TA的每日心情 | 开心 2019-11-19 15:19 |
签到天数: 1 天 [LV.1]初来乍到
/ G6 l" H3 x' m% r
1 R; x& `+ g( T. n$ W. T, s5 F" [滑动滤波函数FPGA实用程序,对输入数据进行滑动滤波,可以减少干扰信号带来的影响。本实用程序设计上取4096个点进行滑动滤波,采样周期可以自行设定或修改。程序如下:
# ^% R7 H8 o6 z- Flibrary ieee;
5 B7 X2 J7 W7 ] m4 J `use ieee.std_logic_1164.all;
( w. T; d4 M' luse ieee.std_logic_arith.all;% t/ m& E4 D0 \; R- z
use ieee.std_logic_signed.all;+ j8 B5 Y- n0 Z% K5 f" N
entity get_filter is2 {; v8 G' @/ U6 a0 j( T2 F+ h
port
; Z1 u' @9 b5 k/ R( b' u (
6 v+ z: }' R E' |; B; v/ q, q clk: in std_logic;9 L4 W, H$ ?6 P
rst: in std_logic; * Q3 x M( _* V) ?& F3 }
clk1ms: in std_logic; / E% _( s: k$ d
data: in std_logic_vector(15 downto 0);
g2 I/ G7 P/ g' a3 o filter_result: out std_logic_vector(15 downto 0)
% B+ o% _. T. I5 y -- get_filter_state:buffer std_logic_vector(3 downto 0)
5 s2 Z- M+ Q$ L4 n );
: V* H: P+ A7 P Kend get_filter;0 x2 z3 d! d9 z }: c2 ^0 n
architecture arch_get_filter of get_filter is; B9 Y4 v+ i) _: E5 ^0 e
component altsyncram
) q5 Q0 `) b1 Q& a- F generic (
7 ~. o% M! z: J; k. T0 | operation_mode : string;) S" X: w( n! k
width_a : natural;7 _* a$ W2 o3 d% _, i [9 ~( p
widthad_a : natural;
9 b& X: |9 g2 }$ v width_b : natural;
- |4 \4 j. k4 Y; j' b" W5 T widthad_b : natural;( Z* e$ C6 _, T6 D
width_byteena_a : natural;
4 `9 i& C- Y& `, I1 }& d2 A outdata_reg_b : string;
+ x6 P& u9 X+ Z; L; { address_reg_b : string;1 z; \# x" O! E
rdcontrol_reg_b : string;
: x" g( o9 d2 v read_during_write_mode_mixed_ports : string;) d6 k) H/ i. ^" S& ]
init_file : string! R7 n4 m& D1 ?( w+ g8 U
8 B6 M4 d- Y) v ~( Z$ U# r port
5 f% |2 E1 a% c* E# Q (
$ S" Z. m- \0 z wren_a : in std_logic ;
2 n1 M, P; U' z1 q; W$ G clock0 : in std_logic ;4 A0 f# L ?2 C" o: x- L1 I
clock1 : in std_logic ;
/ ^) ~8 Y7 c/ q+ j. x address_a : in std_logic_vector (widthad_a-1 downto 0);
, o, a0 I6 i; ^7 D4 Q7 h address_b : in std_logic_vector (widthad_b-1 downto 0);
. a3 r& _; ?- m0 B8 k8 r rden_b : in std_logic ;
9 X Q2 j" F' i) {/ ]8 M q_b : out std_logic_vector (width_b-1 downto 0);8 R& U; ?6 Z5 q! k+ s
data_a : in std_logic_vector (width_a-1 downto 0)
! N- z3 g, f1 y4 `4 Y );
- Z7 d; M& \/ L& l0 w end component;
9 {. l6 l, X; H; M9 d, b; @ signal sum: std_logic_vector(31 downto 0);/ D6 q/ d+ Q0 N" v0 V. h
signal get_filter_wraddr: std_logic_vector(11 downto 0);. |& t7 r* X- b' J4 D
signal get_filter_rdaddr:std_logic_vector(11 downto 0);* H; I; O, V/ W: m
signal get_filter_rd,get_filter_wr: std_logic;
( U" Q9 s |' u% H signal get_filter_wrdata: std_logic_vector(15 downto 0);3 a& q3 Z7 [4 f2 r% Z0 d5 O
signal get_filter_rddata: std_logic_vector(15 downto 0);$ _3 k4 q% ` a* ]3 }4 c
signal get_filter_state: std_logic_vector(3 downto 0);, L$ e# d8 y; X8 j
begin
' t/ }+ [# t0 |8 r$ s -------all rx data buffer---------------------------------------
# p3 _3 N" {2 ?# H" p0 Oget_filter_ram : altsyncram" r6 o) i6 f! \+ A# E* ^$ n+ T, c
generic map
3 r7 l2 R( z4 K" o, \( Z+ q! b- R (
* W |8 `- |0 ]0 V: o operation_mode => "dual_port",# W! X$ G( W- W7 p7 S9 \6 a, n
width_a => 16,* t% j% w0 A8 Y; O: ~. N$ p
widthad_a => 12,
# a3 [6 Z# v9 _& E3 g' z, j width_b => 16,8 e4 d% b3 W3 L! R" ^; t0 G: H' T
widthad_b => 12,' [; o/ ~* f* M! ~* y( {% G
width_byteena_a => 1,
/ D- s% u) y& r# P: ?8 [ \ outdata_reg_b => "unregistered",
. f2 P1 z/ ~. H% ^$ V7 d% i' b address_reg_b => "clock1",' \2 T1 y# `2 k' `- p- {, W, |) O
rdcontrol_reg_b => "clock1",9 M9 \' _ M0 k
read_during_write_mode_mixed_ports => "old_data",
