查看: 1342|回复: 0
导出网络表时不能停住不能继续,怎么办?
发表于 2009-9-6 18:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我导出网络表时每次到第35个警告就处于不动的
" l* O( m8 E" ?" ?状态,只能自己取消操作,怎么回事?& R* C- |3 A& t5 V% I. t% Y
另外能不能不要让检pin name 和part name 的长度3 U% v) D! U1 h# ^. u* Z- H
那个不是无所谓吗?谢谢! ]0 q) v$ o! l' u6 `7 v
6 _/ V' }+ D4 q4 D5 X5 {1 ~. t) G% R
#1 Warning [ALG0016] #1 Warning [ALG0016]Part Name "CAP 100NF CERMC 16V 10% 603_EIA0402_5.6PF" is renamed to "CAP 100NF CERMC   16V10% 603_EIA".
& e! C4 d8 N. y0 A4 t* G
6 q+ ?6 K+ G: s! {" R$ k# N#2 Warning [ALG0016] #2 Warning [ALG0016]Part Name "CAPACITOR POL_1_EIA1206P_10UF 6.3V" is renamed to "CAPACITOR POL_1_EIA1206P_10UF 6".
1 P! ~* I" k% i$ `# g4 q
# l4 M) I) W- h& b0 ?/ e' G#3 Warning [ALG0016] #3 Warning [ALG0016]Part Name "CAPACITOR POL_0_EIA1206P_10UF,6.3V" is renamed to "CAPACITOR POL_0_EIA1206P_10UF,6".
- w+ D! N) p6 l" ]1 s: r
' q! r# z# C5 A5 g1 H/ K
/ g5 K0 v9 Q1 P" V, C; ?, @
6 V' e: f' S4 w. C8 E6 }+ U1 u' B7 s0 [: `
+ V3 q0 Q& F6 T+ H) z5 G
1 D; N' p! X* m0 [' D
5 V( e  t7 x; b6 n2 i* |3 u; L- h5 w5 o7 s5 _% t, L
* X7 l7 _. e$ x, I
  H6 _7 O# M1 F" r( K
, E+ a$ K" _$ R* x. K, p
3 I0 p4 P. y( |
6 k6 w0 v% q, |8 t5 x- k#32 Warning [ALG0016] #32 Warning [ALG0016]Part Name "SW DIP-4_TI_SMTDIPSW8R_PADDLE DIP-4" is renamed to "SW DIP-4_TI_SMTDIPSW8R_PADDLE D".
( r/ e: l2 I% \8 n3 h( g
7 j# e4 q1 L4 }#33 Warning [ALG0016] #33 Warning [ALG0016]Part Name "DIP_SWITCH_4_SMTDIPSW8A_TDA10H0SK1" is renamed to "DIP_SWITCH_4_SMTDIPSW8A_TDA10H0".
6 B8 h, P9 z3 W# b
% f3 `% U( ~, ^
#34 Warning [ALG0016] #34 Warning [ALG0016]Part Name "SN74CBTLV3125_TSSOP14_SN74CBTLV3125" is renamed to "SN74CBTLV3125_TSSOP14_SN74CBTLV".
' O7 y) C- F: h9 ]& X
4 s8 h# I4 e  t* W& u' i
#35 Warning
% I5 O& y% C5 R# K: {1 I2 W7 D/ V  c
/ m9 b! R  I2 ?9 I8 g/ ?; K[ALG0016] Part Name "SN74LVTH241_P
3 `+ s( c  _8 J
& N$ Q( g9 D6 `5 DUser cancelled operation... Aborting ...
5 ^' ~; J, U  e& \- i
% i. |6 c2 U9 i, X1 ^
GMT+8, 2025-7-30 11:00 , Processed in 0.109375 second(s), 25 queries , Gzip On.
