查看: 1306|回复: 5
[allegro 15.7]【6层】RK3066+RK618+2片DDR3 pcb文件分享
发表于 2019-12-13 17:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 ce958www 于 2019-12-13 17:33 编辑   l- J2 r) l, `- v) M) L5 C  ]
' m, V$ @# g0 z4 Q6 W7 C2 T
) s0 S( X. Q0 V; H4 s/ c' U; }
0 L$ e% @/ D8 E- y. M( i. X4 r2 r: a$ j- Q
文件描述:
  ^* c% d; f2 r: O  c& E
1. 软件版本:allegro 15.7
2. 层数:6层
3. 用到的主要芯片:RK3066+RK618+2片DDR3
4. PCB尺寸:异形
$ `+ T7 W, p" k" |  q
- L3 ]! _( _$ G
作品截图如下:
7 B, c; s- k$ |' Y3 k# h3 B
顶层截图:
0 w$ u' B# H& D2 ]9 {9 ~2 K; n6 E0 V: T  T5 ^7 G5 U- L
底层截图:
: ?, Z1 P& b3 H' [; E
6 g, a" C6 q2 A. x  ]
1 t* ^& s. s- ?. V. z* k
8 D: a( D# m0 i
全层截图:
1 @/ @9 }; s( h1 y; `) I; a2 k+ n; A! [5 A( G1 F
& r1 |+ q1 L8 S1 G7 C; q6 w
1 a2 c  J( s4 n$ q' t' H+ h- H' a6 Q" ~5 [+ U! L8 k6 Q1 \, g4 d5 f
/ Y/ ~6 Q# [6 e1 i' Q9 {
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0D5SMD-6HCON6_0D5SMD-6H_6PIN-DOWN6PIN-DOWNIC1CN35
0D5SMD-6HCON6_0D5SMD-6H_NCNCIC1CN42
0D5SMD-24HOV9712_0D5SMD-24H_24P-0D5-DOWN24P-0D5-DOWNIC1CN55
1D25SMD-2HCON2_1D25SMD-2H_SIP2SIP2IC1CN30
1D25SMD-4HCON4_1D25SMD-4H_4PIN-H4PIN-HIC2CN41; CN47
1D65SMD-6HS2329_1D65SMD-6H_S2329S2329IC1U619
2D0SIP-4VSIP4_2D0SIP-4V_NCNCIC1CN1
2D0SIP-4VSIP4_2D0SIP-4V_4PIN4PinIC1CON11
2D0SMD-10HCON10_2D0SMD-10H_10PIN10PINIC1CN54
2D95SMD-4HMIC-4_2D95SMD-4H_ZTS6011DZTS6011DIC1MIC1
BGA453-19X19RK3066N_BGA453-19X19_RK3066RK3066IC1U4
BGA618-0_65-9_75X9_75RK618_BGA618-0_65-9_75X9_75_RK6RK618IC1U622
C0402CAP NP_C0402_104/16V104/16VIC109C3; C32; C34; C36; C37; C38; C39; C40; C47; C52; C53; C54; C55; C56; C57; C58; C60; C61; C62; C63; C65; C70; C71; C72; C73; C74; C75; C76; C77; C83; C85; C86; C87; C88; C89; C90; C91; C92; C97; C98; C103; C104; C109; C110; C111; C112; C114; C121; C124; C131; C135; C138; C139; C149; C154; C155; C156; C157; C158; C159; C160; C161; C162; C173; C183; C185; C194; C195; C208; C212; C219; C222; C225; C232; C233; C238; C252; C253; C258; C261; C268; C272; C273; C277; C278; C280; C285; C289; C290; C291; C292; C293; C295; C296; C298; C299; C300; C302; C303; C304; C305; C306; C308; C312; C313; C314; C315; C320; C420
C0402CAP NP_4_C0402_NCNCIC1C6
C0402CAP NP_C0402_12P/50V12P/50VIC2C18; C22
C0402CAP NP_C0402_16V/1UF16V/1UFIC36C19; C24; C25; C26; C41; C45; C50; C51; C101; C102; C129; C132; C134; C136; C143; C144; C148; C170; C171; C209; C216; C218; C251; C254; C275; C283; C284; C307; C317; C319; C325; C326; C328; C330; C366; C385
C0402R_C0402_100P100PIC1C30
C0402CAP NP_C0402_22NF/50V22nF/50VIC1C33
