47.8097 -11 43.4078 44.5058 45.6271 -10 41.4765 42.5062 43.5570 -9 39.6345 40.5997 41.5843 -8 37.8855 38.7905 39.7131 -7 36.2244 37.0729 37.9374 -6 34.6461 35.4417 36.2519 -5 33.1462 33.8922 34.6515 -4 31.7202 32.4197 33.1313 -3 30.3641 31.0200 31.6869 -2 29.0740 29.6890 30.3140 -1 27.8465 28.4231 29.0088 0 26.6780 27.2186 27.7675 1.1.2 P沟通增强型MOS管: 用于控制加热电阻,MOSFET选用 Diodes DMP3099L;从Diodes官网下获取DMP3099L Pspice模型数据如下: .SUBCKT DMP3099L 10 20 30 * TERMINALS: D G S M1 1 2 3 3 PMOS L = 1E-006 W = 1E-006 RD 10 1 0.02942 RS 30 3 0.001 RG 20 2 10.27 CGS 2 3 5.366E-010 EGD 12 30 2 1 1 VFB 14 30 0 FFB 2 1 VFB 1 CGD 13 14 4.4E-010 R1 13 30 1 D1 13 12 DLIM DDG 14 15 DCGD R2 12 15 1 D2 30 15 DLIM DSD 10 3 DSUB .MODEL PMOS PMOS LEVEL = 3 U0 = 400 VMAX =1E+006 ETA = 0.001 TOX = 6E-008 NSUB = 1E+016 KP = 8.769 KAPPA = 19.32 VTO =-1.917 .MODEL DCGD D CJO = 2.502E-010 VJ = 0.8 M =0.6 .MODEL DSUB D IS = 4.949E-009 N = 1.628 RS= 0.02235 BV = 33 CJO = 5.295E-011 VJ = 0.8 M = 0.6 .MODEL DLIM D IS = 0.0001 .ENDS *Diodes DMP3099L Spice Model v1.0M Last Revised 2017/12/7 1.1.3 模型的使用 1. 通过 cadence Pspice Mode Editor工具打开DMP3099L 模型数据,另存为DMP3099L.lib模型文件. 2. 导出MOSFET的原理图符号库 1.2 温控电路设计与仿真1.2.1 温控电路图 1. 打开 orcad,点击菜单file – New – Project,在New Project窗口选择Analog Mixed A/D,输入项目名,点击OK创建Pspice项目文件 2. 通过如下方式调用Pspice元器件; 3. 通过Place Part窗口,Add Library找到DMP3099L原理图符号库,放置到原理图页 4. 连接相关网络,完成原理图的设计; 1.2.2 仿真分析 1. 点击PSpice下的New Simulation Profile,命名为NTC_Sweep 1.2.2.1 设置仿真参数-PSpice模型库的添加 1.2.2.2 设置仿真参数-DC_sweep,将NTC电阻作为变量27K~100K进行扫描 1.2.2.3 运行PSpice菜单下面的Run,查看分析结果 从仿真结果来看,NTC电阻值在30K(-3度)时开始加热,到达40K(-10度)接近最大的加热电流,电路功能达到设计需求;
: {% y' H" t3 q$ g3 N# m# a |
