查看: 506|回复: 2
STM32串口USART1中断接收和中断发送
发表于 2019-9-11 15:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  先贴出中断函数:1 c. x& N2 ]) c/ K: r* H
" j1 E$ _7 A0 e) r* G* S9 Q$ y
  1. [plain] view plain copy; }  R, n6 i2 n& ?
  2. ( Z- L, @8 u2 J+ u
  3.   void USART1_IRQHandler(void){
    , X$ i  O8 u& ~- r4 g- K' E
  4. " U: ?. Z  D( a0 Q
  5.   IF (USART_GetiTStatus(USART1, USART_IT_RXNE) != RESET) {0 k" |: i! ?* F
  6. ' }5 t; U; k- K. Q
  7.   USART_ClearITPendingBit(USART1, USART_IT_RXNE);9 H, |  j0 m  A: R% @+ C- N5 P' n
  8. 0 }, r) x! c7 p5 Q
  9.   USART1_Buffer[i++]=USART_ReceiveData(USART1); //USART1_Buffesh是一个自己定义的接收数组% r8 c7 ?$ i+ A2 f6 Y, V' l9 M2 Y
  10. " ~6 ]% H4 _8 q2 y6 P) B0 ^: M
  11.   if(i>3){0 D! V4 u1 P3 J/ z* U, d: Z) g$ _
  12. ( w" `4 N% S( m; v3 F
  13.   SendFlag = 1;8 d1 E8 H7 h" F7 l
  14. : Z2 L5 Y  _& r! W  ~
  15.   }
    $ `$ V' Q& W& X) s
  16. 3 E0 o% e5 c- e: u/ L
  17.   }4 G+ }' c/ }" @7 ^, n# j
  18. " l& A2 p- |. I- \) R1 G* \
  19.   if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET){ //USART_IT_TC这里也可替换
    1 O: `) L) U. ]& m4 J5 s( a
  20. 5 K$ C) ^* a! }  C  k
  21.   if(Open_Send_Flag){ //这是一个发送的标志4 E- C; V6 T5 C; V. u2 Q$ L
  22. * K: U+ E  O% W& c1 Z
  23.   uart1_sendstring(temp_data);
    ( U6 n2 x* x+ v7 d8 J9 J6 s+ I) m, F
  24. , I4 l' |1 u" F' w- E
  25.   USART_ITConfig(USART1, USART_IT_TXE, DISABLE); //USART_IT_TC' V; k! s" F8 G; \3 `: Y. m- I
  26. 2 ?/ I6 m3 ^- ~/ @
  27.   Open_Send_Flag = 0;' U% L+ K. I9 M0 j2 M2 \6 V5 I$ `" R
  28. ( i$ r- {6 w: c: d
  29.   }
    ' U* ]& q2 m9 W2 b( Q
  30. 7 @9 W; I) @4 b0 U: V: u
  31.   else{2 U5 U2 e+ y" n# |
  32.   m; |+ I% }( G: G# E
  33.   USART_ITConfig(USART1, USART_IT_TXE, DISABLE); //USART_IT_TC
    - D: H7 I$ ^: f5 X" b
  34. - R$ z7 H9 _8 j9 ~7 u
  35.   }
    , j, ?: A; ~8 q
  36. / Q3 v4 ]$ ~7 F
  37.   }/ `/ y0 O* J% ~& U
  38. & Y- [+ e. l& H3 \; S
  39.   }
复制代码
- p8 O5 T  a& l* M0 m$ l) ^0 V  x3 \
  发送字符串的函数:; ]4 y; O! U. g/ ]; }3 f
, b$ E. X% V) _( S( {
    2 T# V; ^! I2 U
  2. ! {: d; K9 @; d
  3.   void uart1_sendstring(uint8_t* cp)% u8 ]: x" E& N% i
  4. $ O9 \- a* ^6 D; u1 p$ O
  5.   {
    % c2 R' n% d8 T3 w8 l
  6. & F! K' ?+ o4 L% {+ N8 l
  7.   while((*cp)!='\0')
    * x4 ]* ?& q# A* t/ a) Y
  8. 4 p* }- C/ M3 p5 \
  9.   {& F" D" K& P7 H
  10. 8 q7 U$ k( h7 j; b4 j- A; {
  11.   Usart1_Send_isr(*cp);
    $ z4 D1 e! L0 ?  z2 T2 K! [
  12. - ?+ E/ T" w: @! d" U" A- `
  13.   cp++;
    ' ]' M, n. p5 r- u% d8 ^5 A
  14. # r0 O! m5 F) z9 |
  15.   }
      z& V6 |6 V: P' P  }) R
  16. 7 X6 B$ u1 P% U# o5 ^5 D
  17.   }
复制代码
' P) _( T; C, k3 t; _
- K: B6 [% }- x5 F8 G
  发送单个字符的函数:+ s8 Z: |) Y6 D5 D/ p
# P) k' R6 i8 }7 j9 u7 g3 i" A( ]* s
    % B9 [% _0 z+ ~" ~4 i
  2.   r' T% T6 _7 S' V1 [( m* h
  3.   void Usart1_Send_isr(uint8_t ch){
    ' V2 R# x* w0 G, P3 d* \6 Z3 e% E
  4. 3 i# r! j: M# O" L& {0 w( |2 J# V
  5.   USART_SendData(USART1, (uint8_t)ch);  P$ [. l* \9 Q' _9 |1 u: M& \9 N% c
  6. ! Y3 `5 X- s8 Q' k' j
  7.   while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET ); //这里做缓冲区是否发送完判断! _: x0 D& I+ h5 C, E1 x5 @- o) {
