查看: 6323|回复: 30
17.2 59号补丁
发表于 2019-10-10 10:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
链接:https://pan.baidu.com/s/1kwK9lgMsSkqHeTYK3-PYZw
" l; S5 o  [' j1 d$ @提取码:yu0s 3 z, E+ \3 V* o0 |
5 c& Q/ A& c, Z" R  ?- H. Y+ l6 ?
6 Q. f4 p- p( z2 j
推荐
 楼主| 发表于 2020-12-31 15:22 | 只看该作者
认识一个gay 发表于 2020-6-29 11:102 N' A# u3 E# ]+ P5 b) M$ i
分享过期了
8 I5 W1 P6 P; G& _2 N) K- a6 C
链接:https://pan.baidu.com/s/1g9UNlhEKpXxLDwAStAMnIA
7 d* n2 y1 ~0 L提取码:ke1b
& m9 c0 e1 `% I6 @5 Y2 D0 n3 d8 @8 U: W* l6 j4 A6 l; i
6 @' g  C/ Q4 R4 P( @
谢谢分享!: 5.0
谢谢分享!: 5
  发表于 2021-10-26 11:24
推荐
发表于 2019-10-12 15:00 | 只看该作者
推荐
发表于 2019-10-10 10:57 | 只看该作者
帮助楼主补充以下Fixed CCRs信息,谢谢楼主:
4 W$ m* k2 h4 G7 o( A$ E, o
0 u1 j/ T  G0 D4 p1 t, O# F' O8 j  v) ]7 V4 L
Fixed CCRs: SPB 17.2 HF059
0 M) `1 r" S3 ]$ I5 A. ^0 g; H8 w09-13-20199 N9 H' S: a; A! V" M5 K
3 d0 u- K5 @6 A0 |  o, Z. ACCRID   Product            ProductLevel2 Title
- q& B- S3 R7 J========================================================================================================================================================# G: R0 q" W$ E8 |2 v1 O
2112454 ADW                DBEDITOR      Icons in DBEditor do not start applications after renaming a model. Y6 n& X4 v& \2 x
2120548 ADW                LIBIMPORT     Missing alternate footprints from vault area after library import.
2 _' t6 Y+ f$ y! L2143314 ADW                PART_BROWSER  Component Browser does not start after installing HotFix 057 of release 17.2-2016
2 m2 e0 K7 x6 |, I1 m: h2122302 ALLEGRO_EDITOR     ARTWORK       Coverlay details not being output to Artwork data as per the visibility
2 U; ~, B, x+ A4 A2135521 ALLEGRO_EDITOR     ARTWORK       Artwork dimensions do not match Allegro PCB Editor/ V8 V8 B, }1 \( ~7 c( V" j
2054584 ALLEGRO_EDITOR     DATABASE      Through hole mechanical pin in zone area without Soldermask Top still shows a pad on Soldermask Top
4 v, A2 X! C  j( O" R/ f2111444 ALLEGRO_EDITOR     DATABASE      No soldermask for mechanical holes within zone
; E* U7 C( E% t! k4 T: \2115596 ALLEGRO_EDITOR     DATABASE      Unused Pad Suppression removes pin connected to shape using Net_short property6 L6 f# w( x9 K) {6 }1 p# W" T
2135436 ALLEGRO_EDITOR     EDIT_ETCH     Allegro PCB Editor crashes when routing with VOID_SAME_NET property on cline
! M5 |/ W0 P1 m' q1825020 ALLEGRO_EDITOR     INTERACTIV    GUI ( Quickplace ) not adjusted to current resolution. [. E; y+ I; s  o' L1 B$ J
1949705 ALLEGRO_EDITOR     INTERACTIV    Quickplace GUI not adjusted to lower resolution9 u( B$ l5 i! K( v! f: `; T
2023090 ALLEGRO_EDITOR     INTERACTIV    Dialog boxes do not fit vertically on the screen, `3 ~4 W( g% X& w" i; a
2109940 ALLEGRO_EDITOR     INTERACTIV    Quickplace pop-up window does not fit vertically on the screen; [! j3 d4 r4 H, P
2136823 ALLEGRO_EDITOR     INTERACTIV    Cannot resize or move dialog box to access buttons
