查看: 981|回复: 15
[allegro16.5][6层]HI3532参考板(FPGA+4片DDR+PCI接口)原理图和pcb文件
发表于 2019-12-31 16:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
6 i6 I+ s2 [, [# F, y
7 i1 d% T. N/ A3 @6 {& K' X* v4 p2 A2 m" t6 R
文件描述:
) B4 y- q1 L, t3 T3 l+ n, {. d1 z* P0 X: s: f: G+ ?
1. 作品用途:HI3532参考板
) O. I; n$ I8 h4 F! [2. 软件版本:allegro16.51 A5 _: A! S& a# w
3. 层数:6层7 F( u) X( W1 Y* c2 `
4. 用到的主要芯片:FPGA+4片DDR+PCI接口5 H; _; j$ y7 {1 M9 \
5. pcb尺寸:8750*8485 MIL) M/ h; b# G/ X( z& Z
2 f0 S3 N+ Q8 ~5 u
作品截图如下:2 }( ?5 u0 F# E% d1 h- d9 S4 h( U
; z8 I& i( P; z顶层截图:4 n/ F2 C9 t4 ]
7 D! G3 V' d" ?3 i底层截图:+ p0 E: M7 v0 T1 {
5 X% }" k2 ?. C- A. ?0 ]
6 ^! L) r- [, j
全层截图:& [: ?5 s2 a. o0 j, r; ^
' o9 f5 i$ O# l; D1 E
5 |" N9 l4 A# S* y* @  ^叠层阻抗信息如下:
/ u) Y% b# R0 u 5 F" S, s' U3 a# W4 s/ S
BOM:2 w/ S: P. Z7 E8 i! S  x; T) ^
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA96-32-1609DBGA96-32-1609DIC4U26; U27; U28; U29
BGA509-26-2727BGA509-26-2727IC1U17
CAP2-300-240CAP2-300-240IC1C453
DB9-2RMDB9-2RMDBR30_09K1206IO1J21
DB15-2RFDB15-2RFIC4J12; J13; J14; J15
DIM0425-80-ADIM0425-80-AIC1J22
HOLE125-8STARHOLE125-8STARHOLE105-8STARIC6M1; M2; M3; M4; M5; M7
HSOD323AHSOD323AIC1D26
HSOT416AHSOT416AIC2Q5; Q6
IDC20-DTM1-AIDC20-DTM1-AIC1J18
MJ8-SRLFYMJ8-SRLFYIC1J28
MLF14A-050-0404LMLF14A-050-0404LIC2U1; U20
MLF32-050-0505LEMLF32-050-0505LEIC1U25
MRT-RVG4M08MRT-RVG4M08IC1RP3
PCI36-12VPCI36-12VIC1J11
PSW3-RAPSW3-RABR_11C_11P6IC1S3
PWC0103-M-CPWC0103-M-CIC1J17
QFN-72QFN-72IC1U39
QFP48-050-0707LQFP48-050-0707LIC1U14
QFP128C-40-1414LQFP128C-40-1414LIC4U40; U41; U42; U43
SC0402SC040233pFDISCRETE130C1; C39; C40; C44; C45; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C64; C65; C67; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C184; C185; C186; C187; C188; C189; C190; C191; C267; C268; C292; C293; C326; C332; C450; C485; C531; C532; C533; C534; C535; C536
SC0603SC060320pFDISCRETE233C6; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C24; C36; C66; C68; C116; C117; C193; C194; C195; C196; C197; C198; C199; C200; C201; C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C246; C247; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C258; C261; C262; C263; C264; C265; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C285; C286; C287; C288; C289; C290; C291; C294; C295; C297; C298; C299; C300; C301; C302; C303; C306; C307; C308; C309; C310; C313; C315; C318; C319; C320; C321; C322; C323; C324; C325; C327; C328; C329; C330; C331; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C346; C347; C348; C349; C350; C351; C352; C353; C354; C355; C357; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C385; C386; C387; C388; C390; C394; C395; C398; C399; C400; C401; C402; C403; C404; C405; C409; C410; C411; C412; C413; C414; C419; C448; C449; C451; C452; C483; C484; C486; C487; C488; C490; C516; C517; C518; C519; C520; C521; C522; C523; C524; C525; C526; C527; C529
SC0805SC08051uFDISCRETE64C2; C3; C5; C25; C26; C27; C28; C29; C30; C31; C32; C42; C43; C296; C416; C425; C426; C427; C428; C429; C430; C431; C432; C433; C434; C435; C436; C437; C438; C439; C440; C441; C442; C443; C444; C445; C446; C447; C455; C456; C457; C458; C459; C460; C461; C462; C463; C464; C465; C466; C467; C470; C471; C472; C474; C475; C476; C477; C478; C479; C480; C481; C482; C528