C0402CAP NP_C0402_27P27PIC4C35; C59; C176; C177
C0402CAP NP_C0402_8P/50V8P/50VIC3C43; C44; C257
C0402CAP NP_C0402_16V/10NF16V/10NFIC1C46
C0402CAP NP_C0402_102102IC14C64; C78; C79; C80; C81; C120; C191; C202; C203; C211; C224; C279; C297; C311
C0402CAP NP_C0402_330PF330PFIC4C68; C69; C115; C122
C0402CAP NP_C0402_NCNCIC21C93; C105; C106; C107; C141; C142; C151; C163; C164; C165; C167; C168; C169; C180; C242; C286; C287; C288; C318; C417; C419
C0402CAP NP_C0402_104104IC5C125; C126; C127; C130; C179
C0402CAP NP_C0402_2.2UF/16V2.2UF/16VIC4C146; C147; C188; C193
C0402CAP NP_C0402_100P100PIC1C150
C0402CAP NP_C0402_103103IC4C174; C205; C207; C243
C0402CAP NP_C0402_22P22PIC3C196; C197; C382
C0402CAP NP_C0402_105105IC1C206
C0402CAP NP_C0402_18P18PIC2C234; C235
C0402CAP NP_C0402_25V/27PF25V/27PFIC2C269; C270
C0402CAP NP_C0402_30P30PIC1C505
C0603CAP NP_C0603_4.7UF/6.3V4.7uF/6.3VIC39C7; C9; C10; C12; C13; C14; C15; C16; C17; C20; C23; C27; C82; C95; C96; C116; C117; C118; C119; C123; C133; C137; C145; C184; C198; C204; C265; C281; C282; C294; C309; C310; C316; C321; C322; C323; C327; C329; C331
C0603CAP NP_C0603_4.7U/6.3V4.7U/6.3VIC2C128; C230
C0603CAP NP_C0603_NCNCIC4C178; C324; C332; C333
C0603CAP NP_C0603_2U2/10V2U2/10VIC1C241
C0603CAP NP_C0603_10UF/6.3V10uF/6.3VIC1C271
C0603CAP NP_C0603_821821IC1C384
C0603CAP NP_C0603_68P68PIC1C416
C0603CAP NP_C0603_822822IC1C418
C0805CAP NP_C0805_10U/10V10U/10VIC16C1; C2; C5; C8; C11; C48; C49; C66; C67; C84; C99; C181; C182; C186; C187; C210
C0805CAP NP_C0805_22UF/6.3V22UF/6.3VIC12C4; C21; C28; C29; C31; C94; C100; C113; C175; C199; C231; C506
C0805CAP NP_C0805_10U/16V10U/16VIC7C42; C213; C221; C262; C264; C267; C301
C0805CAP NP_C0805_104104IC1C108
C0805CAP NP_C0805_NCNCIC1C172
C0805CAP NP_C0805_105/25V105/25VIC2C236; C274
C0805CAP NP_C0805_10UF/10V10UF/10VIC1C240
C1206CAP NP_C1206_22U/10V22U/10VIC3C239; C259; C276
CD550INDUCTOR_CD550_22UH/CD55022uH/CD550IC5L5; L7; L9; L11; L20
CD1050INDUCTOR_CD1050_47UH/CD10547uH/cd105IC1L30
CON25P-0D6-9X4HTP49805-04ZTAP-E_CON25P-0D6-9XHTP49805-04ZTAP-EIC1LCD2
CON25P-0D6-9X4B14T50084N-02_CON25P-0D6-9X4_NCNCIC1LCD3
CRY-D3225CRYSTAL-4_0_CRY-D3225_24M-20PPM24M-20ppmIC1Y2
CRY-MC146CRYSTAL_2_CRY-MC146_32.768K32.768KIC1Y1
DO-214ABDIODE SCHOTTKY_DO-214AB_B540CB540CIC1D33
DO-214ACDIODE SCHOTTKY_DO-214AC_58195819IC1D19
DO-214ACDIODE_DO-214AC_40014001IC1D41
DO-214ADDIODE_DO-214AD_IN5406IN5406IC1D42
EC6D3X5D3MCAP E_EC6D3X5D3M_220U/6V3220U/6V3IC2C140; C263
