查看: 956|回复: 16
[allegro16.3][6层]4418工控机(S5P4418+axp22x+DDR3)pcb文件
发表于 2019-12-17 18:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
" t, w7 T* ]1 l" G! B; k( Z3 V2 s0 u
8 M  c6 U: L7 H+ q6 K* Y' i$ }[allegro16.3][6层]4418工控机(S5P4418+axp22x+DDR3)pcb文件
+ r# I5 {8 O; M7 j( w* c( |" h6 K1 V2 [; ]/ D
文件描述:4 ]. g7 x, b$ C; L3 ~* H: O& x
: E3 p1 I/ D/ I, w8 ~+ Q1. 作品用途:4418工控机7 ~4 g& j4 G: v+ s+ D+ p
2. 软件版本:allegro16.3
6 W4 [0 Z9 I4 O& C  U& a' g3. 层数:6层( C8 ~5 L8 ?, J0 p' m: v9 z, Z
4. 用到的主要芯片:S5P4418+axp22x+DDR3, W$ w/ t3 {8 t9 g1 L* ?
5. PCB尺寸:57.295*43.098 mm
: h* ~7 R+ g9 K' B& R' h4 ?
+ s  ?( Q( A' G* V作品截图如下:
+ D) u1 Z+ `* _% p5 d& H0 m2 Y! K, B  h- s
顶层截图:
& A: o+ y2 `8 G9 a: T
0 q- Z8 I9 x3 G* g- ~( n, f. | ' X. S0 D% F! `( V3 h
底层截图:
& ]- @, K5 w  k% N
8 h/ T2 f, Y! a # I9 \6 q4 |' X1 M( n
4 r+ ]% p3 x& o- @' b
全层截图:% H5 G4 b2 U6 a" U  |: |
" j9 L5 b1 Y$ b0 Q6 c
2 [1 ]2 Y$ U) L+ J, n. C4 H4 S$ Q. w3 m' I& q
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402CAPCAP_0402CAP_0.1UF0.1uFIC29C2; C4; C23; C43; C55; C59; C62; C68; C72; C74; C79; C80; C81; C84; C86; C89; C90; C98; C101; C102; C104; CM2; CM4; CM6; CM7; CM26; CM33; CM36; CM40
0402CAPCAP_0402CAP_6P6pIC2C5; C6
0402CAPCAP_0402CAP_18P18pIC2C7; C8
0402CAPCAP_0402CAP_1UF1uFIC30C12; C13; C15; C18; C19; C20; C24; C25; C31; C32; C33; C34; C35; C36; C38; C39; C40; C42; C44; C45; C46; C47; C51; C73; C77; C78; CE8; CM5; CM38; CM45
0402CAPCAPCE_0402CAP_10UF/16V10uF/16vIC4C14; C16; C22; C26
0402CAPCAP_0402CAP_1NF1nFIC3C21; C41; C49
0402CAPCAP_0402CAP_NCNCIC1C52
0402CAPCAP_0402CAP_22P22pIC1C96
0402CAPCAP_0402CAP_0.1UF(NC)0.1uF(NC)IC2CM1; CM3
0402CAPCAP_0402CAP_10NF10nFIC9CM8; CM9; CM10; CM27; CM28; CM34; CM35; CM37; CM39
0402RESRESIS_0402RES_100R100RIC2R1; R75
0402RESRESIS_0402RES_10K10KIC29R2; R3; R8; R13; R28; R33; R35; R36; R37; R38; R39; R41; R43; R45; R49; R51; R52; R53; R54; R58; R59; R61; R63; R66; R67; R76; R102; R104; RE10
0402RESRESIS_0402RES_NCNCIC6R4; R14; R50; R55; R62; R65
0402RESRESIS_0402RES_1K1KIC6R5; R6; RM1; RM2; RM7; RM8
0402RESRESIS_0402RES_240R240RIC1R7
0402RESRESIS_0402RES_10M(1%)10M(1%)IC1R9
0402RESRESIS_0402RES_1M1MIC1R10
0402RESRESIS_0402RES_100K100KIC2R12; R32
