查看: 1460|回复: 2
capture cis 元件命名
发表于 2009-8-19 15:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
创建的原理图库中元件命名不长,可为什么生成网络表时元件名却特别长,例如,原理图库中命名为EP3C25Q_240P,而capture cis生成网络表时元件命名为EP3C25Q_240P_PQFP240_(S1+S2+S3+S4)_EP3C25,而且弹出以下警告, P( [2 M! U& h, `" ]  l2 T
#18 Warning [ALG0016] Part Name "EP3C25Q_240P_PQFP240_(S1+S2+S3+S4)_EP3C25" is renamed to "EP3C25Q_240P_PQFP240_(S1+S2+S3+".& {: y" p5 S' e! ]7 \9 Y: S
最后还产生了以下错误
- l) h; r1 Z& [$ ?5 m#89 Error   [ALG0014] Conflicting values of part name found on1 g) r* v7 _$ x  Z
different sections of "U8".& O/ Q  D( b  x: }6 z
  Conflicting values: EP3C25Q_240P_PQFP240_(S1+S2+S3+S4)_EP3C25 & EP3C25Q_240P_PQFP240_EP3C25
' \2 K& \& D( s- {! ~- y' R  Property values of "Device","PCB FootPrint" and "Value" should be identical , p1 p- M! A$ R7 ?+ }, _( C
  on all sections of the part.) t; ^4 a# P: ^( Q
#90 Error   [ALG0013] Conflicting values of following Component Definition properties found on different sections of U8.
# z# A% I# l% _; G( F! j+ S              SWAP_INFO4 P3 k& r" C* K) K! p6 F3 z+ @
#91 Error   [ALG0014] Conflicting values of part name found on different sections of "U8".
$ B; M" ^# c) j" f/ U& Q2 I$ Y  Conflicting values: EP3C25Q_240P_PQFP240_(S1+S2+S3+S4)_EP3C25 & EP3C25Q_240P_PQFP240_EP3C25
$ H/ o' B4 e# t3 Y  Property values of "Device","PCB FootPrint" and "Value" should be identical # M: H# r+ r/ p5 m( {  _" X
7 u% c0 G4 A& z( l- A. X1 I! n#92 Aborting Netlisting... Please correct the above errors and retry.
+ }: j: x. v# `9 ^7 `  }& m4 p- A( H( L这是怎么回事啊,谢谢各位大侠了
发表于 2009-8-19 17:07 | 只看该作者
EP3C25Q240P(元件名)__PQFP240(封装名)__(S1+S2+S3+S4)(CLASS)_EP3C25(值VALUE)
# m0 V2 S0 \. U
% o$ ?+ v  {: s8 u' H9 H3 e5 K# z" X' k  m1 K  h; l( |
  我猜得  希望大家指点
 楼主| 发表于 2009-8-19 17:11 | 只看该作者
那名字太长出问题怎么办啊
GMT+8, 2025-7-29 21:43 , Processed in 0.109375 second(s), 24 queries , Gzip On.
