查看: 2743|回复: 26
[allegro16.3][12层]ZYNQ_7Z020_CLG400+EPIPHANY_E16G301+DDR3 原理图和pcb文件
发表于 2019-12-23 15:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
) m- x- H! h7 M0 g& I5 d! n7 m$ G4 `# x1 `! E6 i, X, l: X4 K8 t3 A' P! u' r
' ^. x1 z" s* f% W
文件描述:
+ n4 \3 f) v% C+ R* h/ y/ u  ?- x+ {* }' h9 q8 Q  M
3 M5 d7 X* a  g$ H1 ~# `7 i9 K
4 `3 Z4 _$ v; x1 c
1. 软件版本:allegro16.3
2. 层数:12层
3. 用到的主要芯片:ZYNQ_7Z020_CLG400+EPIPHANY_E16G301+DDR3
4. PCB尺寸:3.4*2.15mm
+ h% d: A+ i) _- q
作品截图如下:
& [7 a8 \- v% u' y4 d6 J6 H, Q, Z% ~7 `. a( P' [
顶层截图:
- r& U+ b2 r& Z( Z! N. f2 w; Y1 R. W' h  y8 Z1 Q/ I3 X1 w: q- E; j
底层截图:
6 ~4 N$ s. m) |% k% F5 n
- M4 F* w2 S9 z: {
. B: ^9 M9 i' E8 u0 g1 S- a' X, B* U/ B% V4 t" `8 I  \, z: B
, v, r: |/ E0 q  R8 y. c0 _
全层截图:
- Y; Q1 w4 v  `9 F" ]9 K- D& a. Q8 L5 m% f+ z# p5 ?7 @+ r! d6 _! n5 w6 B& a: R
. s0 f1 j7 F* q' |  `; i8 A
6 J. B# L" g% n! h$ }+ e$ H2 z
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BEAD_0603BLM18SG121TN1D120-OHM_3AIC3FB1; FB2; FB12
BGA324_15SQX1P5_P8MMPEPIPHANY_E16G30116-CORE MICROPROCESSORIC1U23
C0402CAP0402_0P1UF_X5R_35V0.1UFDISCRETE52C7; C9; C10; C11; C16; C24; C25; C26; C27; C28; C31; C32; C35; C36; C37; C39; C41; C42; C43; C44; C45; C46; C47; C50; C51; C52; C55; C56; C58; C59; C60; C64; C65; C67; C68; C69; C144; C145; C196; C239; C258; C259; C260; C261; C263; C264; C288; C289; C290; C291; C297; C298
C0402CAP0402_0P47UF_X5R0.47UFIC41C21; C75; C77; C78; C79; C80; C81; C126; C127; C128; C129; C130; C135; C136; C137; C138; C139; C154; C155; C156; C188; C189; C190; C191; C268; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C285; C292; C293; C294; C295
C0402CAP0402_6PF_NPO_50V6pFIC4C54; C61; C62; C85
C0402CAP0402_2P2UF_X5R2.2UFIC2C57; C66
C0402CAP0402_4P7UF_X5R4.7UFIC19C72; C73; C97; C99; C131; C132; C133; C140; C141; C142; C150; C151; C152; C153; C174; C182; C192; C193; C284
C0402CAP0402_10NF_X7R_16V_C0402_10NF10nFDISCRETE8C95; C230; C231; C233; C234; C262; C265; C266
C0402CAP0402_0P047UF_X5R0.047UFIC12C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C242; C244
C0402_BGACAP0402_4P7UF_X5R4.7UFIC12C13; C18; C19; C74; C98; C149; C162; C169; C175; C180; C181; C282
C0402_BGACAP0402_0P47UF_X5R0.47UFIC27C14; C15; C20; C22; C76; C100; C101; C102; C103; C157; C158; C159; C160; C164; C165; C170; C171; C176; C177; C178; C183; C184; C185; C186; C187; C283; C307
C0402_BGACAP0402_10NF_X7R_16V_C0402_10NF10nFDISCRETE10C23; C82; C198; C200; C202; C204; C206; C208; C210; C212
C0402_BGACAP0402_0P1UF_X5R_35V0.1UFDISCRETE18C83; C96; C197; C199; C201; C203; C205; C207; C209; C211; C213; C215; C217; C219; C221; C223; C225; C227
