General$ p5 h) t: f5 d$ d
% C- O. [9 C% r7 N w* [8 W" R
6 E/ B# R! r! h+ ]. O Tablet, two mcu subsystems architecture6 t6 V1 f6 [$ D1 I$ p- U/ S& F0 H
) ], F7 A# |9 c) l( k
% v! W( R5 e o @ Supports eMMC/uFS boot3 |: Q3 w' t& @! N
, F2 R1 V' B f* f% J* i7 ^7 B4 U5 E5 h- O$ p1 V9 Y
Supports LPDDR3
- D/ M1 N/ k! v: b" g& r7 x1 X |" t; w: W6 t8 t" g
0 w6 \2 ?1 v0 Y Supports LPDDR4X" }9 U9 O& l7 F4 A& G
" V* J( k& e% K: N$ N! n9 r$ B- S8 O* J
) _8 g% `2 N X6 S- t5 d7 J& ^
" B. Y4 v6 o% H% g
; m; d* u; F/ s9 m8 [2 O# n! l$ kAP MCU subsystem
" i, e$ ]( M4 k' l- n8 G$ }4 v6 m3 ^* W5 R4 J0 G k
( o$ N9 A: |* w6 ]
Quad-core ARM® 2.0GHz Cortex-A73 MPCoreTM with 64KB L1 I-cache, 64KB L1 D-cache and 1MB unified L2 cache
) W' ?% F) H4 A6 [! S6 J; u- u& k- Z5 ^; C i p. _# t
) g* s- T* V4 d0 q; h
Quad-core ARM® 2.0GHz Cortex-A53 MPCoreTM with 32KB L1 I-cache, 32KB L1 D-cache and 1MB unified L2 cache
) v' _3 V! B2 d+ ^# Y* ~* s$ b5 D- j3 h8 _8 Z
- V, n2 b# X4 K/ r1 L+ s
NEON multimedia processing engine with SIMDv2/VFPv4 ISA support
5 R7 a' J5 s, E$ j# G* n' ^ k: L, i7 {& R8 {# Y) _+ H y$ v- r
5 e) O3 t0 h7 c! t8 Z" {% Z9 u DVFS technology with adaptive operating voltage from 0.6V to 1.12V
" P& W6 p0 Y4 S& a' \ V
; A) ?* C% q7 D2 [' ]8 G
* b( H; w) c# c5 g6 v# H, Z( \; V5 Q7 r
* w- r; e: r7 N8 P, i: L1 j( ]" Y$ X
; l" R2 Z! m: ]
MD MCU subsystem
, \; R( K- P5 R3 }% B7 ?7 T3 V# K/ t# j& w0 n
# k: K T4 s! P$ w. N, P
Imagination MIPS32® InterAptive processor with max. 864MHz operation frequency
' F9 V z6 X& o+ U. u4 u$ q: I5 s2 q$ i/ h/ @; X
3 w& f0 J9 }0 x6 |& r( U High-peRFormance multi-core and multithread processor architecture (two cores and two threads)
9 H! e! K0 L5 d; t& J& |5 |0 n4 I0 e- ]2 i3 H7 @" B5 t* o
) f3 k& E& y7 k9 d! m8 g' l r9 \ 32KB L1 I-cache and 32KB L1 D-cache per core8 U8 R( L- Q( J- F4 J% o7 e" x
7 y q3 G, W. q8 f
y4 y6 T0 B% Q8 F
384KB SPRAM (Scratchpad memory, Two-Core’s ISPRAM and DSPRAM)
' a5 a; U# D9 u1 p9 F s t1 E, c# B. e) @- p) z, C$ T8 d# F/ {
4 F9 t: R v% ? 256KB L2 Cache (share L2 cache for two cores)
% Z5 z4 w# K4 X! m9 U# d7 F( I
! V5 G4 \3 z4 c) i9 R
8 ~/ H( o! w( ?( v. q High-performance AXI bus Interfaces
# O; j' w q o$ ? b7 }3 s: n" f, s# F$ g" Q" a6 M' ^9 c
+ f' I; D x1 h9 [: w: G1 A Power management for clock gating control: Z C, n& o! a' n* G. ?