& n- k$ j& W' J) R( {' Y2116748 ALLEGRO_EDITOR     IN_DESIGN_ANA Impedance vision data not available for cline segments for some nets- q: I5 y' N8 g* \
2138977 ALLEGRO_EDITOR     IN_DESIGN_ANA Impedance check results are incorrect and Crosstalk analysis stops running after updating to HotFix 057
5 U. P0 B3 V5 t9 I# m2132628 ALLEGRO_EDITOR     NC            Improve the User Preference description for BACKDRILL_OVERSIZE_OPTION9 A" e/ I" J! P9 f7 W) u, W
2152244 ALLEGRO_EDITOR     SCHEM_FTB     Netrev.lst is written in the package folder
0 ]/ T$ D0 F+ X" `+ w/ S  _5 Q- j2152493 ALLEGRO_EDITOR     SCHEM_FTB     netrev.lst is not created in the correct folder - error displayed for neltist import# {1 G. F. _; l
2104559 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes while performing shape operation 'andnot'
7 V+ m8 |& h! h4 R/ N# e9 F% o& ^& a2108207 ALLEGRO_EDITOR     SHAPE         No Void Overlap option is not working in AMB6 Z" R9 T' y  J/ H& m
2125571 ALLEGRO_EDITOR     SHAPE         Allegro PCB Editor crashes for a RAVEL rule/ m' K% {" e& R1 X& T
2140707 ALLEGRO_EDITOR     SHAPE         Allegro PCB Editor crashes on creating dynamic shape
) N, ?4 C9 N( j. l( h4 r% ~2078434 ALLEGRO_PROD_TOOLB CORE          Shield Router - cline end caps treated differently than cline-segment end caps9 b. I* R5 t1 a1 ?5 J# J6 \& f
2101020 ALLEGRO_PROD_TOOLB CORE          Productivity Toolbox Z-DRC with multiple net classes: script selects only the last two classes in a group
, W; ]5 x) r, N/ m2029279 CAPTURE            SCHEMATICS    Slow response when selecting parts in schematic
7 L3 d* S5 J$ y: P; h- S2 r1 O2039931 CAPTURE            SCHEMATICS    Slowness in OrCAD Capture when ITC is enabled4 q3 D9 \. X2 M( }: p
2106942 CAPTURE            SCHEMATICS    Inter-tool communication needs to be disabled to resolve the lag issues in Capture) ^) E9 b( f4 X9 V# `- v
2131683 RF_PCB             ROUTING       PCB Editor stops responding on using RF - Add Connect/ q5 M( F) p' C- q7 v
2126505 SCM                OTHER         Thevenin Termination dialog displays resistors incorrectly4 H2 U6 t) C+ K# H
2102383 SIP_LAYOUT         WLP           Advanced WLP Non-standard fillets not working properly: fillets not added
发表于 2019-10-10 15:46 | 只看该作者
Thanks a lot!
发表于 2019-10-10 18:58 | 只看该作者
目前58  坐等60号补丁再来搞啊
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2019-10-10 23:11 | 只看该作者
    感謝大大的分享囉!!
    发表于 2019-10-11 12:39 | 只看该作者
    終於等到了!謝謝熱心提供分享。
    发表于 2019-10-12 00:20 | 只看该作者
    hotfix060已经出来了
    发链接,我去下载。  详情 回复 发表于 2019-10-12 13:17
    13#
     楼主| 发表于 2019-10-12 13:17 | 只看该作者
    金志峰 发表于 2019-10-12 00:20
    ( y2 L3 P* _' q& a9 r4 Y, rhotfix060已经出来了
    - ?% B6 u9 b& S- B  f& j* K# d  b发链接,我去下载。- ?# J0 Y' W% v7 b/ l+ C
    15#
    发表于 2019-10-12 15:01 | 只看该作者
    GMT+8, 2025-11-4 14:21 , Processed in 0.171875 second(s), 26 queries , Gzip On.