EC6D3X5D3MCAP E_EC6D3X5D3M_100U/16V100U/16VIC7C192; C214; C220; C237; C255; C256; C260
EC6D3X5D3MCAP E_EC6D3X5D3M_220UF/6V3220UF/6V3IC1EC42
FBGA96-10X14DDRII_3_FBGA96-10X14_DDR3-512MBDDR3-512MBIC2U6; U7
GPS-ANTPADGPSANT_2_GPS-ANTPAD_NCNCIC1ANT1
HC-49SCRYSTAL_HC-49S_28.63636MHZ28.63636MHzIC1X3
HC-49SCRYSTAL_HC-49S_12M12MIC2X4; X5
INAND_5D0ANDROID_32_INAND_5D0_INAND 5.0-INAND 5.0-8GBIC1U8
IND-4X4INDUCTOR_1_IND-4X4_2.2UH2.2uHIC3L1; L2; L3
IND-4X4INDUCTOR_1_IND-4X4_3.3UH/3A3.3uH/3AIC1L4
IND-CDH2B18INDUCTOR_1_IND-CDH2B18_2.2UH/1.2.2uH/1.60AIC1L13
L0402FERRITE BEAD_L0402_NCNCIC8FB20; FB25; FB32; FB33; FB35; FB38; FB39; FB42
L0402FERRITE BEAD_L0402_BLM15AG601SNBLM15AG601SN1IC23FB21; FB22; FB27; FB28; FB29; FB30; FB31; FB36; FB37; FB40; FB41; FB95; FB96; FB97; FB98; FB99; FB100; FB101; FB102; FB103; FB104; FB105; FB106
L0402FERRITE BEAD_L0402_BLM15BD102SNBLM15BD102SN1IC28FB66; FB67; FB68; FB69; FB70; FB71; FB72; FB73; FB74; FB75; FB76; FB77; FB78; FB79; FB80; FB81; FB82; FB83; FB84; FB85; FB86; FB87; FB88; FB89; FB90; FB91; FB92; FB93
L0603INDUCTOR_0_L0603_BLM18PG181SN1BLM18PG181SN1IC1FB7
L0603INDUCTOR_0_L0603_NCNCIC1FB8
L0603INDUCTOR_L0603_3.3UH/06033.3uH/0603IC2L10; L25
L0603INDUCTOR_L0603_BLM18HG601SN1DBLM18HG601SN1DIC7L31; L32; L33; L34; L35; L37; L38
L0603INDUCTOR_L0603_NCNCIC1L36
L0805FERRITE BEAD_L0805_FB601/0805FB601/0805IC1FB34
L0805FERRITE BEAD_L0805_GZ2012U601GZ2012U601IC1FB94
L1008INDUCTOR_L1008_NCNCIC1L24
L1206FERRITE BEAD_L1206_FB310/1206FB310/1206IC2L6; L12
LED0603LED_LED0603_BLUEBLUEIC1D7
LED0805LED_LED0805_WHITEwhiteIC1D5
LGA2X2D5X0D95BMP280_0_LGA2X2D5X0D95_NCNCIC1U613
LGA12BAM250_0_LGA12_BMA250EBMA250EIC1U216
LGA54_0_4SN9C5811_LGA54_0_4_SN9C5811SN9C5811IC1U618
LQFP-48STM8S207CB_LQFP-48_STM8S207CBT6STM8S207CBT6IC1U608
MARKMARK_MARK_**IC4MARK1; MARK2; MARK3; MARK4
MINI_PCIEMINI-PCIE-SOCKET_0_MINI_PCIE_MIMINI-PCIE-SOCKETIC1CN57
MSOP-10QN8027_MSOP-10_NCNCIC1U217
QFNS32_0D5_1GADV7180_32_QFNS32_0D5_1G_ADV718ADV7180KCP32ZIC1U621
R0402R_R0402_100R0100R0IC4R1; R299; R300; R690
R0402R_R0402_0R0RIC13R2; R9; R90; R244; R563; R564; R567; R568; R569; R570; R610; R625; R691
R0402R_R0402_4.99K04.99K0IC1R3
R0402R_R0402_20K020K0IC1R4
R0402R_R0402_47K47KIC7R5; R6; R86; R92; R137; R225; R662
R0402R_R0402_150K150KIC2R7; R11
R0402R_R0402_1K1KIC20R8; R24; R28; R57; R61; R66; R70; R76; R77; R78; R116; R151; R164; R315; R372; R385; R450; R458; R659; R665