/ p9 T$ d h3 V ~6 B5 e# a! d" K1 ]
p i/ t, U6 G/ W3 ~' Z FD216 DSP for running GSM modem with max. 312MHz operation frequency+ w; x' l2 b: m1 {4 _0 |2 ?
# G0 ?. R6 C4 q8 v
7 k* W* C9 M8 V6 f- s
" U3 ?3 d m9 N3 ]0 ^
- J0 j2 t% L1 B4 C R* O1 c: R& Z% D, k3 n$ q
( {& U9 g1 F4 t/ i/ X, C, ZMD external interfaces8 S1 }/ b9 f: ^- o
1 ^/ p3 o4 Q3 V& r
~' Z* h9 C( P- r Dual SIM/USIM interface, f+ F1 g8 z+ M7 ?8 E& F5 Z
Interface pins with RF and radio-related peripherals (antenna tuner, PA, etc.)
; x0 q, H& }7 v/ `$ U: O% z! e; o+ q2 \7 g/ ^9 p& o% L0 C
! h2 m% ?0 x( q! Q5 R
+ P# X8 u+ I- }7 b" x4 a; B
2 ^7 d/ d8 I. y1 W$ J& H0 G1 x# A) M" B$ G
0 I# Q: I( t! I% W# l$ l, BSecurity
+ i- ^# c: {/ W+ j+ f* {( W9 `, F0 ~# [/ M! l0 b$ [6 {
* F2 _9 v( }& @" m6 _7 _ ARM® TrustZone® Security
; C. L: R9 l* D) }. o7 |% E4 o3 f, }, A f3 {
+ f/ d$ {0 J) p, f' _2 V5 R! E2 T i. s4 v) k; m4 s7 S4 u
. ]" M1 \6 m! M, g% V: C! `3 {
+ b8 N1 I- W$ S S" k" V2 r6 q5 z/ v1 ]6 {3 Q' }9 n
External memory interface ?. [2 H( o0 |. V
% o W* u3 [! Q3 E) A, N
1 W2 b" Q) f. E" x4 k* `+ w
LPDDR3 up to 4GB (single channel with 32-bit data bus width)0 _, Z6 ?& M8 C/ F- \3 D0 I6 i: a
. L& [; ~# ?+ q% C( Z1 P7 f
3 n3 w3 f4 P" B* C) P) _- a' M
LPDDR4X up to 8GB (dual channels with 16-bit data bus width)
$ X& o$ f6 S4 l, v9 q4 p4 n
4 b9 R! ]% h) V6 I* z& Y/ Q- o% e4 o# |+ Y5 i- I& q
Memory clock up to LPDDR3-1866 or LPDDR4X-3600
) @! {+ |0 a+ u$ f& w( N. n' @, Z; Z+ a( |4 `! T& U1 c+ V% L
6 [2 s, ]6 E* k& @7 a. R1 ?
Self-refresh/partial self-refresh mode
. O! J' r, |7 T# S5 a y9 p/ }( c5 X: v4 @; i" O- f
2 K* S- h) o* P' v) v+ s& y; y Low-power operation; w( x; q7 w8 Q- ]0 T) x/ y, v
. E! L. L7 Y3 |5 p2 s6 ?
