查看: 1082|回复: 11
[allegro16.6][8层]英特尔 BayTrail4代凌动4核E3845(E3845_FCBGA1170+DDR3+CH7318...
发表于 2019-12-28 11:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]英特尔 BayTrail4代凌动4核E3845(E3845_FCBGA1170+DDR3+CH7318C-BF)pcb文件
文件描述:
1. 作品用途:英特尔 BayTrail4代凌动4核E3845
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:E3845_FCBGA1170+DDR3+CH7318C-BF
5. PCB尺寸:8385*6567 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类被数量位号
1N5817A1N5817ASS14(1N5819)DISCRETE4D1; D34; D39; D40
1N5817A1N5817ASS14(1N5819)/NCDISCRETE1D9
1N5817A1N5817ASMAJ33CA_DO214AC(SMA)DISCRETE4TVS1; TVS2; TVS3; TVS4
2N7002B2N7002B2N7002/SOT23DISCRETE29Q3; Q4; Q5; Q6; Q7; Q8; Q15; Q20; Q24; Q25; Q32; Q35; Q36; Q39; Q40; Q41; Q46; Q47; Q49; Q50; Q52; Q53; Q54; Q56; Q57; Q69; Q70; Q77; Q86
2N7002B2N7002BAO3414/SOT23DISCRETE16Q16; Q17; Q18; Q19; Q21; Q23; Q26; Q27; Q42; Q48; Q62; Q63; Q64; Q68; Q81; Q87
2N7002B2N7002BAM2324N-T1-TRG_SOT23DISCRETE4Q28; Q29; Q30; Q31
5EHDRM-03P_5MM5EHDRM-03P_5MM5EHDRM-03P_D90IC2DC_IN1; DIO_PWR1
A694BA694BLED HOLDER(GREEN/YELLOW)_3MM_D90IC5LED1_1; LED2_1; LED3_1; LED4_1; LED1
AJ_424-05211T02_D90AJ_424-05211T02_D90PHONEJACK STEREO SW(GREEN)IC1LINE_OUT1
AJ_424-05211T02_D90AJ_424-05211T02_D90PHONEJACK STEREO SW(PINK)IC1MIC1
APL1108P-R30MAPL1108P-R30M0.3UH/41A_APL1108P-R30-AX_D180/NCIC2L15; L20
BAT54C_132BAT54C_132BAT54C_SOT23DISCRETE2D23; D28
BAT54C_132BAT54C_132BAS21A_SOT23DISCRETE1D33
BAT54S_132BAT54S_132BAV99_SOT23DISCRETE6D2; D3; D4; D5; D6; D17
BAT54_132BAT54_132BZX84C51_SOT23DISCRETE5D7; D24; D25; D26; D27
BH800-9_S180BH800-9_S180BATTERY HOLDER CR2032LIC1BAT1
BZ_250BZ_250BUZZERIC1BZ1
CFAST_S90_PP-1CFAST_S90_PP-1CFAST SOCKET_H=8.35MMIC1CFAST1
CM315DCM315D32.768KHZ/SMDIC1X2
CON2X2_165A3CON2X2_165A3ATX MALE CONNECTOR 2X2_4.2MM_D180IC1DIO_PWR2
CON4_BCON4_BWAFER 1X4_2.0MM_D180DISCRETE1POWER1
CON6_BCON6_BWAFER 1X6_2.0MM_D180IC1PS2_1
COPPER_1COPPER_1COPPER/NCIC10S1; S2; S3; S4; S6; S7; S8; S9; S10; S11
COPPER_2COPPER_2COPPER/NCIC1S5
DCON9MDCON9MCOM9M_D90IC2COM1_1; COM2_1
DCON9M-TDCON9M-TCOM9M_THIN_D90IC2COM3_1; COM4_1
DDR3_SODIMM_R_S90_HLDDR3_SODIMM_R_S90_HLDDR3 SODIMM REVERSE 204P 1.5V 9.2MM_S90IC1SODIMM1
DFN2X3-6TDFN2X3-6TLTC4357CDCB_DFN2X3-6TIC1U43
DFN4120P10EDFN4120P10EAZ1065-06F_DFN4120P10EIC1ESD5
DIP2A-300DIP2A-300SW1X1_D180(EDS101SZ)IC1CLR_CMOS1
DP_WDPE20_D90DP_WDPE20_D90DISPLAYPORT_20H_D90IC1DP1
DVI30ADVI30ADVI-I CONNECTORDISCRETE1DVI_I1
ECH350R-10PECH350R-10PECH350R-10P_D90IC2DIO1; DIO_TEST1
EL357N-GEL357N-GEL357N(C)(TA)-GIC8U1; U2; U3; U4; U7; U8; U9; U10
FCBGA1170FCBGA1170E3845_FCBGA1170IC1U20
