我的是9.5.2的,read me:! {% Q+ R* f3 d9 F% j
DownStream CAM350 9.5 license path/ y1 U+ |8 f( a
4 l' k' U5 W4 g. C$ n) U. iUse for cam350 v9.5 win32 version which used flexnet 11.4, fix ECC signture and 5 H! r/ r& K0 J8 i) n9 ~
force it to default license(not test in Vista)# A! ] G. z+ D1 G5 }
& d8 p1 m/ p& f% q. ?+ ^2 C8 wUsage:- K6 p9 {/ i9 ^$ } D
copy the files(sdb400c.dll and license.dat) into cam350 v9.5 install folder4 n1 Z* N0 ?& n2 d
eg.(C:\Program Files\DownStream Technologies\CAM350 9.5)
5 {* t- Q6 y" \, f
' _4 Z" ^; w" ]1 mNOTE:
7 d5 t* s5 F3 { ]* l7 a1, There are no editable fields in this license file,any editing will invalidate the license ( x& a3 @0 ^ R4 c% b# g
and will cause cam350 run in DEMO.: Q0 E, U; b: V# l/ Z
2, If you are locked into DEMO in some case, pls delete it in registor1 ?9 G3 O3 m' M
[HKEY_LOCAL_MACHINE\SOFTWARE\DownStream Technologies\CAM350\9.5\Demo]
9 ^0 h# |5 N$ x# Z+ w, T or import my unlock.reg to unlock...
0 I# Y* z3 K, e* e8 x2 o1 y ; v. q1 ~* K# ^) d3 _/ J, i7 v' ?
3, Don't use it for commercial purpose.
9 ?9 U+ B" B9 a5 I' F& B( l) d" f) t7 q
LONG
, l5 R* c6 |% N8 ~ 2007.05.04 |