% w( [* m* b4 V) z
Programmable slew rate for memory controller’s IO pads
3 [: V6 b' r- X) F+ Z8 d7 \
' K: U5 L3 E8 L) U7 L
0 n. Y+ O. I5 Z6 N Dual rank memory device
+ G2 k& w* g3 K+ e' k- O9 ^1 X9 w3 @' ^* L5 B5 m. [6 U
- _/ a4 I6 c: U; w% n! O2 t+ s
Advanced bandwidth arbitration control6 s9 h: H8 r0 b% |2 P
3 b7 R# O7 k/ S/ ]0 i6 C- A
8 B* h3 |- G8 Y; j4 O7 k' V
5 H5 j/ I9 d& n
& `" N* _6 C0 L, a3 v/ @
' ]- J- e C2 U
( D8 O' N! Y0 l+ m) k! w$ xPeripherals! R7 }+ ?2 V' z) k4 T0 ?- J/ @, g, ? d
+ K- i3 n! `$ G
0 K; T' S- }' P2 h' }! n% O USB one port with USB3.0 device mode or USB2.0 OTG mode" q" h$ f$ v X- E ?7 d0 R( Q
3 b7 T- ~" R' v4 A- z2 D6 X6 V, `& n6 X" F/ e" R+ k2 K
eMMC5.1
& z! M- V2 J" f# K/ g! H B1 ^6 I. e+ L. c: q
. w8 N; D! I& k* N7 w
uFS 2.1
1 ~: a5 f. f; j- v- { ~
3 x4 t/ `0 i/ U
8 Q, k3 X( n. U 3 UART for debugging and applications
/ j# K4 z" B- c1 p4 D' F# C9 B; i7 n% b) N
' ?5 Z M3 N* n; \+ v 6 SPI masters for external devices0 N- [# K; o, a
) ]5 A* z4 y+ c" ]0 z
$ N5 b3 K1 k, T 6 I2C/3 I3C to control peripheral devices, e.g. CMOS image sensor, LCM or FM receiver module# x: y" C# v/ o W' \5 U3 J) i
- h) L' [9 |3 \+ B
2 D% c1 U8 W& |3 R3 E4 j6 z Max. 3 PWM channels (depending on system configuration/IO usage)
" K2 H# Z* ~( y n2 r% W& r }- N/ V6 m0 N7 D+ C+ }9 W
7 {4 K1 j k8 [- |1 i8 O1 N I2S for connection with optional external hi-end audio codec) l6 n& C. r# t" A0 ]: I/ E
% }0 ?& e s' A5 l5 B0 w7 |: u# _1 ~0 W+ A0 e/ s! Z, e
GPIOs
) E4 R# E, d% @
$ E3 S n+ I7 f% |7 S( o: G; ]& s, g
2 sets of memory card controllers supporting SD/SDHC/MS/MSPRO/MMC and SDIO2.0/3.0 protocols
( F& |; |( ]2 f4 e0 J0 k
3 T4 r3 [7 Q, A; x0 X- H j: D" m* P2 I/ X
- J! ^# u! ?9 W1 c# ?. \
2 `# s4 y; p+ p1 v+ p) H$ I
6 ]- U( \: f* f+ e) O% {# hOperating conditions8 c E: n: }$ Y* l
, q. I7 e9 g1 ~0 v. ]3 q
" e* ^+ w+ { Y Core voltage: 0.7V/0.8V9 ]5 z7 m3 w* f V
; ~; p) ~1 ]2 Y+ l; I
S8 ^: {1 ^/ R8 d+ T5 F I/O voltage: 1.8V/2.8V/3.3V ( G, T* _: N9 r. i P5 k/ T; a
5 s4 O q- K0 O) n) ]+ \; T9 M
; u0 c) N. h* B5 ]- [1 L: z4 }4 c; d Memory: 1.1V/0.6V D4 ]# M1 Y7 S9 r5 R
" Y* N5 F3 ~+ [8 a/ Z: D