FH25X2_1D27M_S180FH25X2_1D27M_S180FEMALE HEADER 2X25_1.27MM_S180IC1BTB_FH1
FUSE_0456FUSE_0456BRICK 125V/20A_SMDIC1FS1
FUSE_SMDFUSE_SMDFUSE_13V/2.6AIC1FS2
FUSE_SMDFUSE_SMDFUSE_16V/1.25AIC3FS3; FS4; FS5
H264P4-MTH_MTH264P4-MTH_MTNUT_M2_5.6MMIC4NUT1; NUT2; NUT3; NUT4
ISL6262ACRZ-QFN48ISL6262ACRZ-QFN48CH7318C-BFIC1U15
JH2X4-HDJH2X4-HDPIN HEADER 2X4_2.54MM_D180IC1JP1
KDCON5X2_2MKDCON5X2_2MPIN HEADER 2X5_2.0MM_D180IC2COM12_SEL1; COM34_SEL1
KDCON7X2_2MKDCON7X2_2MPIN HEADER 2X7_2.0MM_D180IC1DEBUG1
LQFP48LQFP48ALC886-GR_LQFP48IC1U37
LQFP128_14X14LQFP128_14X14F81866AD_LQFP128_14X14IC1U52
MINIPCIE_52MINIPCIE_52MINI-PCIE_5.6MMIC2MINIPCIE1; MINIPCIE2
MSOP8MSOP8F75909M_MSOP8IC8U13; U19; U31; U46; U49; U50; U56; U61
MTH276_138MTH276_138138 DRILL / 276PADIC16H1; H2; H3; H4; H5; H6; H7; H8; H9; H10; H11; H12; H13; H14; H15; H16
MYEC100_250MYEC100_250820UF/2.5VIC3SC6; SC8; SC9
MYEC138_350MYEC138_350270UF/16VIC7SC4; SC5; SC7; SC10; SC11; SC12; SC15
MYEC200_400MYEC200_400470UF/16VDISCRETE4SC1; SC2; SC13; SC14
MYSMDTO252_GDSMYSMDTO252_GDSAP6679GH_TO252DISCRETE1Q85
OSC-5X3OSC-5X3OSC-48MHZ_4P/SMDIC1OSC1
PH1X2_2D_D180PH1X2_2D_D180PIN HEADER 1X3_2.0MM_D180/NCIC1RESET1
PH25X2_1D27M_H_S180PH25X2_1D27M_H_S180PIN HEADER 2X25_1.27MM_S180IC1BTB_PH1
POWER56POWER56FDMS7694_POWER56IC14Q9; Q10; Q13; Q51; Q55; Q58; Q65; Q66; Q71; Q73; Q74; Q76; Q78; Q82
POWER56POWER56FDMS0312S_POWER56IC7Q11; Q12; Q59; Q60; Q61; Q67; Q79
POWER56POWER56FDMS86300DC_POWER56IC1Q33
POWER56POWER56FDMS8333L_POWER56IC3Q34; Q43; Q45
POWER56POWER56FDMS86103L_POWER56IC3Q37; Q38; Q44
POWER56POWER56FDMS7694_POWER56/NCIC1Q75
PQFN34-3T_5D5X5PQFN34-3T_5D5X5FAN2356MPX_PQFN34-3T_5D5X5IC2U18; U58
QFN36-T_6X6QFN36-T_6X6USB2514B-AEZC_QFN36-T_6X6IC1U57
QFN40-T_5X5QFN40-T_5X5ISL95837HRZ-HF_QFN40-T_5X5IC1U26
QFN40-T_6X6QFN40-T_6X6SP339EER1-L_QFN40-T_6X6IC4U5; U6; U30; U60
QFN64-T_9X9QFN64-T_9X9WGI210-AT_QFN64-TIC2U16; U17
RJ45_RT7-174AAM1ARJ45_RT7-174AAM1ARJ45+TRANSFORMERLEDIC2LAN1; LAN2
RN8SMDARN8SMDA4.7K(8P4R)/NCDISCRETE1RN1
RN8SMDARN8SMDA4.7K(8P4R)DISCRETE1RN2
SATA22P_F_15D15_S90SATA22P_F_15D15_S90SATA CONN 7+15PIN_S90IC1SATA1
SC_10D3X10D3_SMDSC_10D3X10D3_SMD82UF/50V_S180IC1SC3
SER1400SER14000.3UH/49.6A_SER1408-301MED_S180/NCIC2L10; L23
SER1400SER14000.3UH/49.6A_SER1408-301MED_S180IC2L16; L19
SER1400SER14002.0UH/18.5A_SER1412-202ME_S180IC3L18; L21; L25
SER2900SER2900SER2915L-103KL_S180IC1L13
SIM_CON_PPSIM_CON_PPSIM CARD SOCKET 6P_SMDIC1SIM1
SK12D02_D90SK12D02_D90SLIDE SWITCH 1P2T_D90IC1AT_ATX1
SLPG1307SLPG1307SLPG1307-100M_S180/NCIC1L14