  8. - ]. l1 D" f# o2 Y, h! e" K
  9.   }
复制代码
' F+ v' V/ R" r* w4 @* m( d+ H: o2 W8 C
  然后在中断函数外面发送数据的时候,打开发送中断。USART_ITConfig(USART1, USART_IT_TXE, ENABLE); //USART_IT_TC+ s" r- X' _1 N$ n$ L1 q
  之后再贴出两个简单的串口接收和发送的测试小例子:) Q! g* e! ~6 k' x; e% g1 D
  第一种:中断接收并把接收到的数据直接发送。
3 I* B, {& x5 c  s# e+ Y. L, F) k+ @. M' L0 s: q
    + W/ Q2 s* [" X5 R/ c. J2 ~
  2. ) {# v1 d' I2 C4 M9 g: |
    : k! Y5 b- w7 _$ u& q9 x
  4. 6 ~6 ~/ Z6 D* L2 E8 s% |
  5.   unsigned char RxData;
    ! o, P1 @* Q2 m5 W. U1 k* a
  6. 7 H7 W& @# n% J$ F! G& X. k! [
  7.   if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) {
    - m+ t1 P" L/ O) e
  8. 8 K' G# o7 n$ z1 C
  9.   USART_ClearITPendingBit(USART1, USART_IT_RXNE);3 x1 ~  W* P" b; `
  10. ' v' W+ G/ h% T; |: j, H
  11.   RxData=USART_ReceiveData(USART1);
    - L  _( D4 N1 ?, G! @
  12. 3 @" e$ |1 k5 a# [6 b
  13.   RxData = RxData + 1;
    ) U0 U4 A$ c0 T/ J
  14. 6 j0 g4 g( ~  W
  15.   USART_SendData(USART1,RxData);. {$ j6 e1 P! x5 Z, Z
  16. & O% K3 z/ t" h! Q$ v% R
  17.   }5 @% |5 l: t9 U3 C. P$ Y) F
  18. / Y0 y  Z" z* T! o3 e( A' }
  19.   }
复制代码
: o* i5 f8 |8 L2 P+ ~
; x2 c. q) S, E- r6 x
  优点:简单,适合很少量数据传输。
6 U2 `4 r* Z# U+ I! F+ d1 O  缺点:无缓存区,并且对数据的正确性没有判断,数据量稍大可能导致数据丢失 。, g. F* V. O" x
  第二种:中断接收之后判断数据头和数据尾,如果正确就直接发送出去。# F, i7 u- ?9 c+ ^. E& u8 p2 F8 `
- n( f! |) g8 B  d0 \
    ' V1 v7 W( [$ R' |
  2. - o4 l9 }* i3 P8 V- l1 R# e* c
    * E8 O& [3 p5 c% p1 T- ~
  4. 5 c" O5 [" o$ W
  5.   if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) {7 g4 |7 v) v: z3 t+ J; U
  6. ! u/ w0 Q! f( V
    + i% K+ p1 o8 ~' T- o1 f2 y
  8. 1 c" }6 g( K6 r: \& \6 r
  9.   USART1_Buffer[i++]=USART_ReceiveData(USART1);) `" Z& k# l; q8 i1 Q
  10. 3 z! p* P$ }0 @. J
  11.   }( ^; z. w! T2 G; u+ b
  12. 7 u+ A0 C! D4 n  y
  13.   if((USART1_Buffer[0] == 0x01) && (USART1_Buffer[i-1] == 0x02)){- s+ l. i6 J$ Q
  14. 7 f7 l7 c3 Q( ?7 G# d
  15.   Flag = 1;
    0 i  ~8 l$ ~( }) |& T" b7 b
  16. ! m# R6 R' O4 _( I' }
  17.   }
    4 x0 n* H# u. T
  18. ; l( {# e( L0 A% o+ ?
  19.   if(USART_GetFlagStatus(USART1,USART_FLAG_ORE) == SET){ //溢出,不明白?
    7 |/ x4 r: q3 ]+ `, D
  20. 0 h$ N6 C, r; j9 `* X  R
  21.   USART_CleaRFlag(USART1,USART_FLAG_ORE);
    " \, ?  c! w) B$ m( ^+ N: y" D
  22. " z& \3 f6 D. n7 o
  23.   USART_ReceiveData(USART1);
    6 X' D7 t9 d) Z6 @. S
  24. ) G* ?$ S% \$ b/ l6 T! B* d% m
  25.   }  x- a! `( v8 n8 ?3 Y, }. U
  26. 7 s# b/ W1 z% L% y' ]7 Q; K& P
  27.   if(Flag){
    . R4 X5 L" X6 n! e! m' d) }
  28. . N2 V! Q+ y' q+ {( _" \, r
  29.   for(j = 0;j<20;j++){, t! e8 A( U- G! U0 @& v$ y# @
  30. 8 f: [  P1 T, Z
  31.   USART_SendData(USART1,USART1_Buffer[j]);
    2 ?: `8 i0 r9 n4 U, O9 ^) ?2 F
  32. : m  \0 G$ W) K* [5 a$ _
  33.   }' {3 ?5 r  d6 L1 B: ^
  34.   P) O7 d$ M* \. B
  35.   }
    ' t/ n2 b* t: x& x* ^
  36. " q$ O; }" h% g  V( k3 r
  37.   }
复制代码
: M  L" e2 m3 [8 t. r+ T1 X
, |' h) _4 L" I* x; f$ g, a
  相关的stm32串口以及中断相关的资料+ ?8 H6 y5 C) p1 d6 N* _2 b" Y
) t1 _& A) Q2 o$ Q) B' p
GMT+8, 2025-10-8 05:42 , Processed in 0.140625 second(s), 23 queries , Gzip On.