C0603CAP0603_10UF_X5R10UFIC13C33; C34; C38; C40; C48; C49; C53; C172; C232; C235; C257; C267; C296
C0603CAP0603_4P7UF_16V_X5R4.7UFIC2C63; C287
C0603CAP06031UFIC3C251; C252; C254
C0805CAP0805_6800PF_X7R6800PFIC2C236; C237
C0805CAP0805_10UF_16V_X5R10UFIC10C238; C241; C243; C245; C247; C248; C250; C253; C255; C256
C1210CAP1210_100UF_X5R_LOESR100uFIC17C12; C17; C70; C71; C84; C134; C143; C168; C173; C179; C194; C195; C214; C216; C218; C281; C286
CBGA400_17SQ_1P6H_P8MMPZYNQ_7Z020_CLG4007Z020-CLG400IC1U2
CONN_BSH60P_13P59X25P88_P5P_VCON_BSH_030_VERTBSH-030-01-F-D-AIC4J8; J9; J11; J13
DC_PWR_JCK_9X14P4X11MMHCON_POWER_PJ002A_THPJ-002AIC1J12
F0603FUSE0603_4A4AIC1F1
FBEAD_0402BLM15AG121SN1D120-OHM@100MHzIC10FB3; FB4; FB5; FB6; FB7; FB14; FB15; FB16; FB17; FB18
FBGA136_11X14X1P1_P8MMPDDR3_256MX32DDR3_256MX32IC1U20
HDMI_MICRO19_6P5X7P5X2P9H_P4PHDMI_MICRO_D_RA_SMTHDMI_MICRO_D_RAIC1J10
HDR_1X2_TH_VERHDR_1X2_TH_VERHDR_1X2_TH_VERIC1J15
HDR_1X3_TH_VERHDR_1X3_TH_VER_0.1PHDR_1X3_TH_VERIC2J2; J14
IND2_2X2P5X1P2MMHIND_1P5UH_2A1.5uHIC4L8; L9; L10; L11
LED_0603LED_0603_5MA_RED_LED_0603_REDREDIC2CR1; CR5
LED_0603LED_0603_5MA_GRN_LED_0603_GREENGREENIC4CR4; CR6; CR8; CR10
LQFP64_10SQX1P6MMH_P5MMPHDMI_DVI_XCVR_ADV7513HDMI/DVI XMTRIC1U26
OSC4_1P6X2X7MMHCRYSTAL_4P_24MHZ24MHZIC1Y1
OSC4_1P6X2X7MMHXTAL_4P_25MHZ25MHZIC1Y2
PTH125_200PADPTH125_200PADPTH125_200PADIC4PTH1; PTH2; PTH3; PTH4
QFN32_5SQXP9H_P5MMP_3P45PADUSB3320_ULPI_XCVRUSB_ULPI_XCVRIC2U12; U17
QFN48_7SQXP5PX1MMH_3P1PAD88E1318_QFN4888E1318_1.8V IOIC1U9
QFN-10_1P55X2P05XP6XP5MMPSN65LVDS4DIFF LINE RECEIVERIC1U38
R0402RES0402_240240IC6R1; R3; R30; R89; R119; R120
R0402RES0402_4K754.75KIC29R4; R9; R10; R12; R18; R19; R20; R21; R22; R24; R33; R34; R35; R36; R37; R38; R39; R40; R61; R111; R156; R157; R158; R159; R161; R162; R163; R164; R300
R0402RES0402_1K1KIC19R28; R66; R67; R69; R86; R160; R165; R166; R167; R168; R169; R170; R171; R223; R237; R294; R295; R327; R328
R0402RES0402_3333DISCRETE24R32; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R322; R323; R324
R0402RES0402_22R122.1IC10R41; R42; R44; R55; R56; R82; R94; R99; R110; R114
R0402RES0402_20K20KIC8R43; R45; R46; R47; R48; R50; R51; R52
R0402RES0402_00DISCRETE28R59; R60; R71; R74; R75; R76; R77; R78; R85; R95; R96; R97; R98; R101; R116; R286; R287; R290; R293; R296; R297; R329; R330; R331; R332; R333; R334; R335
R0402RES0402_100100IC3R72; R73; R193
R0402RES0402_4K994.99KIC1R79
R0402RES0402_620620IC3R84; R100; R288
R0402RES0402_8K068.06KIC2R90; R106
R0402RES0402_10K10KIC14R103; R246; R247; R273; R276; R277; R280; R283; R284; R285; R298; R299; R301; R326
