查看: 360|回复: 1
[allegro16.6][2层]手机测试的过流过压保护(OR8012+UART_DB9)pcb文件
发表于 2019-12-26 11:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
0 @5 }, x" D. v# j
5 j9 d/ @* j# D; V0 e
& W$ V& d* ]" U5 z& I7 A& M
文件描述:
: i& \9 ]( U2 l) @2 G
1. 作品用途:手机测试的过流过压保护
2. 软件版本:allegro16.6
3. 层数:2层
4. 用到的主要芯片:OR8012+UART_DB9
5. PCB尺寸:4929*3149 mil
. I  r: E- ?7 F0 g* ?1 b# p$ B
作品截图如下:
_% f/ [3 L0 ?8 w5 f
顶层截图:
9 j% e; M% ~' m) \6 a
1 b) M  T8 @; F3 S; o
底层截图:
+ g% [4 B% w5 {0 T* g+ i
5 T9 L3 t0 e# U" f8 q
全层截图:
6 k: }$ E- W4 L# q7 D; |
; Y. F# ]+ e6 W; F3 w
9 s) o! c* x$ {7 J4 `
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1DC5HCE3800_0_1DC5_HEC3800HEC3800IC2J3; J8
603CAP NP_0603_100NF100NFIC31C2; C3; C6; C7; C9; C10; C12; C15; C17; C20; C23; C26; C27; C31; C36; C37; C38; C45; C60; C62; C64; C66; C122; C123; C124; C125; C128; C129; C131; C132; C133
603CAP NP_0603_470NF470NFIC2C8; C21
603CAP NP_0_0603_100NF100NFIC1C11
603CAP NP_0603_39PF39PFIC1C19
603CAP NP_0603_4700PF4700PFIC1C22
603CAP NP_0603_20PF20PFIC2C30; C32
603CAP NP_0603_100NF/NC100NF/NCIC2C47; C58
603CAP NP_0603_1UF/10V1UF/10VIC2C48; C53
603CAP NP_0603_1UF1UFIC1C134
603INDUCTOR_0603_BLM18PG181SN1BLM18PG181SN1IC1L2
603R_0603_15K/%115K/%1IC1R1
603R_0603_10K10KIC7R2; R16; R30; R104; R111; R116; R118
603R_0603_191K/1%191K/1%IC4R3; R10; R22; R31
603R_0603_33R33RIC4R4; R8; R21; R66
603R_0603_1K1KIC7R5; R9; R110; R117; R124; R125; R126
603R_0603_2K/1%2K/1%IC3R6; R38; R39
603R_0603_23.2K/1%23.2K/1%IC4R7; R11; R28; R35
603R_0603_2.7K/1%2.7K/1%IC2R12; R14
603R_0603_4.7K4.7KIC19R13; R20; R25; R26; R32; R36; R49; R52; R56; R65; R109; R120; R121; R122; R127; R128; R129; R130; R131
603R_0603_1.87K/1%1.87K/1%IC1R15
603R_0603_10K/1%10K/1%IC1R17
603R_0603_47K47KIC3R18; R112; R113
603R_0603_49.9K49.9KIC1R29
603R_0603_1.5K/%11.5K/%1IC3R33; R50; R51
603R_0603_75K/%175K/%1IC4R34; R37; R44; R45
603R_0603_330R330RIC5R55; R62; R63; R64; R67
603R_0603_20K20KIC3R103; R115; R123
603R_0603_3.9K3.9KIC1R132
805CAP_0_0805_10UF/16V10UF/16VIC10C1; C4; C5; C14; C29; C39; C41; C51; C69; C116
805CAP_0_0805_22UF/10V22UF/10VIC5C33; C35; C40; C43; C130
805CAP NP_0805_10UF/16V10UF/16VIC1C127
805CHOKE_0805_100UH/100MA100UH/100mAIC4L1; L3; L5; L6
1206CAP_0_1206_10UF/35V10UF/35VIC6C16; C34; C49; C54; C59; C61
