查看: 429|回复: 4
Attenuator Bridged T Excel計算器
    2021-8-25 15:52
  • 签到天数: 316 天
    [LV.8]以坛为家I
    发表于 2019-9-3 08:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    可以簡單地輸入特性阻抗計算出需要的電阻值,或輸入電阻值計算出特性阻抗..' N# v; T3 r- B9 U( _
    Attenuator Bridged T.rar
    4.26 KB, 下载次数: 6, 下载积分: 威望 -5
    发表于 2019-9-6 09:30 | 只看该作者
    * r, h9 o. l, y9 _8 v; j3 n# v
    发表于 2019-9-6 09:31 | 只看该作者
    https://www.eda365.com/thread-188514-1-1.html8 H  f% _6 R! B& E
    3 s2 o+ |3 `! e$ @7 X
    奇怪,两者对比,偏差有点大。
    Bridged-T Attenuator Example A bridged-T attenuator is required to reduce the level of an 8Ω audio signal line by 4dB. Calculate the values of the resistors required. [attachimg]227872[/attachimg]  详情 回复 发表于 2019-12-3 17:29
    The Bridged-T Attenuator is another resistive attenuator design which is a variation on the standard symmetrical T-pad Attenuator. As its name implies, the bridged-T attenuator has an additional resi  详情 回复 发表于 2019-11-29 15:38
    2021-8-25 15:52
  • 签到天数: 316 天
    [LV.8]以坛为家I
     楼主| 发表于 2019-11-29 15:38 | 只看该作者
    汪洋大海 发表于 2019-9-6 09:316 p' [; a9 s9 G: K) y
    0 g4 q. i1 L- k: O: U) X% M3 q4 ~$ s6 M  P/ M1 z6 W
    奇怪,两者对比,偏差有点大。
    1 ^) {9 v# _6 N; s$ [; h% U& i. jThe Bridged-T Attenuator is another resistive attenuator design which is a variation on the standard symmetrical T-pad Attenuator.
      f3 u$ B5 a- J* KAs its name implies, the bridged-T attenuator has an additional resistive element forming a bridged network across the two series resistors of the standard T-pad.
    0 r: E( J5 X% q6 `" {This additional resistive element enables the circuit to reduce the level of a signal by the required attenuation without changing the characteristic impedance of the circuit
    3 U8 H3 Z' D/ r: o4 h5 bas the signal appears to “bridge” across the T-pad network. Also the two series resistances of the original T-pad are always equal to the input source and output load
    ) i* }' n7 n; timpedances. + N$ S0 [- n& t
    The circuit for a “bridged-T attenuator”, ( T ) is given below.1 C0 f5 L0 L% N& `2 j
    7 V& d& N/ f0 y: [+ L! W, X) F
    8 I  N3 D) a7 g) @2 E4 D+ JResistor, R3 forms the bridge network across a standard T-pad attenuator. The two series resistors, R1 are chosen to equal the source/load line impedance. One major
    9 x# Z2 |. w7 ?- {advantage of the bridged-T attenuator over its T-pad cousin, is that the bridged-T pad has a tendency to match itself to the transmissions lines characteristic impedance.# a& Z* x' X1 E% y
    However, one disadvantage of the bridged-T attenuator circuit is that the attenuator requires that its input or source impedance, ( Z ) equals its output or load impedance,  n6 b! x# L8 y, Q# H7 O* p3 x
    ( Z ) and therefore cannot be used for impedance matching.
    : _, y7 b) Y  t. o; LThe design of a bridged-T attenuator is as simple as for the standard T-pad attenuator. The two series resistors are equal in value to the lines characteristic
    . c" q4 r1 `4 r9 f" Y& himpedance and therefore require no calculation. Then the equations given to calculated the parallel shunt resistor and the additional bridging resistor of a bridged-T attenuator circuit used for impedance matching at any desired attenuation are given as:6 x4 Z% u, s0 P( K
    Bridged-T Attenuator Equations:/ p8 _4 `" E9 l7 c2 I: r
    + m  O9 l7 t7 R2 ?# C1 ~  V) L  f/ Z% ^  k3 v' w
    where: K is the impedance factor, and Z is the source/load impedance.
    - P0 F+ M3 v) n# R: _0 V' T; W2 l4 O+ h0 I
    , ~( j" }5 U  P
    9 }' v4 E" q: x: y
    2021-8-25 15:52
  • 签到天数: 316 天
    [LV.8]以坛为家I
     楼主| 发表于 2019-12-3 17:29 | 只看该作者
    汪洋大海 发表于 2019-9-6 09:31: `! v8 Z# M+ Z% O
    https://www.eda365.com/thread-188514-1-1.html( x" L9 u4 e5 ?* t
    2 l: T* a1 V0 x( `5 ]
    奇怪,两者对比,偏差有点大。
    ! B  ~$ u* T# Z5 o2 K' ]! D8 K9 N
    . }, _+ ?0 U( h  @, S4 m+ BA bridged-T attenuator is required to reduce the level of an 8Ω audio signal line by: b/ i/ C8 x1 E; Q# C3 Y
    4dB. Calculate the values of the resistors required.- h2 T) |4 g5 O: z
    4 m  A0 k7 W: c  v# A3 z  uThen resistors R1 are equal to the line impedance of 8Ω, resistor R2 is equal to 13.7Ω8 }( ~1 T' s! Q4 y$ x# e9 f
    and the bridging resistor R3 is equal to 4.7Ω, or the nearest preferred values.7 U# Z- v0 g/ G( D  r
    As with the standard T-pad attenuator, as the amount of attenuation required by the
    5 N5 Z; ?0 `0 |0 V1 N- ~: z0 Vcircuit increases, the series bridge impedance value of resistor R3 also increase while
    * R- }4 K# h2 V  P( A# x# X5 `the parallel shunt impedance value of resistor R2 decreases. This is characteristic of a5 F$ b' c3 {- Q" g; s
    symmetrical bridged-T attenuator circuit used between equal impedances.7 G! E( \* p9 W8 l' l1 _
    " o& C" y5 H9 c+ Z
    GMT+8, 2025-10-31 09:42 , Processed in 0.156250 second(s), 28 queries , Gzip On.
