在出TOP时出现以下问题:
/ ?. I8 D! w/ z2 B1 V V& ~: i ---- Photoplot outline rectangle not found ... using drawing extents3 m1 P8 O5 I3 N3 }4 f- |
esults from parameter file ...
* z: v8 A' y/ ]! p, V6 D DEVICE-TYPE GERBER6X00+ ~6 [6 Q/ j1 t+ p5 ]1 N6 Y
OUTPUT-UNITS INCHES
: e% S4 V) p+ h# N FILM-SIZE 24000 160005 ~% G+ H+ F3 ^' r! z% b. |
FORMAT 5.3
2 Z- U+ l1 ]0 E; J ABORT-ON-ERROR NO! X {2 x! V8 o$ }3 S0 m! k4 y I
SCALE 1: n! B# Z8 `6 }; j1 v+ ^( k! Q/ E
G-CODES NO
/ z+ L# @* K* |- a/ q OPTIMIZE YES
4 d& E% Q! N P% k5 `2 w STATIONS-PER-WHEEL 9996 c2 b, L( G0 R T7 h
COORDINATES ABSOLUTE n2 l- u3 r8 D! q0 \! p A+ C
SUPPRESS-LEAD-ZEROES YES5 y8 ?: m `$ H
SUPPRESS-TRAIL-ZEROES NO3 V: c4 j7 A; d+ \+ t4 X' _
SUPPRESS-EQUAL YES
2 N$ l) K( j! ^6 {: F1 O, o
9 K$ l9 P' e& o6 A# M6 ]FILM PARAMETERS :
5 T9 `( }& V# m& i! b" X ---------------------------------------------------------
4 P6 C- a0 e; J# }, x undefined line width ... 66 ]2 p) x. n. v: [" r* q
plot wheels allowed .... 1 2 3 4 5 6 7 8 9 10
' V2 F7 p9 _( ^5 L mirror code ..... NONE, u) a8 e: f3 Y
rotate angle .... NONE
' D9 ~( z0 A6 ~- V$ E7 R; ]9 H offset X: 0 Y: 0% e% i& T$ m( L3 u& _' h
plot negative ... NO/ O0 i" x2 X. ^5 n) B5 V. |. J& k6 x
draw (fill) pads lacking apertures .. NO* w: W$ L* {$ m3 P% b0 S) E
suppress unconnected internal pads .. NO; h) D- I+ t9 x3 f; A% L
make use of rotated apertures ....... NO
+ P" Y2 V' b5 o- W1 a5 K9 i9 Q( i( F4 Q$ a9 }6 l+ L3 I% x9 e( ]4 |* `
WARNING: Photoplot window exceeds film size (24000 x 16000)
8 k% a1 }; j$ D stated in parameter file. % N: d0 D+ l& y% h
WARNING: Photoplot window exceeds film size (24000 x 16000)/ t, H# p7 N7 l6 D
stated in parameter file. ; K/ B D$ I. T7 o
, ?8 L- ~% O$ e8 b====> top created with warnings4 a; l) ^: S, }* ~
" r3 I8 U. e% S* U
TOP GEBER 文件可以打开,但不对,请教各位.谢谢
/ u) z5 m" L+ A* f7 }! Z$ t. N
