查看: 1217|回复: 4
谁能帮我看看?
发表于 2009-5-26 17:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
% I  L" {3 m4 ?: g$ o3 I1 }& a/ [$ A; Z' O" v
E- No command ID mapping files (allegro ) found in MENUPATH.) I7 ]% I4 l9 ~; i/ D9 ^
function _saveSelSet redefined
7 v  u5 l) `5 K9 T" F8 Mfunction _restoreSelSet redefined
& {" Y, Y0 R/ t# e. Y6 d8 gfunction _saveSelSet redefined' H, W5 ?8 A& J0 ?$ M! R
: i* u: Q! ~% z" u2 Ifunction findAllOfType redefined
! J; t  y3 ^$ J$ T" L  i7 p$ l7 t* Ffunction ashFindAllClines redefined
- O( t! ^* r# ?function ashFindAllClinesegs redefined* e1 {" p' g& W! x3 W
function Form_Action redefined+ Z; j0 r# B  G" ?% N3 g0 A" ~
function _saveSelSet redefined3 i. {: L# E7 \& z
  r; _& b& L; h0 Z/ r8 U9 Dfunction findAllOfType redefined
7 o9 W7 f! p! wfunction skillFindAll redefined
0 X4 a2 `5 u5 `; L9 sfunction ashFindAllPins redefined
7 e% J8 ~$ ^3 w+ P0 |. o2 Hfunction ashFindAllVias redefined/ d* d! l8 ^5 L" c
function ashFindAllClines redefined$ ?9 w! H( e% c% X
function ashFindAllClinesegs redefined; y- t0 m& o4 N" W
function ashFindAllLines redefined4 m3 M& P6 n8 n) ]6 N  e
function ashFindAllLinesegs redefined
: `4 ~$ [8 _, Y7 R( Q2 ^+ k3 T- lfunction ashFindAllDrcs redefined% z  B& |! V" r+ S+ O
function ashFindAllText redefined
8 i. K9 [" J4 D6 G4 E* _( Ffunction ashFindAllShapes redefined
3 _5 L' q6 R' E0 I0 jfunction ashFindAllShapesegs redefined
/ q8 f3 n' _* `2 pfunction ashFindAllVoids redefined
- a/ T, Y- L; v, C6 ufunction ashFindAllVoidsegs redefined# B- g8 w& k' g) V  n; @
function ashFindAllSymbols redefined
9 ^6 Y0 z$ s  h# b4 Qfunction ashFindAllComponents redefined
; p  e0 W: `" W' T. e+ vfunction ashFindAllNets redefined8 i) R: ?9 U& ]0 d. e4 v$ E
function ashFindAllFigures redefined
) l! F/ \6 J$ ]8 i& j8 w6 ]"skill load_ok"
" V5 X) ~. [" R, f) pOpening existing drawing...; S* T9 C/ {% D
E- No command ID mapping files (allegro ) found in MENUPATH.) K$ _  T* ~) |/ _$ r4 k2 D% C1 K
Command >   n2 x% j5 y. E; g( D) a  Z
' Q) s- F" R  Q3 Y一打开Allegro就出现这个,而且菜单全变成灰色的用不了了。5 z& Z* L- B" F
不知道哪出了问题,新装的15.5.
发表于 2009-5-26 21:37 | 只看该作者
我猜是不是把ENV文件改了,
 楼主| 发表于 2009-5-27 09:24 | 只看该作者
是C:\Cadence\SPB_15.5.1\share\pcb\text下面的env吗?* L* `/ f2 s0 T5 `
我们用的是公共盘里面的env和license,问题是我电脑里面以前装的是15.2,我把15.2的卸载了又装的15.5
发表于 2009-5-27 09:50 | 只看该作者
不是,是home下面的pcbenv。在安装是要求指定一个work directory,下面有一个pcbenv的目录。估计是次目录下的文件与软件不兼容。可在系统的环境变量里重新建一个home。
 楼主| 发表于 2009-5-27 10:05 | 只看该作者
解决啦,我把home删除了再新建一下就好了。
, d5 ~5 I6 p$ K! R0 i谢谢楼上的2位兄弟!!
GMT+8, 2025-7-28 06:56 , Processed in 0.125000 second(s), 24 queries , Gzip On.