SM0603CSM0603C0.1UF/50VDISCRETE250C1; C2; C23; C25; C26; C27; C28; C29; C30; C36; C42; C45; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C92; C96; C103; C105; C107; C109; C112; C113; C116; C117; C118; C119; C120; C121; C122; C123; C124; C126; C127; C130; C131; C134; C136; C137; C141; C142; C143; C148; C149; C150; C151; C152; C153; C155; C159; C160; C163; C171; C186; C187; C214; C217; C218; C219; C220; C221; C223; C225; C226; C227; C230; C231; C232; C234; C238; C242; C243; C248; C250; C252; C253; C255; C260; C261; C268; C269; C270; C272; C273; C274; C275; C276; C278; C280; C281; C282; C287; C291; C292; C296; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C309; C311; C312; C313; C315; C316; C317; C318; C319; C320; C322; C325; C326; C328; C329; C330; C335; C336; C337; C338; C339; C342; C343; C344; C345; C346; C349; C350; C351; C352; C353; C354; C356; C357; C360; C361; C364; C365; C366; C369; C371; C372; C373; C376; C377; C383; C384; C385; C388; C390; C397; C398; C399; C403; C404; C405; C406; C407; C410; C411; C412; C414; C416; C418; C424; C425; C430; C431; C435; C436; C445; C446; C451; C458; C467; C469; C485; C486; C488; C492; C497; C500; C502; C513; C517; C520; C524; C529; C534; C537; C538; C539; C540; C546; C547; C549; C550; C557; C558; C559; C560; C564; C565; C566; C569; C573; C574; C576; C577; C579; C581; C583; C584; C585; C586; C593; C595; C596; C599; C600; C602; C604; C605; C606; C607; C608
SM0603CSM0603C100PF/50VDISCRETE43C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C19; C32; C33; C34; C35; C94; C98; C258; C314; C367; C368; C597; C614; C615; C616; C617; C618; C619; C620; C621; C622; C623; C624; C625; C626; C627; C628; C629
SM0603CSM0603C10PF/50VDISCRETE25C39; C40; C41; C46; C59; C60; C61; C62; C67; C69; C70; C73; C206; C207; C212; C240; C244; C283; C284; C285; C286; C293; C294; C295; C588
SM0603CSM0603C1UF/16VDISCRETE91C44; C90; C91; C93; C97; C99; C114; C115; C138; C144; C154; C157; C161; C164; C165; C166; C170; C172; C173; C174; C175; C177; C178; C179; C181; C182; C183; C184; C185; C188; C189; C192; C194; C202; C203; C222; C235; C245; C246; C247; C251; C254; C257; C358; C359; C363; C374; C379; C380; C386; C402; C408; C409; C413; C415; C417; C420; C426; C428; C433; C437; C438; C439; C442; C449; C450; C452; C454; C457; C459; C460; C461; C462; C472; C474; C476; C478; C479; C480; C491; C496; C498; C501; C521; C563; C578; C580; C589; C601; C610; C611
SM0603CSM0603C0.01UF/50V/NCDISCRETE1C63
SM0603CSM0603C22PF/50VDISCRETE4C64; C66; C323; C327
SM0603CSM0603C0.039UF/50VDISCRETE2C68; C71
