做的PWM直流电机调速,我用定时器0定时产生PWM脉冲,定时器1计时50msTMOD = 0x11;
9 r. W. ]& a& J/ r4 ` TH0 = 0x0FF;3 |7 J" |6 n) D
TL0 = 0x9C;//100us! q$ Q, }1 J. I" f& E( K8 Q
TH1=0x3C;$ I& i r$ T: D1 r: [/ k
TL1=0x0B0;//50ms1 k0 }. ^ u1 p+ y8 d" p9 Y
EA = 1;( J4 E# r8 S& Q
ET0 = 1;
4 G* M; m( e1 k9 \( W TR0 = 1;: c! W% T2 c+ D. c( e4 k7 t; \9 @, Y
ET1 = 1;) D, B! z- b- H- w2 o
TR1 = 1;
8 z9 S2 O! T k8 q; L8 Q( _8 r' S5 W
关了T1PWM波形正常,但是只要开了T1波形就不对了,像图中那样,中间会有一端高电平。外部中断1检测速度脉冲,这个没啥影响。求各位大佬这个怎么解决啊
6 X+ t5 a h: e _: p+ W1 k1 H! d: n k) a: ^
void time_0()interrupt 13 J% ^& y w) _3 b8 g
{) e& T- N8 i' i
TR0=0;+ E o7 g6 I2 I1 d& {
num++;4 L( ]! q1 s! P( Y& T. W( {
IF(num<PWM)
" v5 F$ X- y+ i) x2 F$ I4 N ENA=1; //L298N使能端
6 Q# J( w* a: ?$ c( p3 v else
; @) k7 L$ J; p; S ENA=0;
- d) h! a; g. _6 }% C7 E4 \ if(num>100) num=1;7 k6 A X$ _6 q" i
TMOD = 0x01;/ P1 F6 o& k; B) X5 u0 i7 X8 @
TH0 = 0x0FF;//100us5 d0 F2 c E. J& I: y( U8 y
TR0=1;
8 V1 h$ n% |" T; E4 o3 V}$ U) O7 y- U" N! U8 R
: x m7 X. {9 x7 L5 Cvoid INT0_INTERRUPT()interrupt 0
/ C! s5 V& c/ }" X{ R" }! K7 [6 n7 k
EX0=0;
$ z8 d- \) z* cvelocity++;' W7 x2 G' n% O K
EX0=1;
+ n7 P6 {8 s! Q}
2 B2 k4 ?* F! L* G4 B. {4 H; A, M* {7 z3 C' ]$ p5 u( v
void time_1()interrupt 3
2 s. E% o0 |- v( L( A9 n{
, I( i, d; w# R0 l7 v. V TR1=0;! N6 a4 n5 K, V/ g
count++;% t/ T- Q9 G. W4 z5 t) q6 [9 B
if(count==51)
. y" V* ` ~% {$ j/ `. E { ! u1 i P9 B& X7 v( ?
sprintf(DSP,"%3d", velocity);
! s4 N" l5 `0 G" C E! z display_string(7,4,dsp);
- ]0 _% R& G% S5 g/ } ldelay(100);
, ?! m1 p1 I' M. x count=1;4 x/ H% C3 R: K( x
velocity=0;9 p7 z5 t0 A9 l! |& F
}+ w0 I! a1 k9 S
TH1=0x3c;
' U2 a$ Q$ k& w- G TL1=0x0b0;
6 `: L# x, ]' C TR1=1;
+ W. H1 ~0 o& t9 s
1 }, [6 Q3 j+ U! }7 {
; d; ], |8 Q( b}5 M+ U0 z8 J4 ~9 j! k: `1 w
7 D. s3 S) y- i8 ^- b8 g/ l$ z( X; h4 q" y( r/ {% \5 c3 g
