' e+ P8 q! Q" V1 P! z; @7 ~3 N
gauspuls产生高斯调制正弦脉冲(Gaussian-modulated sinusoidal pulse)
+ C+ Y6 ?; h9 Y( p2 a$ F
1 c9 }( J$ h7 y语法格式:5 I; R7 Y6 v+ p0 e m
( ~8 _) p1 h" t( M, ?
! Z' Z- V) w. E* R4 v& a
) N X# ?1 x+ _# H' X8 Q& ?yi = gauspuls(t,fc,bw) returns a unity-amplitude Gaussian RF pulse at the times indicated in array t, with a center frequency fc in hertz and a fractional bandwidth bw, which must be greater than 0. The default value for fc is 1000 Hz and for bw is 0.5. C6 {2 E) F! ]$ {2 X
7 e2 a1 v' A" c# m: C2 Q: tyi = gauspuls(t,fc,bw)在数组t指定的时间内返回一个单位幅度的高斯射频脉冲,中心频率为fc,单位Hz,分数带宽为bw,但必须大于0。fc的默认值为1000Hz,bw为0.5.
/ }, }9 l2 h! k2 l* w/ [
! l& X3 {8 C+ Z. m# v6 p" Q1 H这并不能给人一个形象的认知,我们举个小例子看下:
6 N; U E7 H, k/ @/ b- r y$ I3 z1 E8 ]! C4 M% s6 Z6 m6 M
举例子之前还必须了解下这个语法格式,用来产生一个高斯调制射频波的截止时间。
# u) y& x- |; v" o% a! F
& J) k* K+ O- [: A0 c" a2 \, r1 Y+ W6 v( D
' b/ S3 }# n0 {' { }* Q: h( Y7 @5 x- F2 t7 ]! {+ y- @
5 m6 u! r5 N1 v( D/ Y1 @7 I4 J
+ S2 y( c* e. R1 V4 x# f& e/ M( `5 m- ~! e! e' T m
