R11代表了Allwinner在智能硬件处理器上的最新成就,它集成了一个以1.2GHz的速度工作的单ARM CortexTM-A7 CPU,并支持多个外围设备。, l5 N% }' S! |0 x3 Z. p4 |, E8 _& I
* c6 P, P, ?- D5 [
( A4 z2 A6 O9 x! Z8 K
CPU+ I+ n7 P0 X) T/ {1 |7 ^3 D
! h' ?( c* [% m9 i3 ]/ e# i7 H0 d% A+ b, y2 K% C5 t- T
ARM CortexTM-A7 MP1 Processor , J& ^9 ?+ Q0 I. [2 b# Y1 X8 G! w
Thumb-2 Technology
1 Z" G3 s. p( m$ T! r" ESupports NEON Advanced SIMD(Single Instruction Multiple Data) instruction for acceleration of media and signal processing functions ; V3 ` P3 r8 O5 q$ @2 F8 b
Supports Large Physical Address Extensions(LPAE) 3 z+ W; ^3 l" |* U6 f' U, f; `+ l! v
VFPv4 Floating Point Unit + l7 }: Q( d$ h9 o1 x
32KB L1 Instruction cache and 32KB L1 Data cache
W& w. t7 ~ H6 ~/ {" F128KB L2 cache
9 l1 m2 n( U4 ^* t6 {0 d5 F' ~) l" |, r, @. F: S
, {5 t- O/ @3 ~! J- _0 c6 [ e
Memory Subsystem % r/ B1 ~. W+ ]& K4 S8 _$ R
Boot ROM
* H( G- S; q3 z% O: ^
& x" g' q+ m- d
) l! s: C6 y8 V% ?6 b, NInternal on-chip memory
9 D& L, f1 T3 g8 M9 zSupports system boot from the following devices: - ?2 C5 { |* u$ [1 S9 p
- SPI Nor flash 0 s( y$ B1 C$ I7 ~ T
- SPI Nand flash
5 R5 V8 B! w. y- SD/TF card 3 F5 H1 d6 d: b9 d( u$ E6 n
- eMMC % K6 ?% _$ b& V% V& W$ B
Supports system code download through USB OTG5 i+ L6 W: V' v# V3 i
9 s2 q1 I% g W7 r) H! B6 n, k
* o1 g/ Q( b# F: [% x% P3 r4 w
SDRAM
, {$ ]% e. U3 [" v0 z+ Z% {7 \* H7 }- G
8 y8 a/ U9 g% u6 }. e" \' p* [
Internal on-chip memory % M: S5 G: @% U5 J+ e
Built-in DDR2 in the R11 8 A. X: P; U0 z
Clock frequency up to 400MHz + r/ Q8 r* c1 o- M" r
Supports Memory Dynamic Frequency Scale(MDFS)
- o+ E6 h' V3 a
7 c3 ] d/ i4 k/ }: f9 K$ H
' Z- R% ^' X) N9 H; i8 X% e( ASD/MMC- J" O* I5 W$ b( }: v
* d0 G9 U9 ^3 B3 a7 C7 w
$ r+ h* Z) Q" l+ n/ y9 I4 rExternal off-chip memory and storage device
4 @, ] q: f) E* M3 _1 x6 U! YTwo SD/MMC controllers ; h, n: N: F: E, B: T7 P. s. N
1/4-bit data bus 6 G: _) t# ~' T% r% `# G) ^ q
Complies with eMMC standard specification V4.41, SD physical layer specification V2.0, SDIO card specification
2 Y; d! \/ D: n6 X( R, o3 h% X( h( [- c8 P5 t
' h. O# _; F: t5 ^$ `( V& X! Y+ |Supports hardware CRC generation and error detection + U7 z' M) n( A) e3 P2 {
Block size from 1 to 65535 bytes4 h7 s. K8 y3 b2 p
: i% ]. O+ W: d
/ T% U5 j) ^! e q% OSystem Peripheral . W* Y. K# x1 J' R
Timer; G& ^) z! _' W8 m" a3 @; |
4 O; t# D' H( N4 Z7 Q8 W# d9 f; r, D8 B; u
Three on-chip timers with interrupt-based operation