# Z) k9 S, a6 b- x& `+ Q4 }% V2 {. W LCM interface: 1.8V7 \1 w6 U+ y8 {( n9 H1 O- B
" c0 g$ T n# \5 o* k0 g. x7 D( j+ h& C' L! ~
Clock source: 26MHz, 32.768kHz# I) N/ G/ w4 u& h1 M; X$ E- T/ B
: ]& x0 y" |5 o% b
l2 j; u+ _3 u7 J7 m/ v
3 [0 j( D$ v3 ^: q; w9 _2 Y9 a+ ^' Y! Q# Z0 y" ]" ^0 m4 q4 G
3 Q! ?) F) v( T8 @9 Z4 X9 }0 m, d$ y
- f0 p6 d# u8 I$ @# X) o( zPackage4 D) [4 e: ^8 r0 K" j. F
; T/ |8 I8 l) |( D8 \: e; {; @3 o; Z' E$ L$ o9 o% o
Type: VFBGA
' a& r! U# U# M9 D1 @ z5 q
) j- I$ |( u# E/ S- o- U
7 Y; O2 {- J; h& q 11.8mm*11.0mm( P; w1 X4 U. a- m) m; c/ i) u
: y1 K: i( |, g3 D# j% i% V
# j5 K0 K! v1 j7 d Height: Max. 0.9mm
0 Z7 s3 e: h. Z7 L$ ^2 s/ Q2 i+ e/ G( C% R
' Z; }, f9 a/ M: A Ball count: 599 balls# ]" P# j# j! @- ?2 B
1 G0 \6 j, r3 v9 K. a& u ~4 |. P( ^$ ]7 M2 G
Ball pitch: 0.4mm
/ s; Q/ }9 L# ]7 f/ l. h( T1 h1 X; t4 R% c
( A$ K# h, F! C- o7 v+ |! C6 }
8 s6 ?1 L' h6 U8 {$ s4 u
8 ] l$ L# Z0 c# @
p9 e2 C8 g- K" L: Y" D% x! cLTE7 p: C/ N5 i; r: g4 m
4 n2 F3 X3 T% `7 L1 r# T
; {4 v% A0 I& n0 c+ I FDD/TDD Up to 300Mbps downlink, 150Mbps uplink
) Y7 j1 V2 T+ q$ {
6 n" B( d% b) a; J/ H5 x: a& ]# T# ?0 w& `4 S/ L
Downlink carrier aggregation (CA) ability; 1.4 to 20MHz RF bandwidth per component carrier (CC) and up to 2 CCs
, q- u& G7 Q# c$ Z" y2 k U" H6 X$ ^2 |$ p2 {2 Z5 f9 I' T9 O
6 I" E$ m# S5 [. v2 F 8*2 downlink SU-MIMO per component carrier
" W! a) z: ~, n, ~8 Q9 Q2 x: n* y/ ?( E' K5 F% C$ J/ m
9 P4 Z ?1 Y5 C7 e- |7 n Downlink MU-MIMO per component carrier
0 X5 |% _; u6 [
8 ?" m6 R D9 v) @- A' B6 I# G" C3 f$ w. }9 ^% D" u
Supports feICIC3 m0 s7 H3 V) W/ A0 c
8 Q( l$ o) t$ t8 l. u; b5 P' e1 G+ e6 n3 d6 m* |0 }. h6 Q
Supports MBMS
$ ]% j/ s% @/ T0 v6 Y# T. ~" e; M$ W
6 |# j, j$ g, V$ E/ K Uplink CoMP ability2 Z0 n( p6 ]. x. @/ n! J Q
2 F) ^ D9 Q: _0 j9 }; h4 a1 a) R- B; I7 Z! x; ~: H
Advanced Interference Cancellation5 m$ N0 K6 r! g( D8 @
3 K9 L9 _( q0 Y8 C
3 e& o9 D/ N1 ]- p
Transmit Atenna Selection0 e) M1 h( Z2 u& g
% J1 H3 w9 \/ f" l; _
& P$ R* c! {' D# u8 b. o" o {- p/ |4 l. R" n o( V. F
7 E8 e+ ~* Q9 q( i8 B& ?7 A
& a- e# D; p5 z. ~( l$ j0 f3 C' R- A7 g, S. m8 w, o# T7 o' L