R0402R_R0402_22K22KIC14R10; R58; R115; R147; R148; R149; R152; R165; R358; R364; R456; R657; R697; R698
R0402R_R0402_100K0100K0IC2R12; R26
R0402R_R0402_14.7K014.7K0IC1R13
R0402R_R0402_196K0196K0IC1R14
R0402R_R0402_7.5K07.5K0IC1R15
R0402R_R0402_6.2K06.2K0IC2R16; R183
R0402R_R0402_120K0120K0IC1R17
R0402R_R0402_10K10KIC57R18; R19; R27; R30; R34; R35; R36; R43; R44; R45; R46; R47; R48; R50; R59; R60; R68; R75; R82; R83; R95; R97; R98; R99; R100; R101; R102; R103; R105; R106; R107; R109; R110; R111; R132; R133; R139; R150; R187; R192; R205; R396; R451; R457; R461; R491; R587; R588; R600; R601; R663; R664; R666; R687; R692; R693; R694
R0402R_R0402_43.2R043.2R0IC2R20; R21
R0402R_R0402_10K010K0IC5R22; R39; R40; R41; R42
R0402R_R0402_4K704K70IC5R29; R49; R131; R455; R658
R0402R_R0402_1M1MIC4R31; R232; R689; R696
R0402R_R0402_22R022R0IC1R32
R0402R_R0402_240R0240R0IC3R37; R87; R88
R0402RESISTOR_R0402_NCNCIC1R38
R0402R_R0402_4.7K4.7KIC8R51; R52; R53; R54; R184; R185; R460; R463
R0402R_R0402_1.5K1.5KIC2R55; R56
R0402R_R0402_33R33RIC51R62; R63; R64; R65; R69; R71; R72; R73; R121; R125; R180; R182; R493; R494; R496; R497; R550; R551; R566; R576; R579; R580; R581; R582; R583; R586; R596; R597; R598; R599; R602; R603; R634; R635; R636; R637; R699; R700; R701; R702; R703; R704; R705; R706; R707; R708; R709; R710; R711; R712; R721
R0402R_R0402_75R075R0IC2R74; R112
R0402R_R0402_27K27KIC3R81; R388; R445
R0402R_R0402_300R300RIC2R84; R85
R0402R_0_R0402_NCNCIC1R89
R0402R_R0402_180K0180K0IC1R91
R0402R_R0402_12K12KIC1R108
R0402R_R0402_39R39RIC2R122; R123
R0402R_R0402_36R36RIC2R126; R129
R0402R_R0402_NCNCIC24R130; R565; R571; R572; R590; R591; R592; R593; R594; R595; R626; R627; R628; R656; R685; R713; R714; R715; R716; R719; R722; R724; R725; R726
R0402R_R0402_150K0150K0IC1R134
R0402R_R0402_33K33KIC2R135; R136
R0402R_R0402_33K033K0IC1R138
R0402R_R0402_680R680RIC1R142
R0402R_R0402_39K39KIC1R178
R0402R_R0402_1.8K1.8KIC1R254
R0402R_R0402_560R560RIC1R312
R0402R_R0402_100K100KIC2R314; R366
R0402R_R0402_2K202K20IC1R322
R0402R_R0402_91K91KIC1R661
R0603CON2_R0603_NCNCIC1J18
R0603R_R0603_2K72K7IC1R25
R0603R_R0603_59K59KIC1R384
R0603R_R0603_11K11KIC1R386
R0603R_R0603_56K56KIC1R688
R0603R_R0603_1K6901K690IC1R695
R0805R_R0805_5R15R1IC2R67; R660
R1206RT_R1206_500MA16V/1206500MA16V/1206IC1R686
RA0402_8R8P4R_RA0402_8_4PX10K4PX10KIC2RN1; RN2
SIM-CARDSIM-C752_SIM-CARD_SIM-C752SIM-C752IC1CN53
SMD-OPLGA-CM3232BAM250_2_SMD-OPLGA-CM3232_CM323CM3232IC1U218
SOD323DIODE_SOD323_1N41481N4148IC3D1; D2; D4