0 T8 u, i) w t5 {, a1 \8 b( J( uOne watchdog to generate reset signal or interrupt ! E( O+ l1 T3 \4 T
33 bits Audio/Video Sync(AVS) Counter
6 u- m# ?8 k0 x" b24MHz or internal OSC clock input4 M0 C6 n' Y) A/ M7 r! O
+ e0 V5 z" y( Q' a% }8 O
) Q5 z8 E) J1 mHigh Speed Timer
7 K0 R( k" K1 {! Z8 `" ?( t* ^- d; T, |7 M
' U$ E3 y! n6 e* AUp to two high speed timers : k4 h$ e4 p: E/ J8 L6 [
Counters up to 56 bits
! D3 Y3 h& [; B! c# TClock source is synchronized with AHB1 clock, much more accurate than other timers/ P& q) e3 f3 h
( U/ o$ ^$ ]& b
5 _0 B- f0 E6 o+ aGIC
2 W$ e( {& c: t/ Z" c/ A* u9 v$ G* z
9 B( o+ K! B. r' G( ^
Supports 16 Software Generated Interrupts(SGIs), 16 Private Peripheral Interrupts(PPIs) and 125 Shared Peripheral
7 c- H0 M% R, |4 Y* t4 s# gInterrupts(SPIs)1 |/ D# t' O$ @1 H6 x3 @
& T" _, M$ c# i& W+ d2 g! Q0 k' Q4 P5 G% M5 d, ?* w3 v: G4 S
DMA3 E8 |% f" x- _( w) m
' J) \& p% ]& h. ^
! C' M E6 H1 J
Up to 8-channel DMA
" u4 H1 [/ D5 T! [6 aFlexible data width of 8/16/32 bits , n( J4 a9 A# | y. T& O3 p
Supports linear and IO address modes , X0 T' s3 X5 a+ j4 Q0 J- B* X, B
Supports data transfer types with memory-to-memory, memory-to-peripheral, peripheral-to-memory
6 g, C* h u! r2 R8 E
2 I: n' M5 w$ T3 z. m1 o5 s& q1 [
# J+ P# G1 s+ Q! OCCU3 {# `" ~: l& G$ i$ p k
) e1 n. G' D7 L+ \
2 J; n8 ~! ^% S2 A9 V; Q3 ]9 PLLs ' V0 C) j4 |+ X" J0 k g
One on-chip RC oscillator 8 ^+ Z; x/ Z0 A
One 24MHz external oscillator
0 [% {+ J& M. w# _( d9 e5 zOne 32.768kHz external oscillator
& [& d9 g; a. |& ~Clock management: clock gating ,clock enabling to the device modules, clock reset, clock generation, clock division/ I. f( p! C4 ]; w. h) O& |
( a$ Y1 `/ Y& l# G+ y2 e4 m+ ~. A* D% Y: T: Z/ ^
PWM9 f( [! p6 o% C
9 k& G5 ~9 ^2 C
E* Z" P: L. |, jTwo PWM channels * ~2 \; ^! P; J8 b/ M
Supports outputting two kinds of waveform: continuous waveform and pulse waveform 2 L- J7 w/ ?2 D3 w% W) g
0% to 100% adjustable duty cycle
- o7 |* K. I5 s' r$ y$ c cUp to 24MHz output frequency
4 ^0 O( m, ~% h/ z$ B+ d) v B; y0 L' s, s4 H% U* A
0 l* d+ w6 F, c8 P1 o6 S! N
RTC
; ^/ I7 u8 u& W/ c! {1 u; R: J2 B0 Z/ j Q$ c( c6 j& b
h4 q8 y; D) {8 ]+ OTime,calendar # `8 q6 a4 J4 _2 ^8 m. R
Counters second,minutes,hours,day,week,month and year with leap year generator " p5 f# |% L+ G! `4 E
Alarm:general alarm and weekly alarm
- Z/ u+ F+ v! `% A" `5 P% _# |5 i
# [" M/ m3 M$ ~6 S2 ?; z& s" e m1 D. ]
LRADC
; E- M/ V) U; I. Y8 A# ]% [0 g
, X1 r' J3 h ~( E; I