3G UMTS FDD supported features" R; I# }3 x3 q$ W; B3 q( G: p# k
5 }& B- s) y k% r# J1 e8 t
" t/ x# F' O2 V$ @2 t 3G modem supports most main features in 3GPP Release 7 and Release 8' q0 m1 {( U, L+ P: h, U1 r
$ y9 i% T$ Y& n/ E7 l0 A# ^$ ^* |6 D" l& L9 y
CPC (DTX in CELL_DCH, UL DRX DL DRX), HS-SCCH-less, HS-DSCH
, Z7 f. B' d8 Q6 |/ [2 m- v, ?+ t
" z: w2 c& ^, f$ t" k. T
8 J4 o X! l" v1 B Dual cell operation6 x0 ?# h! C. @* U
4 O. D3 [$ z, b; z9 e* l4 v; O" M" b
MAC-ehs
% O# w, ~! L" y
9 c3 z; y3 c, ~0 }# y/ }6 S
4 ]. l: p4 N" Q9 ?& o' B9 p2 o 2 DRX (receiver diversity) schemes in URA_PCH and CELL_PCH( R; o6 R! Q* }. D% T. g0 t" \* |- Z
! G8 W- s2 Z& }& c' ?% a4 C7 j
8 G; A6 {( c1 H: M- Q- Z Uplink Cat. 7 (16QAM), throughput up to 11.5Mbps6 b2 d* P# R5 \* _* c' Z
4 h5 W8 }' z: B: S7 a! b X
6 y; P4 d0 ? y" |2 J$ m Downlink Cat. 24 (64QAM, dual-cell HSDPA), throughput up to 42.2Mbps. }/ S4 ]4 L1 o' {8 t0 y
$ T: D( ?) @, W8 Q0 t$ `+ V, E
8 r" Y$ l. k5 D( J# a, I& B Fast dormancy- B9 ^1 {: a8 D! E
! K* B. Q* F9 m/ A! f" y) x2 o8 J. q0 f- ], D) x( @
ETWS' l1 L/ m+ Y9 p+ {. o9 N
2 Q: `/ M9 K N) Z& R- u; T8 _
% q5 M4 J+ g3 V! M4 A5 h Network selection enhancements6 p) M. q& \# u3 c
1 a9 K) Y5 @/ c7 _. W' \* m: y
' q5 m1 \5 r, }4 m3 ]: E Transmit Atenna Selection# U, |( w1 D* G3 B5 o6 x
9 `; I, w7 U! N) ^; b4 x v# b) z
* T. ^0 |+ E# R8 M3 M! `
/ l4 p" R" U2 v( h2 U; _
: x, B- I8 d0 q( A( I- z* U6 y) f1 l% r" {" s
* _) @& z$ ^4 e6 i, s8 H
TD-SCDMA
$ }, k( b" G* m. Z% r" X% o& ?/ ]. C2 u
. s7 y$ ?, X6 ^$ R
CDMA/HSDPA/HSUPA baseband
7 C% z* Q7 d( A6 ^
4 b7 Q' l) ]; \9 r* L& K9 }) r4 G* s' G0 z
TD-SCDMA Bands 34, 39 & 40 and Quad band GSM/EDGE
$ G% h& D' D ]1 n, i+ o& |4 F: }# u- J
% ?1 f7 N. B0 m8 r6 O( K Circuit-switched voice and data; packet switched data + X; \$ g- A. P# Y; R- G
' d* v, O/ g! W) K3 j9 T* |
8 C. D- Y& |( K$ d4 ^2 v 384/384Kbps class in UL/DL for TD SCDMA! _; A. g. C1 v6 O
* M7 \; h& A+ {5 b0 f2 f
( g2 t4 K6 f* j: y6 A) c* s TD-HSDPA: 2.8Mbps DL (Cat.14)* Z" g4 y( J' x; O. W
4 Y% X2 q: V8 S3 Z$ B" K9 U9 o2 B" i+ v
TD-HSUPA: 2.2Mbps UL (Cat.6)