SM0603CSM0603C0.015UF/50VDISCRETE2C72; C594
SM0603CSM0603C1000PF/50VDISCRETE8C85; C198; C199; C211; C499; C509; C525; C541
SM0603CSM0603C0.1UF/50V/NCDISCRETE6C86; C102; C190; C191; C233; C477
SM0603CSM0603C18PF/50VDISCRETE4C87; C88; C568; C572
SM0603CSM0603C0.01UF/50VDISCRETE11C101; C104; C108; C111; C394; C395; C505; C506; C507; C508; C531
SM0603CSM0603C4.7UF/10VDISCRETE13C139; C277; C396; C400; C422; C427; C434; C455; C473; C530; C532; C551; C582
SM0603CSM0603C0.22UF/50VDISCRETE6C180; C516; C526; C528; C536; C555
SM0603CSM0603C470PF/50VDISCRETE5C200; C201; C545; C556; C567
SM0603CSM0603C220PF/50VDISCRETE2C204; C548
SM0603CSM0603C680PF/50VDISCRETE1C208
SM0603CSM0603C82PF/50VDISCRETE1C213
SM0603CSM0603C10PF/50V/NCDISCRETE1C228
SM0603CSM0603C0.022UF/50VDISCRETE6C229; C362; C393; C504; C527; C570
SM0603CSM0603C1000PF/50V/NCDISCRETE6C262; C263; C264; C265; C266; C267
SM0603CSM0603C0.033UF/50VDISCRETE2C378; C514
SM0603CSM0603C100PF/50V/NCDISCRETE1C387
SM0603CSM0603C27PF/50VDISCRETE2C391; C392
SM0603CSM0603CNCDISCRETE6C464; C484; C598; C603; R633; R774
SM0603CSM0603C220PF/50V/NCDISCRETE1C523
SM0603CSM0603C330PF/50V/NCDISCRETE1C535
SM0603CSM0603C68PF/50VDISCRETE1C542
SM0603CSM0603C1500PF/50VDISCRETE1C543
SM0603CSM0603C0.068UF/50VDISCRETE1C561
SM0603LSM0603LBEAD 30IC20L1; L2; L3; L4; L5; L6; L7; L8; L11; L12; L27; L28; L29; L30; L31; L32; L33; L34; L35; L36
SM0603RSM0603R100KDISCRETE23R1; R4; R5; R19; R22; R23; R48; R57; R211; R355; R452; R476; R591; R616; R624; R649; R672; R687; R689; R690; R691; R692; R694
SM0603RSM0603R2KDISCRETE7R2; R6; R128; R247; R285; R686; R718
SM0603RSM0603R10KDISCRETE87R3; R34; R35; R36; R39; R49; R53; R55; R67; R70; R106; R107; R119; R120; R122; R126; R127; R163; R170; R171; R206; R207; R209; R220; R237; R262; R274; R301; R302; R309; R313; R327; R328; R332; R340; R363; R371; R406; R408; R413; R414; R415; R416; R417; R421; R426; R427; R428; R430; R431; R439; R442; R451; R454; R462; R480; R491; R515; R517; R537; R544; R573; R587; R603; R604; R607; R625; R627; R631; R650; R660; R667; R697; R701; R702; R717; R724; R734; R736; R747; R763; R770; R771; R779; R781; R788; R798
SM0603RSM0603R2.2DISCRETE4R7; R292; R367; R639
SM0603RSM0603R220DISCRETE5R8; R10; R323; R331; R526
SM0603RSM0603R4.7KDISCRETE65R9; R16; R18; R21; R81; R99; R129; R131; R134; R141; R142; R150; R152; R155; R159; R219; R221; R230; R256; R308; R324; R329; R333; R334; R341; R342; R343; R344; R352; R356; R387; R388; R399; R458; R464; R466; R467; R483; R485; R487; R494; R506; R513; R518; R519; R527; R528; R533; R534; R539; R540; R546; R547; R559; R560; R567; R568; R577; R615; R634; R635; R642; R696; R765; R782
