查看: 900|回复: 2
DRC出错,请大家帮我分析一下,TKS
发表于 2009-9-24 20:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有个DRC问题,请大家帮我分析一下,谢谢!
7 O2 @# o! I, s$ m
  y- e& e" S; U  _" l. ILISTING: 1 element(s)
* @- F& x& D  |1 r4 V           < DRC ERROR >             T+ {' U1 ~/ H
  Class:           DRC ERROR CLASS
; R& w6 `# _0 j% n  Subclass:        BOTTOM9 m# f' n* ]1 w2 v( @# B2 O) ]
  Origin xy:       (4904.00 725.00)1 T; m5 J7 ~( E3 n8 @3 t
  CONSTRAINT:      Line to Line Spacing
, W& ~1 Q9 ]+ z$ O  t  CONSTRAINT SET:  DEFAULT8 }7 y  f- M7 o
  CONSTRAINT TYPE: NET SPACING CONSTRAINTS- L1 x1 ^9 p) _. t3 s4 K
    Constraint value: 5 MIL
- \- w* _; f- \; S% M    Actual value:     0 MIL/ z. W0 v: v& ^4 a
' b+ ]; i7 X6 I0 V1 G% |0 y  Element type:    VERTICAL LINE SEGMENT$ [6 g/ t, i! m2 f( P1 }
  Class:           ETCH
$ ^; Q+ [" T. l8 d2 H0 C0 H" j  Subclass:        BOTTOM
% Q$ T( S1 r& c" D  part of a connect line
5 |, U. U( x: \$ E1 ?4 y- v  Part of Net Name: I2C_SDA- p3 d( g+ M$ M1 E7 Q: x+ x
segment:xy (4904.00 650.00) xy (4904.00 725.00) width (5.00) 3 a7 c" i; x6 y- c" E* N( L
* d& }8 b" F- }! ^8 \" z  Element type:    HORIZONTAL LINE SEGMENT
5 U" S1 m" W4 ?/ L7 O  Class:           ETCH- x7 ]7 ^: d# R! F
  Subclass:        BOTTOM
1 r; C, d3 Q/ J9 ]  part of a connect line
" l+ S/ o# Z6 D  Part of Net Name: PF2; d% [) [. J6 @4 N; d8 e6 p- d, W6 d
segment:xy (4846.00 725.00) xy (4905.00 725.00) width (10.00) & d. [; d; W" I1 l$ L* G
发表于 2009-9-25 09:50 | 只看该作者
ETCH   BOTTOM    " C$ o1 K  x# H, q/ c4 j* \
NETF2  12C_SDA  LINE TO LINE 的间距不够  你查查看
 楼主| 发表于 2009-9-25 17:14 | 只看该作者
好的,谢谢啊。
GMT+8, 2025-7-31 03:32 , Processed in 0.109375 second(s), 24 queries , Gzip On.