/ j2 j" n; C$ B# k( M- R: G init_file =>"E:\JstHvfZkSoft\wavesim\get_pf.mif"$ ~( d6 `: B3 _% S7 L% x
), ~7 e$ n! ]' {. N
port map (
5 d `8 v) n7 {" Y wren_a => get_filter_wr,
% Y) x ~- e7 M: F clock0 => clk,7 \! I# Y2 g9 w$ h% j; l0 @! u6 s
clock1 => clk, M! ]7 V$ ~; C4 F
address_a => get_filter_wraddr, 5 l% T# Y* f! Z x) E5 L
address_b => get_filter_rdaddr,
% h+ y/ P6 K. B4 m# y! \+ \+ y* d5 A rden_b => get_filter_rd,
+ l6 g$ X6 h5 x9 R3 G/ s+ ? data_a => get_filter_wrdata, : z: C; l; l! T* F3 F: e
q_b => get_filter_rddata
$ @ ]7 l5 c: I. S r );" Q% m7 _2 s) j& L) `
process(clk,rst); j" T- S& O( Q7 L4 z
begin
# K+ S/ k) \8 w( Z if (rst='0') then" ?$ I4 c0 i7 P0 \- h
get_filter_wraddr<=(others=>'1');+ b& {7 G4 B3 n2 r
get_filter_rdaddr<=(others=>'0');( C- }# B, `7 x) E, L* {
get_filter_wrdata<=(others=>'0');
. e* _4 d# q6 T1 M% y get_filter_rd<='0';% U8 }- F5 }/ ^
get_filter_wr<='0'; ; @/ H8 A6 r- n
get_filter_state<=(others=>'0');' U2 Q2 E- g9 y+ Y
elsif clk'event and clk='1' then
# } [2 p1 ?4 | if (get_filter_state="0000") then7 h( I) d D) o- p8 c8 B- u
sum<=(others=>'0');
5 e6 U3 Z, G' |% {# m- V) h( w get_filter_rd<='1';" ~' U' g6 w5 H4 ?! \
get_filter_rdaddr<=get_filter_rdaddr+'1';" p0 T3 Z: V* c+ a+ G7 }' t
get_filter_state<="0001";
; S' u5 {1 b/ r, Y. H. S% t" y+ A elsif (get_filter_state="0001") then4 J1 z' v7 l% {% u( S8 ^
get_filter_rdaddr<=get_filter_rdaddr+'1';/ J+ t8 w$ _. a& f5 J+ u
get_filter_state<="0010";
" N$ j' g7 q* u% h; B" d elsif (get_filter_state="0010") then3 B: u" M& V1 ^4 ]
get_filter_wr<='1';# U' h3 U5 L8 o0 |
get_filter_wraddr<=get_filter_wraddr+'1'; j$ q% f [, Z3 Y4 N' b( ]
if (get_filter_rdaddr/=x"fff")then' C6 U- B) j; v8 L2 R, ^6 B
get_filter_rdaddr<=get_filter_rdaddr+'1';2 h. p" L. A: h
end if;0 b3 I! B; g) ]
get_filter_wrdata<=get_filter_rddata;
( H* V$ X- y2 z: g sum<=sum+(get_filter_rddata(15)& get_filter_rddata(15)&get_filter_rddata(15)&get_filter_rddata(15)
' `1 U. l9 R K: ]6 K' | &get_filter_rddata(15)&get_filter_rddata(15)&get_filter_rddata(15)&get_filter_rddata(15)&get_filter_rddata);/ L r7 ?" C% a# J; ~4 U
--- filter_result<=get_filter_rddata; -----used in test!
C! } |% \/ Z4 `" C9 J if (get_filter_wraddr=x"ffd") then9 f0 `+ L) l0 Z9 w6 l* a; M: L( j
get_filter_state<="0011";4 T" m" R' p. _& p' [+ Y
get_filter_rd<='0';
& h& j5 A. j5 y+ l c, T8 n end if;
7 ?' v$ [# P7 p9 [5 R' y! g+ a6 U elsif (get_filter_state="0011") then. P" [" C; }' F, U( g" O3 q3 v
sum<=sum+(data(15)& data(15)&data(15)&data(15)1 P# e0 s; H$ d( d
&data(15)&data(15)&data(15)&data(15)&data);1 Z: D' x3 @- q1 S; l) e+ ]1 O( _- t4 W
--- filter_result<=data; -----used in test!3 V/ f7 H9 I* w; F1 a7 r
get_filter_rdaddr<=(others=>'0');$ R& P: z# A% q7 [+ d
get_filter_wraddr<=get_filter_wraddr+'1'; ( S/ F0 W: V% \
get_filter_wrdata<=data;
2 Z5 W0 Y/ F4 }5 Y( ]2 V get_filter_state<="0100";5 ^$ l# W; B5 t* }7 l. V. z q0 n; n
! l6 b( w2 b+ m7 q9 a elsif (get_filter_state="0100") then
/ F& {# j: P. ~0 e! z5 }8 u filter_result<=sum(27 downto 12);
* N6 c* {% U+ ~ S2 r" T2 R) Z" G$ f -- if (clk1ms='1') then- {4 e" X7 w+ M o
get_filter_state<="0000";. d2 N% ~$ _# P! t* h- Y [
-- end if;/ f, k' N9 n2 o/ |6 f: p
else
: b- b P9 a9 c+ }: J! a3 t" v get_filter_state<="0000";* j$ m i' h( f
end if;
% h$ F$ b9 b9 h& L end if;
' {/ q1 W9 @- ~ W: L end process;
0 X. p d! j4 A/ [* a0 o$ y& [ end arch_get_filter;
- M! I) M/ e4 m5 T! e
$ u3 s6 N& d0 N4 a9 w. _( I: V1 Q |