SM0603RSM0603R100K/NCDISCRETE11R11; R12; R13; R14; R20; R133; R139; R422; R486; R648; R789
SM0603RSM0603R22DISCRETE4R17; R172; R175; R392
SM0603RSM0603R1KDISCRETE60R24; R31; R33; R44; R66; R69; R72; R78; R79; R82; R83; R84; R86; R87; R91; R93; R94; R96; R97; R101; R103; R111; R162; R166; R169; R178; R191; R199; R212; R225; R243; R245; R261; R269; R277; R294; R295; R304; R401; R409; R453; R459; R461; R481; R482; R489; R493; R495; R508; R558; R565; R593; R628; R647; R664; R676; R700; R706; R710; R762
SM0603RSM0603R2.2KDISCRETE49R25; R26; R136; R137; R143; R149; R156; R157; R158; R168; R265; R266; R293; R326; R338; R381; R432; R444; R449; R473; R474; R478; R488; R490; R505; R512; R516; R530; R532; R536; R556; R561; R571; R579; R588; R606; R609; R644; R645; R678; R679; R681; R707; R711; R735; R756; R784; R785; R786
SM0603RSM0603R150DISCRETE7R28; R29; R30; R548; R562; R563; R564
SM0603RSM0603R4.99K,1%DISCRETE2R32; R425
SM0603RSM0603R0DISCRETE130R37; R38; R47; R52; R54; R58; R59; R60; R61; R62; R63; R74; R113; R115; R124; R125; R132; R135; R138; R140; R148; R160; R161; R164; R165; R184; R187; R189; R193; R197; R200; R203; R205; R210; R214; R222; R232; R233; R235; R236; R239; R241; R248; R249; R255; R268; R273; R275; R288; R290; R298; R300; R305; R310; R311; R320; R321; R322; R330; R336; R337; R348; R349; R359; R360; R361; R362; R375; R377; R383; R384; R385; R386; R390; R391; R395; R400; R420; R424; R435; R441; R443; R456; R477; R498; R500; R501; R521; R549; R566; R586; R589; R594; R596; R599; R600; R602; R621; R637; R646; R651; R654; R658; R674; R685; R704; R714; R716; R721; R728; R730; R731; R738; R740; R741; R742; R744; R750; R751; R753; R754; R758; R760; R768; R775; R776; R777; R794; R795; R796
SM0603RSM0603R15KDISCRETE5R40; R64; R620; R761; R769
SM0603RSM0603R51DISCRETE6R41; R117; R507; R510; R520; R531
SM0603RSM0603R33DISCRETE22R43; R46; R51; R173; R182; R186; R192; R280; R281; R282; R283; R318; R440; R445; R446; R450; R457; R732; R748; R755; R757; R783
SM0603RSM0603R27.4K,1%DISCRETE3R45; R227; R260
SM0603RSM0603R54.9K,1%DISCRETE2R50; R767
SM0603RSM0603R100DISCRETE20R56; R65; R68; R104; R118; R196; R238; R240; R242; R455; R468; R469; R479; R538; R574; R578; R583; R590; R638; R725
SM0603RSM0603R0/NCDISCRETE34R71; R77; R112; R201; R213; R231; R254; R276; R279; R312; R317; R346; R347; R365; R366; R368; R369; R370; R394; R397; R429; R436; R463; R525; R542; R569; R575; R581; R618; R622; R659; R727; R778; R799
