查看: 2366|回复: 3
[HELP] SKILL ERROR
发表于 2009-7-23 15:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助下列ERROR MESSAGE是错在哪里
E- *Error* axlGRPDrwInit: argument #1 should be any user-defined (other) type (type template = "otg") – nil
procedure( IFormTest(fw)
prog( (position)
; need to do this since have a return
;; Good pratice
;; If form is open expose it and return
(cond (fw
(axlUIWExpose fw)
(return fw)
position = '("NE")
;; no msg lines in form
position = '("NE" "msglines" 1)
;; create a form handle, position form and set-up mode
fw = axlFormCreate('f1s "axlform" position '_afCallback t nil )
bitmap_handle = axlGRPDrwInit(fw "bitmap" 'FlipIt)
bitmap_handle->Flip = 0
graphic_handle = axlGRPDrwInit(fw "graphic" 'FlipIt)
graphic_handle->Flip = 1
fw->Bitmap_handle = bitmap_handle
fw->Graphic_handle = graphic_handle
;; Set a better title then the form file
axlFormTitle(fw "--F1-- skill Test Form" )
;; Build a dynamic popup for enum field
;axlFormBuildPopup(fw "enum" '(("item1" "1") ("item2" "2") ("item3" "3")) )
axlFormBuildPopup(fw "enum" '(("item1") ("item2") ("item3")) )
; demostrate color and font type in popups
axlFormBuildPopup(fw "enumcolor"
'(("green" 1 green)
("yellow" 2 yellow bold)
("red" 3 red underline)
("blue" 4 blue )
("button" 5 button )
("black" 6 black )
("white" 7 white )
("Bold" 8 bold )
("Underline" 9 underline )
;; Set form fields to starting values
IFormRefresh(fw)
;; Last thing to do is display the form
axlFormDisplay(fw)
return(fw)
; return form handle to caller
 楼主| 发表于 2009-8-3 09:03 | 只看该作者
已解决
发表于 2011-5-26 14:51 | 只看该作者
回复 seanhung99 的帖子
怎么解决的,急求,谢谢
发表于 2011-5-27 10:06 | 只看该作者
把axlform.form放到当前工作目录下面
GMT+8, 2025-10-26 02:09 , Processed in 0.140625 second(s), 25 queries , Gzip On.