SC1206SC120622uFDISCRETE61C4; C33; C34; C35; C37; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C356; C359; C383; C415; C420; C421; C422; C423; C424; C468; C469; C473; C497; C500; C501; C502; C503; C504; C505; C506; C507; C508; C509; C510; C511; C512; C513; C514; C530
SCAPC2-280-327SCAPC2-280-327100uFDISCRETE7C8; C22; C23; C38; C41; C417; C418
SD0805-LEDSD0805-LEDLEDIC1D25
SD2723SD2723DIODEDISCRETE1D1
SDSW8-LSDSW8-LGSW3DISCRETE3SW1; SW2; SW3
SF6127SF6127SSQ4DISCRETE2F1; F2
SIP-1PSIP-1P013-0018-192IC10J1; J2; J3; J4; J5; J6; J7; J8; J9; J10
SL0402SL0402IC3LB15; LB16; LB53
SL0603SL0603IC3LB45; LB54; LB55
SL0805SL08051uHDISCRETE12LB44/NC; LB1; LB4; LB5; LB6; LB7; LB13; LB14; LB43; LB48; LB49; LB52
SL1206SL1206LBIC32LB12/NC; LB37/NC; LB38/NC; LB2; LB3; LB9; LB10; LB11; LB17; LB18; LB23; LB24; LB25; LB26; LB27; LB28; LB29; LB30; LB31; LB32; LB33; LB34; LB35; LB36; LB39; LB40; LB41; LB42; LB46; LB47; LB50; LB51
SOD323SOD323D_AIC2D6; D29
SOP8-50-150SOP8-50-15024LC16B_SNIC1U16
SOP8-50-150ASOP8-50-150AIC1U15
SOP8-50-157HSOP8-50-157HIC2U31; U32
SOP8H-50-155ASOP8H-50-155AIC3U36; U37; U38
SOP16-26-173SOP16-26-173IC1U4
SOP16-26-208-255SOP16-26-208-255ICL3232EIA_TIC1U30
SOP16-50-300ASOP16-50-300AIC1U33
SOP38-20-173ASOP38-20-173AIC1U2
SOP56-20-250-550SOP56-20-250-550IC10U3; U5; U6; U7; U8; U9; U10; U11; U12; U13
SOT23SOT23PMOS-GSDIC28D2; D3; D4; D5; D7; D8; D9; D10; D11; D12; D13; D14; D15; D16; D17; D18; D19; D20; D21; D22; D23; D24; D27; D28; Q2; Q3; Q4; Q7
SOT23-5BSOT23-5BSN74LVC1G125DBVRIC2U18; U19
SOT23-6ASOT23-6AIC1U35
SPL1209SPL120910uHDISCRETE4L1; L2; L6; L7
SR0402SR0402DISCRETE122R1; R34; R43; R57; R60; R61; R77; R79; R80; R81; R82; R83; R84; R85; R89; R90; R91; R92; R97; R98; R99; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R126; R127; R134; R135; R136; R137; R157; R158; R159; R160; R162; R172; R174; R184; R185; R188; R189; R190; R191; R192; R193; R202; R246; R247; R248; R249; R302; R309; R310; R312; R314; R317; R318; R319; R327; R328; R329; R330; R331; R332; R333; R334; R336; R340; R341; R342; R343; R344; R345; R346; R375; R376; R395; R474; R475; R476; R477; R478; R479; R480; R481; R482; R483; R484; R485; R538; R618; R634; R635; R639; R685; R687; R688; R689; R690; R691; R692; R693; R694
SR0603SR060349.9DISCRETE516R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R35; R36; R37; R38; R39; R40; R41; R42; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R59; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R78; R86; R87; R88; R124; R125; R128; R129; R130; R131; R132; R133; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R161; R163; R164; R166; R167; R168; R169; R173; R176; R177; R178; R179; R180; R181; R182; R183; R186; R187; R194; R195; R196; R197; R198; R199; R200; R201; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R215; R216; R217; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R234; R235; R237; R242; R243; R244; R245; R250; R251; R252; R253; R254; R255; R256; R258; R259; R260; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R272; R273; R274; R275; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R289; R290; R291; R292; R293; R294; R295; R296; R299; R300; R301; R305; R306; R307; R308; R313; R315; R316; R320; R321; R322; R323; R324; R325; R337; R338; R339; R348; R349; R350; R351; R352; R358; R359; R360; R361; R362; R363; R364; R365; R366; R367; R368; R369; R370; R371; R372; R373; R374; R377; R378; R379; R380; R381; R382; R383; R384; R385; R386; R387; R388; R389; R390; R391; R392; R393; R394; R396; R397; R398; R399; R400; R401; R402; R403; R404; R405; R406; R407; R408; R409; R410; R411; R412; R413; R414; R415; R416; R417; R418; R419; R420; R421; R422; R423; R424; R425; R426; R427; R428; R429; R430; R431; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453; R454; R455; R456; R457; R458; R459; R460; R461; R462; R463; R464; R465; R466; R467; R468; R469; R470; R471; R472; R473; R486; R487; R488; R489; R490; R491; R492; R493; R494; R495; R496; R497; R498; R499; R500; R503; R504; R505; R506; R507; R508; R509; R510; R511; R513; R514; R515; R516; R518; R519; R520; R521; R526; R528; R529; R530; R531; R535; R536; R537; R539; R540; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553; R554; R555; R556; R557; R558; R559; R560; R561; R562; R563; R564; R565; R566; R567; R568; R569; R570; R571; R572; R573; R574; R575; R576; R577; R578; R579; R580; R581; R582; R583; R584; R585; R586; R587; R588; R589; R590; R591; R592; R593; R594; R595; R596; R597; R598; R599; R600; R601; R602; R603; R604; R605; R606; R607; R608; R609; R612; R613; R614; R615; R616; R619; R620; R621; R622; R623; R624; R625; R626; R627; R628; R629; R630; R631; R632; R633; R637; R638; R640; R641; R642; R643; R644; R645; R646; R647; R648; R649; R650; R651; R652; R653; R654; R655; R656; R657; R658; R659; R660; R662; R663; R664; R665; R666; R667; R668; R669; R670; R671; R672; R673; R674; R675; R676; R677; R678; R679; R680; R681; R682; R683; R684; R686
SR0805SR08050DISCRETE8R76; R138; R297; R298; R303; R304; R617; R636
SR1206SR1206IC1R58
SRN8-1608SRN8-160833DISCRETE3RN1; RN2; RN3
SSW-PUSHSSW-PUSHTC-108IC2S1; S2
STFM16-50-285STFM16-50-285S558_5999_U7_FDISCRETE1T1
STP40STP40IC25TS5; TS19; TS20; TS21; TS22; TS24; TS25; TS26; TS27; TS28; TS29; TS30; TS31; TS32; TS33; TS34; TS35; TS36; TS37; TS38; TS39; TS40; TS41; TS42; TS43
SX2-1205SX2-120525MHzIC2X2; X4
SX4-0503CSX4-0503CIC1X3
SX4-0705SX4-070527MHzDISCRETE2OSC1; OSC2
TW-MKT2-26TW-MKT2-26IC2J19; J20
TW-MKT2-100-FTW-MKT2-100-FIC2J25; J26
VAF3-AVAF3-AAV2_84_9B_PBIC2J23; J24
VAF5-AVAF5-AIC1J16
WBC0109-20RAWBC0109-20RAIC1J29
附件:
1 L) t( E+ Q# u. e( a原理图和PCB文件如下:
3 z+ i6 N" W6 F# }" w
游客,如果您要查看本帖隐藏内容请回复
' B  S& v% h5 H5 N2 M2 _! \
' ^7 n2 h7 }1 h2 H3 u: h8 w/ ^7 j
发表于 2020-4-13 08:57 | 只看该作者
是否收费
“来自电巢APP”
发表于 2020-4-13 22:56 | 只看该作者
感谢楼主分享!
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2020-4-15 18:23 | 只看该作者
    谢谢楼主的分享
    “来自电巢APP”
    发表于 2020-10-7 09:34 | 只看该作者
    谢谢楼主的分享
    发表于 2020-10-8 14:37 | 只看该作者
    # `3 }( \  z0 [+ \; [) f
    发表于 2020-11-24 12:21 | 只看该作者
    收藏看看!值得学习
    ; m9 I! ]" o2 c) Y
    无聊
    2022-9-28 15:48
  • 签到天数: 69 天
    [LV.6]常住居民II
    发表于 2020-11-24 19:16 | 只看该作者
    11111111111111111
    发表于 2020-11-26 16:51 | 只看该作者
    文件不错,可以练习下
    . r/ m8 @) M2 O
    2025-8-12 15:01
  • 签到天数: 25 天
    [LV.4]偶尔看看III
    发表于 2024-7-19 20:11 | 只看该作者
    文件不错,可以练习下
    发表于 2024-11-16 20:08 | 只看该作者
    1111111111111
    " L  O5 D" R' q7 c# N2 K) O7 T7 g+ ?$ d" X0 `: T
    14#
    发表于 2025-9-30 10:17 | 只看该作者
    谢谢,学习学习。
    GMT+8, 2025-10-9 21:13 , Processed in 0.171875 second(s), 27 queries , Gzip On.