SM0603RSM0603R1K/NCDISCRETE22R73; R76; R80; R85; R92; R244; R284; R402; R404; R410; R418; R447; R448; R471; R475; R492; R535; R554; R601; R605; R723; R797
SM0603RSM0603R1.21K,1%DISCRETE2R75; R511
SM0603RSM0603R10DISCRETE6R88; R89; R90; R465; R746; R749
SM0603RSM0603R20K,1%/NCDISCRETE1R95
SM0603RSM0603R4.7K/NCDISCRETE29R98; R116; R151; R195; R198; R224; R271; R272; R296; R514; R552; R553; R580; R612; R613; R623; R636; R641; R670; R671; R688; R693; R695; R703; R712; R726; R766; R780; R800
SM0603RSM0603R10MDISCRETE2R100; R105
SM0603RSM0603R45.3,1%DISCRETE2R102; R541
SM0603RSM0603R4.02K,1%DISCRETE2R108; R656
SM0603RSM0603R10K/NCDISCRETE25R109; R123; R208; R257; R258; R259; R303; R314; R319; R364; R509; R529; R543; R592; R617; R619; R626; R629; R668; R733; R737; R745; R752; R772; R792
SM0603RSM0603R1.24K,1%DISCRETE2R110; R555
SM0603RSM0603R20K,1%DISCRETE8R114; R130; R335; R339; R389; R484; R759; R793
SM0603RSM0603R47.5,1%DISCRETE1R121
SM0603RSM0603R2.2K/NCDISCRETE9R144; R382; R496; R497; R550; R557; R570; R572; R680
SM0603RSM0603R33/NCDISCRETE1R145
SM0603RSM0603R20,1%DISCRETE2R146; R299
SM0603RSM0603R16.9,1%DISCRETE2R147; R287
SM0603RSM0603R560/NCDISCRETE3R153; R154; R585
SM0603RSM0603R5.1KDISCRETE5R176; R229; R351; R522; R655
SM0603RSM0603R49.9,1%DISCRETE5R177; R179; R180; R597; R608
SM0603RSM0603R150KDISCRETE1R183
SM0603RSM0603R330DISCRETE14R185; R204; R223; R234; R250; R263; R291; R306; R315; R316; R374; R376; R379; R380
SM0603RSM0603R2.2/NCDISCRETE1R188
SM0603RSM0603R5.6KDISCRETE2R190; R228
SM0603RSM0603R5.1DISCRETE1R194
SM0603RSM0603R619K,1%DISCRETE1R202
SM0603RSM0603R301,1%DISCRETE1R218
SM0603RSM0603R1.33K,1%DISCRETE1R246
SM0603RSM0603R287K,1%DISCRETE1R251
SM0603RSM0603R2.21K,1%DISCRETE1R252
SM0603RSM0603R49.9K,1%DISCRETE1R253
SM0603RSM0603R6.98K,1%DISCRETE2R264; R708
SM0603RSM0603R3.83K,1%DISCRETE2R267; R657
SM0603RSM0603R2K/NCDISCRETE2R270; R669
SM0603RSM0603R73.2,1%DISCRETE3R286; R289; R297
SM0603RSM0603R330/NCDISCRETE1R307
SM0603RSM0603R10/NCDISCRETE1R350
SM0603RSM0603R7.5KDISCRETE1R393
SM0603RSM0603R3.3K/NCDISCRETE6R396; R398; R403; R405; R411; R419
SM0603RSM0603R1.5KDISCRETE2R407; R764
SM0603RSM0603R6.65K,1%DISCRETE1R423
SM0603RSM0603R200KDISCRETE3R433; R434; R499
SM0603RSM0603R576K,1%DISCRETE1R437
SM0603RSM0603R866K,1%DISCRETE1R438
SM0603RSM0603R1M/NCDISCRETE1R460
SM0603RSM0603R1.65K,1%DISCRETE2R470; R739
SM0603RSM0603R51K/NCDISCRETE1R472
SM0603RSM0603R147K,1%DISCRETE1R502
SM0603RSM0603R115K,1%DISCRETE1R503
SM0603RSM0603R12.7K,1%DISCRETE1R504
SM0603RSM0603R1MDISCRETE3R523; R545; R729