* K; \8 g s* t! W% E6 q( D' C6-bit resolution 6 w' P/ m; O& l5 }# H4 h
Supports hold key and continuous key + m( c/ f8 w2 D) d4 @/ r* l
Supports single key, normal key and continuous key
! t5 B1 J& S. r
) E1 c& W' z, F- o3 H$ a
. U: [- b2 N7 a5 yCrypto Engine- i# V) O# l& |7 T* d4 B- V! X u
% V1 k+ q7 Z2 m3 w( V$ f) F8 D7 {( i
0 G" s. ~) u/ {, ]" g0 ]! b" z
Supports AES 128/192/256-bit with ECB,CBC,CTS,CTR mode 8 p$ {0 ] W+ u, \9 g3 l
Supports DES/TDES with ECB,CBC,CTR mode " r& ~5 x$ R* h. }* @
Supports SHA1 and MD5 % [2 w' c! @: m6 G# b+ P) Y
160-bit hardware PRNG with 175-bit seed+ m# }" A% ^" L; V% C
8 J8 A- q% ?8 j0 u0 ], p# ?* C
! @. `/ `; b7 e4 U6 PDisplay Subsystem
3 C0 n5 Z8 w' |% i$ O1 YDE2.04 P! L' Y5 ?; ?( l
" I4 u4 C8 F! w
( y' T4 {" N. O7 ^0 [
Output size up to 1024x1024
) n/ M( E: R. i! ^+ H: ], j9 cSupports three alpha blending channel for main display " y1 \- [* _1 w5 p- u1 ?& s3 j
Supports four overlay layers in each channel, and has a independent scale
* U/ p0 [7 K) _) D, @2 v6 [+ F' PSupports potter-duff compatible blending operation
& l R) b. W' U0 U! S7 I1 zSupports input format YUV422/YUV420/YUV411/ARGB8888/XRGB8888/RGB888/ARGB4444/ARGB1555/RGB5655 `4 k }4 k% @; G7 R$ S
6 f! `. N" Q* {2 c5 f( b! s4 @ C9 p: i! a. k/ x3 Q
Display Output" S/ L0 z4 V2 F/ g
* M( i" |- s: t$ }9 W0 f
, Q. I; b# I3 U/ C" c
Supports LVDS inteRFace with single link, up to 1024x768@60fps
/ G9 r2 J$ I/ X% }( h: }Supports RGB interface with DE/SYNC mode, up to 1024x768@60fps
8 ]1 k a* ?2 r/ g8 O. f6 |Supports serial RGB/dummy RGB/CCIR656 interface, up to 800x480@60fps " j" L$ B- t+ J
Supports i80 interface with 18/16/9/8 bit, support TE, up to 800x480@60fps % L' n# c( p5 ~ e( q& s
Supports pixel format: RGB888, RGB666 and RGB565 , _! g# Z2 I7 o5 B9 p
Dither function from RGB666/RGB565 to RGB888 , f. {- G2 } D- t$ p, ?/ c
Gamma correction with R/G/B channel independence. k4 U0 b( j* Y) o
1 a4 s8 }5 F1 V; a# ~5 n" u* V
+ \$ u& J+ ^+ z% E1 ^$ z+ FVideo Engine ( [0 T0 F( p) N
Video Decoding. ]' p. J% O2 f
, G( W1 O b' w3 Y. ?' X
+ e: n* \; w' Q. D
Supports video decoder for H.264 and JPEG/MJPEG
! K9 I4 T$ n X1 ^2 K- KSupports H.264 BP/MP/HP up to 1080p@30fps 9 B, e, c; l7 \ W9 a: v0 ]# T
Supports H.264 output formats :NV21,NV12,YU12,YV12
5 H7 @ {: u9 J4 YSupports JPEG/MJPEG up to 1080p@30fps& l( Q6 g! C& |0 i7 |7 [/ q
# r: r" L {, a) D7 b2 L& e
' _" Q: R1 o: L$ n7 V7 t
Video Encoding: T9 T; W" x4 `% G
( X7 ~7 H( ^, G/ K% H' w% ?
