TA的每日心情 | 怒 2019-11-19 15:55 |
签到天数: 1 天 [LV.1]初来乍到
oElectrical Specifications电气参数
$ x# A, @8 u5 h: L8 ` h型号
& s; l1 m: `% d3 QHolder Type
' X! d7 V! g5 y& D3 E6 t5x7mm Ceramic SuRFace Mount: M4 _9 P9 G9 K/ f5 K" K
频率范围! y: t% Q0 Z. W" i. I
Frequency Range) \: u( l$ L# B: f& Q- }4 D
5.500 to 150. 000 MHZ
% s4 C. O* T9 S& x% Z调整频差
1 ~4 w9 Q$ F7 @9 M6 m+ @/ BFrequency Tolerance (OF) (at25C.
5 A5 H7 v" A/ ^! L: K* `5 Y土10ppm to土100ppm
" l( \8 G3 o! ~8 m! ~9 y0 I温度频差# e/ T) _# K# H r9 J, d
Frequency Drift0 P! Y9 l& I# P. |
土10ppm to土100ppm
. u# ~5 B) d- h工作温度范围 x' ^3 O% I0 j5 U- S z+ x. V0 G, [
Operating Temperature Range
" |2 n6 I) _; r. q-10C - +60C to -40'C - +85"C4 H0 C3 o N% o( h+ K
储存温度范围
9 S/ m0 f6 O* w; @7 vStorage Temperature Range
& U, n; ~- R2 [( m [* l5 F-40C - +85'C/-55C - +125C9 v I+ [& S1 m; n# L
老化
3 F# v7 h1 \* Q/ p! ]. X" MAging (25"C)& ~7 C e2 X) u
士5ppm/ year Maximum% {. ~, B* @' g6 e$ H- T
静电容
9 {( R, ]( w3 t& C: ~Shunt Capacitance (C0)1 z! C3 l" }& i9 q1 n) q8 K! w
7pF max imum8 c8 }8 J* C* ~9 f
激励功率 o9 @4 R, Z, K; x
Drive Level
( }% |* o/ V" v100uW Typical
( G5 I `) O. h; W! [绝缘阻抗; z; t: A m8 s" ~/ Y! t; H# p7 |
Insulaton Resistance (Rs )
# K7 u& R5 K1 @. T4 v+ H500 Megaohms Minimum at D. C100V
" [; h" o6 x" S: w7 u6 P负载电容
: E/ ]+ b. ^& c) C: yLoad Capacitance (CL)
7 \; D: ]$ a6 [# O2 SSuggested by customer8 T( H& J" V* {4 S* y9 }( o
●Equivalent Series Resistance and Mode of Operation! w+ J* k# p0 k- s/ Z: w3 i: P5 \' ~3 `
等效阻抗和振荡模式" w0 X6 d- y" u
Frequency Range 频率范围/ Q- l |* w D/ ]
ESR( 2 )等效阻抗' Y6 u* M% p6 }5 Z$ y
Mode振荡模式
8 ?5 m4 [ k# g( X- j, w5.500 to 8.000 MHZ
# \" u0 T9 k' u! X5 E) G100Max
" ]0 @+ R4 j1 u, A- P" k/ L基频Fundamenta I
% {$ ]; `0 m1 U8 B1 Z8.000 to 10. 000 MHZ
5 ?$ u5 B9 m" }60Max; o( A$ W4 j# q- s1 s9 \$ [$ R
Fundamenta I
' c3 ` z9 }! H9 [, w+ ?0 f/ A10.000 to 14. 000MHZ
# o( V# M& m; `) b50Max
4 v" m% t" ?# m' TFundamenta |
u) Y" m6 v3 D: d3 |: \% r+ C7 O3 @14.000 to 20.000MHZ
. k2 _1 n4 ^; f40Max
3 H4 p, r) b7 `% q ]& VFundamenta I4 E! j. m, Y9 R
≥20.000 MHZ
9 Q/ r* I: r3 X: u+ O5 \$ a# y30Max
% M. q( q6 w8 J( SFundamenta |
' f9 h2 [, d, m; W35. 000 to 150. 000MHZ# j" E, l2 \/ ]
80Max
9 j1 l7 p$ x' F: H三次泛音Third 0ver tone; V* l. W( ~3 Q+ n' ?
9 h) C* k4 A1 `2 U* d) m
, u3 R, n5 c! _/ R W- J0 z
9 U3 ~+ x1 x1 e% [ H# u |
