查看: 844|回复: 1
matlab和C++混编的程序怎样运行呢? ??
发表于 2019-7-16 15:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
( _& w( m0 J/ R& P% J! z0 ~
& A9 h5 @, s) Y' F3 o1 \3 E/ n+ b4 ?- H' d$ f1 w2 l
这是readme文件中的说明:
Please follow these simple instructions to get the # [  }& m. ^% }% x3 t
ToolBox working:
1) Download and unzip SegToolBox.zip from the website.
****** PRECAUTION: Please make sure that the path-name to the directory where files are unzipped does NOT contain any spaces. ******
2) Open Matlab. Cd to the unzipped directory whcih has all the files.
3) Make sure you have mex C++ compiler installed (Ex: Visual C++.)
  • To choose the compiler type "mex -setup" at the matlab commandline.
  • Follow the instructions therein until you have chosen a C++ compiler.
      D! _: R. N9 p/ y, h, C1 T- G
4) Build the library files required by the toolbox by executing
% k: i- D$ V+ s! m* hthe following at the matlab commandline:
mex GraphCutSegment.cpp graph.cpp maxflow.cpp& Q# l, h- `1 T( e% |, h
0 K; ~& t9 o$ w  kAND
+ E: u5 e0 ?/ X8 z9 P' |" Umex GraphCutSegmentLazy.cpp graph.cpp maxflow.cpp
This should create the library files (ex: FileName.dll in Windows or( M. f8 ^0 Z8 a6 a
FileName.mexmac in MacOS)
我按上面操作生成了一个GraphCutSegmentLazy.mexw64文件 另一个生成失败了 但是按照readme说明不是应该生成.dll文件吗?这个列表里本来就有,这个mexw64是来运行程序的吗?
$ _! y: J/ K8 W) O' p
6 P- P# s6 A9 ]! g1 p- h9 o! w! c* C) [! m8 u
3 a# S! K6 }( g; x4 e) C$ o
    2019-11-19 15:34
    发表于 2019-7-16 18:15 | 只看该作者
    Matlab调用C/C++的方式主要有两种:利用MEX技术和调用C/C++动态连接库。
      在Matlab与C/C++混合编程之前,必须先对Matlab的编译应用程序mex和编译器mbuild进行正确的设置[1]:
      对Matlab编译应用程序mex的设置:Mex –setup.
      对Matlab编译器mbuild的设置:Mbuild –setup.
    * T! t5 b4 B* j/ K* n; |
    GMT+8, 2025-10-29 00:08 , Processed in 0.140625 second(s), 27 queries , Gzip On.