, Y; J* {& ]: E3 K" }( t; z, t# M- Z1 w' }
( f0 K/ H# \' X/ Z F8/F9 ciphering/integrity protection6 O- B. a# Z" E: ], D
& O' r1 g [- O& B7 |
. r/ p8 }. \( z$ E Transmit Atenna Selection; H) b' A1 U* P. f( X
5 h. G8 ]( S/ y1 `6 y W7 ^' f
9 g [ a; P& A+ } q' I3 L
' S3 n& G U' ]' _1 i3 [3 r# F$ a' i* |0 v& T2 e
3 E7 }4 {6 [7 C1 |$ ]. F# z* H' A$ z2 Z
4 l0 l& f% S: P5 N5 ~* n
Radio interface and baseband front end
7 b8 M2 ~4 L6 W: l2 L2 C5 S
5 W7 k0 l% A1 Z( K9 K+ _
8 M3 t1 }/ L' m s High dynamic range delta-sigma ADC converts the downlink analog I and Q signals to digital baseband.
( z( ^' w; y* G3 z. u7 ]- b6 W, f+ Z+ z& M! Y( s1 k
# v; c _: A0 V
10-bit D/A converter for Automatic Power Control (APC)
5 [) M5 {, x8 `4 w8 U8 i) ^* E6 C) D4 T% @4 [$ [% b, r) Y
, M6 ?$ _, p+ X Programmable radio Rx filter with adaptive gain control
7 |5 u& V- W! F# D& L% q8 o/ Z
5 n6 j) c+ j0 L; a' k
Dedicated Rx filter for FB acquisition) @$ S' ? m, R. P, k
: @2 ^( U: ~% A% @+ }
8 Y" I7 J7 r1 w, k1 u) _ Baseband Parallel Interface (BPI) with programmable driving strength
) L; I: ]2 s4 n8 E) Y: x% t' Q, w/ v9 x% e; g
. i3 s' |( F; l/ t
Supports multi-band
9 n3 Y- Z# z3 h( j9 Z3 j, l. ~* c% U
, l# l) t1 J# p$ K
3 i" x# M1 v2 c" i2 j+ ~2 S3 \1 W7 [& Y
2 ^) p/ D# r% U) \7 K, g/ y" s5 F
& v( b( X, x' z1 D% h7 p( IGSM modem and voice CODEC" s& U, _9 D/ q+ f# i! t7 W5 \4 }
2 C3 j1 e C: G/ v9 U2 z6 l$ k2 p% O. M& [# N
Dial tone generation
/ x, ?4 [) g; J2 j& v6 i8 C
+ q6 U& ?) q1 [1 C' M% W; n& P5 h+ O% L0 {! W. v6 q
Noise reduction
# i E) Y8 `: {1 U/ F
6 q2 J; q+ d- d5 U/ C) N
. h m8 L3 J, v2 I. o5 Y( Q1 P Echo suppression3 X# ?& g% \, G/ V
/ ]$ ^4 h$ B) o% |
b3 b) F H3 ^: }7 Q2 F9 W. O Advanced side-tone oscillation reduction' a: a/ z& l) @" O
& `( d; y7 X* w2 |
6 @' b/ ]. p" j" T# a9 L
Digital side-tone generator with programmable gain7 ~) u. Z) O5 k$ K* n. R
! q6 j! n# G$ T# Q& Q/ p" l
Z# W) T7 r" z$ N! @ 2 programmable acoustic compensation filters
0 i B! O; ]4 {- r. h/ n& s$ i. r. k3 b. R7 c
y: L& b) p& r8 t ^ GSM quad vocoders for adaptive multi rate (AMR), enhanced full rate (EFR), full rate (FR) and half rate (HR)2 J. S5 w& f: H; }4 K) L
