本帖最后由 mnfvbnk 于 2019-12-12 16:13 编辑 " B$ z' P1 _$ @; s/ R* V5 b8 N
9 W, H' {; V- P2 u8 j) m# T* h+ w文件描述 1. 作品为海思 HI3516CV300 开发板 3. 层数:4层板 4. 用到的主要芯片:HI3516CV300 ! \ | w9 ]) _! q
顶层 " v- p2 E+ p& D z
底层
+ A8 w5 H5 ]# [- _4 o! ]* L
全层 ! Y' Y) j+ w0 |; S9 k- b; U$ l9 r
( \2 m/ ~ D }/ u; { G: O
2 f S9 v, n2 d+ X0 I) e
6 J$ j, p, r6 ^6 S. N( I {' aBOM REFDES$ X4 w2 s+ E. V, s
位号 | COMP_DEVICE_TYPE
) j# y7 [1 e' j类型 | COMP_VALUE
! O% M3 c! B8 P; c K* M. n/ L W属性 | C1 | SC0402 | 5.6PF | C2 | HSC0402 | 330N | C3 | SC0805 | 10UF | C4 | SC0402 | 10NF/NC | C8 | SC0805 | 10UF | C10 | SC0402-BGA | 1UF | C11 | SC0402 | 47PF | C12 | SC0402 | 47PF | C14 | SC0805 | 10UF | C15 | HSC0402 | 2.2UF | C16 | SC0402-BGA | 2.2UF | C17 | SC0402-BGA | 2.2UF | C18 | SC0402-BGA | 2.2UF | C21 | SC0402-BGA | 1UF | C23 | HSC0402 | 2.2UF | C24 | HSC0402 | 2.2UF | C29 | SC0402 | 100NF | C30 | SC0402 | 100NF | C31 | SC0402 | 100NF | C36 | SC0805 | 1UF | C37 | SC0402 | 100NF | C38 | SC0805 | 1UF | C39 | SC0805 | 1UF | C41 | SC0402-BGA | 100NF | C42 | SC0603 | 220PF | C43 | SC0603 | 220PF | C48 | SC0603 | 10UF | C52 | SC0402 | 1NF | C53 | SC1206 | 1NF | C57 | SC0402-BGA | 100NF | C59 | SC0402-BGA | 100NF | C60 | SC0402-BGA | 1UF | C68 | SC0402 | 100NF | C70 | SC0402-BGA | 1UF | C71 | SC0402-BGA | 1UF | C75 | SC0402 | 100NF | C76 | SC0402 | 100NF | C78 | SC0402 | 100NF | C79 | SC0402 | 100NF | C80 | SC0402 | 100NF | C81 | SC0402 | 100NF | C82 | SC0402 | 100NF | C83 | SC0402 | 100NF | C84 | SC0805 | 10UF | C85 | SC0402 | 1UF | C86 | SC0402-BGA | 1UF | C88 | SC0402-BGA | 4.7UF | C90 | SC0402-BGA | 1UF | C91 | SC0402 | 100NF | C92 | SC0402 | 100NF | C94 | SC0402 | 100NF | C96 | SC0402 | 100NF | C97 | SC0402 | 100NF | C98 | SC0402 | 100NF | C99 | SC0402 | 100NF | C100 | SC0402 | 100NF | C102 | SC0402-BGA | 100NF | C103 | SC0402 | 100NF | C104 | SC0402 | 1UF | C105 | SC0402 | 1UF | C106 | SC0603 | 100NF | C107 | SC0603 | 100NF | C108 | SC0603 | 100NF | C109 | SC0402 | 100NF | C110 | SC0603 | 100NF | C111 | SC0402-BGA | 100NF | C112 | SC0402 | 100NF | C113 | SC0402-BGA | 100NF | C114 | SC0402 | 1UF | C116 | SC0402-BGA | 1UF | C118 | SC0603 | 1UF | C119 | SC0603 | 1UF | C121 | HSC0402 | 2.2UF | C122 | SC0402 | 15PF | C123 | SC0402 | 1UF | C124 | SC1210B | 22UF | C125 | SC1210B | 22UF | C126 | SC1210B | 22UF | C127 | SC1210B | 22UF | C128 | SC0805B | 22UF | C129 | SC0402 | 10NF | C137 | SC0603 | 10UF | C139 | SC1206 | 22UF | C144 | SC0402 | 1NF | C145 | SC0402 | 1NF | C147 | SC0603 | 2.2UF | C148 | SC0603 | 2.2UF | C151 | STC7343 | 100UF | C178 | SC0402 | 1UF | C180 | SC0603 | 10UF | C181 | SC0402 | 22NF | C182 | SC0402 | 4.7UF | C184 | SC0603 | 10UF | C188 | SC0402 | 100NF/NC | C189 | SC1210B | 22UF | C190 | SC1210B | 22UF | C191 | SC0402 | 33PF | C192 | SC0603 | 4.7UF/NC | C193 | SC0402 | 10PF | C195 | SC0603 | 10UF | C196 | SC0402 | 10PF | C197 | SC0402 | 27PF | C198 | SC0402 | 27PF | C199 | SC0402 | 18PF | C200 | SC0402 | 18PF | C201 | SC0603 | 10UF | C203 | SC0603 | 10UF | C204 | SC1206 | 22UF | C206 | SC1206 | 47UF | C207 | SC0805B | 22UF | C221 | SC0402 | 15PF | C222 | SC0402 | 15PF | C223 | SC0805 | 10UF | C226 | SC0603 | 10UF | C227 | SC0805 | 10UF | C263 | SC1210 | 100UF | C264 | SC0805 | 10UF | C265 | HSC0402 | 330N | C267 | SC0402-BGA | 2.2UF | C268 | SC0402 | 100NF | C269 | SC0402 | 100NF | C270 | SC0402-BGA | 100NF | C271 | SC0402-BGA | 100NF | C272 | SC0402-BGA | 100NF | C273 | SC0402-BGA | 100NF/NC | C276 | SC0402-BGA | 100NF | C277 | SC0402-BGA | 100NF | C278 | SC0402-BGA | 100NF | C279 | SC0402 | 100NF | C281 | SC0402 | 100NF | C282 | SC0603 | 100NF | C283 | SC0603 | 100NF | C284 | SC0402 | 10NF | C285 | SC0402 | 10NF | C287 | SC0805 | 1UF | C288 | SC0402 | 22PF | C289 | SC0402 | 22PF | C290 | SC0402 | 680PF | C291 | SC0402 | 680PF | C292 | SC0402-BGA | 1UF | C293 | SC0402-BGA | 1UF | C294 | SC0402-BGA | 1UF | C295 | SC0402-BGA | 1UF | C296 | SC0402-BGA | 1UF | C297 | SC0402-BGA | 1UF | C301 | SC0402-BGA | 1UF/NC | C302 | SC0402-BGA | 1UF | C303 | SC0402-BGA | 1UF | C304 | SC0402-BGA | 1UF | C305 | SC0402-BGA | 1UF | C306 | SC0402-BGA | 1UF | C307 | SC0402-BGA | 1UF | C310 | SC0402 | 22NF | C311 | SC0402-BGA | 4.7UF | C312 | SC0402 | 4.7UF | C313 | SC0402 | 4.7UF | C314 | SCAPC2-280-327 | 220UF | C315 | SC1206 | 47UF | C316 | SC1206 | 47UF | C317 | SC0402-BGA | 1NF | C318 | STC3528 | 100UF | C319 | STC3528 | 100UF | C320 | SC0402 | 15PF | C321 | SC0603 | 10UF | C322 | SC0603 | 10UF | C324 | SC0402 | 33PF | C325 | SC0402-BGA | 100NF | C328 | SC0402-BGA | 100NF | C330 | SC0402 | 1UF | C331 | SC0402 | 100NF | C332 | SC0402 | 1UF | C333 | SC0402-BGA | 100NF | C334 | SC0402 | 100NF | D1 | SD1710A | DZ3 | D4 | HSOD882 | DZ3 | D5 | HSOD882 | DZ3 | D10 | HSOD882 | DZ3 | D11 | HSOD882 | DZ3 | D12 | HSOD882 | 0 | D13 | HSOD882 | 0 | D14 | HSD0603-LED | LED | D20 | HSOD882 | DZ3 | D21 | HSOD882 | DZ3 | D23 | HSOD882 | DZ3 | D24 | HSOD882 | DZ3 | D25 | HSOD882 | DZ3 | D26 | HSOD882 | DZ3 | D27 | HSOD882 | DZ3 | D28 | HSOD882 | DZ3 | D31 | SD1714D | DZ3 | F1 | SF6127 | FUSE2 | ID1 | ID-BOARD | NC | ID2 | ID-BOARD | NC | ID3 | ID-BOARD | NC | ID4 | ID-BOARD | NC | ID5 | ID-BOARD | NC | ID6 | ID-BOARD | NC | J1 | MJ8-SRLFY | MJ8-SL | J2 | HSDC10-1614B | MMC8S4 | J3 | SED60-16F-A | MIPI_60_CON_F | J4 | HEAD0101-T-B | NC | J5 | HEAD0101-T-B | NC | J6 | HEAD0101-T-B | NC | J9 | PWC0103-M-N | PWC3_A | J10 | SHEAD-8P-49 | WBC1X8 | J12 | USB4-200-1907 | USB-4S4 | J13 | SHEAD-4P-49 | WBC1X4-M2 | J15 | SHEAD-8P-49 | WBC1X8 | J16 | SHEAD-4P-49 | WBC1X4-M2 | J20 | SHEAD-4P-49 | WBC1X4-M2 | J24 | SIP-2P | NC | J29 | VAF6-1406E | MIC6M1_B | J30 | VAF6-1406E | MIC6M1_B | J32 | SIP-2P | NC | L1 | SPL0404L | 3.9UH | L2 | SPL0404L | 3.9UH | L5 | HSL1008 | 2.2UH | L7 | HSL1008 | 2.2UH | L8 | HSL1008 | 2.2UH | L10 | HSL1008 | 2.2UH | L11 | HSL1008C | 4.7UH | LB1 | SL0402 | LB | LB2 | SL0805 | LB | LB3 | SL0805 | LB | LB5 | SL0402 | LB | LB6 | SL0402 | LB | LB7 | SL0402 | LB | LB9 | SL0805 | LB | LB10 | SL0402 | LB | LB11 | SL0603 | LB | LB12 | SL0603 | LB | LB23 | SL0402 | LB | LB24 | SL0402 | LB | LB25 | SL0402 | LB | LB26 | SL0402 | LB | LB27 | SL0402 | LB | LB28 | SL0402 | LB | LB29 | SL0402 | LB | LB30 | SL0402 | LB | LB31 | SL0402 | LB | LB32 | SL0603 | LB | M1 | MTH_C6MMD3P2MM | NC | M2 | MTH_C6MMD3P2MM | NC | M3 | MTH_C6MMD3P2MM | NC | M4 | MTH_C6MMD3P2MM | NC | Q2 | SOT23 | PMOS-GSD | Q4 | SOT23 | NPN-BEC | Q6 | SOT23 | NPN-BEC | Q7 | SOT23 | NPN-BEC | Q10 | SOT23 | PMOS-GSD | Q11 | SOT23 | NPN-BEC | Q12 | SOT23 | PMOS-GSD | R1 | SR0402 | 15K | R2 | SR0402 | 47K | R3 | SR0603 | 100 | R4 | SR0402 | 15K | R5 | SR0402 | 100 | R6 | SR0402 | 0/NC | R7 | SR0402 | 100 | R8 | SR0603 | 5.1K | R9 | SR0402 | 47K | R10 | SR0402 | 61.9K | R11 | SR0402 | 61.9K | R14 | SR0402 | 0 | R17 | SR0402 | 4.7K/NC | R18 | SR0402 | 15K | R22 | SR0402 | 22 | R23 | SR0402 | 22 | R25 | SR0402 | 4.7K | R26 | SR0402 | 0 | R27 | SR0402 | 0/NC | R28 | SR0402 | 1MEG | R29 | SR0402 | 22 | R30 | SR0402 | 22 | R32 | SR0402 | 10 | R36 | SR0402 | 4.7K | R37 | SR0402 | 1MEG | R38 | SR0402 | 0/NC | R39 | SR0402 | 10K | R40 | SR0603 | 1.1K | R47 | SR0603 | 75 | R48 | SR0603 | 0/NC | R49 | SR0402 | 10K/NC | R50 | SR0603 | 0 | R51 | SR0402 | 10K | R53 | SR0402 | 1K | R54 | SR0402 | 4.7K | R55 | SR0402 | 4.7K | R56 | SR0402 | 10K | R57 | SR0603 | 1.1K | R58 | SR0402 | 15K | R59 | SR0402 | 15K | R64 | SR0402 | 100K | R65 | SR0402 | 4.7K | R67 | SR0402 | 4.7K | R68 | SR0402 | 10K | R69 | SR0402 | 10K | R70 | SR0402 | 4.7K | R71 | SR0402 | 22 | R73 | SR0402 | 22 | R78 | SR0402 | 4.7K/NC | R80 | SR0603 | 10K | R84 | SR0402 | 0 | R85 | SR0402 | 0/NC | R88 | SR0402 | 240 | R91 | SR0402 | 4.7K | R92 | SR0402 | 100K | R93 | SR0402 | 470K/NC | R94 | SR0402 | 470K/NC | R95 | SR0402 | 20K | R96 | SR0402 | 10K | R97 | SR0402 | 4.7K | R98 | SR0402 | 100K | R99 | SR0402 | 100K | R100 | SR0402 | 100K | R103 | SR0603 | 1.1K | R104 | SR0603 | 1.1K | R105 | SR0603 | 1.1K | R106 | HSR0402 | 560 | R107 | SR0402 | 75 | R110 | SR0402 | 2.7K | R111 | SR0402 | 2.7K | R114 | SR0603 | 11.3K | R115 | SR0603 | 11.3K | R119 | SR0402 | 22K | R127 | SR0402 | 100K/NC | R128 | SR0402 | 47K/NC | R129 | SR0402 | 47K/NC | R130 | SR0402 | 47K/NC | R131 | SR0402 | 47K/NC | R132 | SR0603 | 0 | R133 | SR0402 | 47K/NC | R135 | SR0402 | 22 | R137 | SR0402 | 33K | R138 | SR0402 | 1K | R139 | SR0402 | 1K | R140 | SR0402 | 1K | R145 | SR0402 | 1K | R146 | SR0402 | 33K | R148 | SR0603 | 7.68K | R154 | SR0402 | 10K | R155 | SR0402 | 10K | R156 | SR0402 | 10K | R157 | SR0402 | 10K | R160 | SR0603 | 27K | R174 | SR0402 | 91K | R175 | SR0402 | 91K | R176 | SR0603 | 30.9K | R177 | SR0603 | 470 | R185 | SR0402 | 1K | R187 | SR0603 | 270 | R189 | SR0402 | 4.7K/NC | R193 | SR0402 | 4.7K | R203 | SR0402 | 4.7K/NC | R204 | SR0402 | 51K | R205 | SR0603 | 18K | R206 | SR0603 | 120K | R207 | SR0402 | 1K | R208 | SR0402 | 4.7K | R230 | SR0402 | 4.7K | R231 | SR0603 | 4.7K | R233 | SR0402 | 4.7K/NC | R234 | SR0402 | 4.7K/NC | R236 | SR0603 | 1.1K | R242 | SR0603 | 12.7K | R248 | SR0402 | 1K | R256 | SR0402 | 51K | R271 | SR0402 | 100 | R272 | SR0402 | 0/NC | R273 | SR0402 | 0 | R274 | SR0402 | 10K | R276 | SR0402 | 1K | R277 | SR0402 | 10K | R278 | SR0402 | 100K | R279 | SR0402 | 2K | R283 | SR0603 | 2 | R284 | SR0603 | 2 | R286 | SR0603 | 40.2K | R288 | SR0402 | 0 | R289 | SR0402 | 0 | R292 | SR0402 | 6.8K | R293 | SR0402 | 6.8K | R314 | SR0603 | 100/NC | R318 | SR0603 | 5.1K | R320 | SR0402 | 0/NC | R322 | SR0402 | 0 | R323 | SR0402 | 0 | R324 | SR0402 | 0/NC | R325 | SR0402 | 0 | R326 | SR0402 | 0/NC | R327 | SR0402 | 0 | R328 | SR0402 | 15K | R343 | SR0402 | 75 | R347 | SR0402 | 22 | R348 | SR0402 | 22 | R350 | SR0402 | 22 | R351 | SR0402 | 12K | R358 | SR0402 | 20K | R359 | SR0402 | 240/NC | R360 | SR0402 | 240 | R361 | SR0603 | 1.1K | R362 | SR0603 | 24.3K | R363 | SR0603 | 24.3K | R364 | HSR0402 | 560 | R366 | SR0402 | 4.7K | R367 | SR0402 | 4.7K | R368 | SR0402 | 4.7K | R369 | SR0402 | 4.7K | R370 | SR0402 | 4.7K/NC | R371 | SR0402 | 4.7K | R372 | SR0402 | 4.7K | R377 | SR0402 | 4.7K | R378 | SR0402 | 4.7K | R397 | SR0402 | 51K | R398 | SR0402 | 51K | R399 | SR0402 | 51K | R400 | SR0402 | 1K/NC | R401 | SR0402 | 1K/NC | R402 | SR0603 | 1.1K | R403 | SR0402 | 10K | R404 | SR0603 | 0/NC | R405 | SR0603 | 0 | R406 | SR0603 | NC/0 | R407 | SR0603 | 0/NC | R408 | SR0603 | 0 | R409 | SR0603 | 0 | R410 | SR0603 | 0/NC | R412 | SR0402 | 100K | R413 | SR0402 | 100K | R415 | SR0402 | 100K | R416 | SR0402 | 100K | R418 | SR0603 | 2.49K | R419 | SR0402 | 12.1K | R420 | SR0603 | 0 | R421 | SR0603 | 0/NC | R426 | SR0402 | 0 | R433 | SR0402 | 4.7K | R439 | SR0402 | 100 | R443 | SR0402 | 100K | R444 | SR0402 | 10K | R445 | SR0402 | 10K | R446 | SR0402 | 100K | R447 | SR0402 | 4.7K/NC | R448 | SR0402 | 4.7K | R449 | SR0402 | 4.7K | R450 | SR0402 | 4.7K/NC | R451 | SR0402 | 1K | R452 | SR0603 | 510 | R453 | SR0603 | 510 | R454 | SR0402 | 4.7K/NC | R455 | SR0402 | 4.7K | R456 | SR0402 | 4.7K | R457 | SR0402 | 4.7K | R458 | SR0402 | 2.2K | R459 | SR0402 | 5.6K | R460 | SR0402 | 10K | R461 | SR0402 | 22 | S2 | SPSW6-T | MSW-6A | S3 | SPSW6-T | MSW-6A | T1 | STFM16-50-299 | 000-7090-37R | TP1 | TP24-SMD | TESTPOINT | U1 | SOP16-50-300A | NC | U2 | MLF6-065-0202L | TPS2551DRVR | U3 | QFN32C-050-0505LH | RTL8201F-VB-CG | U5 | MSOP8A-26-118 | PAM8303D | U7 | SGM8903 | SGM8903 | U8 | BGA273-26-1818A | HI3516CV300_PER | U12 | BGA96-32-1609N | NT5CC256M16CP | U19 | SOP8-50-150 | LMC6482 | U20 | QFN16-050-0303LH | MP6507 | U24 | SBAT2-13A | PWR1-2 | U31 | TSOT23-8 | MP2122 | U33 | WSON8-MX25L12835ZN | MX25L12835ZN | U35 | TSOT23-8 | MP1494S | U36 | TSOT23-8 | MP1494S | U37 | SOT23-6B | RT9065 | U38 | SOT23-6B | RT9065 | X1 | HSX4-0302 | 24MEG | X2 | HSX2-0302 | 32.768KHZ | X3 | HSX4-0302 | 25MHZ |
- r, Z9 _4 Y: ^' V$ d
! n( H3 x# ?% s: H& N+ J" g! Z4 b
下载附件:
8 I/ F/ ^+ ?4 v+ y2 F6 g/ l4 J# Q* x. f4 u( ^' q* o: F
5 r d" C1 B9 R1 V, f |