1206CAP NP_1206_10UF/35V10UF/35VIC2C24; C25
1206_POLARSGL41/SM_1206_POLAR_IN4620IN4620IC2D1; D4
1206_POLARSGL41/SM_1206_POLAR_IN4148IN4148IC2D2; D6
1210R_1210_10MR10mRIC2R46; R53
3216_POLARCAP POL_3216_POLAR_10UF/35V10UF/35VIC1C18
C6_3-SMDCAP POL_C6_3-SMD_100UF/35V100UF/35VIC3C13; C28; C42
C10-SMDCAP POL_C10-SMD_470UF/35V470UF/35VIC4C56; C68; C117; C126
C945TR_NPN_C945_C945C945IC2Q6; Q7
CD75CHOKE_CD75_6.8UH/4A6.8UH/4AIC1L4
CRYSTAL_SOURCECRYSTAL_SOURCE_CRYSTAL_SOURCE_33.579MHZIC1U2
DB_9_SUART_DB9_DB_9_S_UART_DB9UART_DB9IC2J1; J10
DB_9_WUART_DB9_DB_9_W_UART_DB9UART_DB9IC2J2; J9
FIX_HOLD_3_54U_BOARD_FIX_HOLD_FIX_HOLD_3_5_4u_board_fix_holdIC4H2; H3; H4; H5
G6K-2F-Y-DC5G6K-2F-DC5_G6K-2F-Y-DC5_G6K-2F-G6K-2F-DC5IC1U15
HEADER_1X3_PLUSCON_V_TEST_HEADER_1X3_PLUS_CON_CON_V_TESTIC1J7
HEADER_2X4CON2X4_HEADER_2X4_CON2X4CON2X4IC1J4
HEADER_2X8CON_0_HEADER_2X8_CON_8X2/NCCON_8X2/NCIC2J5; J6
LED_X4LED_X4_LED_X4_LED_X4led_x4IC1U19
MARK_POINT4U_BOARD_FIX_HOLD_MARK_POINT_4U4u_board_fix_holdIC2H1; H6
MF-MSMD200FUSE_MF-MSMD200_MF-MSMD100MF-MSMD100IC1F1
MF-MSMD200R_MF-MSMD200_49.9R49.9RIC2R108; R119
QFP10S48P0_5M052_QFP10S48P0_5_M058LBNM058LBNIC1U10
RCLAMP0544TRCLAMP0524_RCLAMP0544T_RCLAMP05RCLAMP0524IC1U46
RS485_PLUG_1X3RS485_PLUG_RS485_PLUG_1X3_PLUGPLUGIC1J11
SGM44599SGM44599_SGM44599_SGM44599SGM44599IC2U43; U44
SMASMBJXXCA_SMA_SMBJ36CASMBJ36CAIC1U1
SMBSGL41/SM_SMB_SMBJ36CASMBJ36CAIC1D3
SMBSGL41/SM_SMB_SS36SS36IC1D5
SOP-8-SPADTPS54331_SOP-8-SPAD_TPS54331DDATPS54331DDARIC1U8
SOP-8_300WLKT4101_SOP-8_300W_LKT4101LKT4101IC1U3
SOP-8_300WLM358_SOP-8_300W_LM358LM358IC2U4; U9
SOP-14_300W74HC04_SOP-14_300W_74HC0474HC04IC1U6
SOT263P-MOS_1_SOT263_OR8012OR8012IC2Q2; Q3
SOT-239013_NPN_SOT-23_2SC9452SC945IC7U7; U14; U38; U39; U40; U41; U42
SOT-23-6LSRV05-4_SOT-23-6L_SRV05-4SRV05-4IC2U17; U18
SOT-223AMS1117_0_SOT-223_AMS1117-3.3AMS1117-3.3IC1U12
TSOP6P-MOS_TSOP6_AO6401AO6401IC1Q10
TUSB211TUSB211_TUSB211_TUSB211TUSB211IC1U45
USBAUSB_PLUS_USBA_USB_PLUSUSB_PLUSIC1J13
USB_PLUS_BUSB_PLUS_USB_PLUS_B_USB_PLUSUSB_PLUSIC1J12
XTAL3225XTAL3225_XTAL3225_12MHZ12MHZIC1Y1
YMD12095-03YMD12095-03_YMD12095-03_YMD1209YMD12095-03IC1Q1
附件:
pcb文件
游客,如果您要查看本帖隐藏内容请回复
0 d9 r& v8 N- I. Q
GMT+8, 2025-10-12 21:19 , Processed in 0.156250 second(s), 27 queries , Gzip On.
