查看: 2091|回复: 12
Hotfix_SPB16.20.015_wint 网盘分享
    2025-7-31 15:01
  • 签到天数: 655 天
    [LV.9]以坛为家II
    发表于 2009-7-27 21:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    http://rapidshare.de/files/47934167/Hotfix_SPB16.20.015_wint_1of1.part1.rar.html
    ! Y* L" [9 |) u& Mhttp://rapidshare.de/files/47934731/Hotfix_SPB16.20.015_wint_1of1.part2.rar.html
    8 C# O  j' G5 y% d; B/ c
    3 m. y% q8 C# J. ]pw:nice3388lovetlf
    发表于 2009-7-28 21:14 | 只看该作者
    谢谢!正在用014呢,看看这个有什么改进?
    发表于 2009-7-29 09:40 | 只看该作者
    2# hysman
    ) V4 y) r# M5 `) j1 i
      Z/ M2 r1 G! }, p/ f3 G( R有谁下载了
    发表于 2009-7-29 09:41 | 只看该作者
    下不下来啊。。。。
    发表于 2009-7-29 19:16 | 只看该作者
    改进如下:6 T6 S8 y( ?& M+ P
    , W* V- J2 ]  T5 w) o# h+ T' bHOTFIX VERSION:  015. g9 k, j# \* M# _) @; e
    ; O* o& k8 m& p' _! v, a8 R: @CCRID      PRODUCT          PRODUCTLEVEL2        TITLE
    * T4 ^: d, [: j3 n========================================================================================================. }! Z3 q& E7 a
    264893     APD              EDIT_SHAPE           Shape Edit Boundary toggle invokes S pattern not flip
      Z# x2 Z$ `) A609206     APD              OTHER                parallel command fails to run on mcm files
    ' P' C3 U8 b7 J8 p) n646375     PCB_LIBRARIAN    CORE                 Saving a design or Export Physical takes a long time
    / \# `6 Z7 p0 b650721     PSPICE           DEHDL                Pins shorted due to update in unnamed netnames
    % J  x( @; j: D6 R# J665343     APD              EDIT_ETCH            Diff pair is routed with gap less then primary gap for a smal" w! L5 Q: A! E# w7 O) L
    666736     ALLEGRO_EDITOR   ARTWORK              There are some shapes not filled when RS274X garber is import# N3 B4 Q( C. j& [8 }& p
    669411     CONSTRAINT_MGR   CONCEPT_HDL          DEHDL Constraint Manager crashes when SigXP is opened for a n
    ( T& R  ^: \! v! W669769     PSPICE           DEHDL                Edit Model on page border causes crash
    5 n  l6 d) F# _" D/ T! M671583     ALLEGRO_EDITOR   SCHEM_FTB            PartLogic does not work with library level ptf files.
      {2 M% ?/ E6 t672656     CONCEPT_HDL      CORE                 Using Select cut/paste commands crashes concepthdl
    $ e# c' ]8 q; R, j6 Y672806     F2B              PACKAGERXL           Export physical fails if datasheet hyperlink is defined as ke; {2 ~8 k5 U  L7 w  K6 L% d
    672995     CONSTRAINT_MGR   CONCEPT_HDL          Changing target on net in RPD groups does not clear the pinpa8 p5 N) V0 G/ x' r5 t
    676268     ALLEGRO_EDITOR   EDIT_ETCH            MIN/MAX heads up meter not working for some nets9 k$ V- N( D9 o7 ?8 b& b9 U
    677049     ALLEGRO_EDITOR   SHAPE                Wrong DRCs created on sliding Nets
    ( Q% }2 j* G0 b" [8 i: V: j) k& z677123     ALLEGRO_EDITOR   SHAPE                Shape does not void cline in slide mode.
    8 }: {7 m0 @6 p678030     SPECCTRA         LICENSING            Cannot start Allegro PCB Router with SIP525 license9 F' h& _5 I3 z8 A: q
    678075     CONSTRAINT_MGR   ANALYSIS             Wrong buffer delays are used in switch/settle times in CM
    $ X+ J( J' S( l, K% b678794     SCM              PACKAGER             Unable to package subdesign
    / C- n- Y" `& }% O- h) u) L# u678851     SIG_INTEGRITY    OTHER                Difference in lengths in 16.01 and 16.2
      M) W3 y3 R1 {6 Y; p678884     ALLEGRO_EDITOR   DATABASE             dbdoctor fixes corruption and then it's reintroduced
    4 v. T4 m6 l7 n$ Z& r679224     ALLEGRO_EDITOR   DATABASE             dbdoctor states it fixes an error but the error returns2 d- x5 P- {) ^
    679228     CONSTRAINT_MGR   DATABASE             Wire Length over Parent Die ADRC is not updated dynamically i: L2 x7 Y  v, f* |# o
    679288     CONSTRAINT_MGR   SCHEM_FTB            ECSets on some of the nets are missing after importing the lo# Z1 S5 B8 U5 ], @% f5 C
    679954     ALLEGRO_EDITOR   DATABASE             Unable to keep changes to the VIA list in constraint manager./ x0 t" f* v; L2 v
    679990     APD              VIA_STRUCTURE        In Via Structure > Replace after selecting the Old and New st3 ^, T8 O' O. J) M
    681074     ALLEGRO_EDITOR   SHAPE                void is not correct with pin having multidri
    " ^9 p. m; y4 U681140     SIG_INTEGRITY    TRANSLATOR           Spc2spc crashes on attached testcase) x6 G7 V, G/ t' g& _' U% u
    681975     APD              SKILL                axlExtentDB and axlExtentLayout functions will return nil if
    : s* Z1 h+ [, f/ _. }4 i. I, n682587     ALLEGRO_EDITOR   OTHER                Allegro moves all text when any text on symbol is out of exte
    6 C* i; L" @5 I  z683479     ALLEGRO_EDITOR   DRC_CONSTR           Modifying design pad to multiple drill creates unexpacted P-L
    9 v1 d& `8 D" k' R683515     APD              DRC_CONSTRAINTS      DRC is possibly bogus as it seems to be confusing layers
    发表于 2009-7-30 10:04 | 只看该作者
    文件有多大?
    慵懒
    2024-1-4 15:56
    发表于 2009-7-30 16:10 | 只看该作者
    下载不了?
    发表于 2009-7-30 19:45 | 只看该作者
    怎么下载啊?
    发表于 2009-8-2 13:30 | 只看该作者
    没有人告诉啊,
    发表于 2009-8-3 08:57 | 只看该作者
    Thanks
    2025-7-31 15:14
  • 签到天数: 614 天
    [LV.9]以坛为家II
    发表于 2009-8-6 11:52 | 只看该作者
    谢谢!看看这个有什么改进!
    发表于 2009-8-6 20:49 | 只看该作者
    已经安装016了
    13#
    发表于 2009-10-11 15:12 | 只看该作者
    已经安装016了  r0 d# k- P" D
    foxconnwj 发表于 2009-8-6 20:49
    ( F/ o% _8 Y! l3 s! O% ~0 y0 S& v' H7 a% W8 ~/ `
    请问我可以直接安装016吗?(没有安装015..)
    GMT+8, 2025-7-31 23:45 , Processed in 0.109375 second(s), 25 queries , Gzip On.
