基于 MCS-51 单片机的智能控制开关的设计$ }. N6 v$ j, D7 A8 x% N
, `+ ^ }+ i/ S3 G1 J摘 要8 r0 r, ?7 d+ D P4 I. M
在自动测控系统中, 特别是长时间无人值守的测控系统中, 经常需要进行长达几小时的定时操作。若采用专门的计时芯片设计,一方面控制复杂,占用硬件资源,另一方面也不经济,一般的时钟芯片价格都比较贵。由于单片机内部有定时器,因此,可以基于单片机设计一款智能控制开关。: j1 J5 f( e6 s4 G
; E+ f+ x d- k
关键词: 定时 单片机 智能控制 开关
5 X! Y4 h- R/ j( D0 E; B5 V
. u5 E& ?' F7 Y0 o
8 K( g6 B9 x& I1 h! y: k* S7 `
! ]) F' `9 }8 V# ?1 e! |ABSTRACT
, P2 A, e8 {- x VIn the automatic control system, especially in a long time unattended monitoring and control systems, often require long hours of regular operation. The use of a specialized chip design time, on the one hand control of complex hardware resources occupied, on the other hand is not economic, the clock chip prices are generally more expensive. As the mcu internal timer, so you can design a microcontroller-based intelligent control switch. 5 V" G9 h( Y/ q* G4 e5 c% e% L
' X& S- L& W$ Y. bKey words:Timing MCU intelligent control switch
% @9 M! E( t7 Z! j- t9 o/ {+ r' [) M& y$ M( D7 j; R. I" c1 p
6 l' L+ q6 T4 ~. U, x" f
; l( V6 ^4 @% E" M
. D8 e3 A! A! s2 f3 ]
: N, w! J" t M# {9 W1 b% X* A+ f8 g' G5 d3 p
. ]) _+ p' Q- Y+ r5 P9 c/ v8 K
( ^# v% \* P# A1 h l, c
% ^) E, m( `8 e2 C {5 L
& T8 k* K# |+ u6 P h( T. b! I7 x8 `. F