`8 s$ I7 H& {; |9 h/ \3 ^2 M7 _; tSupports H.264 video encoding up to 720p@60fps
& r' k6 E3 M9 J% v; S' n7 JJPEG baseline: picture size up to 8192x8192
" e) u" J; I) U, ~8 P; C8 z. S/ s: `Supports input picture size up to 4800x4800
( v1 H+ m* r1 p! x! ~Supports input format: YU12/YV12/NV12/NV21/YUYV/YVYU/UYVY/VYUY ) \9 K1 i% w' O" [, T- h4 |* W
Supports Alpha blending
6 u q8 J, e wSupports thumb generation
, c" a" R: B% j& g9 X6 PSupports 4x2 scaling ratio: from 1/16 to 64 arbitrary non-integer ratio ' U1 Y, z8 Q, R
Supports rotated input. L+ w5 i; ]0 }3 o8 h) d
# v6 J3 P9 f9 W( v9 F
1 U0 K5 J E8 G
Image Subsystem , ?9 j( f2 o1 [$ F$ p. g' o
Image Input) K) u) Q5 j. J0 A
# H2 R* Y" R( C+ X8 U- x0 N
o" }* \* G/ D) S1 k& ?3 f. ISupports 8/10-bit CMOS sensor parallel interface
8 {/ z9 w) b" J1 Q K% o2 `Supports 8-bit CCIR656 protocol for NTSC and PAL # u0 t& d3 r9 W( _6 N# z3 k" g
Supports ITU-R BT 1120 protocol for HD-CIF system 6 L& }$ B$ n* j4 N% i' I& |& D
Supports 16-bit interface with separate syncs
) G8 u8 P# o* x0 \1 N: Q$ oMIPI-CSI2 interface compliant with MIPI-DPHY v1.0 and MIPI-CSI2 v1.0 $ l @, d' B% D8 \. M3 I0 }4 {0 M
Supports MIPI-CSI2 1/2 data lanes configuration ' t& S; {! x; x: O, T6 l
Supports Format:
2 m7 W0 n( h% l2 a V. Z# e. i6 n; }& ~9 k
' \/ q- o6 z/ F* g8 q- YUV422-8/10 bits : j: a2 J% b: y+ K X" }" M
- YUV420-8/10 bits(for MIPI-CSI2 only)
# t: g1 \+ G' Y3 t0 J, B" \# C- RAW-8/10 bits 5 |9 p) Z/ m! ^, W: R3 R
- RGB888/RGB565(for MIPI-CSI2 only)
3 u1 _& v$ z6 }* _, H4 P4 e& b; P: l) k
8 w3 Q6 Z- X6 E" r o g& YPerformance: T6 O* W' u- t/ z, f
* r; P9 i, v6 W$ v' C. `
( m( k n! g/ d+ N) ?9 b% F- Still capture resolution up to 5M with parallel interface * X: q; R- M* ?2 a
- Video capture resolution up to 1080p@30fps with parallel interface . t$ ?$ P# X6 m$ I, F% N$ {; ?. J& M
- Still capture resolution up to 5M with MIPI-CSI2 interface
) z6 u' X2 Z' Y# E' P- G$ z' b0 \- Video capture resolution up to 1080p@30fps with MIPI-CSI2 interface , H$ x' K2 ~% {" \$ o( z! V
