首先我將一個電路圖的netlist導入allegro
3 Z5 U$ U& a# T0 K2 `import logic時發生錯誤,顯示電路圖與footprint的腳位不符合
9 m. Q% W! a8 Y# w2 F後來我去更改電路圖,使得跟footprint相符
8 q5 W X/ ?" P$ {8 t2 G+ U0 \4 j導入import logic沒問題,可是在placement零件時
8 z1 H. C4 i. x# _ Y; V/ ^放不進PCB板,命令列顯示"pin numbers don't match"
. `$ R' _0 _ ?9 D後來我將電路圖改回來,並將footprint修改,並且另外命名8 S9 g4 g/ D# I7 Z; W
import logic也是沒問題,但placemet時又放不進去
O/ n" u7 I. I3 x也顯示一樣的問題,請各位高手幫我看一下,謝謝!!!# x6 e* ~; Z4 g0 C Y n) N
, Q' N. |. z# C$ D% s+ M2 h) V5 \
這是我再次import logic時的設定
% M, u# `: q, W" y1 V+ z' T9 @7 y
http://cid-62830e8aedb51db8.skydrive.live.com/self.aspx/footprint%7C_not%7C_place/import%7C_logic%7C_RN50.JPG
) x9 m+ B E, r* x3 R, a1 h7 P# W, r2 v# l+ j3 x$ u
4 s2 k. |; @- u/ Q這是未修改前的footprint& d, `+ \ t9 N/ N0 Z M
3 M$ w5 `& h2 R: L2 D" W- ^8 G0 K
http://cid-62830e8aedb51db8.skydrive.live.com/self.aspx/footprint%7C_not%7C_place/tqfp64-19p7.JPG
8 {+ D! R) ~) H s( @& T8 o, `0 O) u. l, T' \8 G
這是更改後的footprint
0 c6 T( P, Z# a( O. b0 w& uhttp://cid-62830e8aedb51db8.skydrive.live.com/self.aspx/footprint%7C_not%7C_place/tqfp64-19p7%7C_1.JPG7 S J9 @8 m9 s" a" D! G6 o
+ S' m8 e3 `: H3 X6 A
這是更改後的footprint要placement時看到的零件圖,顯示pin有66,但我已將
. L5 b5 U0 B2 B: G8 w1 r& U上圖的M1,M2pin del掉了,可是圖還有顯示66pin,正常因該是64pin5 d9 V0 j, {/ F5 r' ?3 X4 p6 r$ K8 ?
http://cid-62830e8aedb51db8.skydrive.live.com/self.aspx/footprint%7C_not%7C_place/tqfp64-19p7%7C_1%7C_not%7C_place.JPG
: R, u( ?; P# M+ w( j* T$ T2 Z' z% w
後來我從tools/padstack/modify design padstack 去看修改後的footprint- e+ [. ~+ X* T! F
發現被我del掉的pad還存在.- ?; G1 G9 ^- N' h( ?/ H
7 `( L0 N" r, A2 u. W& `http://cid-62830e8aedb51db8.skydrive.live.com/self.aspx/footprint%7C_not%7C_place/tqfp64-19p7%7C_1%7C_not%7C_place.JPG
$ B8 Q# m8 {& A+ C9 ]; t0 Z7 ^( x' l" z; `' R
. u- S$ R1 }: o$ w4 p, U4 J請聞到底是那個步驟錯了,導致零件放不進PCB謝謝!!!
; I7 ]" f E5 }2 A2 o0 n' R( |4 h# f+ M