R0402RES0402_80P680.6IC2R112; R113
R0402RES0402_887887IC1R224
R0402RES0402_27K427.4KIC1R225
R0402RES0402_56K256.2KIC1R281
R0402RES0402_1010DISCRETE1R325
R0402_BGARES0402_4K754.75KIC2R8; R179
R0402_BGARES0402_1K1KIC5R11; R62; R63; R70; R178
R0402_BGARES0402_20K20KIC1R49
R0402_BGARES0402_00DISCRETE11R80; R81; R219; R220; R221; R222; R238; R239; R289; R291; R292
R0402_BGARES0402_80P680.6IC1R115
R0402_BGARES0402_100100IC49R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R194; R195; R196; R197; R198; R199; R200; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236
R0402_BGARES0402_10K10KIC6R240; R241; R242; R243; R244; R245
R0603RES0603_24K924.9KIC1R278
R0603RES0603_100K100KIC1R279
R0603RES0603_69K869.8KIC1R282
RJ45_17PINS_2LEDRJ45-10_100_1000-BELFUSERJ-45IC1J5
SC_70_6PSMTNC7WZ16NC7WZ16IC3U5; U11; U14
SDMICRO_8PIN_REV_15SQX1P51MMHCONN_MICROSD_CARDMicroSD_CARDIC1J3
SOD-523DIODE_BAS16XV2T1G2mA_75VIC1D1
SOIC8_33P94X4P93X1P63H_P65PMIC2025_1_USB_SWUSB PWR DISTIC1U13
SOT_5PINNC7SZ125NC7SZ125IC2U33; U36
SWITCH_2P5X4X1P6MMHSW_PB_SPST_2PINSW_PB_VERTIC1SW2
TP55TEST_TERM_BLKBLACKIC2TP12; TP14
TP55TEST_TERM_REDREDIC2TP13; TP15
TQFN16_4SQXP75H_P65PIC_ISL9307_DCDC_CONVDC-TO-DC PWR SUPPLYIC1U29
TQFN16_4SQXP75H_P65PIC_ISL9305_DCDC_CONVDC-TO-DC PWR SUPPLYIC1U30
TSSOP8_3SQX1P1H_P65PVOLTMON_4IN_3P3VOLT_MONITORIC1U34
TSSOP8_3X4P4X1P2H_P65MMPIC_SI51219_TSSOP8_3X4P4X1P2H_P6CLOCK GENERATORIC1U35
TSSOP24_6P4X7P9X1P2MMH_P65PTPD12S016ESD PROT & LEVEL SHIFTIC1U37
USB_MICRO5P_5X7X3P07MMHUSB_MICRO_AB_RA_SMTUSB_MICRO_AB_RAIC1J6
USB_MICROB_5P05X7P86X3P1MMH_RUSB_MICRO_B_RA_SMTUSB_MICRO_B_RAIC1J7
VPDFN-8_6X8XP85H_1P27MMPIC_SPI_FLASH_QUAD_128MBSPI-FLASH-QUADIC1U7
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
$ G4 M$ O' Y. W7 t4 X1 e7 x
推荐
发表于 2022-1-18 16:22 | 只看该作者
THANKS
% Y* Z$ g9 ^1 }2 l3 A# E4 E
    慵懒
    2023-1-28 15:08
  • 签到天数: 245 天
    [LV.8]以坛为家I
    推荐
    发表于 2024-8-2 10:46 | 只看该作者
    ZYNQ_7Z020_CLG400+EPIPHANY_E16G301+DDR3 原理图和pcb文件" |+ a* f4 H% z4 g4 g0 x: h
    推荐
    发表于 2020-10-16 14:52 | 只看该作者
    ,积极恢复,积极恢复,积极恢复, `2 R$ V, p# \+ e( H
    谢谢楼主) r; p  T. v" Y! b
    头像被屏蔽
    发表于 2021-9-21 13:46 | 只看该作者
    提示: 作者被禁止或删除 内容自动屏蔽
    发表于 2021-10-21 17:38 | 只看该作者
    谢谢楼主分享!
    发表于 2021-10-21 20:42 | 只看该作者
    看看,学习学习, thanks
    发表于 2022-1-2 10:56 | 只看该作者
    2022-4-8 15:52
  • 签到天数: 35 天
    [LV.5]常住居民I
    13#
    发表于 2022-1-6 15:37 | 只看该作者
    下下来看看% S; y6 H1 a! K
    16#
    发表于 2022-10-20 22:17 | 只看该作者
    回复看看,学习一下
    GMT+8, 2025-10-10 03:28 , Processed in 0.171875 second(s), 30 queries , Gzip On.
