6 }! _" g; A$ Y* R) T% i单位样本序列
" @# Y: C7 r5 s- @) H# {+ s0 p7 N& U! \
/ w( Y3 D5 Y( v1 t' }% T; e& r
+ _" C* `5 j: H% P# l+ @5 l- T- clc
- clear
- close all
- n1 = 0;
- n2 = 5;
- n0 = 3;
- n = [n1:n2];
- x = [(n - n0) == 0];
- stem(n,x,'filled');
- ylim([-1,2]);. G) R: \. L7 B5 H4 d$ ]" y0 b; I
2 `& v" M* {2 `& K, g/ J3 z: z' f
1 N0 i/ J. m6 o2 ]
' `7 r9 E0 s5 ^改成一个函数:0 @0 p+ I1 i. k- x2 Z
7 M; c* w5 }, y9 u$ k! ?- O
- function [x,n]=delta(n0,n1,n2);
- % generate x(n) = delta(n - n0); n1 <= n <= n2
- %_____________________________________________
- %[x,n] = delta(n0, n1, n2);
- n = [n1:n2];
- x = [(n-n0) == 0];3 }6 E5 t; ^/ t- N6 r7 L0 `7 k
+ h, \4 V: T* @7 D" q6 S( R* I) W
命名为delta.m
2 n a/ S. w, S% I3 k. H) E% c* h2 B1 w3 T. r8 [7 @
新建一个脚本:
. H6 F! |* [; B1 x1 B% k$ j2 a7 M4 y! @! k+ d
- n0 = 3;
- n1 = -3;
- n2 = 6;
- [x,n] = delta(n0,n1,n2);
- ylim([-1,2]);
0 x, v% ~' ]( f9 A6 A6 [0 \5 ~
6 E7 F; l% }6 ?( u+ a运行得到:. m2 [6 [& t+ j! t
& @1 O2 @4 w; P0 ?' K* x2 v
, b; v- g0 c5 d- i6 \4 m* [9 y3 A2 v+ _
( \0 ~. x- [; w+ W+ `! @: h1 N6 D
单位阶跃序列
; t+ z: j; P* ?. X# `6 M, s4 n+ a3 Y! x9 ]2 |
( R; k# X3 M8 n- L
0 k8 y8 Y* S2 H6 D0 T; x n4 y w直接写成函数形式吧:
7 I- i# ?0 d1 M8 v- b/ M4 `0 C# y8 |9 A; I$ d
- function [x,n]=stepseq(n0,n1,n2);
- % generate x(n) = u(n - n0); n1 <= n <= n2
- %[x,n] = stepseq(n0, n1, n2);
- n = [n1:n2];
- x = [(n-n0) >= 0];
/ k: A4 {8 ^/ { 9 B4 i: U( g1 w. A2 [* K- a
新建一个脚本,测试:
* C$ S( l9 N- k$ z3 P# ~ O) |, o% Q4 H+ z8 ?0 j8 s/ o
- clc
- clear
- close all
- n0 = 3;
- n1 = -3;
- n2 = 6;
- [x,n] = stepseq(n0,n1,n2);
- ylim([-1,2]);* t5 F% d8 d% E1 n! e
+ a* F3 _! K6 L
结果:
4 x5 y0 j1 e. m* V0 d! s( ]5 ]& [
, M5 w/ W! |8 B1 L8 S
" m( |; e' K9 e" ?, D9 M: d% C" l
2 j5 P' |& D Q& b' j9 Z; x( b1 V8 G1 b6 c ~! e2 \# R* E
实值指数序列: L! G% j0 {$ }7 u0 ^& E
8 e8 \ G/ J `% U# y* h
为一般形式。2 E: U7 z6 G0 j$ V
- ]# V: d W4 H e, N下面产生一个序列:6 ]# h* z/ c* s! a+ e- M. Q
+ ~2 {" w+ t) r, `; }$ h! F
2 e5 n% l$ G9 H+ X
: M; N! j' l+ ^( R L' [
脚本代码:
7 Y& B- @* _, K3 ~9 l0 [
7 U) K7 M8 W1 @6 R% s. W) D9 @- clc
- clear
- close all
- n = -3:10;
- x = 0.9.^n;
- xlabel('n');
- ylabel('0.9^n');
- xlim([-5,13]);
- ylim([0,2]);& z! v8 l* R: P# C2 a
( n/ U% g+ N# F5 M- ]* S$ @
" r3 m9 z5 }( i$ A1 R4 k' k/ C* h: z+ B
$ j$ p, F5 d# g8 L! F+ g% G- [* ^3 D& n3 w. c$ Y) h8 b
复指数序列
6 ?; ^* O- ~4 r5 i
0 u7 {7 Q5 y. X
2 i3 v7 U1 I; N" }
2 b& j. m( I4 O- clc
- clear
- close all
- n = 0:10;
- x = exp( (2+3j)*n );
- stem(n,x);
- xlabel('n');
- W/ G; L& \& {% _9 E7 M3 l; m
) B0 o: C+ H, j+ ~; t+ M) h v
: f1 @4 [; ~! Z: Y9 c& y7 S! i1 S! \+ T$ i. s h+ [* [( r4 S
# S& b- D |1 {* b( A- \0 m周期序列* f3 Y5 K+ O# E9 T# G6 u* W
, V6 ?. n7 N2 y
- clc
- clear
- close all
- n = 0:10;
- subplot(2,1,1)
- stem(n,x);
- xlabel('n');
- title('Not Period Sequence');
- % the number of period
- P = 5;
- xtilde = x' * ones(1,P);
- xtilde = xtilde(:)';
- subplot(2,1,2);
- stem(xtilde);
- title('Period Sequence');
3 R4 D1 h: c. o, ?- e
3 y/ r: z0 q/ N4 }' r
. `( l, X+ E$ C
4 }. u1 Y( d' Q% z: V) I
8 w) F) @1 z, A7 v7 U, e2 Z