- MIPI-DPHY maximum data rate up to 1Gbps per lane
8 |& c8 N0 Y- v# Z
, W4 Q% i- t8 v# x& CISP
( }) y% b' B* [5 A& l
8 n* a# ]: P& T# b6 r4 I5 G, X$ n: g& A+ |, b1 H! a0 k
Supports input formats:8/10-bit RAW RGB,8-bit YCbCr ( ]6 J+ p. q1 x% r% A2 f
Supports output formats: YCbCr420 semi-planar,YCrCb420 semi-planar, YCbCr422 semi-planar,YCrCb422 semi-planar,YUV420 planar,YUV422 planar
+ M t: t9 Y- P0 D3 {+ x6 @2 CSupports image mirror flip and rotation : e6 q* B1 N9 d
Supports two output channels
4 [9 }2 r, R5 j& B* r# N! ySpeed up to 8MPixels@24fps
+ X' A2 U- [4 }8 X/ h+ YDefect pixel correction
5 @& ]/ ~& D4 K; e5 sSuper lens shading correction 8 u- h2 n7 c' z/ K
Anisotropic non-linear Bayer interpolation with false color suppression
/ l' U" r! n% r' jProgrammable color correction
3 P$ ]# {2 W+ B0 S, tAdvanced contrast enhance and sharping
1 o4 G) `6 K1 R- u' j5 M) HAdvanced saturation adjust
" @+ }: l2 M( f6 PAdvanced spatial(2D) de-noise filter
4 z& e9 k6 H! J6 aAdvanced chrominance noise reduction 2 X, B. Y8 f* ?3 A- N
Zone-based AE/AF/AWB statistics
9 `" ~/ t* F7 Z8 c5 @# {3 ZAnti-flick detection statistics ) c, H2 f3 c! c$ p1 s7 H- y- R
Histogram statistics; j9 R2 |1 A% M2 ?3 w! f
; z' u$ n) [ K2 ~" r
' W; m) f/ |9 E. B
Audio Subsystem / s8 j7 o5 h* Q0 z1 k" c! t
Audio Codec
5 z3 y9 ^# _2 v+ }5 g; j3 |+ A
6 i( b- `4 H& E$ O3 f$ Y i0 @7 [/ c( p, w3 X# [8 i( j
Two audio digital-to-analog(DAC) channels ; H& v- _) K- D o1 s
Supports analog/digital volume control
, k& y& ^* Z$ Z# M6 MOne low-noise analog microphone bias output " h" b4 {: x+ i; g: [% D) z, u
Analog low-power loop from microphone to headphone outputs ' _9 N0 t0 o' J# U' ?) r# A4 @
Supports Dynamic Range Controller adjusting the DAC playback output 7 g( S3 v: m% D6 @, q
One Microphone input
y+ w# {3 H3 [3 t: aOne Stereo Lineout output
. c% ^, c8 F. @$ }& G( q# uTwo audio analog-to-digital(ADC) channels
. l. Z9 E# G4 ~# P% f4 B; z2 K
9 f3 o; z* @6 b# `5 C9 J* P6 j& }! R, v) ?