SM0603RSM0603R57.6K,1%DISCRETE1R524
SM0603RSM0603R560DISCRETE2R576; R584
SM0603RSM0603R357,1%DISCRETE1R582
SM0603RSM0603R402,1%DISCRETE3R595; R598; R610
SM0603RSM0603R162,1%DISCRETE1R611
SM0603RSM0603R23.2,1%DISCRETE1R614
SM0603RSM0603R29.4,1%DISCRETE1R630
SM0603RSM0603RNCDISCRETE4R632; R643; R787; R791
SM0603RSM0603R3.24K,1%DISCRETE1R640
SM0603RSM0603R100/NCDISCRETE2R661; R698
SM0603RSM0603R1.1,1%DISCRETE2R662; R722
SM0603RSM0603R866,1%DISCRETE2R663; R705
SM0603RSM0603R182,1%DISCRETE1R673
SM0603RSM0603R210,1%DISCRETE1R675
SM0603RSM0603R3.83K,1%/NCDISCRETE1R677
SM0603RSM0603R2.37K,1%DISCRETE1R683
SM0603RSM0603R6.8KDISCRETE1R684
SM0603RSM0603R2.61K,1%DISCRETE2R699; R713
SM0603RSM0603R2.55K,1%DISCRETE1R709
SM0603RSM0603R301K,1%DISCRETE2R715; R720
SM0603RSM0603R51KDISCRETE1R719
SM0603RSM0603R12K,1%DISCRETE1R743
SM0603RSM0603R5.36K,1%DISCRETE1R773
SM0603RSM0603R10K,5% THRMDISCRETE4RT1; RT2; RT5; RT6
SM0603RSM0603R100K,5% THRM/NCDISCRETE2RT3; RT4
SM0805CSM0805C22UF/6.3V(0805)IC35C21; C89; C95; C125; C133; C167; C168; C195; C196; C215; C216; C224; C334; C382; C389; C429; C440; C444; C453; C463; C471; C475; C481; C482; C490; C493; C494; C495; C503; C511; C512; C552; C553; C575; C609
SM0805CSM0805C10UF/10V(0805)IC52C22; C43; C100; C106; C110; C132; C140; C146; C147; C156; C158; C162; C169; C176; C193; C197; C205; C209; C210; C237; C241; C249; C256; C259; C279; C297; C308; C321; C324; C331; C332; C340; C347; C375; C381; C419; C423; C441; C443; C447; C456; C465; C466; C468; C470; C489; C510; C515; C518; C544; C554; C587
SM0805CSM0805C0.47UF/50V(0805)IC2C333; C370
SM0805LSM0805LBEAD 30(0805)IC3L37; L38; L39
SM0805RSM0805R2.2(0805)IC5R181; R217; R652; R653; R666
SM0805RSM0805R0(0805)IC6R215; R216; R373; R378; R665; R682
SM0805RSM0805R1(0805)IC1R226
SM1206CSM1206C10UF/16V(1206)DISCRETE28C18; C20; C24; C31; C37; C128; C129; C135; C145; C239; C288; C289; C341; C348; C401; C421; C432; C448; C483; C487; C519; C522; C533; C562; C571; C590; C591; C592
SM1206CSM1206C0.001UF/2KV(1206)DISCRETE6C38; C47; C236; C355; C612; C613
SM1206D_ACSM1206D_AC1N4148WDISCRETE15D13; D14; D18; D22; D29; D30; D31; D32; D35; D36; D38; D41; D42; D43; D44
SM1206RSM1206R2.49K,1%(1206)DISCRETE4R15; R353; R357; R358
SM1206RSM1206R0(1206)DISCRETE3R42; R174; R790
SM1206RSM1206R0(1206)/NCDISCRETE2R167; R278
SM1206RSM1206R5.1K(1206)DISCRETE4R325; R345; R354; R372
SM1210CSM1210C2.2UF/100V(1210)DISCRETE4C65; C271; C290; C310
SM2512RSM2512R0.002,1%(2512)DISCRETE3R27; R412; R551
SMA-LSSMA-LSFM1100LSIC2D8; D37
SMCSMCSMDJ58CA_SMCIC1TVS5