SOD-80DIODE ZENER_SOD-80_16V16VIC1ZD4
SOD-80DIODE ZENER_SOD-80_7V57V5IC1ZD6
SOD-323DIODE_SOD-323_1N41481N4148IC8D3; D9; D10; D12; D31; D35; D39; D40
SOD-523ESD_SOD-523_RSTD5L10SRSTD5L10SIC6ESD3; ESD4; ESD5; ESD8; ESD9; ESD10
SOD-523ESD_SOD-523_RSES25V030R15RSES25V030R15IC2ESD6; ESD7
SOP16APA2068_SOP16_APA2068apa2068IC1U30
SOP-8EFR9887_0_SOP-8E_FR9887FR9887IC1U10
SOP-8EAPW7080_SOP-8E_APW7080APW7080IC1U39
SOT25DS8008_6_SOT25_SY8009ASY8009AIC1U3
SOT-23NPN1_SOT-23_KRC103SKRC103SIC14Q1; Q2; Q3; Q12; Q14; Q18; Q20; Q25; Q26; Q27; Q28; Q30; Q36; Q37
SOT-23NPN_SOT-23_S8050S8050IC8Q6; Q7; Q16; Q34; Q47; Q52; Q55; Q56
SOT-23NPN1_SOT-23_AO3401AO3401IC7Q13; Q17; Q19; Q21; Q29; Q35; Q57
SOT-23PNP_SOT-23_S8550S8550IC1Q15
SOT-23NPN_SOT-23_MMBT3904MMBT3904IC1Q24
SOT-23AX6901ARA_0_SOT-23_S1206B12S1206B12IC3U11; U16; U20
SOT-23AX6901ARA_0_SOT-23_BL8064-1V5BL8064-1V5IC1U12
SOT-23AX6901ARA_0_SOT-23_BL8064-2V5BL8064-2V5IC1U13
SOT-23BAT54C_SOT-23_BAT54CBAT54CIC2U15; U18
SOT-23-5MP2105_SOT-23-5_MP2104MP2104IC1U9
SOT-23-6MP3202_SOT-23-6_MP3202MP3202IC1U25
SOT-8978MXX_0_SOT-89_HT7550-5.0HT7550-5.0IC1U27
SSOP8EON25T16_SSOP8_MX25L1006EMX25L1006EIC1U620
SSOP28AU9254_1_SSOP28_GL850GL850IC1U17
SW3D5X8X4D5SW-4P_SW3D5X8X4D5_7*2.5*3.5MM7*2.5*3.5MMIC1SW1
SW6X3D5X5MSW_SW6X3D5X5M_TW2X5TW2x5IC3GPS1; MUTE1; POWER1
T-1_0TEST_0_T-1_0_TEST-1V2TEST-1V2IC1T1
T-1_0TEST_0_T-1_0_TEST-1V5TEST-1V5IC1T2
T-1_0TEST_0_T-1_0_TEST-3V3TEST-3V3IC1T3
T-1_0TEST_0_T-1_0_TESTTESTIC13T4; T5; T6; T7; T8; T9; T10; T11; T13; T20; T21; T22; T23
T-1_0TEST_1_T-1_0_TESTTESTIC1T12
TF-CARDTF-CARD_0_TF-CARD_TF-CARDTF-CARDIC2DVR1; MEDIA1
TO-2521117-TO252_TO-252_AZ1117D/3V3AZ1117D/3V3IC1U23
TPS40TP_TPS40_TPTPIC26TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP31; TP32; TP33; TP34; TP35; TP36
USB-14D3X11USB-8P_USB-14D3X11_USB-8PUSB-8PIC1CN56
VQFN48LP28300_9_VQFN48_TPS659102TPS659102IC1U2
WIFI-GOC-MD-725GOC-MD-725_WIFI-GOC-MD-725_GOC-GOC-MD-725IC1U14
XTAL3CRYSTAL_XTAL3_16MHZ16MHZIC1X1
附件:
pcb文件如下:
游客,如果您要查看本帖隐藏内容请回复
) x3 n" e% ^0 b; ^. n. n/ g- O
    2019-11-29 15:37
    发表于 2019-12-13 19:54 | 只看该作者
    好想学这个软件啊
    奋斗
    2025-10-11 15:32
  • 签到天数: 116 天
    [LV.6]常住居民II
    发表于 2020-10-31 14:29 | 只看该作者
    6666666666
    发表于 2020-11-1 10:03 | 只看该作者
    学习学习,,谢谢分享!:
    发表于 2021-5-6 14:27 | 只看该作者
    6666666666
    发表于 2023-4-11 19:05 | 只看该作者
    学习学习学习
      o; K# d* @6 ]4 S3 _7 Q
    GMT+8, 2025-10-12 14:50 , Processed in 0.156250 second(s), 27 queries , Gzip On.