- 92dB SNR@A-weight 9 `- K6 T( ?. z5 }0 y
- Supports ADC Sample Rates from 8kHz to 48kHz
: D$ B1 Q. V2 v: qSupports Automatic Gain Control(AGC) and Dynamic Range Control(DRC) adjusting the ADC recording input
9 K6 `( c) F$ `$ o( x
8 |, A' T; ?7 H, U; r6 m5 ^; ?% Z0 T* c4 P
External Peripherals
9 `2 k- ~8 Q# [& @; h5 ^9 [" f6 V" K# l
8 u/ @% x6 F1 C5 A/ ~' N1 d
USB6 ]( `& ^# {* M
# p8 Y* f) A# d* j
, N: C4 F4 J7 s( mOne USB 2.0 OTG controller with integrated PHY
& t" l9 Y- n0 s: @" TComplies with USB2.0 Specification
2 C; R/ I# t& B4 S8 }# _/ ]Supports High-Speed(HS,480 Mbit/s),Full-Speed(FS,12 Mbit/s),and Low-Speed(LS,1.5 Mbit/s) in host mode 4 U2 W0 j4 U3 n, U, p0 S
Complies with Enhanced Host Controller Interface (EHCI) Specification, Version 1.0,and the Open Host Controller & t: t, i+ R& w1 C7 H
Interface(OHCI) Specification,Version 1.0a for host mode
$ ~3 I* {# T: u2 o, r) qUp to 8 User-Configurable Endpoints in device mode
6 V$ c. X$ q4 `3 ZSupports point-to-point and point-to-multipoint transfer in both host and peripheral mode, J% k4 Q' Y! ^6 a b' R# Z
4 P, r+ I0 ]) \9 x, j$ h' k+ C
* u' L4 f2 m* E" xI2S/PCM+ V1 Z# x0 Z! t# E1 w9 Q6 q+ c
7 l, _0 F6 D% B1 F2 ?
: g& @$ E! O7 S d; g$ rCompliant with standard Inter-IC sound(I2S) bus specification 9 W- j# D/ l* Q0 \, H: Q
Compliant with left-justified, right-justified, PCM mode, and TDM(Time Division Multiplexing) format
- T- _3 V1 b" g* G# dFull-duplex synchronous work mode
+ l! S1 y, G& G/ X9 [: UMaster and slave mode configured
+ P9 O2 d5 ]4 Q8 k6 JAdjustable audio sample resolution from 8-bit to 32-bit
- d; G4 l5 ?, k8 ?Sample rate from 8 kHz to 192 kHz
( c6 W) M' B7 h6 ^0 X# {Supports 8-bit u-law and 8-bit A-law companded sample u& R% J3 y9 n2 ~3 V0 n, B# p2 @
# R5 g% M) V, K, }3 H4 a$ |4 F8 w) h2 Q6 h5 p$ z* H N
EMAC- y% s' n7 D r' N9 d
3 J# e; C6 d! g7 O5 a. A# j
" ]7 L8 U+ _; z- e9 tSupports 10/100/1000 Mbit/s data transfer rate / Z) K9 w ]' K; e; W
Supports RGMII/MII/RMII interface
5 C& t; W' ~, ZFull-duplex and half-duplex operation . R/ h( w8 T" r: u
Linked-list descriptor list structure
3 g p. E- Q* p, XProgrammable frame length to support Standard or Jumbo Ethernet frames with sizes up to 16 KB
" b3 z- |& l9 R; b/ |Supports a variety of flexible address filtering modes
4 t4 D, u# l6 _7 k! a) K4 C X0 a2 R, V z
3 P" i. g( ~2 n& S" tUART
- b2 v+ c0 {' D" |0 C& @" a' K# h0 x' h B% V) }7 t
( w$ y& A5 `0 d9 L Q2 E
Up to three UART controllers 3 S2 t5 g z0 L2 d
64-Bytes Transmit and receive data FIFOs for all UART ' v+ H; R( T6 b
Compliant with industry-standard 16550 UARTs
. p) c- K5 f/ f
# q7 ~- M9 L& O; x) ^
! ^3 F" k# `# o- X/ p# w; l9 K不直接翻译了,且资料内容太多了,想要看完整的,可参考全志R11 datasheet
, F; V7 v- w2 g. v1 `' x% p `4 c0 J$ G% y: A: r0 u2 Q4 \- w
- Y. @, s1 U5 A$ M( i* R' V
3 ?! W6 M" p: y7 h% v
/ L( u2 q: j+ W& H. a