0402RESRESIS_0402RES_4.3K(1%)4.3K(1%)IC1R15
0402RESRESIS_0402RES_4.7K(1%)4.7K(1%)IC1R16
0402RESRESIS_0402RES_2K2KIC6R17; R18; R19; R22; R23; R24
0402RESRESIS_0402RES_4.7K4.7KIC3R20; R25; R103
0402RESRESIS_0402RES_200R200RIC2R21; R26
0402RESRESIS_0402RES_0R0RIC3R27; R56; R64
0402RESRESIS_0402RES_47K47KIC1R48
0402RESRESIS_0402RES_2.2K2.2KIC1R87
0402RESRESIS_0402RES_33R33RIC1R95
0402RESRESIS_0402RES_400K400KIC1R98
0402RESRESIS_0402RES_270K270KIC1R99
0402RESRESIS_0402RES_10K(NC)10K(NC)IC1R101
0402RESRESIS_0402RES_22K22KIC5R202; R203; R204; R205; R206
0402RESRESIS_0402RES_51K51KIC4RE3; RE4; RE11; RE12
0402RESRESIS_0402RES_22R22RIC1RE15
0402RESRESIS_0402RES_240R(1%)240R(1%)IC2RM3; RM4
0603CAPCAPCE_0603CAP_47UF/10V47uF/10vIC4C70; C71; C75; C100
0603CAPCAPCE_0603CAP_10UF/10V10uF/10vIC2C94; C95
0603CECAPCE_0603CE_10UF/16V10uF/16vIC1C48
0603CECAPCE_0603CE_47UF/10V47uF/10vIC4C58; C63; C97; C99
0603CECAP_0603CE_0.1UF0.1uFIC1C61
0603CECAPCE_0603CE_10UF/10V10uF/10vIC3C91; C92; C93
0603CECAPCE_0603CE_1UF/10V1uF/10vIC1C103
0603INDINDUCTOR_0603IND_1.5UH1.5uHIC6L1; L2; L3; L5; L6; L7
0603RESRESIS_0603RES_0R(NC)0R(NC)IC2R96; R100
0603RESTHERMISTOR_0603RES_DAE06GJ103H3DAE06GJ103H3435VIC1RT1
CY015X7MMCRY_32K768_CY015X7MM_32.768KHZ32.768KHzIC1X4
FBGA96E0MM8BL9X13MMH5TQ4G63AFR_FBGA96E0MM8BL9X13MMh5tq4g63afr_pbcIC2UM1; UM2
FBGA169_EMMCINAND_SANDISK_FBGA169_EMMC_KLM8KLM8G2FEJA-A002IC1EMMC1
FCFBGA537E0MM65S5P4418_FCBGA537_FCFBGA537E0MM6s5p4418_fcbga537IC1U1
OSC3225CRYSTAL4PIN_OSC3225_24MHZ_10PPM24Mhz_10ppmIC1X5
QFN68E0MM4F8X8MMAXP22X_QFN68E0MM4F8X8MM_AXP22Xaxp22xIC1U3
SOD323DIODE_SOD323_1N58191n5819IC2D1; D4
SOD323DIODE_SOD323_S4S4IC1D3
SOT23V5PINSN74LVC1G32DBVR_C325_SOT23V5PINsn74lvc1g32dbvr_c325IC1U7
SOT23V6PINAS1363ADSOT23V6_0_SOT23V6PIN_ALALPU-MP_sot23v6IC1U6
SOT23V123SOT23V123NPN_SOT23V123_2N70022N7002IC1Q1
TH06R10B06R12D05CON1_TH06R10B06R12D05_SIGPsigpIC182PAD1; PAD2; PAD3; PAD4; PAD7; PAD9; PAD10; PAD11; PAD12; PAD13; PAD14; PAD16; PAD17; PAD18; PAD19; PAD20; PAD21; PAD22; PAD23; PAD24; PAD25; PAD26; PAD27; PAD28; PAD29; PAD31; PAD32; PAD33; PAD34; PAD37; PAD38; PAD43; PAD44; PAD48; PAD49; PAD52; PAD69; PAD71; PAD73; PAD74; PAD75; PAD78; PAD79; PAD80; PAD81; PAD82; PAD83; PAD