#14 Error [ALG0013] Conflicting values of following Component Definition properties found on different sections of U8.
6 d6 }, T& c& G+ L2 A5 d1 X* G" C1 N SWAP_INFO/ h3 ~; {/ E4 D3 O! j2 J
#15 Error [ALG0014] Conflicting values of part name found on different sections of "U8".% U* r( [% [& o, f
Conflicting values: EP3C25Q240_PQFP240__EP3C25 & EP3C25Q240_PQFP240_EP3C25 8 S* e9 k. y, Y# \, A' G& F( C
Property val5 {* y b3 I6 q+ ]" h! v; _
ues of "Device","PCB FootPrint" and "Value" should be identical
5 k' n4 a' C; o5 z on all sections of the part.* g& E; J, t1 L; j$ ~) i" Y4 D
#16 Error [ALG0013] Conflicting values of following Component Definition properties found on different sections of U8.
: a8 r0 V! m$ j7 J0 z SWAP_INFO6 A& i4 g/ `# e4 I- n* B
#17 Error [ALG0014] Conflicting values of part name found on different sections of "U8".
, ]2 u5 [& ~, S7 E. k+ j Conflicting values: EP3C25Q240_PQFP240__EP3C25 & EP3C25Q240_PQFP240_EP3C25 ; M' X$ } s0 c. I# I4 m
Property values of "Device","PCB FootPrint" and "Value" should be identical K% n& t' y R, X/ U5 U
on all sections of the part.+ n% B! U/ v. ?# V% H' G
EP3C25Q240有A、B、C、D四部分,Value值为EP3C25
8 e+ \: R' V0 D0 `0 ?6 i' G对了,转网表时元件名称只有31个字符,如何修改 |