x- [5 p3 s- i( \
1 d3 @6 m9 r2 f GSM channel coding, equalization and A5/1, A5/2 and A5/3 ciphering; n3 ~6 i( Q# W! w' ~1 T
% W I% t7 R: n9 O- P
5 m K0 e3 B* ^+ W# D; `+ }' F
GPRS GEA1, GEA2 and GEA3 ciphering
4 d% ?, n8 Z+ z5 R2 b% j' V c) n1 ~+ \+ E/ _& |# \3 y/ P4 I. J a
# z4 c- M0 ?. o6 K Programmable GSM/GPRS/EDGE modem A+ A9 O4 l. k; U2 h+ y. z
* z" @' z" _. m5 z' G
+ q7 H1 x: H& U3 Q. ^% t) \ Packet switched data with CS1/CS2/CS3/CS4 coding schemes
: N8 V# u" \! h- |, b
9 _/ A* z4 J1 v
* w1 U: e' ~/ s4 H2 ]+ x$ f! N4 V2 T GSM circuit switch data% E! T. g8 e. ]3 @, B# X; V$ E% m1 d
5 V6 e$ H# B& k! y: a. U
' S. r2 B8 P! y8 d, u H$ @- s GPRS/EDGE Class 12! b# L- A5 }8 C ?9 P0 Z
1 G: i! \1 [4 H
+ j) x O4 r( Z# J" d& [: a: ^( E
) \* q0 p4 w* }0 L# y
- W, g# m/ K. @ ?1 o- h- Z) Z! D0 O m8 g; \ |8 k
" H0 b5 |+ Q- G6 A0 s( F% e! ECDMA2000 modem interfaces
4 f% T; Y5 l9 j2 ^, E+ B( ]1 q: ~" n3 b0 k& w& o) f7 a
) i7 ~! s0 B A$ ~ h* P. {7 K- f
Supports CDMA2000 1xRTT (releases 0) and CDMA2000 HRPD/1xEV-DO Revision 0 and A5 s5 z- I% ?( `& D6 t7 n! Q& c
5 w( S4 v1 d% N
4 ]1 F) e, n: Z Supports maximum 1x data rates of 153.6kbps for forward and reverse links and DO data rates of 3.1Mbps for forward link and 1.8Mbps for reverse link8 c7 Q- o. E2 d5 v+ f: u0 v: B p
- i# [& A y/ G, s; ]
/ U1 N' r% Y6 d Hybrid operation between 1x and HRPD
0 |( y* e5 S1 u2 {" d5 j' }
6 U0 |$ `3 S2 d# I# J W- a0 ]8 U6 L, K9 X: X1 i
Simultaneous Hybrid Dual Receiver (SHDR) support
7 z. |$ u' A4 x1 P) u L$ g1 D: L) I k) e4 T
3 r* Y" Y% n/ P; V
Supports 1x Diversity9 H" D5 t- k+ H7 v4 s/ F
0 q7 R: G9 l) c& \- S3 V% h$ V
+ w; r' d( \; \; \. x
Supports SRLTE
8 D1 k9 u2 _* W4 u( T/ U' }6 T
' ~% A- c- \9 C* D1 s3 Q8 o, H5 h+ q) o8 G# o0 |& W; J
# y" e& A, F# q0 i& X W& B: x( Y' g! \- ~/ k1 ]; X% }
! J- w2 z: M- [8 J0 p1 s% G% F9 c: l$ T3 ^! T% B( N: E3 R* \+ O9 O9 q& _) A
" K3 X% ~) ~- Y3 I, N
' a5 ]5 n A8 W9 A
5 d2 B9 v: D- P- W4 b更多芯片参数特点,可参考MT8788规格书资料
0 w4 k- {" L. T0 O
* K* f E$ o2 H9 R' K" }- u5 z- E8 R" b$ x$ g' x% f
& b6 [! V" o, V+ T2 P
/ ]: b' C; V) O7 o/ i0 a |