SOD123SOD123MMSZ5226B-TG_SOD-123IC8D10; D11; D12; D15; D16; D19; D20; D21
SOIC8SOIC8APW7120KE-TRL_SOIC8DISCRETE2U53; U59
SOP8B-209SOP8B-209W25Q64FWSSIG-HF_SOIC8-209DISCRETE1U27
SOP8B-209SOP8B-209W25Q16DVSSIG-HF_SOIC8-209DISCRETE2U45; U48
SOP14B-300SOP14B-300LM1877M-9_SOP14B-300IC1U36
SOT23-5SOT23-5SN74LVC1G14DBVR_SOT23-5IC12U11; U12; U28; U29; U33; U34; U35; U38; U39; U40; U41; U42
SOT23-5SOT23-5SN74AHCT1G125DBVR_SOT23-5IC2U14; U44
SOT23-5SOT23-5SN74LVC1G32DBVR_SOT23-5IC2U21; U24
SOT23-5SOT23-5SN74AHC1G08DBVR_SOT23-5/NCIC3U32; U55; U62
SOT23-5SOT23-5SN74AHC1G08DBVR_SOT23-5IC1U54
SOT23-6SOT23-6SESD099-04AT1_SOT23-6DISCRETE10ESD1; ESD2; ESD3; ESD4; ESD6; ESD7; ESD8; ESD9; ESD10; ESD11
SOT23-6SOT23-6RT9194_SOT23-6DISCRETE3U23; U25; U51
SOT23_QASOT23_QA2N3904/SOT23DISCRETE6Q1; Q2; Q14; Q80; Q83; Q84
SOT23_QASOT23_QA2N3904/SOT23/NCDISCRETE2Q22; Q72
TAND_7343TAND_7343330UF/2VIC10TC1; TC2; TC3; TC4; TC5; TC9; TC10; TC11; TC12; TC13
TAND_7343TAND_7343150UF/6.3VIC3TC6; TC7; TC8
TC006-N12AAATC006-N12AAATC006-N12AAAXXXX-3IC1PWR_SW1
TP20TP20N/AIC61TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58; TP59; TP60; TP61
TSSOP38-TTSSOP38-TLT3791-1_TSSOP38-TIC1U47
TYL17X10TYL17X10GRT-CM127125-3R0N-40110_D180/NCDISCRETE3L17; L22; L26
USB2_L_UA04FSXL1930USB2_L_UA04FSXL1930USB2.0_L_D90IC1USB2_1
USB2_L_UA04FWS-ACUSB2_L_UA04FWS-ACUSB2.0_S90IC2USB2_2; USB2_3
USB3_L_124-0921NUSB3_L_124-0921NUSB3.0_L_D90IC1USB3_1
WQFN-20L-T_3X3WQFN-20L-T_3X3RT8207MZQW_WQFN-20L-T_3X3IC1U22
XTL_4P_5X3D2_S180XTL_4P_5X3D2_S18025MHZ_4P/SMDIC3X1; X3; X4
XTL_4P_5X3D2_S180XTL_4P_5X3D2_S18024MHZ_4P/SMDIC1X5
ZPWM-1040ZPWM-10400.36UH/30A_ZPWM-1040MA-R36_S180IC2L9; L24
附件:( I$ {) N/ u1 U7 Z2 N
pcb文件+ t; u2 f2 A9 ]8 D
游客,如果您要查看本帖隐藏内容请回复
- ^2 R/ C, M' t3 h
发表于 2020-5-2 10:50 | 只看该作者
看看有没有SCH
    2023-11-2 15:14
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2020-5-12 10:59 | 只看该作者
    有sch吗?
    “来自电巢APP”
    2023-11-2 15:14
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2020-5-12 11:19 | 只看该作者
    版本太高
    “来自电巢APP”
    2025-9-28 15:26
  • 签到天数: 454 天
    [LV.9]以坛为家II
    发表于 2022-7-3 16:12 | 只看该作者
    学习了,支持~
    奋斗
    2019-11-21 15:17
    发表于 2024-12-17 08:39 | 只看该作者
    感谢分享,学习一下
    发表于 2024-12-20 09:24 | 只看该作者
    学习了,支持~
    发表于 2024-12-20 10:18 | 只看该作者
    感谢分享,谢谢
    难过
    2019-11-19 16:26
    发表于 2024-12-22 10:06 | 只看该作者
    感谢群主分享
    # ?4 h9 h& t0 h8 D4 j5 D5 t% W6 J) k5 I4 b$ Q% @! v2 O6 D
    发表于 2025-9-2 21:00 | 只看该作者
    感谢分享
    “来自电巢APP”
    GMT+8, 2025-10-10 05:07 , Processed in 0.203125 second(s), 27 queries , Gzip On.