84; PAD86; PAD97; PAD100; PAD101; PAD113; PAD123; PAD125; PAD133; PAD134; PAD135; PAD136; PAD137; PAD138; PAD159; PAD163; PAD165; PAD166; PAD167; PAD168; PAD169; PAD170; PAD171; PAD172; PAD173; PAD174; PAD175; PAD176; PAD177; PAD178; PAD179; PAD180; PAD182; PAD183; PAD184; PAD185; PAD186; PAD187; PAD188; PAD189; PAD190; PAD191; PAD192; PAD193; PAD194; PAD195; PAD196; PAD197; PAD198; PAD199; PAD200; PAD201; PAD202; PAD203; PAD204; PAD205; PAD206; PAD207; PAD208; PAD209; PAD210; PAD211; PAD212; PAD213; PAD214; PAD215; PAD216; PAD217; PAD218; PAD219; PAD221; PAD222; PAD223; PAD224; PAD225; PAD226; PAD227; PAD228; PAD229; PAD230; PAD231; PAD232; PAD233; PAD235; PAD236; PAD244; PAD245; PAD246; PAD247; PAD248; PAD249; PAD250; PAD251; PAD252; PAD253; PAD254; PAD255; PAD256; PAD257; PAD258; PAD259; PAD260; PAD261; PAD262; PAD263; PAD264; PAD265; PAD266; PAD267; PAD268; PAD269; PAD270; PAD271; PAD272; PAD273; PAD274; PAD275; PAD276; PAD277; PAD278; PAD279; PAD280; PAD281; PAD282; PAD284; PAD285; PAD286; PAD287; PAD288; PAD289; PAD290; PAD291; PAD292; PAD293; PAD294
WDFN_8L2X2ETA3451D2I_T_WDFN_8L2X2_ETA3451eta3451d2I_tIC1U5
附件:( U7 L; ?+ L/ r' W
PCB文件如下:6 K' v. M7 j9 J$ h0 q7 U
" e4 D  b8 t% M- C, c- N2 D
游客,如果您要查看本帖隐藏内容请回复
. \1 k! B: [+ q, o2 d6 @- W2 w9 [2 U3 q: j- n6 l  m) Q4 M
    奋斗
    2023-2-20 15:29
    推荐
    发表于 2020-8-17 11:23 | 只看该作者
    感谢分享感谢分享感谢分享感谢分享感谢分享感谢分享感谢分享感谢分享
    推荐
    发表于 2023-3-17 19:11 | 只看该作者
    享感谢分享感谢分享感谢分享感谢分享
    推荐
    发表于 2020-6-6 22:47 | 只看该作者
    ganxiefenxiang,hehehhehhhehhhh+ Y- b6 Q' B- S+ b, O
    擦汗
    2021-9-2 15:13
  • 签到天数: 344 天
    [LV.8]以坛为家I
    发表于 2019-12-19 08:01 | 只看该作者
    不错的核心版谢谢分享
    2025-10-10 15:06
  • 签到天数: 593 天
    [LV.9]以坛为家II
    发表于 2019-12-21 10:08 | 只看该作者
    不错的核心版
    发表于 2019-12-21 14:50 | 只看该作者
    gan xie qian bei d fenxiang
    * c) K% v# W1 d7 x
    发表于 2020-2-28 10:01 | 只看该作者
    发表于 2020-2-28 13:22 | 只看该作者
    学习学习学习学习学习# }& E/ t( p* o/ ]: ?  ]+ ~9 y! C
    发表于 2020-2-29 00:05 | 只看该作者
    感谢分享!
    “来自电巢APP”
    发表于 2020-6-6 21:42 | 只看该作者
    haodongxi ,hhehhehehehe e
    3 _% a! C: |- C4 E0 \1 G8 \
    GMT+8, 2025-10-12 14:50 , Processed in 0.171875 second(s), 29 queries , Gzip On.
